串口log如下,uboot自己编译的,内核群文件下载的,文件系统是最小ubuntu,麻烦大家看看能不能看出来是什么问题
log_20200507-2242.txt
这是串口log
不想下载文件的大佬可以看看截图
下面是内核文件
image.rar
文件系统用的最小ubuntu,这里我怀疑是文件系统没搞好,想问我是解压后复制到SD卡的,是不是这里出了问题。。
应该如何操作
最近编辑记录 mysteryli (2020-05-07 22:43:10)
我改了一下,日志变了,你看还是和之前一样文件系统的问题么
直接把日志贴出来吧, 用 code 标签
[ 2.688725] systemd[61]: /lib/systemd/system-generators/systemd-gpt-auto-generator failed with error code 127.
[ 2.889637] systemd[1]: Cannot add dependency job for unit dbus.socket, ignoring: Unit dbus.socket failed to load: No such file or directory.
[ 2.907827] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
文件系统有问题请,要先解决上面这几个错误吧
U-Boot SPL 2017.01-rc2-g32ab180 (Apr 29 2020 - 00:30:51)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-g32ab180 (Apr 29 2020 - 00:30:51 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
dotclock: 10000kHz = 10000kHz: (1 * 3MHz * 20) / 6
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
Hit any key to stop autoboot: 2 1 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
292 bytes read in 14 ms (19.5 KiB/s)
reading zImage
3971936 bytes read in 208 ms (18.2 MiB/s)
11533 bytes read in 26 ms (432.6 KiB/s)
Loading Device Tree to 42dfa000, end 42dffd0c ... OK
[ 0.000000] Linux version 4.13.0-rc7-licheepi-zero (xiaoxiongmao@xiaoxiongmao-vm) (gcc version 6.3.0 20170321 (Debian 6.3.0-10)) #4 SMP Thu Aug 31 00:05:26 CST 2017
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 16 pages/cpu @c3edf000 s33868 r8192 d23476 u65536
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16129
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 console=tty0 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[ 0.000000] Memory: 54564K/65024K available (6144K kernel code, 230K rwdata, 1452K rodata, 1024K init, 263K bss, 10460K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3f80000 ( 63 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB)
[ 0.000000] .data : 0xc0a00000 - 0xc0a39b80 ( 231 kB)
[ 0.000000] .bss : 0xc0a40874 - 0xc0a825ec ( 264 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000182] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000401] Console: colour dummy device 80x30
[ 0.000827] console [tty0] enabled
[ 0.000863] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000901] pid_max: default: 32768 minimum: 301
[ 0.001037] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001067] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001676] CPU: Testing write buffer coherency: ok
[ 0.002066] /cpus/cpu@0 missing clock-frequency property
[ 0.002107] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002552] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002760] Hierarchical SRCU implementation.
[ 0.003268] smp: Bringing up secondary CPUs ...
[ 0.003299] smp: Brought up 1 node, 1 CPU
[ 0.003319] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003339] CPU: All CPU(s) started in SVC mode.
[ 0.004113] devtmpfs: initialized
[ 0.007147] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.007444] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.007502] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007680] pinctrl core: initialized pinctrl subsystem
[ 0.008562] random: get_random_u32 called from bucket_table_alloc+0xf4/0x244 with crng_init=0
[ 0.008727] NET: Registered protocol family 16
[ 0.009203] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.010415] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.010466] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.023642] SCSI subsystem initialized
[ 0.023974] usbcore: registered new interface driver usbfs
[ 0.024070] usbcore: registered new interface driver hub
[ 0.024179] usbcore: registered new device driver usb
[ 0.024460] pps_core: LinuxPPS API ver. 1 registered
[ 0.024485] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.024532] PTP clock support registered
[ 0.024759] Advanced Linux Sound Architecture Driver Initialized.
[ 0.026585] clocksource: Switched to clocksource arch_sys_counter
[ 0.037212] NET: Registered protocol family 2
[ 0.037827] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.037884] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.037921] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.038063] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.038129] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.038365] NET: Registered protocol family 1
[ 0.038980] RPC: Registered named UNIX socket transport module.
[ 0.039026] RPC: Registered udp transport module.
[ 0.039045] RPC: Registered tcp transport module.
[ 0.039062] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.041122] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.050056] NFS: Registering the id_resolver key type
[ 0.050131] Key type id_resolver registered
[ 0.050150] Key type id_legacy registered
[ 0.051153] random: fast init done
[ 0.053938] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.053993] io scheduler noop registered
[ 0.054012] io scheduler deadline registered
[ 0.054260] io scheduler cfq registered (default)
[ 0.054288] io scheduler mq-deadline registered
[ 0.054305] io scheduler kyber registered
[ 0.058743] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.125378] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.128794] console [ttyS0] disabled
[ 0.149093] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.731095] console [ttyS0] enabled
[ 0.738194] libphy: Fixed MDIO Bus: probed
[ 0.742697] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.748611] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.754366] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.760578] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.766261] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.773535] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.779221] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.786456] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.791441] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.798423] libphy: stmmac: probed
[ 0.803685] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.810372] ehci-platform: EHCI generic platform driver
[ 0.815927] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.821639] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.829601] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.856607] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.863827] hub 1-0:1.0: USB hub found
[ 0.867819] hub 1-0:1.0: 1 port detected
[ 0.872310] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.878632] ohci-platform: OHCI generic platform driver
[ 0.884190] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.890940] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.898946] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 0.971664] hub 2-0:1.0: USB hub found
[ 0.975510] hub 2-0:1.0: 1 port detected
[ 0.982641] usbcore: registered new interface driver usb-storage
[ 0.989363] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.998909] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.007895] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.014714] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.019382] i2c /dev entries driver
[ 1.024702] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.086825] sunxi-mmc 1c0f000.mmc: base:0xc4101000 irq:23
[ 1.143619] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.151762] sunxi-mmc 1c10000.mmc: base:0xc4105000 irq:24
[ 1.158312] usbcore: registered new interface driver usbhid
[ 1.163910] usbhid: USB HID core driver
[ 1.168587] mmc0: new high speed SDHC card at address b368
[ 1.174744] mmcblk0: mmc0:b368 USD00 7.48 GiB
[ 1.181370] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.189471] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.197013] mmcblk0: p1 p2
[ 1.203925] NET: Registered protocol family 17
[ 1.208658] Key type dns_resolver registered
[ 1.213089] Registering SWP/SWPB emulation handler
[ 1.222326] simple-framebuffer 43f80000.framebuffer: framebuffer at 0x43f80000, 0x7f800 bytes, mapped to 0xc4300000
[ 1.232997] simple-framebuffer 43f80000.framebuffer: format=x8r8g8b8, mode=480x272x32, linelength=1920
[ 1.245266] Console: switching to colour frame buffer device 60x34
[ 1.253838] simple-framebuffer 43f80000.framebuffer: fb0: simplefb registered!
[ 1.262482] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.279536] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.289152] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.302070] hub 3-0:1.0: USB hub found
[ 1.308026] hub 3-0:1.0: 1 port detected
[ 1.315117] using random self ethernet address
[ 1.321632] using random host ethernet address
[ 1.330000] usb0: HOST MAC ce:88:a8:78:2d:4a
[ 1.336175] usb0: MAC 26:1d:73:a7:a0:c5
[ 1.341950] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.352996] g_cdc gadget: g_cdc ready
[ 1.360989] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.372973] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:05 UTC (5)
[ 1.384818] vcc5v0: disabling
[ 1.389619] ALSA device list:
[ 1.394309] #0: V3s Audio Codec
[ 1.401244] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.413920] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 2.239860] EXT4-fs (mmcblk0p2): recovery complete
[ 2.251365] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.263031] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.282728] devtmpfs: mounted
[ 2.288922] Freeing unused kernel memory: 1024K
[ 2.465481] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 2.484555] systemd[1]: Detected architecture 'arm'.
[ 2.514305] systemd[1]: Failed to insert module 'autofs4'
[ 2.521909] systemd[1]: Failed to insert module 'ipv6'
[ 2.530543] systemd[1]: Set hostname to <LicheePi>.
[ 2.930618] systemd[1]: Expecting device dev-ttyS0.device...
[ 2.942711] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 67.046687] random: crng init done
[ 93.207838] systemd-journald[81]: Received request to flush runtime journal from PID 1
[ 2.907827] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.文件系统有问题请,要先解决上面这几个错误吧
有关于荔枝派制作文件系统的标准操作么,我就是解压到主分区,可能是我操作有问题
DRAM: 64 MiB
In: serial@01c28000
Scanning mmc 0:1...
reading /boot.scr
reading zImage
3971936 bytes read in 211 ms (18 MiB/s)
11533 bytes read in 25 ms (450.2 KiB/s)
[ 0.000189] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000414] Console: colour dummy device 80x30
[ 0.000838] console [tty0] enabled
[ 0.000879] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000916] pid_max: default: 32768 minimum: 301
[ 0.001054] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001086] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001697] CPU: Testing write buffer coherency: ok
[ 0.002091] /cpus/cpu@0 missing clock-frequency property
[ 0.002137] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002585] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002786] Hierarchical SRCU implementation.
[ 0.003296] smp: Bringing up secondary CPUs ...
[ 0.003328] smp: Brought up 1 node, 1 CPU
[ 0.003347] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003366] CPU: All CPU(s) started in SVC mode.
[ 0.004135] devtmpfs: initialized
[ 0.007167] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.007461] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.007520] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007698] pinctrl core: initialized pinctrl subsystem
[ 0.008576] random: get_random_u32 called from bucket_table_alloc+0xf4/0x244 with crng_init=0
[ 0.008745] NET: Registered protocol family 16
[ 0.009223] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.010451] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.010500] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.023701] SCSI subsystem initialized
[ 0.024031] usbcore: registered new interface driver usbfs
[ 0.024122] usbcore: registered new interface driver hub
[ 0.024229] usbcore: registered new device driver usb
[ 0.024517] pps_core: LinuxPPS API ver. 1 registered
[ 0.024544] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.024591] PTP clock support registered
[ 0.024823] Advanced Linux Sound Architecture Driver Initialized.
[ 0.026656] clocksource: Switched to clocksource arch_sys_counter
[ 0.037244] NET: Registered protocol family 2
[ 0.037860] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.037920] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.037956] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.038092] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.038155] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.038384] NET: Registered protocol family 1
[ 0.039002] RPC: Registered named UNIX socket transport module.
[ 0.039044] RPC: Registered udp transport module.
[ 0.039062] RPC: Registered tcp transport module.
[ 0.039079] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.041148] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.050073] NFS: Registering the id_resolver key type
[ 0.050147] Key type id_resolver registered
[ 0.050167] Key type id_legacy registered
[ 0.051181] random: fast init done
[ 0.053956] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.054012] io scheduler noop registered
[ 0.054030] io scheduler deadline registered
[ 0.054278] io scheduler cfq registered (default)
[ 0.054304] io scheduler mq-deadline registered
[ 0.054322] io scheduler kyber registered
[ 0.058760] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.125276] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.128699] console [ttyS0] disabled
[ 0.148994] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.731000] console [ttyS0] enabled
[ 0.738087] libphy: Fixed MDIO Bus: probed
[ 0.742585] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.748497] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.754255] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.760459] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.766144] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.773420] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.779107] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.786341] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.791325] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.798306] libphy: stmmac: probed
[ 0.803548] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.810234] ehci-platform: EHCI generic platform driver
[ 0.815791] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.821503] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.829466] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.856682] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.863897] hub 1-0:1.0: USB hub found
[ 0.867887] hub 1-0:1.0: 1 port detected
[ 0.872388] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.878705] ohci-platform: OHCI generic platform driver
[ 0.884263] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.891010] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.899010] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 0.971722] hub 2-0:1.0: USB hub found
[ 0.975566] hub 2-0:1.0: 1 port detected
[ 0.982703] usbcore: registered new interface driver usb-storage
[ 0.989432] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.998978] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.007957] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.014776] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.019441] i2c /dev entries driver
[ 1.024774] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.086891] sunxi-mmc 1c0f000.mmc: base:0xc4101000 irq:23
[ 1.143693] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.151841] sunxi-mmc 1c10000.mmc: base:0xc4105000 irq:24
[ 1.158393] usbcore: registered new interface driver usbhid
[ 1.163992] usbhid: USB HID core driver
[ 1.168673] mmc0: new high speed SDHC card at address b368
[ 1.174837] mmcblk0: mmc0:b368 USD00 7.48 GiB
[ 1.181510] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.189604] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.197145] mmcblk0: p1 p2
[ 1.204051] NET: Registered protocol family 17
[ 1.208776] Key type dns_resolver registered
[ 1.213203] Registering SWP/SWPB emulation handler
[ 1.222424] simple-framebuffer 43f80000.framebuffer: framebuffer at 0x43f80000, 0x7f800 bytes, mapped to 0xc4300000
[ 1.233090] simple-framebuffer 43f80000.framebuffer: format=x8r8g8b8, mode=480x272x32, linelength=1920
[ 1.245363] Console: switching to colour frame buffer device 60x34
[ 1.253936] simple-framebuffer 43f80000.framebuffer: fb0: simplefb registered!
[ 1.262599] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.279660] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.289284] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.302174] hub 3-0:1.0: USB hub found
[ 1.308137] hub 3-0:1.0: 1 port detected
[ 1.315250] using random self ethernet address
[ 1.321758] using random host ethernet address
[ 1.330129] usb0: HOST MAC 12:07:8b:43:f5:cd
[ 1.336304] usb0: MAC f6:e0:a9:20:10:31
[ 1.342086] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.353143] g_cdc gadget: g_cdc ready
[ 1.361139] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.373126] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:05 UTC (5)
[ 1.384973] vcc5v0: disabling
[ 1.389770] ALSA device list:
[ 1.394459] #0: V3s Audio Codec
[ 1.401210] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.413892] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 1.897756] EXT4-fs (mmcblk0p2): recovery complete
[ 1.910185] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.921855] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.940988] devtmpfs: mounted
[ 1.947125] Freeing unused kernel memory: 1024K
[ 2.129074] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 2.148128] systemd[1]: Detected architecture 'arm'.
[ 2.177400] systemd[1]: Failed to insert module 'autofs4'
[ 2.184830] systemd[1]: Failed to insert module 'ipv6'
[ 2.193557] systemd[1]: Set hostname to <LicheePi>.
[ 2.618526] systemd[1]: Cannot add dependency job for unit dbus.socket, ignoring: Unit dbus.socket failed to load: No such file or directory.
[ 2.636794] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 2.659535] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 2.671576] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.683020] systemd[1]: Expecting device dev-ttyS0.device...
[ 2.906341] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.386479] systemd-udevd[92]: starting version 215
[ 4.407494] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 4.895137] systemd-journald[80]: Received request to flush runtime journal from PID 1
[ 7.221770] Generic PHY stmmac-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:01, irq=-1)
[ 7.237190] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[ 7.248370] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[ 32.033314] random: crng init done
Debian GNU/Linux 8 LicheePi ttyS0
LicheePi login: root
Password:
Last login: Thu Jan 1 08:20:03 HKT 1970 on ttyS0
Linux LicheePi 4.13.0-rc7-licheepi-zero #4 SMP Thu Aug 31 00:05:26 CST 2017 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
root@LicheePi:~# free -m
total used free shared buffers cached
Mem: 54 44 10 5 4 19
-/+ buffers/cache: 20 34
Swap: 0 0 0
root@LicheePi:~#
现在可以登陆了,之前应该是SD卡擦除不干净,但是现在好久才出登陆,所以想问下大家,这是啥情况,另外内存占用好像比较高,这个是大家都这样嘛。。
你好歹还能登陆进去,我的板子是启动不了
cache是文件系统占用吧, 如果你申请内存, 这部分会自动释放,
free + cached = 10 + 19 = 29M
你应该还有 29M 可以用.
https://whycan.cn/files/members/3311/QQ截图20200508225407.png
U-Boot 2017.01-rc2-g32ab180 (Apr 29 2020 - 00:30:51 +0800) Allwinner Technology CPU: Allwinner V3s (SUN8I 1681) Model: Lichee Pi Zero DRAM: 64 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment Setting up a 480x272 lcd console (overscan 0x0) dotclock: 10000kHz = 10000kHz: (1 * 3MHz * 20) / 6 In: serial@01c28000 Out: serial@01c28000 Err: serial@01c28000 Net: No ethernet found. starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot.scr reading /boot.scr 292 bytes read in 14 ms (19.5 KiB/s) ## Executing script at 41900000 reading zImage 3971936 bytes read in 211 ms (18 MiB/s) reading sun8i-v3s-licheepi-zero-dock.dtb 11533 bytes read in 25 ms (450.2 KiB/s) ## Flattened Device Tree blob at 41800000 Booting using the fdt blob at 0x41800000 Loading Device Tree to 42dfa000, end 42dffd0c ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.13.0-rc7-licheepi-zero (xiaoxiongmao@xiaoxiongmao-vm) (gcc version 6.3.0 20170321 (Debian 6.3.0-10)) #4 SMP Thu Aug 31 00:05:26 CST 2017 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] percpu: Embedded 16 pages/cpu @c3edf000 s33868 r8192 d23476 u65536 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16129 [ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 console=tty0 rootwait root=/dev/mmcblk0p2 earlyprintk rw [ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes) [ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes) [ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Memory: 54564K/65024K available (6144K kernel code, 230K rwdata, 1452K rodata, 1024K init, 263K bss, 10460K reserved, 0K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB) [ 0.000000] lowmem : 0xc0000000 - 0xc3f80000 ( 63 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB) [ 0.000000] .init : 0xc0900000 - 0xc0a00000 (1024 kB) [ 0.000000] .data : 0xc0a00000 - 0xc0a39b80 ( 231 kB) [ 0.000000] .bss : 0xc0a40874 - 0xc0a825ec ( 264 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU event tracing is enabled. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1 [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000019] Switching to timer-based delay loop, resolution 41ns [ 0.000189] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000414] Console: colour dummy device 80x30 [ 0.000838] console [tty0] enabled [ 0.000879] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.000916] pid_max: default: 32768 minimum: 301 [ 0.001054] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001086] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.001697] CPU: Testing write buffer coherency: ok [ 0.002091] /cpus/cpu@0 missing clock-frequency property [ 0.002137] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.002585] Setting up static identity map for 0x40100000 - 0x40100060 [ 0.002786] Hierarchical SRCU implementation. [ 0.003296] smp: Bringing up secondary CPUs ... [ 0.003328] smp: Brought up 1 node, 1 CPU [ 0.003347] SMP: Total of 1 processors activated (48.00 BogoMIPS). [ 0.003366] CPU: All CPU(s) started in SVC mode. [ 0.004135] devtmpfs: initialized [ 0.007167] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5 [ 0.007461] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.007520] futex hash table entries: 256 (order: 2, 16384 bytes) [ 0.007698] pinctrl core: initialized pinctrl subsystem [ 0.008576] random: get_random_u32 called from bucket_table_alloc+0xf4/0x244 with crng_init=0 [ 0.008745] NET: Registered protocol family 16 [ 0.009223] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.010451] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.010500] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.023701] SCSI subsystem initialized [ 0.024031] usbcore: registered new interface driver usbfs [ 0.024122] usbcore: registered new interface driver hub [ 0.024229] usbcore: registered new device driver usb [ 0.024517] pps_core: LinuxPPS API ver. 1 registered [ 0.024544] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.024591] PTP clock support registered [ 0.024823] Advanced Linux Sound Architecture Driver Initialized. [ 0.026656] clocksource: Switched to clocksource arch_sys_counter [ 0.037244] NET: Registered protocol family 2 [ 0.037860] TCP established hash table entries: 1024 (order: 0, 4096 bytes) [ 0.037920] TCP bind hash table entries: 1024 (order: 1, 8192 bytes) [ 0.037956] TCP: Hash tables configured (established 1024 bind 1024) [ 0.038092] UDP hash table entries: 256 (order: 1, 8192 bytes) [ 0.038155] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes) [ 0.038384] NET: Registered protocol family 1 [ 0.039002] RPC: Registered named UNIX socket transport module. [ 0.039044] RPC: Registered udp transport module. [ 0.039062] RPC: Registered tcp transport module. [ 0.039079] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.041148] workingset: timestamp_bits=30 max_order=14 bucket_order=0 [ 0.050073] NFS: Registering the id_resolver key type [ 0.050147] Key type id_resolver registered [ 0.050167] Key type id_legacy registered [ 0.051181] random: fast init done [ 0.053956] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 0.054012] io scheduler noop registered [ 0.054030] io scheduler deadline registered [ 0.054278] io scheduler cfq registered (default) [ 0.054304] io scheduler mq-deadline registered [ 0.054322] io scheduler kyber registered [ 0.058760] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 0.125276] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 0.128699] console [ttyS0] disabled [ 0.148994] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A [ 0.731000] console [ttyS0] enabled [ 0.738087] libphy: Fixed MDIO Bus: probed [ 0.742585] dwmac-sun8i 1c30000.ethernet: PTP uses main clock [ 0.748497] dwmac-sun8i 1c30000.ethernet: No regulator found [ 0.754255] dwmac-sun8i 1c30000.ethernet: Will use internal PHY [ 0.760459] dwmac-sun8i 1c30000.ethernet: Chain mode enabled [ 0.766144] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported [ 0.773420] dwmac-sun8i 1c30000.ethernet: Normal descriptors [ 0.779107] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported [ 0.786341] dwmac-sun8i 1c30000.ethernet: COE Type 2 [ 0.791325] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported [ 0.798306] libphy: stmmac: probed [ 0.803548] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.810234] ehci-platform: EHCI generic platform driver [ 0.815791] ehci-platform 1c1a000.usb: EHCI Host Controller [ 0.821503] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1 [ 0.829466] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000 [ 0.856682] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00 [ 0.863897] hub 1-0:1.0: USB hub found [ 0.867887] hub 1-0:1.0: 1 port detected [ 0.872388] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.878705] ohci-platform: OHCI generic platform driver [ 0.884263] ohci-platform 1c1a400.usb: Generic Platform OHCI controller [ 0.891010] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2 [ 0.899010] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400 [ 0.971722] hub 2-0:1.0: USB hub found [ 0.975566] hub 2-0:1.0: 1 port detected [ 0.982703] usbcore: registered new interface driver usb-storage [ 0.989432] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers [ 0.998978] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0 [ 1.007957] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0 [ 1.014776] sun6i-rtc 1c20400.rtc: RTC enabled [ 1.019441] i2c /dev entries driver [ 1.024774] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 1.086891] sunxi-mmc 1c0f000.mmc: base:0xc4101000 irq:23 [ 1.143693] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.151841] sunxi-mmc 1c10000.mmc: base:0xc4105000 irq:24 [ 1.158393] usbcore: registered new interface driver usbhid [ 1.163992] usbhid: USB HID core driver [ 1.168673] mmc0: new high speed SDHC card at address b368 [ 1.174837] mmcblk0: mmc0:b368 USD00 7.48 GiB [ 1.181510] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered [ 1.189604] sun4i-codec 1c22c00.codec: Failed to register our card [ 1.197145] mmcblk0: p1 p2 [ 1.204051] NET: Registered protocol family 17 [ 1.208776] Key type dns_resolver registered [ 1.213203] Registering SWP/SWPB emulation handler [ 1.222424] simple-framebuffer 43f80000.framebuffer: framebuffer at 0x43f80000, 0x7f800 bytes, mapped to 0xc4300000 [ 1.233090] simple-framebuffer 43f80000.framebuffer: format=x8r8g8b8, mode=480x272x32, linelength=1920 [ 1.245363] Console: switching to colour frame buffer device 60x34 [ 1.253936] simple-framebuffer 43f80000.framebuffer: fb0: simplefb registered! [ 1.262599] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 1.279660] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 1.289284] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3 [ 1.302174] hub 3-0:1.0: USB hub found [ 1.308137] hub 3-0:1.0: 1 port detected [ 1.315250] using random self ethernet address [ 1.321758] using random host ethernet address [ 1.330129] usb0: HOST MAC 12:07:8b:43:f5:cd [ 1.336304] usb0: MAC f6:e0:a9:20:10:31 [ 1.342086] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008 [ 1.353143] g_cdc gadget: g_cdc ready [ 1.361139] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok [ 1.373126] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:05 UTC (5) [ 1.384973] vcc5v0: disabling [ 1.389770] ALSA device list: [ 1.394459] #0: V3s Audio Codec [ 1.401210] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities [ 1.413892] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities [ 1.897756] EXT4-fs (mmcblk0p2): recovery complete [ 1.910185] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.921855] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.940988] devtmpfs: mounted [ 1.947125] Freeing unused kernel memory: 1024K [ 2.129074] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 2.148128] systemd[1]: Detected architecture 'arm'. [ 2.177400] systemd[1]: Failed to insert module 'autofs4' [ 2.184830] systemd[1]: Failed to insert module 'ipv6' [ 2.193557] systemd[1]: Set hostname to <LicheePi>. [ 2.618526] systemd[1]: Cannot add dependency job for unit dbus.socket, ignoring: Unit dbus.socket failed to load: No such file or directory. [ 2.636794] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. [ 2.659535] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 2.671576] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 2.683020] systemd[1]: Expecting device dev-ttyS0.device... [ 2.906341] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 3.386479] systemd-udevd[92]: starting version 215 [ 4.407494] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 4.895137] systemd-journald[80]: Received request to flush runtime journal from PID 1 [ 7.221770] Generic PHY stmmac-0:01: attached PHY driver [Generic PHY] (mii_bus:phy_addr=stmmac-0:01, irq=-1) [ 7.237190] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available [ 7.248370] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW [ 32.033314] random: crng init done Debian GNU/Linux 8 LicheePi ttyS0 LicheePi login: root Password: Last login: Thu Jan 1 08:20:03 HKT 1970 on ttyS0 Linux LicheePi 4.13.0-rc7-licheepi-zero #4 SMP Thu Aug 31 00:05:26 CST 2017 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. root@LicheePi:~# free -m total used free shared buffers cached Mem: 54 44 10 5 4 19 -/+ buffers/cache: 20 34 Swap: 0 0 0 root@LicheePi:~#
我看网上说和分区有关系,我的SD卡是偏移2M,开了一个20M分区,一个8G分区,20M分区放的内核
看看设备树是不是正确
你的荔枝派怎么装ubuntu,想学习下。
