楼主 #1 2020-04-30 15:05:22
已发帖子: 3,394
Macronix/MXIC/旺宏的spi flash W25L64/W25L128/W25L256/W25L512的4K OPT区有没有用过
II. Additional 4K-bit secured OTP for unique identifier: to provide 4K-bit one-time program area for setting
device unique serial number - Which may be set by factory or system customer.
- Security register bit 0 indicates whether the chip is locked by factory or not.
- To program the 4K-bit secured OTP by entering 4K-bit secured OTP mode (with Enter Security OTP command),
and going through normal program procedure, and then exiting 4K-bit secured OTP mode by writing Exit Security
OTP command.
- Customer may lock-down the customer lockable secured OTP by writing WRSCUR(write security register)
command to set customer lock-down bit1 as "1". Please refer to  "Table 8. Security Register Definition" for
security register bit definition and "Table 3. 4K-bit Secured OTP Definition" for address range definition.
- Note: Once lock-down whatever by factory or customer, it cannot be changed any more. While in 4K-bit secured
OTP mode, array access is not allowed.
二。 附加的4K位安全OTP,用于唯一标识符:提供4K位一次性程序区域以进行设置
设备唯一的序列号-可由工厂或系统客户设置。
-安全寄存器位0指示芯片是否被工厂锁定。
-要通过进入4K位安全OTP模式(使用Enter Security OTP命令)对4K位安全OTP进行编程,
并执行正常的程序过程,然后通过编写退出安全性退出4K位安全OTP模式OTP命令。
-客户可以通过写WRSCUR(写安全寄存器)来锁定客户可锁定的安全OTP
命令将客户锁定位1设置为“ 1”。 请参考“表8.安全寄存器定义”。
安全寄存器位定义和地址范围定义的“表3. 4K位安全OTP定义”。
-注意:一旦被工厂或客户锁定,就不能再更改了。 在4K位安全状态下OTP模式,不允许阵列访问。
楼主 #2 2020-04-30 15:05:55
已发帖子: 3,394
Re: Macronix/MXIC/旺宏的spi flash W25L64/W25L128/W25L256/W25L512的4K OPT区有没有用过
楼主 #3 2020-04-30 15:06:28
已发帖子: 3,394
The serial flash discoverable parameters (SFDP) is needed to
spi nor devices for some specific features. I added some sfdp
structure and detect method. And I hope the method will be
useful in the future.
The code have been tested on lower version Linux and can
successfully work with Macronix chips. So I also modified the
chip support list of Macronix.
Signed-off-by: Jim Kuo <jimtingkuo at gmail.com>
 drivers/mtd/devices/m25p80.c  |  83 ++++-
 drivers/mtd/spi-nor/Kconfig   |  11 +
 drivers/mtd/spi-nor/spi-nor.c | 774 +++++++++++++++++++++++++++++++++++++++---
 include/linux/mtd/spi-nor.h   | 201 +++++++++++
 4 files changed, 1009 insertions(+), 60 deletions(-)
diff --git a/drivers/mtd/devices/m25p80.c b/drivers/mtd/devices/m25p80.c
index 85e35467..731f568 100644
--- a/drivers/mtd/devices/m25p80.c
+++ b/drivers/mtd/devices/m25p80.c
@@ -170,6 +170,74 @@ static int m25p80_erase(struct spi_nor *nor, loff_t offset)
+static int m25p80_write_xfer(struct spi_nor *nor,
+ struct spi_nor_xfer_cfg *cfg, u8 *buf, size_t len)
+ struct m25p *flash = nor->priv;
+ struct spi_device *spi = flash->spi;
+ struct spi_transfer t[2] = {};
+ struct spi_message m;
+ unsigned int dummy = cfg->dummy_cycles;
+ int ret;
+ dummy /= 8;
+ if (cfg->wren) {
+ ret = nor->write_reg(nor, SPINOR_OP_WREN, NULL, 0, 0);
+ if (ret)
+ return ret;
+ spi_message_init(&m);
+ flash->command[0] = cfg->cmd;
+ m25p_addr2cmd(nor, cfg->addr, flash->command);
+ t[0].tx_buf = flash->command;
+ t[0].len = cfg->cmd_pins + cfg->addr_pins + dummy;
+ spi_message_add_tail(&t[0], &m);
+ t[1].tx_buf = buf;
+ t[1].tx_nbits = cfg->mode_pins;
+ t[1].len = len;
+ spi_message_add_tail(&t[1], &m);
+ spi_sync(spi, &m);
+ return 0;
+static int m25p80_read_xfer(struct spi_nor *nor,
+ struct spi_transfer t[2];
+ dummy /= 8;
+ memset(t, 0, sizeof(t));
+ t[1].rx_buf = buf;
+ t[1].rx_nbits = cfg->mode_pins;
+ t[1].len = len;
+ return 0;
  * board specific setup should have ensured the SPI clock used here
  * matches what the READ command supports, at least until this driver
@@ -199,6 +267,8 @@ static int m25p_probe(struct spi_device *spi)
  nor->erase = m25p80_erase;
  nor->write_reg = m25p80_write_reg;
  nor->read_reg = m25p80_read_reg;
+ nor->write_xfer = m25p80_write_xfer;
+ nor->read_xfer = m25p80_read_xfer;
  nor->dev = &spi->dev;
  nor->mtd = &flash->mtd;
@@ -261,10 +331,15 @@ static const struct spi_device_id m25p_ids[] = {
  {"mr25h256"}, {"mr25h10"},
  {"gd25q32"}, {"gd25q64"},
  {"160s33b"}, {"320s33b"}, {"640s33b"},
- {"mx25l2005a"}, {"mx25l4005a"}, {"mx25l8005"}, {"mx25l1606e"},
- {"mx25l3205d"}, {"mx25l3255e"}, {"mx25l6405d"}, {"mx25l12805d"},
- {"mx25l12855e"},{"mx25l25635e"},{"mx25l25655e"},{"mx66l51235l"},
- {"mx66l1g55g"},
+ {"mx25l512e"}, {"mx25l5121e"}, {"mx25l1006e"}, {"mx25l1021e"},
+ {"mx25l2006e"}, {"mx25l4006e"}, {"mx25u4035"}, {"mx25v4035"},
+ {"mx25l8006e"}, {"mx25u8035"}, {"mx25v8035"}, {"mx25l1606e"},
+ {"mx25l1633e"}, {"mx25l1635e"}, {"mx25u1635e"}, {"mx25l3206e"},
+ {"mx25l3239e"}, {"mx25l3225d"}, {"mx25l3255e"}, {"mx25l6406e"},
+ {"mx25l6439e"}, {"mx25l12839f"}, {"mx25l12855e"},
+ {"mx25u12835f"}, {"mx25l25635e"}, {"mx25l25655e"},
+ {"mx25u25635f"}, {"mx66l51235f"}, {"mx66u51235f"},
+ {"mx66l1g45g"}, {"mx66l1g55g"},
  {"n25q064"}, {"n25q128a11"}, {"n25q128a13"}, {"n25q256a"},
  {"n25q512a"}, {"n25q512ax3"}, {"n25q00"},
  {"pm25lv512"}, {"pm25lv010"}, {"pm25lq032"},
diff --git a/drivers/mtd/spi-nor/Kconfig b/drivers/mtd/spi-nor/Kconfig
index 64a4f0e..f40548b 100644
--- a/drivers/mtd/spi-nor/Kconfig
+++ b/drivers/mtd/spi-nor/Kconfig
@@ -21,6 +21,17 @@ config MTD_SPI_NOR_USE_4K_SECTORS
   Please note that some tools/drivers/filesystems may not work with
   4096 B erase size (e.g. UBIFS requires 15 KiB as a minimum).
+config MTD_SPI_NOR_SFDP
+ bool "Serial Flash Discoverable Parameters (SFDP) Probe"
+ default n
+ help
+  SFDP includes the most detailed information of SPI NOR flash memory.
+  It can be used to detect flash and get devices' parameters.
+  Attention that there are many flash flags can not covered by SFDP such
+  as SST_WRITE, USE_FSR, SPI_NOR_NO_FR and SECT_4K_PMC. Please do not
+  enable this option if your device is highly related with these flags.
 config SPI_FSL_QUADSPI
  tristate "Freescale Quad SPI controller"
  depends on ARCH_MXC
diff --git a/drivers/mtd/spi-nor/spi-nor.c b/drivers/mtd/spi-nor/spi-nor.c
index 0f8ec3c..2340ead 100644
--- a/drivers/mtd/spi-nor/spi-nor.c
+++ b/drivers/mtd/spi-nor/spi-nor.c
@@ -119,6 +119,25 @@ static int read_cr(struct spi_nor *nor)
+ * Read the security register, returning its value in the location
+ * Return the security register value.
+ * Returns negative if error occurred.
+static int read_scur(struct spi_nor *nor)
+ int ret;
+ u8 val;
+ ret = nor->read_reg(nor, SPINOR_OP_RDSCUR, &val, 1);
+ if (ret < 0) {
+ pr_err("error %d reading SCUR\n", (int) ret);
+ return ret;
+ return val;
  * Dummy Cycle calculation for different type of read.
  * It can be used to support more commands with
  * different dummy cycle requirements.
@@ -147,6 +166,15 @@ static inline int write_sr(struct spi_nor *nor, u8 val)
+ * Set LDSO bit with Write Security Register command.
+static inline int write_scur(struct spi_nor *nor)
+ return nor->write_reg(nor, SPINOR_OP_WRSCUR, NULL, 0, 0);
  * Set write enable latch with Write Enable command.
@@ -545,19 +573,37 @@ static const struct spi_device_id spi_nor_ids[] = {
  { "640s33b",  INFO(0x898913, 0, 64 * 1024, 128, 0) },
  /* Macronix */
- { "mx25l2005a",  INFO(0xc22012, 0, 64 * 1024,   4, SECT_4K) },
- { "mx25l4005a",  INFO(0xc22013, 0, 64 * 1024,   8, SECT_4K) },
- { "mx25l8005",   INFO(0xc22014, 0, 64 * 1024,  16, 0) },
- { "mx25l1606e",  INFO(0xc22015, 0, 64 * 1024,  32, SECT_4K) },
- { "mx25l3205d",  INFO(0xc22016, 0, 64 * 1024,  64, 0) },
- { "mx25l3255e",  INFO(0xc29e16, 0, 64 * 1024,  64, SECT_4K) },
- { "mx25l6405d",  INFO(0xc22017, 0, 64 * 1024, 128, 0) },
- { "mx25l12805d", INFO(0xc22018, 0, 64 * 1024, 256, 0) },
- { "mx25l12855e", INFO(0xc22618, 0, 64 * 1024, 256, 0) },
- { "mx25l25635e", INFO(0xc22019, 0, 64 * 1024, 512, 0) },
- { "mx25l25655e", INFO(0xc22619, 0, 64 * 1024, 512, 0) },
- { "mx66l51235l", INFO(0xc2201a, 0, 64 * 1024, 1024, SPI_NOR_QUAD_READ) },
- { "mx66l1g55g",  INFO(0xc2261b, 0, 64 * 1024, 2048, SPI_NOR_QUAD_READ) },
+ { "mx25l512e",   INFO(0xc22010, 0, 64 * 1024,    1, SECT_4K) },
+ { "mx25l5121e",  INFO(0xc22210, 0, 64 * 1024,    1, SECT_4K) },
+ { "mx25l1006e",  INFO(0xc22011, 0, 64 * 1024,    2, SECT_4K) },
+ { "mx25l1021e",  INFO(0xc22211, 0, 64 * 1024,    2, SECT_4K) },
+ { "mx25l2006e",  INFO(0xc22012, 0, 64 * 1024,    4, SECT_4K) },
+ { "mx25l4006e",  INFO(0xc22013, 0, 64 * 1024,    8, SECT_4K) },
+ { "mx25u4035",   INFO(0xc22533, 0, 64 * 1024,    8, SECT_4K) },
+ { "mx25v4035",   INFO(0xc22553, 0, 64 * 1024,    8, SECT_4K) },
+ { "mx25l8006e",  INFO(0xc22014, 0, 64 * 1024,   16, 0) },
+ { "mx25u8035",   INFO(0xc22534, 0, 64 * 1024,   16, 0) },
+ { "mx25v8035",   INFO(0xc22554, 0, 64 * 1024,   16, 0) },
+ { "mx25l1606e",  INFO(0xc22015, 0, 64 * 1024,   32, SECT_4K) },
+ { "mx25l1633e",  INFO(0xc22415, 0, 64 * 1024,   32, 0) },
+ { "mx25l1635e",  INFO(0xc22515, 0, 64 * 1024,   32, 0) },
+ { "mx25u1635e",  INFO(0xc22535, 0, 64 * 1024,   32, 0) },
+ { "mx25l3206e",  INFO(0xc22016, 0, 64 * 1024,   64, 0) },
+ { "mx25l3239e",  INFO(0xc22536, 0, 64 * 1024,   64, SPI_NOR_QUAD_READ) },
+ { "mx25l3225d",  INFO(0xc25e16, 0, 64 * 1024,   64, 0) },
+ { "mx25l3255e",  INFO(0xc29e16, 0, 64 * 1024,   64, SECT_4K |
SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) },
+ { "mx25l6406e",  INFO(0xc22017, 0, 64 * 1024,  128, 0) },
+ { "mx25l6439e",  INFO(0xc22537, 0, 64 * 1024,  128,
+ { "mx25l12839f", INFO(0xc22018, 0, 64 * 1024,  256, SPI_NOR_QUAD_READ) },
+ { "mx25l12855e", INFO(0xc22618, 0, 64 * 1024,  256,
+ { "mx25u12835f", INFO(0xc22538, 0, 64 * 1024,  256,
+ { "mx25l25635e", INFO(0xc22019, 0, 64 * 1024,  512,
+ { "mx25l25655e", INFO(0xc22619, 0, 64 * 1024,  512,
+ { "mx25u25635f", INFO(0xc22539, 0, 64 * 1024,  512,
+ { "mx66l51235f", INFO(0xc2201a, 0, 64 * 1024, 1024,
+ { "mx66u51235f", INFO(0xc2253a, 0, 64 * 1024, 1024,
+ { "mx66l1g45g",  INFO(0xc2201b, 0, 64 * 1024, 2048,
+ { "mx66l1g55g",  INFO(0xc2261b, 0, 64 * 1024, 2048,
  /* Micron */
  { "n25q032", INFO(0x20ba16, 0, 64 * 1024,   64, 0) },
@@ -784,19 +830,12 @@ time_out:
  * FLASH_PAGESIZE chunks.  The address range may be any size provided
  * it is within the physical boundaries.
-static int spi_nor_write(struct mtd_info *mtd, loff_t to, size_t len,
- size_t *retlen, const u_char *buf)
+static int spi_nor_do_write(struct spi_nor *nor, loff_t to, size_t len,
+ size_t *retlen, const u_char *buf)
- struct spi_nor *nor = mtd_to_spi_nor(mtd);
  u32 page_offset, page_size, i;
  int ret;
- dev_dbg(nor->dev, "to 0x%08x, len %zd\n", (u32)to, len);
- ret = spi_nor_lock_and_prep(nor, SPI_NOR_OPS_WRITE);
- if (ret)
- return ret;
  write_enable(nor);
  page_offset = to & (nor->page_size - 1);
@@ -817,7 +856,7 @@ static int spi_nor_write(struct mtd_info *mtd,
  ret = spi_nor_wait_till_ready(nor);
  if (ret)
- goto write_err;
+ return ret;
  write_enable(nor);
@@ -825,12 +864,416 @@ static int spi_nor_write(struct mtd_info *mtd,
- ret = spi_nor_wait_till_ready(nor);
-write_err:
+ return 0;
+static int spi_nor_write(struct mtd_info *mtd, loff_t to, size_t len,
+ struct spi_nor *nor = mtd_to_spi_nor(mtd);
+ int ret;
+ dev_dbg(nor->dev, "to 0x%08x, len %zd\n", (u32)to, len);
+ ret = spi_nor_lock_and_prep(nor, SPI_NOR_OPS_WRITE);
+ if (ret)
+ return ret;
+ ret = spi_nor_do_write(nor, to, len, retlen, buf);
+ if (!ret)
+ ret = spi_nor_wait_till_ready(nor);
  spi_nor_unlock_and_unprep(nor, SPI_NOR_OPS_WRITE);
  return ret;
+ * Power suspend and resume.
+static int spi_nor_suspend(struct mtd_info *mtd)
+ return nor->write_reg(nor, SPINOR_OP_DP, NULL, 0, 0);
+static void spi_nor_resume(struct mtd_info *mtd)
+ nor->write_reg(nor, SPINOR_OP_RDP, NULL, 0, 0);
+ * Read/Write manufacture or user protection area (One Time Program).
+ * Enter security OTP mode before access, and exit after access.
+ * The OTP area can be locked to prevent any modification, and there
+ * is no way to unlock it.
+static int macronix_otp(struct mtd_info *mtd, loff_t addr, size_t len,
+ size_t *retlen, u_char *buf, enum spi_nor_ops ops)
+ int ret;
+ ret = spi_nor_lock_and_prep(nor, ops);
+ if (ret)
+ return ret;
+ /* enter security OTP */
+ ret = nor->write_reg(nor, SPINOR_OP_ENSO, NULL, 0, 0);
+ if (ret) {
+ spi_nor_unlock_and_unprep(nor, ops);
+ return ret;
+ if (ops == SPI_NOR_OPS_READ)
+ nor->read(nor, addr, len, retlen, buf);
+ else { /* ops == SPI_NOR_OPS_WRITE */
+ /* exit if OTP has been locked */
+ if (read_scur(nor) & 0x03) {
+ return 0;
+ spi_nor_do_write(nor, addr, len, retlen, buf);
+ /* eixt security OTP */
+ nor->write_reg(nor, SPINOR_OP_EXSO, NULL, 0, 0);
+ return 0;
+static int macronix_get_fact_prot_info(struct mtd_info *mtd,
+ size_t len, size_t *retlen, struct otp_info *buf)
+ * Factor area stores electronical serial number (ESN).
+ * And the area can not be modified.
+ buf->start  = 0;
+ buf->length = 0x10;
+ buf->locked = 1;
+ return 0;
+static int macronix_read_fact_prot_reg(struct mtd_info *mtd,
+ loff_t from, size_t len, size_t *retlen, u_char *buf)
+ if (from < 0 || from + len > 0x10)
+ return -EINVAL;
+ return macronix_otp(mtd, from, len, retlen, buf,
+ SPI_NOR_OPS_READ);
+static int macronix_get_user_prot_info(struct mtd_info *mtd,
+ buf->start  = 0x10;
+ if (mtd->size > 0x800000) {
+ /* The OTP size are 0x200 if the device exceeds 8MiB. */
+ buf->length = 0x1f0;
+ } else {
+ buf->length = 0x30;
+ buf->locked = (read_scur(nor) & 0x03) ? 1 : 0;
+ return 0;
+static int macronix_read_user_prot_reg(struct mtd_info *mtd,
+ * Macronix user and factor security area are the same.
+ * If the device is larger than 8 Mbyte, it only support
+ * factor area.
+ if (from < 0x10 || from + len > 0x40 ||
+ (mtd->size > 0x800000 && from + len > 0x200)) {
+ return -EINVAL;
+static int macronix_write_user_prot_reg(struct mtd_info *mtd,
+ loff_t to, size_t len, size_t *retlen, u_char *buf)
+ if (to < 0x10 || to + len > 0x40 ||
+ (mtd->size > 0x800000 && to + len > 0x200)) {
+ return -EINVAL;
+ return macronix_otp(mtd, to, len, retlen, buf,
+ SPI_NOR_OPS_WRITE);
+ * Write LDSO bit (Lock-Down Security OTP) to 1.
+static int macronix_lock_user_prot_reg(struct mtd_info *mtd,
+ loff_t from, size_t len)
+ if (len == 0)
+ return 0;
+ write_enable(nor);
+ return write_scur(nor);
+ * Write protect selection command should be done before block lock.
+static int macronix_wpsel(struct spi_nor *nor)
+ int retval;
+ /* read security register to check WPSEL status */
+ retval = read_scur(nor);
+ if (retval < 0)
+ return retval;
+ if ((u8)retval & 0x80)
+ return 0;
+ return nor->write_reg(nor, SPINOR_OP_WPSEL, NULL, 0, 0);
+static int macronix_gang_lock(struct mtd_info *mtd,
+ enum spi_nor_ops ops)
+ if (ops == SPI_NOR_OPS_LOCK)
+ return nor->write_reg(nor, SPINOR_OP_GBLK, NULL, 0, 0);
+ else /* ops == SPI_NOR_OPS_UNLOCK */
+ return nor->write_reg(nor, SPINOR_OP_GBULK, NULL, 0, 0);
+static int macronix_read_lock_status(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len, enum macronix_lock_type type)
+ struct spi_nor_xfer_cfg cfg;
+ uint64_t end;
+ u32 move;
+ u8 status;
+ int ret;
+ /* do write protect selection first */
+ ret = macronix_wpsel(nor);
+ if (ret)
+ return ret;
+ ret = spi_nor_lock_and_prep(nor, SPI_NOR_OPS_READ);
+ if (ret)
+ return ret;
+ if (type == MX_SBLK) {
+ cfg.cmd = SPINOR_OP_RDBLOCK;
+ cfg.addr_pins = nor->addr_width;
+ } else {
+ if (type == MX_SPB)
+ cfg.cmd = SPINOR_OP_RDSPB;
+ else /* type == MX_DPB */
+ cfg.cmd = SPINOR_OP_RDDPB;
+ cfg.addr_pins = 4;
+ cfg.cmd_pins = 1;
+ cfg.mode_pins = 0;
+ cfg.dummy_cycles = 0;
+ end = ofs + len - 1;
+ for (; ofs <= end && ofs < mtd->size; ofs += move) {
+ /* align the sector/blok size */
+ if (ofs < 0x10000 || ofs >= mtd->size - 0x10000)
+ move = 0x1000;
+ else
+ move = 0x10000;
+ cfg.addr = ofs;
+ nor->read_xfer(nor, &cfg, &status, 1);
+ /* status 0xff: protected, return 1 */
+ if (status == 0xff) {
+ spi_nor_unlock_and_unprep(nor, SPI_NOR_OPS_READ);
+ return 1;
+ return 0;
+ * Macronix individual block lock. There are many types of
+ * block protection used on different flash memory.
+ * Single lock: volatile lock for E-series chips.
+ * Solid protection bit: non-volatile.
+ * Dynamic protection: volatile.
+static int macronix_block_lock(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len, enum macronix_lock_type type,
+ uint64_t end;
+ u32 move;
+ u8 *val, valtmp;
+ size_t datalen;
+ int ret;
+ if (ret)
+ return ret;
+ /* use gang command to do whole chip lock and unlock */
+ if (len == mtd->size && type != MX_SPB)
+ return macronix_gang_lock(mtd, ops);
+ if (ret)
+ return ret;
+ if (type == MX_DPB) {
+ cfg.cmd = SPINOR_OP_WRDPB;
+ valtmp = (ops == SPI_NOR_OPS_LOCK) ? 0xff : 0;
+ val = &valtmp;
+ datalen = 1;
+ } else {
+ cfg.cmd = (ops == SPI_NOR_OPS_LOCK) ?
+ SPINOR_OP_SBLK : SPINOR_OP_SBULK;
+ } else { /* type == MX_SPB */
+ cfg.cmd = SPINOR_OP_WRSPB;
+ val = NULL;
+ datalen = 0;
+ cfg.cmd_pins = 1;
+ cfg.wren = 1;
+ * The lock regions of Macronix are uniform. There use
+ * unit sector (4KB) in the first/last block, and unit
+ * block (64KB) in middle space of chips.
+ move = 0x1000;
+ else
+ move = 0x10000;
+ cfg.addr = ofs;
+ nor->write_xfer(nor, &cfg, val, datalen);
+ return 0;
+ * Single block lock/unlock/islock command.
+static int macronix_single_lock(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len)
+ return macronix_block_lock(mtd, ofs, len, MX_SBLK,
+ SPI_NOR_OPS_LOCK);
+static int macronix_single_unlock(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len)
+ SPI_NOR_OPS_UNLOCK);
+static int macronix_single_is_locked(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len)
+ return macronix_read_lock_status(mtd, ofs, len, MX_SBLK);
+ * Solid protection bit lock/unlock/islock command.
+static int macronix_solid_lock(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len)
+ return macronix_block_lock(mtd, ofs, len, MX_SPB,
+static int macronix_solid_unlock(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len)
+ int ret;
+ if (ret)
+ return ret;
+ /* erase solid bits will unlock all the blocks */
+ return nor->write_reg(nor, SPINOR_OP_ESSPB, NULL, 0, 0);
+static int macronix_solid_is_locked(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len)
+ return macronix_read_lock_status(mtd, ofs, len, MX_SPB);
+ * Dynamic protection bit lock/unlock/islock command.
+static int macronix_dynamic_lock(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len)
+ return macronix_block_lock(mtd, ofs, len, MX_DPB,
+static int macronix_dynamic_unlock(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len)
+static int macronix_dynamic_is_locked(struct mtd_info *mtd, loff_t ofs,
+ uint64_t len)
+ return macronix_read_lock_status(mtd, ofs, len, MX_DPB);
 static int macronix_quad_enable(struct spi_nor *nor)
  int ret, val;
@@ -913,6 +1356,202 @@ static int set_quad_mode(struct spi_nor *nor,
struct flash_info *info)
+ * Read SFDP ia an fundamental but important command for doing
+ * flash scan and probe.
+static int sfdp_read(struct spi_nor *nor, loff_t from, size_t len,
+ void *buf)
+ cfg.cmd = SPINOR_OP_RDSFDP;
+ cfg.cmd_pins = 1;
+ cfg.addr = from;
+ cfg.addr_pins = 3;
+ cfg.dummy_cycles = 8;
+ return nor->read_xfer(nor, &cfg, (u8 *)buf, len);
+ * Setup Macronix device with sfdp parameters.
+static void macronix_detect_sfdp(struct spi_nor *nor,
+ struct sfdp_param_header *facthdr)
+ struct sfdp_macronix_params mxchip;
+ struct mtd_info *mtd = nor->mtd;
+ u32 ptr, len;
+ /* get macronix parameters */
+ ptr = facthdr->pointer[0] + (facthdr->pointer[1] << 8) +
+ (facthdr->pointer[2] << 16);
+ len = (facthdr->length * 4/*DWORDs*/ < sizeof(mxchip)) ?
+ (facthdr->length * 4) : sizeof(mxchip);
+ if (sfdp_read(nor, ptr, len, &mxchip))
+ return;
+ /* security OTP support */
+ if (mxchip.protection_param & 0x0800) {
+ mtd->_get_fact_prot_info  = macronix_get_fact_prot_info;
+ mtd->_read_fact_prot_reg  = macronix_read_fact_prot_reg;
+ mtd->_get_user_prot_info  = macronix_get_user_prot_info;
+ mtd->_read_user_prot_reg  = macronix_read_user_prot_reg;
+ mtd->_write_user_prot_reg = macronix_write_user_prot_reg;
+ mtd->_lock_user_prot_reg  = macronix_lock_user_prot_reg;
+ /* individual block lock support */
+ if (mxchip.protection_param & 0x0001) {
+ switch ((mxchip.protection_param >> 2) & 0xff) {
+ case SPINOR_OP_SBLK:
+ mtd->_lock      = macronix_single_lock;
+ mtd->_unlock    = macronix_single_unlock;
+ mtd->_is_locked = macronix_single_is_locked;
+ break;
+ case SPINOR_OP_WRSPB:
+ mtd->_lock      = macronix_solid_lock;
+ mtd->_unlock    = macronix_solid_unlock;
+ mtd->_is_locked = macronix_solid_is_locked;
+ break;
+ case SPINOR_OP_WRDPB:
+ mtd->_lock      = macronix_dynamic_lock;
+ mtd->_unlock    = macronix_dynamic_unlock;
+ mtd->_is_locked = macronix_dynamic_is_locked;
+ break;
+ default:
+ pr_err("Can not find Macronix protection parameters.\n");
+ return;
+ if (!(mxchip.protection_param & 0x0400))
+ mtd->_unlock(mtd, 0, mtd->size);
+ * Check if the SPI NOR is SFDP compliant, returns 1 if it is, 0 otherwise.
+ * Directly update mtd information.
+static int spi_nor_detect_sfdp(struct spi_nor *nor, enum read_mode mode)
+ struct spi_nor_sfdp_params sfdp;
+ struct sfdp_jedec_params jedec;
+ struct sfdp_param_header *jedechdr = NULL, *facthdr = NULL;
+ struct flash_info info;
+ u32 ptr, len;
+ int i, sect;
+ /* get JEDEC parameters */
+ sfdp_read(nor, 0, 4/*sizeof(sfdp.signature)*/, &sfdp.signature);
+ if (sfdp.signature != SFDP_SIGNATURE)
+ return 0;
+ if (sfdp_read(nor, 4, 4, &sfdp.minor_rev))
+ return 0;
+ if (sfdp.num_of_param_header < 1)
+ return 0;
+ if (sfdp_read(nor, 8,/*sizeof(sfdp.signature) + revision + header_num*/
+ sizeof(struct sfdp_param_header)*(sfdp.num_of_param_header+1),
+ sfdp.header)) {
+ return 0;
+ * Get JEDEC and manufacture parameter header.
+ * Attention that num_of_param_header is zero base.
+ for (i = 0; i <= sfdp.num_of_param_header; i++) {
+ if (sfdp.header[i].id == 0)
+ jedechdr = &sfdp.header[i];
+ else if (sfdp.header[i].id != 0xFF)
+ facthdr = &sfdp.header[i];
+ if (jedechdr && facthdr)
+ break;
+ if (!jedechdr || !facthdr || jedechdr->major_rev == 0)
+ return 0;
+ /* read JEDEC parameters */
+ ptr = jedechdr->pointer[0] + (jedechdr->pointer[1] << 8) +
+ (jedechdr->pointer[2] << 16);
+ len = (jedechdr->length * 4/*DWORDs*/ < sizeof(jedec)) ?
+ jedechdr->length * 4 : sizeof(jedec);
+ if (sfdp_read(nor, ptr, len, &jedec))
+ return 0;
+ mtd->writesize = (jedec.f_param & 0x04) ? 64 : 1;
+ mtd->size = jedec.flash_density + 1;
+ /* max number of sector type = 4 */
+#ifdef CONFIG_MTD_SPI_NOR_USE_4K_SECTORS
+ for (sect = 0; sect < 4; sect++)
+ if (jedec.e_type[sect].size_power == 12)
+ break;
+ if (sect == 4)
+#endif
+ /* use largest sector as erase unit */
+ for (sect = 0, i = 1; i < 4; i++) {
+ if (jedec.e_type[i].size_power >
+ jedec.e_type[sect].size_power)
+ sect = i;
+ nor->erase_opcode = jedec.e_type[sect].opcode;
+ mtd->erasesize = (1 << jedec.e_type[sect].size_power);
+ if (nor->erase_opcode == 0xff)
+ mtd->flags |= MTD_NO_ERASE;
+ if (mode == SPI_NOR_QUAD && jedec.fr_support & 0x20) {
+ if (set_quad_mode(nor, &info))
+ return 0;
+ nor->flash_read = SPI_NOR_QUAD;
+ } else if (mode == SPI_NOR_DUAL && jedec.fr_support & 0x01) {
+ nor->flash_read = SPI_NOR_DUAL;
+ nor->addr_width = ((jedec.fr_support >> 1) & 0x03) ? 4 : 3;
+ * Most of JEDEC 1.6 parameters are no use to mtd.
+ * They are reserved in the struct 'spi_nor_sfdp_params'
+ * for future usage.
+ if (jedechdr->major_rev > 1 || jedechdr->minor_rev >= 6) {
+ nor->page_size = 1 << ((jedec.p_param >> 4) & 0x0F);
+ mtd->writebufsize = nor->page_size;
+ dev_info(nor->dev, "sfdp %u.%u compliant, jedec rev %u.%u\n",
+ sfdp.major_rev, sfdp.minor_rev,
+ jedechdr->major_rev, jedechdr->minor_rev);
+ * Get the manufacture defined parameters to mtd:
+ * protection area, lock, unlock and islock function.
+ switch (facthdr->id) {
+ case CFI_MFR_MACRONIX:
+ macronix_detect_sfdp(nor, facthdr);
+ break;
+ case CFI_MFR_ST:
+ /* nor protection support for STmicro chips */
+ mtd->_lock = spi_nor_lock;
+ mtd->_unlock = spi_nor_unlock;
+ break;
+ return 1;
 static int spi_nor_check(struct spi_nor *nor)
  if (!nor->dev || !nor->read || !nor->write ||
@@ -982,7 +1621,8 @@ int spi_nor_scan(struct spi_nor *nor, const char
*name, enum read_mode mode)
  if (JEDEC_MFR(info) == CFI_MFR_ATMEL ||
     JEDEC_MFR(info) == CFI_MFR_INTEL ||
-    JEDEC_MFR(info) == CFI_MFR_SST) {
+    JEDEC_MFR(info) == CFI_MFR_SST ||
+    JEDEC_MFR(info) == CFI_MFR_MACRONIX) {
  write_enable(nor);
  write_sr(nor, 0);
@@ -990,17 +1630,11 @@ int spi_nor_scan(struct spi_nor *nor, const
char *name, enum read_mode mode)
  if (!mtd->name)
  mtd->name = dev_name(dev);
  mtd->type = MTD_NORFLASH;
- mtd->writesize = 1;
  mtd->flags = MTD_CAP_NORFLASH;
- mtd->size = info->sector_size * info->n_sectors;
  mtd->_erase = spi_nor_erase;
  mtd->_read = spi_nor_read;
- /* nor protection support for STmicro chips */
- if (JEDEC_MFR(info) == CFI_MFR_ST) {
- mtd->_lock = spi_nor_lock;
- mtd->_unlock = spi_nor_unlock;
+ mtd->_suspend = spi_nor_suspend;
+ mtd->_resume = spi_nor_resume;
  /* sst nor chips use AAI word program */
  if (info->flags & SST_WRITE)
@@ -1011,21 +1645,6 @@ int spi_nor_scan(struct spi_nor *nor, const
  if (info->flags & USE_FSR)
  nor->flags |= SNOR_F_USE_FSR;
-#ifdef CONFIG_MTD_SPI_NOR_USE_4K_SECTORS
- /* prefer "small sector" erase if possible */
- if (info->flags & SECT_4K) {
- nor->erase_opcode = SPINOR_OP_BE_4K;
- mtd->erasesize = 4096;
- } else if (info->flags & SECT_4K_PMC) {
- nor->erase_opcode = SPINOR_OP_BE_4K_PMC;
- } else
-#endif
- nor->erase_opcode = SPINOR_OP_SE;
- mtd->erasesize = info->sector_size;
  if (info->flags & SPI_NOR_NO_ERASE)
@@ -1048,6 +1667,45 @@ int spi_nor_scan(struct spi_nor *nor, const
  if (info->flags & SPI_NOR_NO_FR)
  nor->flash_read = SPI_NOR_NORMAL;
+ * We prepare to use SFDP to replace flash info struct, but
+ * there are many flags not covered by SFDP such as SST_WRITE,
+ * USE_FSR, SPI_NOR_NO_FR and SECT_4K_PMC. This part still need
+ * to be modified by each flash manufacturer. Finally, we hope
+ * we can setup spi-nor all from SFDP.
+#ifndef CONFIG_MTD_SPI_NOR_SFDP
+ if (0)
+#endif
+ /* If the chip is SFDP compliant, update the mtd info. */
+ if (spi_nor_detect_sfdp(nor, mode))
+ goto scan_done;
+ mtd->writesize = 1;
+ mtd->size = info->sector_size * info->n_sectors;
+ if (JEDEC_MFR(info) == CFI_MFR_ST) {
+ /* prefer "small sector" erase if possible */
+ if (info->flags & SECT_4K) {
+ nor->erase_opcode = SPINOR_OP_BE_4K;
+ mtd->erasesize = 4096;
+ } else if (info->flags & SECT_4K_PMC) {
+ nor->erase_opcode = SPINOR_OP_BE_4K_PMC;
+ } else
+#endif
+ nor->erase_opcode = SPINOR_OP_SE;
+ mtd->erasesize = info->sector_size;
  /* Quad/Dual-read mode takes precedence over fast/normal */
  if (mode == SPI_NOR_QUAD && info->flags & SPI_NOR_QUAD_READ) {
  ret = set_quad_mode(nor, info);
@@ -1060,6 +1718,16 @@ int spi_nor_scan(struct spi_nor *nor, const
+ if (info->addr_width)
+ nor->addr_width = info->addr_width;
+ else if (mtd->size > 0x1000000) {
+ /* enable 4-byte addressing if the device exceeds 16MiB */
+ nor->addr_width = 4;
+ } else {
+ nor->addr_width = 3;
+scan_done:
  /* Default commands */
  switch (nor->flash_read) {
  case SPI_NOR_QUAD:
@@ -1081,11 +1749,7 @@ int spi_nor_scan(struct spi_nor *nor, const
  nor->program_opcode = SPINOR_OP_PP;
- if (info->addr_width)
- nor->addr_width = info->addr_width;
- else if (mtd->size > 0x1000000) {
- /* enable 4-byte addressing if the device exceeds 16MiB */
- nor->addr_width = 4;
+ if (info->addr_width == 4) {
  if (JEDEC_MFR(info) == CFI_MFR_AMD) {
  /* Dedicated 4-byte command set */
@@ -1108,8 +1772,6 @@ int spi_nor_scan(struct spi_nor *nor, const char
  } else
  set_4byte(nor, info, 1);
- } else {
- nor->addr_width = 3;
  nor->read_dummy = spi_nor_read_dummy_cycles(nor);
diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h
index 63aeccf..8f8f892 100644
--- a/include/linux/mtd/spi-nor.h
+++ b/include/linux/mtd/spi-nor.h
@@ -35,6 +35,11 @@
 #define SPINOR_OP_RDID 0x9f /* Read JEDEC ID */
 #define SPINOR_OP_RDCR 0x35 /* Read configuration register */
 #define SPINOR_OP_RDFSR 0x70 /* Read flag status register */
+#define SPINOR_OP_WRSCUR 0x2f /* Write security register */
+#define SPINOR_OP_RDSCUR 0x2b /* Read security register */
+#define SPINOR_OP_SUSPEND 0xb0 /* Erase/program suspend */
+#define SPINOR_OP_RESUME 0x30 /* Erase/program resume */
+#define SPINOR_OP_RDSFDP 0x5a /* Read SFDP */
 /* 4-byte address opcodes - used on Spansion and some Macronix flashes. */
 #define SPINOR_OP_READ4 0x13 /* Read data bytes (low frequency) */
@@ -53,6 +58,23 @@
 #define SPINOR_OP_EN4B 0xb7 /* Enter 4-byte mode */
 #define SPINOR_OP_EX4B 0xe9 /* Exit 4-byte mode */
+/* Used for Macronix flashes. */
+#define SPINOR_OP_DP 0xb9 /* Deep power-down */
+#define SPINOR_OP_RDP 0xab /* Release from deep power-down */
+#define SPINOR_OP_ENSO 0xb1 /* Enter secured OTP */
+#define SPINOR_OP_EXSO 0xc1 /* Exit secured OTP */
+#define SPINOR_OP_WPSEL 0x68 /* Write protect selection */
+#define SPINOR_OP_SBLK 0x36 /* Single block lock */
+#define SPINOR_OP_SBULK 0x39 /* Single block unlock */
+#define SPINOR_OP_GBLK 0x7e /* Gang block lock */
+#define SPINOR_OP_GBULK 0x98 /* Gang block unlock */
+#define SPINOR_OP_RDBLOCK 0x3c /* Read block lock status */
+#define SPINOR_OP_WRSPB 0xe3 /* Write solid protection bit */
+#define SPINOR_OP_RDSPB 0xe2 /* Read solid protection bit */
+#define SPINOR_OP_ESSPB 0xe4 /* Rease solid protection bit */
+#define SPINOR_OP_WRDPB 0xe1 /* Write dynamic protection bit */
+#define SPINOR_OP_RDDPB 0xe0 /* Write dynamic protection bit */
 /* Used for Spansion flashes only. */
 #define SPINOR_OP_BRWR 0x17 /* Bank register write */
@@ -80,6 +102,185 @@ enum read_mode {
  SPI_NOR_QUAD,
+enum macronix_lock_type {
+ MX_SBLK = 0,
+ MX_SPB,
+ MX_DPB,
+ * struct sfdp_vendor_macronix - Macronix SFDP parameter table
+ * @vcc_supply_max_voltage: Maximun voltage of chip
+ * @vcc_supply_min_voltage: Minimun voltage of chip
+ * @f_param: Macronix flash parameters:
+ * Bit 0: support of H/W Reset# pin
+ * Bit 1: support of H/W Hold# pin
+ * Bit 2: support of deep power down mode
+ * Bit 3: support of S/W Reset
+ * Bit 4~11: software reset instruction
+ * Bit 12: support of program suspend/resume
+ * Bit 13: support of erase suspend/resume
+ * Bit 15: support of wrap-around read
+ * @wrap_around_read_opcode: Wrap around read instrction
+ * @wrap_around_read_length: Wrap around read length
+ * @protection_param: Protection related parameters:
+ * Bit 0: support of individual block lock
+ * Bit 1: individual lock bits
+ * Bit 2~9: individual block lock opcode
+ * Bit 10: default status of individual lock
+ * Bit 11: support of security OTP
+ * Bit 12: support of read lock
+ * Bit 13: support of permanent lock
+struct sfdp_macronix_params {
+ u16 vcc_supply_max_voltage;
+ u16 vcc_supply_min_voltage;
+ u16 f_param;
+ u8 wrap_around_read_opcode;
+ u8 wrap_around_read_length;
+ u16 protection_param;
+ u8 reserved[6];
+ * struct sfdp_erase_type - SFDP erase type parameter
+ * @size_power: Erase size (2 to the n-th power)
+ * @opcode: Erase instruction
+struct sfdp_erase_type {
+ u8 size_power;
+ u8 opcode;
+ * struct sfdp_jedec_params - Basic JEDEC parameters of SFDP
+ * @f_param: JEDEC flash parameters:
+ * Bit 0~1: Block/sector erase size
+ * Bit 2: write granularity (0 - 1B, 1 - 64B)
+ * Bit 3~4: command of write enable
+ * @be_4k_opcode: 4KByte block/sector erase instruction
+ * @fr_support: Fast read supports:
+ * Bit 0: support of fast read 1-1-2
+ * Bit 1~2: address width
+ * Bit 3: support of DTR
+ * Bit 4~6: support of fast read 1-2-2, 1-4-4, 1-1-4
+ * @flash_density: Flash memory density
+ * @fr_XXX_param: (X-X-X) Fast read parameters:
+ * Bit 0~4: number of dummy clocks
+ * Bit 5~7: number of mode clocks
+ * @fr_XXX_opcode: (X-X-X) Fast read instruction
+ * @fr_222_444_support: Fast read (2-2-2/4-4-4) supports:
+ * Bit 0: support of fast read 2-2-2
+ * Bit 4: support of fast read 4-4-4
+ * @erase_type: Erase type (size & instruction)
+ * @e_param: Erase parameters (timing):
+ * Bit 0~3: multiplier from typical to max erase time
+ * Bit 4~32: typical time of each type of erase
+ * @p_param: Program parameters:
+ * Bit 0~3: multiplier from typical to max program time
+ * Bit 4~7: page size (2 to the n-th power)
+ * Bit 8~30: typical time of PP, BP and chip erase
+ * @susp_param: Suspend/Resume parameters:
+ * Bit 0~7: prohibited operations during suspend
+ * Bit 9~30: timing defininition
+ * Bit 31: support of suspend/resume
+ * @p_resu_opcode: Program resume instruction
+ * @p_susp_opcode: Program suspend instruction
+ * @resu_opcode: Write/Erase resume instruction
+ * @susp_opcode: Write/Erase suspend instruction
+ * @dp_param: Deep powerdown parameters:
+ * Bit 2~14: delay and SR polliong
+ * Bit 15~22: exit deep powerdown instruction
+ * Bit 23~30: enter deep powerdown instruction
+ * Bit 31: support of deep powerdown
+ * @fr_quad_param: (X-4-4) Fast read parameters:
+ * Bit 0~8: 4-4-4 mode disable/enable sequences
+ * Bit 9: support of fast read 0-4-4
+ * Bit 10~19: 0-4-4 mode exit/entry method
+ * Bit 20~22: quad enable requirements (QER)
+ * Bit 23: HOLD or RESET disable
+ * @en4b_param: Method of enter 4-byte address
+ * @ex4b_softreset_param: method of exit 4-byte address and software reset
+ * @sr_param: Volatile/Non-volatile status register 1 parameters
+struct sfdp_jedec_params {
+ u8 f_param;
+ u8 be_4k_opcode;
+ u8 fr_support;
+ u8 reserved1;
+ u32 flash_density;
+ u8 fr_144_param;
+ u8 fr_144_opcode;
+ u8 fr_114_param;
+ u8 fr_114_opcode;
+ u8 fr_112_param;
+ u8 fr_112_opcode;
+ u8 fr_122_param;
+ u8 fr_122_opcode;
+ u8 fr_222_444_support;
+ u8 reserved2[5];
+ u8 fr_222_param;
+ u8 fr_222_opcode;
+ u8 reserved3[2];
+ u8 fr_444_param;
+ u8 fr_444_opcode;
+ struct sfdp_erase_type e_type[4];
+ u32 e_param;
+ u32 p_param;
+ u32 susp_param;
+ u8 p_resu_opcode;
+ u8 p_susp_opcode;
+ u8 resu_opcode;
+ u8 susp_opcode;
+ u32 dp_param;
+ u32 fr_quad_param;
+ u8 en4b_param;
+ u16 ex4b_softreset_param;
+ u8 sr_param;
+ * struct sfdp_param_header - SFDP parameter header
+ * @id: Parameter ID LSB (manufacture ID)
+ * @minor_rev: Parameter table minor revision number
+ * @major_rev: Parameter table major revision number
+ * @length: Parameter table length (DWORDs)
+ * @pointer: Parameter table pointer (start address)
+ * @id_reserved: Parameter ID MSB
+struct sfdp_param_header {
+ u8 id;
+ u8 minor_rev;
+ u8 major_rev;
+ u8 length;
+ u8 pointer[3];
+ u8 id_reserved;
+/* SFDP signature (ASCII: 'S' 'F' 'D' 'P') */
+#define SFDP_SIGNATURE 0x50444653
+ * struct spi_nor_sfdp_params - Serial Flash Discoverable Parameters
+ * @signature: SFDP signature for identification
+ * @minor_rev: SFDP minor revision number
+ * @major_rev: SFDP major revision number
+ * @num_of_param_header: Number of parameter headers (0 indicates 1 header)
+ * @header: Header of JEDEC or vendor's parameters
+struct spi_nor_sfdp_params {
+ u32 signature;
+ u8 minor_rev;
+ u8 major_rev;
+ u8 num_of_param_header;
+ u8 reserved0;
+ struct sfdp_param_header header[5];
  * struct spi_nor_xfer_cfg - Structure for defining a Serial Flash transfer
  * @wren: command for "Write Enable", or 0x00 for not required
1.9.1
#4 2020-05-07 10:07:11
qdk0901
这个不错,就是不知道破解代价有多大,要是淘宝几千块就破解了,就没意思了
#5 2021-08-13 15:01:49
佐须之男
实际上OTP也是可以破解的,难度也不大。用CPLD就可以破解了,可以看我的教程:https://www.bilibili.com/video/BV1Lt411s7z8
最近编辑记录 佐须之男 (2021-08-13 18:07:17)
