楼主 #1 2020-05-06 14:21:42
孤星泪
已发帖子: 235
V3s Linux 应用程序跑了7个小时挂了, 请大家帮我把把脉.
[19329.649078] Unable to handle kernel paging request at virtual address c4ec5eec
[19329.656332] pgd = c3380000
[19329.659042] [c4ec5eec] *pgd=00000000
[19329.662640] Internal error: Oops: 80000005 [#1] SMP ARM
[19329.667861] Modules linked in: g_ffs usb_f_fs libcomposite
[19329.673368] CPU: 0 PID: 6104 Comm: kworker/0:1 Not tainted 4.13.16-licheepi-zero+ #53
[19329.681187] Hardware name: Allwinner sun8i Family
[19329.685893] task: c3a29140 task.stack: c3bde000
[19329.690427] PC is at 0xc4ec5eec
[19329.693591] LR is at notifier_call_chain+0x48/0x84
[19329.698380] pc : [<c4ec5eec>]    lr : [<c0138a6c>]    psr: 60000193
[19329.704639] sp : c3bdfef0  ip : 00000000  fp : c3bdff3c
[19329.709858] r10: c0a03de4  r9 : c0701d04  r8 : c31e4e00
[19329.715077] r7 : c31e4e00  r6 : c39eee00  r5 : c3a29140  r4 : c3deca40
[19329.721598] r3 : c01027a4  r2 : 00000000  r1 : 00000002  r0 : c39eee00
[19329.728123] Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment none
[19329.735337] Control: 10c5387d  Table: 4338006a  DAC: 00000051
[19329.741076] Process kworker/0:1 (pid: 6104, stack limit = 0xc3bde210)
[19329.747511] Stack: (0xc3bdfef0 to 0xc3be0000)
[19329.751872] fee0:                                     60000013 00000008 c3804500 00000064
[19329.760044] ff00: 00000000 00000008 c064631c 0349f000 c3b7fe50 00000004 c3b7fe50 ffffe000
[19329.768215] ff20: c3dec640 c3dec640 c0a02d00 c3dec658 ffffe000 00000008 c3bdff4c c064631c
[19329.776387] ff40: c3173280 c3dec640 c3dec640 c01327b8 a0000013 c0a38e54 c07e0780 00000000
[19329.784558] ff60: ffffe000 c337c400 c337c700 00000000 c3bde000 c3173280 c01326b8 c391fed8
[19329.792729] ff80: c337c41c c01374b4 c3bde000 c337c700 c0137368 00000000 00000000 00000000
[19329.800899] ffa0: 00000000 00000000 00000000 c0107538 00000000 00000000 00000000 00000000
[19329.809069] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[19329.817239] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[19329.825443] [<c0138a6c>] (notifier_call_chain) from [<00000008>] (0x8)
[19329.831968] Code: bad PC value
[19329.835031] ---[ end trace 87f5bdfbf0efad40 ]---
#2 2020-05-06 14:40:34
checkout
已发帖子: 173
Re: V3s Linux 应用程序跑了7个小时挂了, 请大家帮我把把脉.
内存泄漏?
楼主 #3 2020-05-06 14:44:16
孤星泪
已发帖子: 235
Mem: 25208K used, 29392K free, 44K shrd, 0K buff, 9512K cached
CPU:   6% usr   0% sys   0% nic  93% idle   0% io   0% irq   0% sirq
Load average: 0.03 0.06 0.02 1/39 485
  PID  PPID USER     STAT   VSZ %VSZ %CPU COMMAND
  203   179 root     S    27788  51%   6% /usr/bin/system_char -platfo
   51     2 root     SW       0   0%   0% [kworker/0:2]
  254   179 root     R     1600   3%   0% top
  107     1 root     S     9268  17%   0% /usr/bin/adbd
  179     1 root     S     1612   3%   0% -/bin/sh
    1     0 root     S     1600   3%   0% {linuxrc} init
  201     1 root     S     1596   3%   0% /sbin/udhcpc -i eth1
  173     1 root     S     1596   3%   0% /sbin/udhcpc -i eth1
   70     1 root     S     1592   3%   0% /sbin/syslogd -n
   74     1 root     S     1588   3%   0% /sbin/klogd -n
   57     2 root     SWN      0   0%   0% [jffs2_gcd_mtd5]
  312     2 root     SW       0   0%   0% [kworker/0:1]
   47     2 root     SW       0   0%   0% [spi32766]
    8     2 root     SW       0   0%   0% [rcu_sched]
    7     2 root     SW       0   0%   0% [ksoftirqd/0]
   48     2 root     SW       0   0%   0% [kworker/u2:1]
    5     2 root     SW       0   0%   0% [kworker/u2:0]
   12     2 root     SW       0   0%   0% [kdevtmpfs]
   11     2 root     SW       0   0%   0% [cpuhp/0]
@checkout 我也有点感觉内存泄漏, 这个VSZ不断增长.
最近编辑记录 孤星泪 (2020-05-06 14:44:43)
#4 2020-05-06 15:00:58
ifree64
已发帖子: 74
内存耗尽了吗?
楼主 #5 2020-05-06 15:06:33
孤星泪
已发帖子: 235
ifree64 说:
内存耗尽了吗?
感觉是耗尽了然后挂了,
我用这个命令开启看门狗    echo 1 > /dev/watchdog
但是我的flash是32M的, 而且是8pin的, 系统会复位, 但是flash里面的寄存器还是指向后面16M,
可能这个原因 V3s 复位的时候没有重启, 就死在那里了.
楼主 #6 2020-05-06 15:17:47
孤星泪
已发帖子: 235
我为什么做出这个判断呢? 因为死机之后, V3s 怎么按reset按键, 怎么拉低V3s reset 引脚都不管用了, 因为 8pin 的 flash没有复位引脚.
应用程序死机问题暂时由我同事去解决,
我先看看如何让看门狗稳定重启.
楼主 #7 2020-05-06 15:29:04
孤星泪
已发帖子: 235
现在问题来了, 看门狗复位会下拉 RESET 引脚吗?
因为我想接 16PIN 的SPI FLASH, 那种芯片有 RESET 引脚, 刚好和 V3S的引脚接一起, 让V3S去复位FLASH.
楼主 #8 2020-05-06 16:05:03
孤星泪
已发帖子: 235
悲剧, RESET引脚接上逻辑分析仪, 事实证明, RESET引脚并有没有任何下拉信号输出.
这下不知道把这个锅甩给谁了.
楼主 #9 2020-05-06 17:47:05
孤星泪
已发帖子: 235
请教了大佬, 叫我用 valgrind 工具测试内存泄露, 试了一下, 不知道如何看结果.
另外一个大佬说, 逐步屏蔽代码, 然后我看最有嫌疑的就是 libcurl 部分, 然后就屏蔽了,
现在VSZ已经不增长了:
Mem: 23808K used, 30792K free, 52K shrd, 16K buff, 8208K cached
CPU:   2% usr   0% sys   0% nic  97% idle   0% io   0% irq   0% sirq
Load average: 0.10 0.07 0.02 1/43 224
  213   189 root     S    25420  47%   2% /usr/bin/system_char -platfo
   20     2 root     SW       0   0%   0% [kworker/0:1]
  220   189 root     R     1600   3%   0% top
  121     1 root     S     9272  17%   0% /usr/bin/adbd
  189     1 root     S     1612   3%   0% -/bin/sh
  211     1 root     S     1596   3%   0% /sbin/udhcpc -i eth1
  184     1 root     S     1596   3%   0% /sbin/udhcpc -i eth1
   73     1 root     S     1592   3%   0% /sbin/syslogd -n
   77     1 root     S     1588   3%   0% /sbin/klogd -n
   60     2 root     SWN      0   0%   0% [jffs2_gcd_mtd5]
  164     2 root     SW       0   0%   0% [kworker/u2:2]
    3     2 root     SW       0   0%   0% [kworker/0:0]
#10 2020-05-06 21:15:21
已发帖子: 1,139
libcurl一般用来干什么的
#11 2020-05-06 21:39:44
staunchheart
已发帖子: 232
内存泄露与野指针,简直是噩梦。。哪个system_char如果是你自己写的话,只能出去玩一下,然后回来静下心。
仔仔细细的将写过的代码重新看一遍,每一个环节都不要错过。
相对来说内存泄露还好差一些,重点看创建的对像有没有释放,比野指针好查。。
这也是为什么应用层流行JAVA、C#、JS这类带GC,无指针语言的原因。
祝你好运吧。。。
#12 2020-05-06 21:44:39
liuchangyin
已发帖子: 204
这个还真不好查,只能不断在程序里打印日志,监测所有的怀疑的问题,一点点缩小范围,还有就是程序一点点屏蔽试试
#13 2020-05-07 08:10:02
chendong
已发帖子: 90
这个只能一步一步屏蔽掉代码,看到哪里不增长了。就是费时间。肯定能找出来。
楼主 #14 2020-05-07 08:16:57
孤星泪
已发帖子: 235
达克罗德 说:
libcurl一般用来干什么的
在程序中post http/https 数据,
我是照抄libcurl最新例程,而且每次调用都释放了全部资源,没想到还是这样,最后我通过 system 函数调用 curl 命令发送数据,跑了一晚,目前还没有死机,感谢大家热心回复。
#15 2020-05-08 15:31:17
zyj
我的系统经常起不来,有时起来几分钟就没了
#16 2020-05-15 21:36:48
huangjian276310465
使用gdb server 或许会对你有用。
#17 2020-05-18 23:25:04
windcys
请问楼主有不有ZERO的全套TF卡烧写文件,我现在还不会编译,想先学习一下烧录。多谢了
#18 2020-05-18 23:37:07
zhiha258
只能不断在程序里打印日志调试,定位。慢慢来吧
#19 2020-05-19 15:06:43
didi
libcurl这么坑?有空我试一试ubuntu版本的。
