楼主 #1 2020-04-16 11:06:02
没事瞎转悠hhh
荔枝派zero linux5.2,spi flash启动识别不到分区
在内核选项中已经添加mtd的 <*> Command line partition table parsing 支持,SPI-NOR 设备的支持。jffs2文件系统的支持,
在内核启动却为识别分区:
只输出了:
[    0.754400] m25p80 spi0.0: xt25f128b (16384 Kbytes)
[    1.368204] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
各位有没有遇到过这问题
#2 2020-04-16 11:15:14
shaoxi2010
已发帖子: 372
Re: 荔枝派zero linux5.2,spi flash启动识别不到分区
可能是驱动没开,也可能是文件系统不对,更可能是MTD分区,信息太少了
#3 2020-04-16 11:15:42
有梦的地方
已发帖子: 284
有没有识别到分区?
楼主 #4 2020-04-16 11:30:34
没事瞎转悠hhh
没有识别到分区
[    0.000000] Linux version 5.2.0-licheepi-zero (ryan@ryan-virtual-machine) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-200
[    0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15883
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(d2
[    0.000000] Memory: 53540K/64036K available (6144K kernel code, 303K rwdata, 1744K rodata, 1024K init, 255K bss, 10496K )
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] random: get_random_bytes called from start_kernel+0x300/0x42c with crng_init=0
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000021] Switching to timer-based delay loop, resolution 41ns
[    0.000208] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000456] Console: colour dummy device 80x30
[    0.000518] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000535] pid_max: default: 32768 minimum: 301
[    0.000708] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000726] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001554] CPU: Testing write buffer coherency: ok
[    0.002070] /cpus/cpu@0 missing clock-frequency property
[    0.002097] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002870] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003080] rcu: Hierarchical SRCU implementation.
[    0.003642] smp: Bringing up secondary CPUs ...
[    0.003665] smp: Brought up 1 node, 1 CPU
[    0.003676] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.003684] CPU: All CPU(s) started in SVC mode.
[    0.004787] devtmpfs: initialized
[    0.008355] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.008694] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.008726] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.008967] pinctrl core: initialized pinctrl subsystem
[    0.010121] NET: Registered protocol family 16
[    0.010674] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.011998] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.012019] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.036179] SCSI subsystem initialized
[    0.036455] usbcore: registered new interface driver usbfs
[    0.036522] usbcore: registered new interface driver hub
[    0.036636] usbcore: registered new device driver usb
[    0.036857] mc: Linux media interface: v0.10
[    0.036897] videodev: Linux video capture interface: v2.00
[    0.037128] Advanced Linux Sound Architecture Driver Initialized.
[    0.038503] clocksource: Switched to clocksource arch_sys_counter
[    0.051249] NET: Registered protocol family 2
[    0.052075] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.052120] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.052146] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.052171] TCP: Hash tables configured (established 1024 bind 1024)
[    0.052322] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.052375] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.052684] NET: Registered protocol family 1
[    0.054305] Initialise system trusted keyrings
[    0.054760] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.062144] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    0.090763] Key type asymmetric registered
[    0.090786] Asymmetric key parser 'x509' registered
[    0.090888] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.090902] io scheduler mq-deadline registered
[    0.090910] io scheduler kyber registered
[    0.091969] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.095817] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.168787] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.171311] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.172421] printk: console [ttyS0] disabled
[    0.192738] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[    0.713602] printk: console [ttyS0] enabled
[    0.742943] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    0.760909] libphy: Fixed MDIO Bus: probed
[    0.765601] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.771508] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.777750] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 38000 (expect 58000)
[    0.787149] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    0.794389] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    0.801617] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    0.806577] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    0.813366] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    0.819030] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    0.824973] libphy: stmmac: probed
[    0.829180] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    0.852651] libphy: mdio_mux: probed
[    0.856621] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.863271] ehci-platform: EHCI generic platform driver
[    0.868836] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.874470] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.882471] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.918503] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.925753] hub 1-0:1.0: USB hub found
[    0.929727] hub 1-0:1.0: 1 port detected
[    0.934358] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.940687] ohci-platform: OHCI generic platform driver
[    0.946276] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.953000] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.960979] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.033637] hub 2-0:1.0: USB hub found
[    1.037485] hub 2-0:1.0: 1 port detected
[    1.044833] usbcore: registered new interface driver usb-storage
[    1.052158] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.061473] sun6i-rtc 1c20400.rtc: registered as rtc0
[    1.066537] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.071292] i2c /dev entries driver
[    1.076239] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.086130] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.094894] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.131395] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.138707] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    1.175565] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[    1.183756] usbcore: registered new interface driver usbhid
[    1.189424] usbhid: USB HID core driver
[    1.195171] sun4i-codec 1c22c00.codec: ASoC: codec-analog@01c23000 not registered
[    1.202804] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.210209] Initializing XFRM netlink socket
[    1.214517] NET: Registered protocol family 17
[    1.219815] Registering SWP/SWPB emulation handler
[    1.225748] Loading compiled-in X.509 certificates
[    1.236026] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0x(ptrval)
[    1.246726] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    1.263052] Console: switching to colour frame buffer device 100x30
[    1.275481] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    1.284342] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.295841] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.301690] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.311110] hub 3-0:1.0: USB hub found
[    1.314997] hub 3-0:1.0: 1 port detected
[    1.321542] debugfs: Directory '1c22c00.codec' with parent 'V3s Audio Codec' already present!
[    1.330227] sun4i-codec 1c22c00.codec: ASoC: Failed to create component debugfs directory: -17
[    1.340434] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.349238] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:43:29 UTC (2609)
[    1.357738] vcc5v0: disabling
[    1.360787] ALSA device list:
[    1.363759]   #0: V3s Audio Codec
[    1.375923] Please append a correct "root=" boot option; here are the available partitions:
[    1.384301] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[    1.392647] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-licheepi-zero #2
[    1.399684] Hardware name: Allwinner sun8i Family
[    1.404420] [<c010ecf4>] (unwind_backtrace) from [<c010b71c>] (show_stack+0x10/0x14)
[    1.412163] [<c010b71c>] (show_stack) from [<c06ce1b0>] (dump_stack+0x84/0x98)
[    1.419384] [<c06ce1b0>] (dump_stack) from [<c011dd3c>] (panic+0x110/0x2fc)
[    1.426346] [<c011dd3c>] (panic) from [<c09012f8>] (mount_block_root+0x214/0x2f0)
[    1.433825] [<c09012f8>] (mount_block_root) from [<c09015a0>] (prepare_namespace+0x144/0x188)
[    1.442342] [<c09015a0>] (prepare_namespace) from [<c06e6604>] (kernel_init+0x8/0x10c)
[    1.450253] [<c06e6604>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    1.457811] Exception stack(0xc3833fb0 to 0xc3833ff8)
[    1.462859] 3fa0:                                     00000000 00000000 00000000 00000000
[    1.471028] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.479194] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    1.485816] Rebooting in 5 seconds..
#5 2020-04-16 15:02:25
shaoxi2010
已发帖子: 372
spi32766.0这个写错了,虽然不知道你32766从那里抄来的,但打印说一定不是这么写的
楼主 #6 2020-04-20 14:28:17
没事瞎转悠hhh
shaoxi2010 说:
spi32766.0是设备名啊,我用4.13y版本已经成功的,我想换成5.2内核时出现的这个问题
楼主 #7 2020-04-20 15:33:08
没事瞎转悠hhh
没事瞎转悠hhh 说:
受楼上老哥启发,查看内核启动日志有一行为:
可知在5.2版本中,flash设备名为spi0.0,所以在uboot环境变量中修改spi32766.0为spi0.0即可正常识别flash及其分区
#8 2020-04-20 16:39:05
WFY2008
bootargs=console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
难道我这个flash设备名也不对哇?始终报“Could not find a valid device tree”
楼主 #9 2020-04-21 16:47:05
没事瞎转悠hhh
WFY2008 说:
老哥,你这明显是没找到设备树啊,dtb文件有没有烧录,或者内核编译设置还有问题
#10 2020-04-27 17:30:02
shunshn
太好了,一直也是这个问题,看到这终于明白了,我在内核下设备树改的
vi arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts
加入别名:spi32766 = &spi0; 代码如下:
    aliases {
        serial0 = &uart0;
        ethernet0 = &emac;
                spi32766 = &spi0;
最近编辑记录 shunshn (2020-04-27 20:09:14)
#11 2020-09-19 09:38:38
shawn.d
已发帖子: 164
学习收藏
