楼主 #1 2019-09-13 22:37:34
Serenade
跪求一份esp-adf的源码
这两天感觉大部分时间都在GitHub上克隆代码 断断续续的 网速太慢它就中断了
fork到码云上又发现有很多子模块没下
求哪位好心的大佬给份完整的源码 或者有什么好的方法教一教
万分感谢   还有中秋快乐~~~
最近编辑记录 Serenade (2019-09-13 22:37:53)
#2 2019-09-13 23:54:03
已发帖子: 9,365
Re: 跪求一份esp-adf的源码
一键下载指令:
git clone https://github.com/espressif/esp-adf.git --recursive
root@DebugDump:/opt# git clone https://github.com/espressif/esp-adf.git --recursive
Cloning into 'esp-adf'...
remote: Enumerating objects: 1263, done.
remote: Counting objects: 100% (1263/1263), done.
remote: Compressing objects: 100% (759/759), done.
remote: Total 4732 (delta 630), reused 1006 (delta 478), pack-reused 3469
Receiving objects: 100% (4732/4732), 18.36 MiB | 23.19 MiB/s, done.
Resolving deltas: 100% (2735/2735), done.
Checking connectivity... done.
Submodule 'components/esp-adf-libs' (https://github.com/espressif/esp-adf-libs) registered for path 'components/esp-adf-libs'
Submodule 'esp-idf' (https://github.com/espressif/esp-idf) registered for path 'esp-idf'
Cloning into 'components/esp-adf-libs'...
remote: Enumerating objects: 183, done.
remote: Counting objects: 100% (183/183), done.
remote: Compressing objects: 100% (135/135), done.
remote: Total 651 (delta 59), reused 143 (delta 37), pack-reused 468
Receiving objects: 100% (651/651), 15.21 MiB | 17.68 MiB/s, done.
Resolving deltas: 100% (276/276), done.
Submodule path 'components/esp-adf-libs': checked out '1351e09dbc8c87deec22828749154cd951b78665'
Cloning into 'esp-idf'...
remote: Enumerating objects: 1060, done.
remote: Counting objects: 100% (1060/1060), done.
remote: Compressing objects: 100% (545/545), done.
remote: Total 109999 (delta 607), reused 742 (delta 503), pack-reused 108939
Receiving objects: 100% (109999/109999), 80.16 MiB | 18.75 MiB/s, done.
Resolving deltas: 100% (79278/79278), done.
Submodule path 'esp-idf': checked out '4aa1058e8a8f7f3fb17d9ac1158227ad161f2996'
Submodule 'components/asio/asio' (https://github.com/espressif/asio.git) registered for path 'components/asio/asio'
Submodule 'components/aws_iot/aws-iot-device-sdk-embedded-C' (https://github.com/espressif/aws-iot-device-sdk-embedded-C.git) registered for path 'components/aws_iot/aws-iot-device-sdk-        embedded-C'
Submodule 'components/bt/lib' (https://github.com/espressif/esp32-bt-lib.git) registered for path 'components/bt/lib'
Submodule 'components/coap/libcoap' (https://github.com/obgm/libcoap.git) registered for path 'components/coap/libcoap'
Submodule 'components/esp32/lib' (https://github.com/espressif/esp32-wifi-lib.git) registered for path 'components/esp32/lib'
Submodule 'components/esptool_py/esptool' (https://github.com/espressif/esptool.git) registered for path 'components/esptool_py/esptool'
Submodule 'components/expat/expat' (https://github.com/libexpat/libexpat.git) registered for path 'components/expat/expat'
Submodule 'components/json/cJSON' (https://github.com/DaveGamble/cJSON.git) registered for path 'components/json/cJSON'
Submodule 'components/libsodium/libsodium' (https://github.com/jedisct1/libsodium.git) registered for path 'components/libsodium/libsodium'
Submodule 'components/lwip/lwip' (https://github.com/espressif/esp-lwip.git) registered for path 'components/lwip/lwip'
Submodule 'components/mbedtls/mbedtls' (https://github.com/espressif/mbedtls.git) registered for path 'components/mbedtls/mbedtls'
Submodule 'components/micro-ecc/micro-ecc' (https://github.com/kmackay/micro-ecc.git) registered for path 'components/micro-ecc/micro-ecc'
Submodule 'components/mqtt/esp-mqtt' (https://github.com/espressif/esp-mqtt.git) registered for path 'components/mqtt/esp-mqtt'
Submodule 'components/nghttp/nghttp2' (https://github.com/nghttp2/nghttp2.git) registered for path 'components/nghttp/nghttp2'
Submodule 'components/protobuf-c/protobuf-c' (https://github.com/protobuf-c/protobuf-c) registered for path 'components/protobuf-c/protobuf-c'
Submodule 'components/spiffs/spiffs' (https://github.com/pellepl/spiffs.git) registered for path 'components/spiffs/spiffs'
Cloning into 'components/asio/asio'...
remote: Enumerating objects: 45479, done.
remote: Total 45479 (delta 0), reused 0 (delta 0), pack-reused 45479
Receiving objects: 100% (45479/45479), 14.69 MiB | 13.74 MiB/s, done.
Resolving deltas: 100% (31301/31301), done.
Submodule path 'esp-idf/components/asio/asio': checked out '55efc179b76139c8f9b44bf22a4aba4803f7a7bd'
Cloning into 'components/aws_iot/aws-iot-device-sdk-embedded-C'...
remote: Enumerating objects: 1292, done.
remote: Total 1292 (delta 0), reused 0 (delta 0), pack-reused 1292
Receiving objects: 100% (1292/1292), 879.58 KiB | 0 bytes/s, done.
Resolving deltas: 100% (717/717), done.
Submodule path 'esp-idf/components/aws_iot/aws-iot-device-sdk-embedded-C': checked out '299183238ffe7a3e6a5ca0af9db19c10eaca62cf'
Cloning into 'components/bt/lib'...
remote: Enumerating objects: 21, done.
remote: Counting objects: 100% (21/21), done.
remote: Compressing objects: 100% (19/19), done.
remote: Total 634 (delta 12), reused 11 (delta 2), pack-reused 613
Receiving objects: 100% (634/634), 2.59 MiB | 0 bytes/s, done.
Resolving deltas: 100% (426/426), done.
Submodule path 'esp-idf/components/bt/lib': checked out '48242ccf7137fd801ea32a7d85d7d66c684d7df3'
Cloning into 'components/coap/libcoap'...
remote: Enumerating objects: 17, done.
remote: Counting objects: 100% (17/17), done.
remote: Compressing objects: 100% (14/14), done.
remote: Total 8739 (delta 5), reused 12 (delta 3), pack-reused 8722
Receiving objects: 100% (8739/8739), 3.28 MiB | 0 bytes/s, done.
Resolving deltas: 100% (6160/6160), done.
Submodule path 'esp-idf/components/coap/libcoap': checked out '6468887a12666f88b8704d797fc176cd4f40ee4c'
Cloning into 'components/esp32/lib'...
remote: Enumerating objects: 282, done.
remote: Counting objects: 100% (282/282), done.
remote: Compressing objects: 100% (125/125), done.
remote: Total 5889 (delta 214), reused 201 (delta 157), pack-reused 5607
Receiving objects: 100% (5889/5889), 57.62 MiB | 20.68 MiB/s, done.
Resolving deltas: 100% (4804/4804), done.
Submodule path 'esp-idf/components/esp32/lib': checked out 'd325ca88f0bc144ce30ec6045978f936fadc6e51'
Cloning into 'components/esptool_py/esptool'...
remote: Enumerating objects: 85, done.
remote: Counting objects: 100% (85/85), done.
remote: Compressing objects: 100% (67/67), done.
remote: Total 2025 (delta 37), reused 48 (delta 17), pack-reused 1940
Receiving objects: 100% (2025/2025), 7.61 MiB | 0 bytes/s, done.
Resolving deltas: 100% (1235/1235), done.
Submodule path 'esp-idf/components/esptool_py/esptool': checked out '9ad444a6e06e58833d5e6044c1d5f3eb3dd56023'
Cloning into 'components/expat/expat'...
remote: Enumerating objects: 9, done.
remote: Counting objects: 100% (9/9), done.
remote: Compressing objects: 100% (7/7), done.
remote: Total 15804 (delta 2), reused 5 (delta 2), pack-reused 15795
Receiving objects: 100% (15804/15804), 13.33 MiB | 11.17 MiB/s, done.
Resolving deltas: 100% (11824/11824), done.
Submodule path 'esp-idf/components/expat/expat': checked out '968b8cc46dbee47b83318d5f31a8e7907199614b'
Cloning into 'components/json/cJSON'...
remote: Enumerating objects: 29, done.
remote: Counting objects: 100% (29/29), done.
remote: Compressing objects: 100% (22/22), done.
remote: Total 4067 (delta 13), reused 19 (delta 7), pack-reused 4038
Receiving objects: 100% (4067/4067), 2.30 MiB | 0 bytes/s, done.
Resolving deltas: 100% (2697/2697), done.
Submodule path 'esp-idf/components/json/cJSON': checked out '7cc52f60356909b3dd260304c7c50c0693699353'
Cloning into 'components/libsodium/libsodium'...
remote: Enumerating objects: 56, done.
remote: Counting objects: 100% (56/56), done.
remote: Compressing objects: 100% (43/43), done.
remote: Total 29781 (delta 21), reused 28 (delta 7), pack-reused 29725
Receiving objects: 100% (29781/29781), 7.58 MiB | 11.63 MiB/s, done.
Resolving deltas: 100% (17550/17550), done.
Submodule path 'esp-idf/components/libsodium/libsodium': checked out '70170c28c844a4786e75efc626e1aeebc93caebc'
Cloning into 'components/lwip/lwip'...
remote: Enumerating objects: 1260, done.
remote: Counting objects: 100% (1260/1260), done.
remote: Compressing objects: 100% (502/502), done.
remote: Total 49540 (delta 823), reused 1029 (delta 737), pack-reused 48280
Receiving objects: 100% (49540/49540), 10.27 MiB | 11.63 MiB/s, done.
Resolving deltas: 100% (37277/37277), done.
Submodule path 'esp-idf/components/lwip/lwip': checked out 'fe9a58cb7abdc74e7a2196b7c4e0a29ff9042f88'
Cloning into 'components/mbedtls/mbedtls'...
remote: Enumerating objects: 71153, done.
remote: Total 71153 (delta 0), reused 0 (delta 0), pack-reused 71153
Receiving objects: 100% (71153/71153), 31.87 MiB | 16.22 MiB/s, done.
Resolving deltas: 100% (54818/54818), done.
Submodule path 'esp-idf/components/mbedtls/mbedtls': checked out '19eb57f7f7b2f4312d497ddbcb5f104fc6877c70'
Cloning into 'components/micro-ecc/micro-ecc'...
remote: Enumerating objects: 1086, done.
remote: Total 1086 (delta 0), reused 0 (delta 0), pack-reused 1086
Receiving objects: 100% (1086/1086), 647.94 KiB | 0 bytes/s, done.
Resolving deltas: 100% (637/637), done.
Submodule path 'esp-idf/components/micro-ecc/micro-ecc': checked out 'd037ec89546fad14b5c4d5456c2e23a71e554966'
Cloning into 'components/mqtt/esp-mqtt'...
remote: Enumerating objects: 6, done.
remote: Counting objects: 100% (6/6), done.
remote: Compressing objects: 100% (6/6), done.
remote: Total 1980 (delta 0), reused 3 (delta 0), pack-reused 1974
Receiving objects: 100% (1980/1980), 1.40 MiB | 0 bytes/s, done.
Resolving deltas: 100% (1054/1054), done.
Submodule path 'esp-idf/components/mqtt/esp-mqtt': checked out 'f08f3b678717865234637164a29ed3a63e756ca7'
Cloning into 'components/nghttp/nghttp2'...
remote: Enumerating objects: 88, done.
remote: Counting objects: 100% (88/88), done.
remote: Total 39952 (delta 51), reused 77 (delta 45), pack-reused 39864
Receiving objects: 100% (39952/39952), 30.79 MiB | 9.22 MiB/s, done.
Resolving deltas: 100% (29793/29793), done.
Submodule path 'esp-idf/components/nghttp/nghttp2': checked out '3bcc416e13cc790e2fb45fcfe9111d38609c5032'
Submodule 'third-party/mruby' (https://github.com/mruby/mruby) registered for path 'third-party/mruby'
Submodule 'third-party/neverbleed' (https://github.com/h2o/neverbleed.git) registered for path 'third-party/neverbleed'
Cloning into 'third-party/mruby'...
remote: Enumerating objects: 110, done.
remote: Counting objects: 100% (110/110), done.
remote: Compressing objects: 100% (69/69), done.
remote: Total 51370 (delta 46), reused 72 (delta 37), pack-reused 51260
Receiving objects: 100% (51370/51370), 12.37 MiB | 11.41 MiB/s, done.
Resolving deltas: 100% (32070/32070), done.
Submodule path 'esp-idf/components/nghttp/nghttp2/third-party/mruby': checked out '22464fe5a0a10f2b077eaba109ce1e912e4a77de'
Cloning into 'third-party/neverbleed'...
remote: Enumerating objects: 40, done.
remote: Counting objects: 100% (40/40), done.
remote: Compressing objects: 100% (24/24), done.
remote: Total 272 (delta 23), reused 29 (delta 16), pack-reused 232
Receiving objects: 100% (272/272), 96.80 KiB | 0 bytes/s, done.
Resolving deltas: 100% (162/162), done.
Submodule path 'esp-idf/components/nghttp/nghttp2/third-party/neverbleed': checked out 'da5c2ab419a3bb8a4cc6c37a6c7f3e4bd4b41134'
Cloning into 'components/protobuf-c/protobuf-c'...
remote: Enumerating objects: 3239, done.
remote: Total 3239 (delta 0), reused 0 (delta 0), pack-reused 3239
Receiving objects: 100% (3239/3239), 1.23 MiB | 0 bytes/s, done.
Resolving deltas: 100% (2059/2059), done.
Submodule path 'esp-idf/components/protobuf-c/protobuf-c': checked out 'dac1a65feac4ad72f612aab99f487056fbcf5c1a'
Cloning into 'components/spiffs/spiffs'...
remote: Enumerating objects: 5, done.
remote: Counting objects: 100% (5/5), done.
remote: Compressing objects: 100% (5/5), done.
remote: Total 1460 (delta 0), reused 0 (delta 0), pack-reused 1455
Receiving objects: 100% (1460/1460), 1019.15 KiB | 0 bytes/s, done.
Resolving deltas: 100% (1020/1020), done.
Submodule path 'esp-idf/components/spiffs/spiffs': checked out 'f5e26c4e933189593a71c6b82cda381a7b21e41c'
感受风一样的下载速度
#3 2019-09-13 23:58:26
已发帖子: 9,365
Re: 跪求一份esp-adf的源码
#4 2019-09-13 23:59:45
已发帖子: 9,365
Re: 跪求一份esp-adf的源码
不用谢, 只用了几分钟搞定了,
文件有点大, 过几天删除.
建议买个外网的vps.
楼主 #5 2019-09-14 00:05:14
Serenade
Re: 跪求一份esp-adf的源码
不用谢, 只用了几分钟搞定了,
文件有点大, 过几天删除.
建议买个外网的vps.
谢大哥  有个自己搭的ss  但是速度慢的扣脚  我还是再去买一个吧。。。
#6 2020-04-22 17:40:10
laotongxiao
Re: 跪求一份esp-adf的源码
是个好解决办法
#7 2020-05-31 15:04:56
TDA2030
Re: 跪求一份esp-adf的源码
建议还是使用科学上网,要不然还有下次clone很慢的时候
