大家好,最近在尝试移植openwrt到我自己的S3开发板时遇到了一点问题,我自己的开发板使用的是UART1 PG6 PG7两个管脚作为终端接口的,通过板载的CP2104转usb直接连接电脑,且仅此一个能连出的串口。具体现象如下:
u-boot引导正常,在引导过程中提示按任意键时按下键盘能进入u-boot的命令行。
内核引导正常,但是引导后不接受任何输入的命令或者回车按键。
日志如下:
U-Boot SPL 2019.01 (Mar 23 2020 - 21:31:05 +0000)
DRAM: 128 MiB
Trying to boot from MMC1
U-Boot 2019.01 (Mar 23 2020 - 21:31:05 +0000) Allwinner Technology
DRAM: 128 MiB
MMC: SUNXI SD/MMC: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial@01c28400
Out: serial@01c28400
Err: serial@01c28400
Net: No ethernet found.
No controllers found
=> ls
ls - list files in a directory (default /)
Usage:
ls <interface> [<dev[:part]> [directory]]
List files in directory 'directory' of partition 'part' on
device type 'interface' instance 'dev'.
接下来引导内核:
In: serial@01c28400
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
377 bytes read in 4 ms (91.8 KiB/s)
2922976 bytes read in 138 ms (20.2 MiB/s)
8631 bytes read in 7 ms (1.2 MiB/s)
Image Name: ARM OpenWrt Linux-4.19.108
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2922912 Bytes = 2.8 MiB
Load Address: 40008000
Entry Point: 40008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
Using Device Tree in place at 41800000, end 418051b6
[ 0.000000] Linux version 4.19.108 (anson@a223aa962705) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r12704-a0027f8dbf)) #0 SMP PREEMPT Mon Mar 23 21:31:05 2020
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=30c5387d
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] random: get_random_bytes called from start_kernel+0x7c/0x428 with crng_init=0
[ 0.000000] percpu: Embedded 15 pages/cpu s31244 r8192 d22004 u61440
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16240
[ 0.000000] Kernel command line: console=ttyS1,115200 earlyprintk root=/dev/mmcblk0p2 rootwait
[ 0.000000] Memory: 53876K/65536K available (5926K kernel code, 394K rwdata, 1636K rodata, 2048K init, 243K bss, 11660K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (7943 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (2048 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 395 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 244 kB)
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000224] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000404] Console: colour dummy device 80x30
[ 0.000461] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000478] pid_max: default: 32768 minimum: 301
[ 0.000657] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000672] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001584] CPU: Testing write buffer coherency: ok
[ 0.002146] /cpus/cpu@0 missing clock-frequency property
[ 0.002176] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.060214] Setting up static identity map for 0x40200000 - 0x40200060
[ 0.080207] rcu: Hierarchical SRCU implementation.
[ 0.120326] smp: Bringing up secondary CPUs ...
[ 0.120355] smp: Brought up 1 node, 1 CPU
[ 0.120364] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.120372] CPU: All CPU(s) started in HYP mode.
[ 0.120378] CPU: Virtualization extensions available.
[ 0.130548] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.131273] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.131311] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.131660] pinctrl core: initialized pinctrl subsystem
[ 0.132922] NET: Registered protocol family 16
[ 0.133401] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.134596] No ATAGs?
[ 0.193152] SCSI subsystem initialized
[ 0.193566] usbcore: registered new interface driver usbfs
[ 0.193638] usbcore: registered new interface driver hub
[ 0.197726] usbcore: registered new device driver usb
[ 0.198607] pps_core: LinuxPPS API ver. 1 registered
[ 0.198627] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.198784] PTP clock support registered
[ 0.200311] Advanced Linux Sound Architecture Driver Initialized.
[ 0.206475] clocksource: Switched to clocksource arch_sys_counter
[ 0.237209] NET: Registered protocol family 2
[ 0.238050] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.238099] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.238123] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.238149] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.238295] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.238347] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.238644] NET: Registered protocol family 1
[ 0.239192] kvm [1]: 8-bit VMID
[ 0.240357] kvm [1]: Hyp mode initialized successfully
[ 0.243162] No memory allocated for crashlog
[ 0.244203] workingset: timestamp_bits=14 max_order=14 bucket_order=0
[ 0.271704] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.272219] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.302157] io scheduler noop registered
[ 0.302181] io scheduler deadline registered
[ 0.302440] io scheduler cfq registered (default)
[ 0.303271] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.310055] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.320159] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.350497] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 30, base_baud = 1500000) is a U6_16550A
[ 0.372731] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 31, base_baud = 1500000) is a U6_16550A
[ 0.942329] console [ttyS1] enabled
[ 0.960167] loop: module loaded
[ 0.968565] libphy: Fixed MDIO Bus: probed
[ 0.975321] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.982756] ehci-platform: EHCI generic platform driver
[ 0.988885] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.995126] ohci-platform: OHCI generic platform driver
[ 1.001437] usbcore: registered new interface driver usb-storage
[ 1.008685] mousedev: PS/2 mouse device common for all mice
[ 1.015964] i2c /dev entries driver
[ 1.022061] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.033102] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
[ 1.066573] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.082768] NET: Registered protocol family 10
[ 1.100422] Segment Routing with IPv6
[ 1.104215] NET: Registered protocol family 17
[ 1.109485] can: controller area network core (rev 20170425 abi 9)
[ 1.116206] NET: Registered protocol family 29
[ 1.121327] 8021q: 802.1Q VLAN Support v1.8
[ 1.125714] Registering SWP/SWPB emulation handler
[ 1.136707] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.147578] mmc0: new high speed SDHC card at address 59b4
[ 1.155004] hctosys: unable to open rtc device (rtc0)
[ 1.161122] ALSA device list:
[ 1.164102] No soundcards found.
[ 1.171115] mmcblk0: mmc0:59b4 SDU1 29.4 GiB
[ 1.188930] mmcblk0: p1 p2
[ 1.262518] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[ 1.270401] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.280104] Freeing unused kernel memory: 2048K
[ 1.284791] Run /sbin/init as init process
[ 1.398944] init: Console is alive
[ 1.402673] init: - watchdog -
[ 1.619778] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 1.649906] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 1.667944] init: - preinit -
[ 1.808517] random: fast init done
[ 1.985555] random: jshn: uninitialized urandom read (4 bytes read)
[ 2.019971] random: jshn: uninitialized urandom read (4 bytes read)
[ 2.046240] random: jshn: uninitialized urandom read (4 bytes read)
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 6.187555] mount_root: mounting /dev/root
[ 6.192290] EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
[ 6.202043] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.310018] urandom-seed: Seeding with /etc/urandom.seed
[ 6.352031] procd: - early -
[ 6.355073] procd: - watchdog -
[ 7.069657] procd: - watchdog -
[ 7.073196] procd: - ubus -
[ 7.091444] random: ubusd: uninitialized urandom read (4 bytes read)
[ 7.128088] random: ubusd: uninitialized urandom read (4 bytes read)
[ 7.134985] random: ubusd: uninitialized urandom read (4 bytes read)
[ 7.142524] procd: - init -
[ 7.570723] kmodloader: loading kernel modules from /etc/modules.d/*
[ 7.631648] urngd: v1.0.2 started.
[ 7.656192] Loading modules backported from Linux version v5.4-rc8-0-gaf42d3466bdc
[ 7.676622] Backport generated by backports.git v5.4-rc8-1-0-g368e8c51
[ 7.737086] random: crng init done
[ 7.740507] random: 4 urandom warning(s) missed due to ratelimiting
[ 7.749704] xt_time: kernel timezone is -0000
[ 7.817280] PPP generic driver version 2.4.2
[ 7.837122] NET: Registered protocol family 24
[ 7.878627] usbcore: registered new interface driver brcmfmac
[ 7.893870] kmodloader: done loading kernel modules from /etc/modules.d/*
这时按什么都没有反应
[ 31.206508] vcc3v0: disabling
[ 31.209507] vcc5v0: disabling
键盘仍然不起作用。
但是在引导过程中按F是可以进入fail safe模式的,而且按1234选择debug level也完全正常,下面是debug level=3的时候输出的日志:
DRAM: 128 MiB
Model: Lichee Pi Zero
DRAM: 128 MiB
In: serial@01c28400
Scanning mmc 0:1...
2922976 bytes read in 137 ms (20.3 MiB/s)
8631 bytes read in 6 ms (1.4 MiB/s)
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000021] Switching to timer-based delay loop, resolution 41ns
[ 0.000236] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000416] Console: colour dummy device 80x30
[ 0.000471] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000487] pid_max: default: 32768 minimum: 301
[ 0.000661] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000676] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001594] CPU: Testing write buffer coherency: ok
[ 0.002156] /cpus/cpu@0 missing clock-frequency property
[ 0.002185] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.060208] Setting up static identity map for 0x40200000 - 0x40200060
[ 0.080212] rcu: Hierarchical SRCU implementation.
[ 0.120337] smp: Bringing up secondary CPUs ...
[ 0.120362] smp: Brought up 1 node, 1 CPU
[ 0.120372] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.120379] CPU: All CPU(s) started in HYP mode.
[ 0.120385] CPU: Virtualization extensions available.
[ 0.130557] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.131312] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.131664] pinctrl core: initialized pinctrl subsystem
[ 0.132908] NET: Registered protocol family 16
[ 0.133379] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.134572] No ATAGs?
[ 0.195223] SCSI subsystem initialized
[ 0.195636] usbcore: registered new interface driver usbfs
[ 0.195706] usbcore: registered new interface driver hub
[ 0.197664] usbcore: registered new device driver usb
[ 0.198548] pps_core: LinuxPPS API ver. 1 registered
[ 0.198568] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.198727] PTP clock support registered
[ 0.200327] Advanced Linux Sound Architecture Driver Initialized.
[ 0.205967] clocksource: Switched to clocksource arch_sys_counter
[ 0.237027] NET: Registered protocol family 2
[ 0.237847] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.237897] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.237922] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.237947] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.238096] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.238146] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.238455] NET: Registered protocol family 1
[ 0.238996] kvm [1]: 8-bit VMID
[ 0.240211] kvm [1]: Hyp mode initialized successfully
[ 0.242994] No memory allocated for crashlog
[ 0.244044] workingset: timestamp_bits=14 max_order=14 bucket_order=0
[ 0.270594] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.271121] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.301401] io scheduler noop registered
[ 0.301425] io scheduler deadline registered
[ 0.301686] io scheduler cfq registered (default)
[ 0.302522] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.309306] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.319881] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.349746] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 30, base_baud = 1500000) is a U6_16550A
[ 0.372038] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 31, base_baud = 1500000) is a U6_16550A
[ 0.941623] console [ttyS1] enabled
[ 0.959444] loop: module loaded
[ 0.967842] libphy: Fixed MDIO Bus: probed
[ 0.974589] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.982025] ehci-platform: EHCI generic platform driver
[ 0.988146] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.994387] ohci-platform: OHCI generic platform driver
[ 1.000689] usbcore: registered new interface driver usb-storage
[ 1.007967] mousedev: PS/2 mouse device common for all mice
[ 1.015255] i2c /dev entries driver
[ 1.021348] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.032416] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
[ 1.066071] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.082205] NET: Registered protocol family 10
[ 1.099861] Segment Routing with IPv6
[ 1.103660] NET: Registered protocol family 17
[ 1.108929] can: controller area network core (rev 20170425 abi 9)
[ 1.115645] NET: Registered protocol family 29
[ 1.120759] 8021q: 802.1Q VLAN Support v1.8
[ 1.125141] Registering SWP/SWPB emulation handler
[ 1.136190] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.146965] mmc0: new high speed SDHC card at address 59b4
[ 1.154389] hctosys: unable to open rtc device (rtc0)
[ 1.160497] ALSA device list:
[ 1.163480] No soundcards found.
[ 1.170494] mmcblk0: mmc0:59b4 SDU1 29.4 GiB
[ 1.188298] mmcblk0: p1 p2
[ 1.261870] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
[ 1.269749] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.279457] Freeing unused kernel memory: 2048K
[ 1.284138] Run /sbin/init as init process
[ 1.398270] init: Console is alive
[ 1.402002] init: - watchdog -
[ 1.618733] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 1.648769] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 1.666802] init: - preinit -
[ 1.805016] random: fast init done
[ 1.982934] random: jshn: uninitialized urandom read (4 bytes read)
[ 2.017476] random: jshn: uninitialized urandom read (4 bytes read)
[ 2.044087] random: jshn: uninitialized urandom read (4 bytes read)
3
[ 3.952584] mount_root: mounting /dev/root
[ 3.957688] EXT4-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
[ 3.967784] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.079520] urandom-seed: Seeding with /etc/urandom.seed
[ 4.121730] procd: - early -
[ 4.134490] procd: Watchdog handover: fd=3
[ 4.139272] procd: - watchdog -
[ 4.203759] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/mem/full","SUBSYSTEM":"mem","SYNTH_UUID":"0","MAJOR":"1","MINOR":"7","DEVNAME":"full","DEVMODE":"0666","SEQNUM":"605"}}
[ 4.243290] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/mem/urandom","SUBSYSTEM":"mem","SYNTH_UUID":"0","MAJOR":"1","MINOR":"9","DEVNAME":"urandom","DEVMODE":"0666","SEQNUM":"606"}}
[ 4.291196] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/mem/null","SUBSYSTEM":"mem","SYNTH_UUID":"0","MAJOR":"1","MINOR":"3","DEVNAME":"null","DEVMODE":"0666","SEQNUM":"607"}}
[ 4.337660] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/mem/random","SUBSYSTEM":"mem","SYNTH_UUID":"0","MAJOR":"1","MINOR":"8","DEVNAME":"random","DEVMODE":"0666","SEQNUM":"608"}}
[ 4.358028] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/hw_random","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"183","DEVNAME":"hwrng","SEQNUM":"609"}}
[ 4.374868] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/network_latency","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"62","DEVNAME":"network_latency","SEQNUM":"610"}}
[ 4.393072] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/psaux","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"1","DEVNAME":"psaux","SEQNUM":"611"}}
[ 4.409095] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/memory_bandwidth","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"60","DEVNAME":"memory_bandwidth","SEQNUM":"612"}}
[ 4.427076] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/cpu_dma_latency","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"63","DEVNAME":"cpu_dma_latency","SEQNUM":"613"}}
[ 4.444858] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/vhost-net","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"238","DEVNAME":"vhost-net","SEQNUM":"614"}}
[ 4.461690] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/soc/1c20ca0.watchdog/misc/watchdog","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"130","DEVNAME":"watchdog","SEQNUM":"615"}}
[ 4.480240] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/kvm","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"232","DEVNAME":"kvm","SEQNUM":"616"}}
[ 4.496142] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/network_throughput","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"61","DEVNAME":"network_throughput","SEQNUM":"617"}}
[ 4.514398] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/loop-control","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"237","DEVNAME":"loop-control","SEQNUM":"618"}}
[ 4.531737] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/misc/userio","SUBSYSTEM":"misc","SYNTH_UUID":"0","MAJOR":"10","MINOR":"240","DEVNAME":"userio","SEQNUM":"619"}}
[ 4.548030] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/soc/1c20ca0.watchdog/watchdog/watchdog0","SUBSYSTEM":"watchdog","SYNTH_UUID":"0","MAJOR":"249","MINOR":"0","DEVNAME":"watchdog0","SEQNUM":"620"}}
[ 4.567412] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty58","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"58","DEVNAME":"tty58","SEQNUM":"621"}}
[ 4.585590] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/ptmx","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"5","MINOR":"2","DEVNAME":"ptmx","DEVMODE":"0666","SEQNUM":"622"}}
[ 4.602512] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty48","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"48","DEVNAME":"tty48","SEQNUM":"623"}}
[ 4.618547] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty1","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"1","DEVNAME":"tty1","SEQNUM":"624"}}
[ 4.634304] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty38","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"38","DEVNAME":"tty38","SEQNUM":"625"}}
[ 4.650435] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty28","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"28","DEVNAME":"tty28","SEQNUM":"626"}}
[ 4.666689] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty56","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"56","DEVNAME":"tty56","SEQNUM":"627"}}
[ 4.682706] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty18","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"18","DEVNAME":"tty18","SEQNUM":"628"}}
[ 4.698729] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty46","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"46","DEVNAME":"tty46","SEQNUM":"629"}}
[ 4.714734] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/console","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"5","MINOR":"1","DEVNAME":"console","SEQNUM":"630"}}
[ 4.730798] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/serial8250/tty/ttyS6","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"70","DEVNAME":"ttyS6","SEQNUM":"631"}}
[ 4.747834] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty36","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"36","DEVNAME":"tty36","SEQNUM":"632"}}
[ 4.763885] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty26","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"26","DEVNAME":"tty26","SEQNUM":"633"}}
[ 4.779891] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty54","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"54","DEVNAME":"tty54","SEQNUM":"634"}}
[ 4.795893] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty16","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"16","DEVNAME":"tty16","SEQNUM":"635"}}
[ 4.811906] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty8","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"8","DEVNAME":"tty8","SEQNUM":"636"}}
[ 4.827653] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty44","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"44","DEVNAME":"tty44","SEQNUM":"637"}}
[ 4.843659] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/serial8250/tty/ttyS4","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"68","DEVNAME":"ttyS4","SEQNUM":"638"}}
[ 4.860696] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty34","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"34","DEVNAME":"tty34","SEQNUM":"639"}}
[ 4.876720] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty62","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"62","DEVNAME":"tty62","SEQNUM":"640"}}
[ 4.892728] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty24","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"24","DEVNAME":"tty24","SEQNUM":"641"}}
[ 4.908719] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty52","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"52","DEVNAME":"tty52","SEQNUM":"642"}}
[ 4.924726] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty14","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"14","DEVNAME":"tty14","SEQNUM":"643"}}
[ 4.940719] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty6","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"6","DEVNAME":"tty6","SEQNUM":"644"}}
[ 4.956603] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty42","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"42","DEVNAME":"tty42","SEQNUM":"645"}}
[ 4.972663] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/serial8250/tty/ttyS2","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"66","DEVNAME":"ttyS2","SEQNUM":"646"}}
[ 4.989736] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty32","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"32","DEVNAME":"tty32","SEQNUM":"647"}}
[ 5.005752] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty60","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"60","DEVNAME":"tty60","SEQNUM":"648"}}
[ 5.021761] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty22","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"22","DEVNAME":"tty22","SEQNUM":"649"}}
[ 5.037771] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty50","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"50","DEVNAME":"tty50","SEQNUM":"650"}}
[ 5.053769] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty12","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"12","DEVNAME":"tty12","SEQNUM":"651"}}
[ 5.069764] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty4","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"4","DEVNAME":"tty4","SEQNUM":"652"}}
[ 5.085506] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty40","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"40","DEVNAME":"tty40","SEQNUM":"653"}}
[ 5.101499] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/soc/1c28000.serial/tty/ttyS0","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"64","DEVNAME":"ttyS0","SEQNUM":"654"}}
[ 5.119234] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty30","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"30","DEVNAME":"tty30","SEQNUM":"655"}}
[ 5.135329] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty59","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"59","DEVNAME":"tty59","SEQNUM":"656"}}
[ 5.151356] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty20","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"20","DEVNAME":"tty20","SEQNUM":"657"}}
[ 5.167379] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty49","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"49","DEVNAME":"tty49","SEQNUM":"658"}}
[ 5.183378] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty10","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"10","DEVNAME":"tty10","SEQNUM":"659"}}
[ 5.199382] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty2","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"2","DEVNAME":"tty2","SEQNUM":"660"}}
[ 5.215126] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty39","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"39","DEVNAME":"tty39","SEQNUM":"661"}}
[ 5.231127] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty29","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"29","DEVNAME":"tty29","SEQNUM":"662"}}
[ 5.247164] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty57","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"57","DEVNAME":"tty57","SEQNUM":"663"}}
[ 5.263188] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty19","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"19","DEVNAME":"tty19","SEQNUM":"664"}}
[ 5.279255] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty47","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"47","DEVNAME":"tty47","SEQNUM":"665"}}
[ 5.295274] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/serial8250/tty/ttyS7","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"71","DEVNAME":"ttyS7","SEQNUM":"666"}}
[ 5.312320] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty0","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"0","DEVNAME":"tty0","SEQNUM":"667"}}
[ 5.328070] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty37","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"37","DEVNAME":"tty37","SEQNUM":"668"}}
[ 5.344075] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty27","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"27","DEVNAME":"tty27","SEQNUM":"669"}}
[ 5.360083] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty55","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"55","DEVNAME":"tty55","SEQNUM":"670"}}
[ 5.376597] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty17","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"17","DEVNAME":"tty17","SEQNUM":"671"}}
[ 5.392614] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty9","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"9","DEVNAME":"tty9","SEQNUM":"672"}}
[ 5.408367] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty45","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"45","DEVNAME":"tty45","SEQNUM":"673"}}
[ 5.424372] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/serial8250/tty/ttyS5","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"69","DEVNAME":"ttyS5","SEQNUM":"674"}}
[ 5.441552] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"5","MINOR":"0","DEVNAME":"tty","DEVMODE":"0666","SEQNUM":"675"}}
[ 5.458255] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty35","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"35","DEVNAME":"tty35","SEQNUM":"676"}}
[ 5.474254] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty63","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"63","DEVNAME":"tty63","SEQNUM":"677"}}
[ 5.490265] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty25","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"25","DEVNAME":"tty25","SEQNUM":"678"}}
[ 5.506463] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty53","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"53","DEVNAME":"tty53","SEQNUM":"679"}}
[ 5.522451] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty15","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"15","DEVNAME":"tty15","SEQNUM":"680"}}
[ 5.538464] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty7","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"7","DEVNAME":"tty7","SEQNUM":"681"}}
[ 5.554200] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty43","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"43","DEVNAME":"tty43","SEQNUM":"682"}}
[ 5.570202] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/serial8250/tty/ttyS3","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"67","DEVNAME":"ttyS3","SEQNUM":"683"}}
[ 5.587294] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty33","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"33","DEVNAME":"tty33","SEQNUM":"684"}}
[ 5.603328] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty61","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"61","DEVNAME":"tty61","SEQNUM":"685"}}
[ 5.619331] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty23","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"23","DEVNAME":"tty23","SEQNUM":"686"}}
[ 5.635326] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty51","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"51","DEVNAME":"tty51","SEQNUM":"687"}}
[ 5.651320] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty13","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"13","DEVNAME":"tty13","SEQNUM":"688"}}
[ 5.667330] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty5","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"5","DEVNAME":"tty5","SEQNUM":"689"}}
[ 5.683078] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty41","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"41","DEVNAME":"tty41","SEQNUM":"690"}}
[ 5.699076] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/soc/1c28400.serial/tty/ttyS1","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"65","DEVNAME":"ttyS1","SEQNUM":"691"}}
[ 5.716821] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty31","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"31","DEVNAME":"tty31","SEQNUM":"692"}}
[ 5.732845] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty21","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"21","DEVNAME":"tty21","SEQNUM":"693"}}
[ 5.748842] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty11","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"11","DEVNAME":"tty11","SEQNUM":"694"}}
[ 5.764832] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/tty/tty3","SUBSYSTEM":"tty","SYNTH_UUID":"0","MAJOR":"4","MINOR":"3","DEVNAME":"tty3","SEQNUM":"695"}}
[ 5.780573] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/block/loop1","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"7","MINOR":"1","DEVNAME":"loop1","DEVTYPE":"disk","SEQNUM":"696"}}
[ 5.798171] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:59b4/block/mmcblk0/mmcblk0p2","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"179","MINOR":"2","DEVNAME":"mmcblk0p2","DEVTYPE":"partition","PARTN":"2","SEQNUM":"697"}}
[ 5.822304] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/block/loop6","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"7","MINOR":"6","DEVNAME":"loop6","DEVTYPE":"disk","SEQNUM":"698"}}
[ 5.839814] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/block/loop4","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"7","MINOR":"4","DEVNAME":"loop4","DEVTYPE":"disk","SEQNUM":"699"}}
[ 5.857327] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/block/loop2","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"7","MINOR":"2","DEVNAME":"loop2","DEVTYPE":"disk","SEQNUM":"700"}}
[ 5.874831] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/block/loop0","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"7","MINOR":"0","DEVNAME":"loop0","DEVTYPE":"disk","SEQNUM":"701"}}
[ 5.892337] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:59b4/block/mmcblk0/mmcblk0p1","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"179","MINOR":"1","DEVNAME":"mmcblk0p1","DEVTYPE":"partition","PARTN":"1","SEQNUM":"702"}}
[ 5.916560] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/block/loop7","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"7","MINOR":"7","DEVNAME":"loop7","DEVTYPE":"disk","SEQNUM":"703"}}
[ 5.934092] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/block/loop5","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"7","MINOR":"5","DEVNAME":"loop5","DEVTYPE":"disk","SEQNUM":"704"}}
[ 5.951614] procd: {{"ACTION":"add","DEVPATH":"/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:59b4/block/mmcblk0","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"179","MINOR":"0","DEVNAME":"mmcblk0","DEVTYPE":"disk","SEQNUM":"705"}}
[ 5.973216] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/block/loop3","SUBSYSTEM":"block","SYNTH_UUID":"0","MAJOR":"7","MINOR":"3","DEVNAME":"loop3","DEVTYPE":"disk","SEQNUM":"706"}}
[ 5.990721] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/input/mice","SUBSYSTEM":"input","SYNTH_UUID":"0","MAJOR":"13","MINOR":"63","DEVNAME":"input/mice","SEQNUM":"707"}}
[ 6.007352] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/vc/vcsu1","SUBSYSTEM":"vc","SYNTH_UUID":"0","MAJOR":"7","MINOR":"65","DEVNAME":"vcsu1","SEQNUM":"708"}}
[ 6.023005] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/vc/vcsu","SUBSYSTEM":"vc","SYNTH_UUID":"0","MAJOR":"7","MINOR":"64","DEVNAME":"vcsu","SEQNUM":"709"}}
[ 6.038443] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/vc/vcsa1","SUBSYSTEM":"vc","SYNTH_UUID":"0","MAJOR":"7","MINOR":"129","DEVNAME":"vcsa1","SEQNUM":"710"}}
[ 6.054133] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/vc/vcs","SUBSYSTEM":"vc","SYNTH_UUID":"0","MAJOR":"7","MINOR":"0","DEVNAME":"vcs","SEQNUM":"711"}}
[ 6.069294] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/vc/vcsa","SUBSYSTEM":"vc","SYNTH_UUID":"0","MAJOR":"7","MINOR":"128","DEVNAME":"vcsa","SEQNUM":"712"}}
[ 6.084794] procd: {{"ACTION":"add","DEVPATH":"/devices/virtual/vc/vcs1","SUBSYSTEM":"vc","SYNTH_UUID":"0","MAJOR":"7","MINOR":"1","DEVNAME":"vcs1","SEQNUM":"713"}}
[ 6.599752] procd: - watchdog -
[ 6.603299] procd: - ubus -
[ 6.606428] procd: Create service ubus
[ 6.610308] procd: Start instance ubus::instance1
[ 6.615669] procd: Started instance ubus::instance1[826]
[ 6.622716] procd: running /etc/init.d/ubus running
[ 6.634849] procd: glob failed on /etc/init.d/ubus
[ 6.649969] random: ubusd: uninitialized urandom read (4 bytes read)
[ 6.659738] random: ubusd: uninitialized urandom read (4 bytes read)
[ 6.666843] random: ubusd: uninitialized urandom read (4 bytes read)
[ 6.674165] procd: Connected to ubus, id=9463e31d
[ 6.679283] procd: - init -
[ 6.691737] procd: running /etc/rc.d/S* boot
[ 7.104871] kmodloader: loading kernel modules from /etc/modules.d/*
[ 7.169727] urngd: v1.0.2 started.
[ 7.205216] Loading modules backported from Linux version v5.4-rc8-0-gaf42d3466bdc
[ 7.226116] Backport generated by backports.git v5.4-rc8-1-0-g368e8c51
[ 7.271738] random: crng init done
[ 7.275161] random: 4 urandom warning(s) missed due to ratelimiting
[ 7.295550] xt_time: kernel timezone is -0000
[ 7.371746] PPP generic driver version 2.4.2
[ 7.390177] NET: Registered protocol family 24
[ 7.428559] usbcore: registered new interface driver brcmfmac
[ 7.453881] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 31.205995] vcc3v0: disabling
[ 31.208994] vcc5v0: disabling
请问该如何修正这个问题?
自己解决了,目前的解决办法是进入failsafe模式打开 /etc/inittab文件
修改ttyS0::askfirst:/usr/libexec/login.sh
为ttyS1::askfirst:/usr/libexec/login.sh
