楼主 #1 2018-08-13 22:41:28
已发帖子: 9,433
厉害了,蓝莓派(Blueberry-PI) ---- 基于V3s全开源的项目
https://github.com/petit-miner/Blueberry-PI
Blueberry PI
Another fruit single board computer (SBC), based on the Allwinner V3s system on a chip (SOC). The Allwinner V3s comes in an easy to solder 128pin TQFP package.
The Blueberry PI features:
100 mbps Ethernet
1 USB Host Port / 1 mini USB port
MIPI CSI interface (unfortunately no support in the linux kernel yet)
Pinheader for an OV2640 and an OV7670
Wifi and bluetooth
RGB interface for connecting displays
Audio jack
an onboard microphone
four buttons for play, pause, next and previous
a Raspberry PI compatible header
SPI Flash
SD card slot
The Blueberry PI can boot from an SD card or SPI Flash. Since the V3s doesn't have a standard video output, I'm planning on creating a video addon board which provides VGA or HDMI. In combination with the ADV7611 it is possible to capture HDMI.
If you have any questions email me at marcel[dot]thuermer(at)smail[dot]emt[dot]h[minus]brs[dot]de
csi 并口摄像头设备树:
https://github.com/petit-miner/Blueberry-PI/blob/master/Software/devicetree%20examples/sun8i-v3s-blueberrypi-csi.dts
csi 并口摄像头驱动补丁:
https://github.com/petit-miner/Blueberry-PI/blob/master/Software/media-V3s-CSI.patch
https://github.com/petit-miner/Blueberry-PI/tree/master/Software
软件介绍 Software
The mainline linux kernel (4.17) has support for:
basic SOC features
Ethernet
USB
parallel CSI (not in mainline kernel yet, see patch)(主线未包含,详见上面的patch)
RGB and TCON
UART
I²C
SPI
SDIO
Audio
LRADC0
RTC
Watchdog
Whats not implemented:
CPU frequency scaling
MIPI CSI
Video Engine (encoding / decoding video)
Have a look at the wiki to find out how to build your own mainline kernel and rootfs. (work in progress)
2020-04-07 28楼更新:
官方git仓库本站下载: BlueberryPI_V3s_368d2eff57bfb12d3ee274370fe14749.7z
转换后DXP版本下载: BlueberryPI_PCB_AD_DXP.7z (仅供参考)
#2 2018-08-14 08:34:02
Re: 厉害了,蓝莓派(Blueberry-PI) ---- 基于V3s全开源的项目
太好了,老外也开始玩v3s了,软件硬件都有源文件!到时候我也去打样一版玩玩
#3 2018-08-14 09:54:03
lcfmax
已发帖子: 329
牛逼,有多了一个新玩法
#4 2018-08-18 11:10:20
Lvy
已发帖子: 107
V3S的玩的人越来越多了。
#5 2018-08-20 14:43:29
abc3240660
已发帖子: 100
还是外国宁开放啊
#6 2018-08-27 11:02:35
wipping
坑哥,这个蓝莓派的摄像头补丁是可以用的吗?我补丁打上了之后有很多函数跟结构体是没找到的
楼主 #7 2018-08-27 15:44:21
已发帖子: 9,433
wipping 说:
我还没有试过呢,你可以在 github.com 给作者提issue
#8 2018-10-22 23:25:47
shengyougao
已发帖子: 21
请问原理图和PCB是什么格式的?我打不开。
#9 2018-10-23 08:29:47
lilo
已发帖子: 215
shengyougao 说:
eagle 试一试,歪果仁喜欢用这个软件,据说设计双层PCB免 licence费用。
楼主 #10 2018-10-23 09:28:35
已发帖子: 9,433
#11 2018-10-23 11:39:06
alan8918
看来高性价比就是一个大杀器,当时STM32F就是这么火起来的吧
#12 2018-10-23 11:40:19
lilo
已发帖子: 215
alan8918 说:
全志的芯片,定价都很有杀伤力.
#13 2018-10-24 11:52:45
已发帖子: 1,409
淘宝搜了下,没有卖的,有人生产吗?想买一块。
楼主 #14 2019-01-06 23:48:25
已发帖子: 9,433
蓝莓PI
我设计了这块PCB,因为这款SoC的功率非常低,功耗非常低,再加上它的显示功能,它提供了制造商从未见过的选择。
有两个版本:2层和4层版本。
查看2层和4层版本的子文件夹以查看特定功能。
蓝莓PI:
•SoC Allwinner V3s:
- ARM Cortex-A7 @ 1.2GHz
- 64兆字节RAM
•10 / 100M以太网
•Wifi和蓝牙(RTL8723BS)
•1个USB主机端口/ 1个微型USB端口
•MIPI CSI接口
•pinheader适用于OV2640和OV7670并行相机
•并行RGB接口,兼容40pin 并行RGB显示器
•音频插孔(3,5毫米)
•板载麦克风
•26针Raspberry PI兼容接头
•SPI闪存
•SD卡插槽
Blueberry PI可以从SD卡或SPI Flash启动。
如果您有任何问题,请发送电子邮件至marcel [dot] thuermer(at)smail [dot] emt [dot] h [minus] brs [dot] de
软件
主线linux内核(4.21)支持:
基本的SOC功能
以太网络
USB
并行CSI
RGB和TCON
UART
I²C
SPI
SDIO
音频
LRADC0
RTC
看门狗
什么没有实现:
CPU频率缩放
MIPI CSI
视频引擎(编码/解码视频)
查看文档以了解如何构建自己的主线内核和rootfs。
DVP CSI 摄像头驱动, 但是 MIPI CSI 摄像头没有驱动.
#15 2019-01-07 08:46:20
jimmy
已发帖子: 316
#16 2019-01-07 08:57:44
jimmy
已发帖子: 316
#17 2019-01-07 10:13:40
Jmhh247
已发帖子: 262
#18 2019-01-07 10:23:51
jimmy
已发帖子: 316
用 egale 脚本转出来的, 估计是要改改才能用吧。
#19 2019-01-09 15:01:46
山无棱
已发帖子: 116
被坑了一把, 里面有个德语字母, 在一般的软件里面和 l(小写L) 渲染一模一样
https://raw.githubusercontent.com/petit-miner/Blueberry-PI/master/Software/Image%20Packer/boot.env/src/boot-lcd.cmd
#20 2019-12-08 15:36:52
GBg
Can not convert to Altium
destination file is not correct
无法转换为Altium
目标文件不正确
最近编辑记录 GBg (2019-12-08 15:38:15)
#21 2019-12-10 14:18:01
ma6254
已发帖子: 41
双层板先打两块再说
嘉立创似乎不支持EAGLE的文件,但是github的repo里有Gerber文件
希望晕哥可以出个图片缩小的功能,图片大了看起来麻烦
楼主 #22 2019-12-10 14:29:24
已发帖子: 9,433
嗯,确实不好用,以后网站改版把图片缩放功能加上。
#23 2019-12-14 18:26:57
WhyKen395
样板打好了吗?想买块PCB自己焊接试试。
#24 2019-12-14 22:02:03
asangqigame
啥情况啊 ,我又该掏钱买板子了!蓝莓派我去 这名字取得 荔枝派 香橙派 树莓派 香蕉派 。。。。。。要是所有的水果都能做派 我还差好多啊火龙果派 榴莲派有木有!
楼主 #25 2019-12-14 22:11:16
已发帖子: 9,433
这个是一个德国朋友做的开源项目,没得卖哦。
#26 2019-12-22 01:18:43
silver
V3s芯片哪里可以买到呢?
#27 2020-03-05 17:38:33
mysteryli
已发帖子: 507
楼主 #28 2020-03-06 11:22:47
已发帖子: 9,433
mysteryli 说:
你好,可以分享一下这个转成AD的文件嘛,那个脚本我不会用。。。
费了九牛二虎之力终于找到以前转出来的DXP格式文件了,PCB能将就看,SCH不忍直视。
#29 2020-04-01 09:18:12
已发帖子: 856
我安装了eagle,也能打开BlueberryPI_PCB,但是pcb器件的名称没有显示,请问这个如何设置
#30 2020-04-01 14:12:18
杨飞武
已发帖子: 55
板子有的买么
#31 2020-04-01 14:41:31
已发帖子: 856
杨飞武 说:
板子有的买么
估计没有,我自己打样了,请大神指教pcb如何显示器件名称
#32 2020-04-01 15:29:05
伍零壹
已发帖子: 158
晕哥 全能啊  软件 硬件 eagle AD 有都看到了,有PADS和allegro么:)
#33 2020-04-01 15:41:03
已发帖子: 856
继续发问,我安装了eagle,也能打开BlueberryPI_PCB,但是pcb器件的名称没有显示,请问这个如何设置
最近编辑记录 kekemuyu (2020-04-01 15:41:25)
#34 2020-04-01 15:55:33
已发帖子: 856
继续发问2,我安装了eagle,也能打开BlueberryPI_PCB,但是pcb器件的名称没有显示,请问这个如何设置
#35 2020-04-01 17:39:17
swt518
已发帖子: 0
牛逼,有多了一个新玩法
#36 2020-04-07 14:05:40
xblzy0423
已发帖子: 48
怎么下载,不会下载
楼主 #37 2020-04-07 14:16:36
已发帖子: 9,433
xblzy0423 说:
怎么下载,不会下载
git clone
或者网页也可以下载
#38 2020-04-07 14:23:17
whycan.cn = 我还要宠爱你.菜鸟
#39 2020-04-07 16:32:02
xblzy0423
已发帖子: 48
https://whycan.cn/files/members/3/Vorentwurf_26_05_18.png
2020-04-07 28楼更新:
AD 20打开出错,AD 15打开第4页是空的?
还是乱码
是不是我AD问题?
最近编辑记录 xblzy0423 (2020-04-07 16:40:24)
楼主 #40 2020-04-07 16:41:30
已发帖子: 9,433
看28楼,仅供参考。
楼主 #41 2020-04-07 16:41:56
已发帖子: 9,433
迪卡 说:
#42 2020-04-07 20:50:38
liuchangyin
已发帖子: 204
关注
#43 2020-04-20 21:03:27
低音炮
感谢开源,前来学习
#44 2020-04-20 22:04:37
Freeboy
迪卡 说:
这解释666
#45 2020-04-21 15:35:52
WFY2008
我就是一只老菜鸟,哈哈!
迪卡 说:
#46 2020-04-21 19:21:51
井蛙
V3S 会不会那天停产的?
#47 2020-04-21 20:47:12
xzm7358
有项目方案也是用的v3s,刚入坑,mark下,积分不够,字数来凑
#48 2020-04-21 20:52:04
raspberryman
已发帖子: 503
井蛙 说:
V3S 会不会那天停产的?
一年停产365次, 闰年停产366次.
#49 2020-04-22 01:20:03
cnicfhnui
csi 并口摄像头驱动补丁:仓库没了,有谁下载了补发一下呗!~
#50 2020-04-22 11:41:39
czllong1989
v3s的电路很简单 闭着眼睛 自动布线都能跑的很好把
#51 2020-05-06 13:22:38
njitnjit
所在地: 眼中有码
已发帖子: 19
V3S值得研究。
蓝莓派(Blueberry-PI) 在哪购买?
最近编辑记录 njitnjit (2020-05-06 13:23:37)
#52 2020-05-06 18:01:07
hameyou
已发帖子: 250
准备打个板自己玩一下,看起来比较好焊接!
#53 2020-05-08 18:29:44
wonrowl
已发帖子: 102
我看到github就去下载,然后发现时eagle pcb,又找半天转换成,最后往下拖,发现有转换好的dxp版本~!
#54 2020-05-27 09:10:49
Meanea
开源生态环境在china发展也越来越好了,支持蓝莓派!
#55 2020-05-27 09:25:02
夜空中最亮的灯
已发帖子: 26
双层板的cortex-a7就很爽了,不用担心bga的焊接问题,估计会很火
#56 2020-05-29 20:44:45
thousands
我怎么在淘宝看到有人卖这个pcb
#57 2020-05-29 21:30:18
a446332161
打板倒是方便,就是焊接不太在行
#58 2020-05-29 23:27:36
xiaowuOK
可以直接下载下来去打样吗???有人试过有没有问题??
#59 2020-06-02 10:25:12
twig
有项目用再试试。
#60 2020-06-02 15:16:35
KingChen
xiaowuOK 说:
打样成本高一些!
#61 2020-06-09 11:10:04
on_raptor
KingChen 说:
打样成本高一些!
不高,现在打样便宜得很。几十块的事
#62 2020-06-25 22:27:30
小酱油
谢谢分享,感觉非常不错。哈哈。
#63 2020-07-01 18:36:39
a570c5954
这个v3s支持rgb屏吗,最大多少寸呢
#64 2020-07-02 09:03:30
Caesar
发现是eagle pcb,去下了eagle软件!
#65 2020-07-04 12:32:36
surelion
下载了,为啥总是打不开哦。头大了    地方
#66 2020-07-04 18:18:41
surelion
什么格式的软件设计的?
#67 2020-07-04 18:34:58
surelion
GOOD
#68 2020-07-09 19:36:46
lz206
有人试过有没有问题??
#69 2020-07-09 22:34:46
wwkkww1983
这个有人测试过没有,我最近想打样做一个DEMO
#70 2020-07-22 09:48:09
thinhx2
Thank you so much
#71 2020-07-22 16:18:38
yqqq
原理图怎么不来份 PDF 版本的
#72 2020-07-22 16:19:47
test2020
V3S的玩的人越来越多了,大神NB
#73 2020-07-31 18:52:35
KappaPROject
tell me why such a large hole is made under the chip? is this made for a heat sink?
最近编辑记录 KappaPROject (2020-07-31 18:53:56)
#74 2020-07-31 18:55:10
湘楚浪子
KappaPROject 说:
V3s肚子下那个焊盘是芯片唯一的数字地,手工感觉必须有洞。
#75 2020-08-02 10:02:07
charles
请问可以分享修改好的ad pcb文件吗,自己用脚本eagle转ad一堆错误
#76 2020-08-02 10:06:27
已发帖子: 3,394
charles 说:
一楼最下面可以下载。
