楼主 #1 2020-05-09 18:31:06
缥缈九哥
已发帖子: 93
基于新唐NUC123的3.0的BSP包的FM25CL64BG驱动开发--缥缈九哥
源码如下:
 * @file     fm25640c.c
 * @version  V3.00
 * $Revision: 5 $
 * $Date: 16/08/04 11:18a $
 * @brief    Demonstrate how to perform timer counting in periodic mode.
 * @note
 * Copyright (C) 2014~2016 PM9GZY Technology Corp. yuanxihua@21cn.com All rights reserved.
/* Includes ------------------------------------------------------------------*/
#include <stdio.h>
#include "NUC123.h"
_________________________________________________
| NUC123ZD4AN0     FM25CL64BG |
| PC8  SS10  ---->  CS   |
| PC9  SPICLK1  ---->  SCK   |
| PC10 MISO10  <----  SO   |
| PC11 MOSI10  ---->  SI   |
|_______________________________________________|
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
//#define  FM25CL64BG_CS   PC8
#define  FM25CL64BG_SIZE  8*1024
//FM25CL64BG命令
#define   FM25CL64BG_WREN  0x06
#define   FM25CL64BG_WRDI  0x04
#define   FM25CL64BG_RDSR  0x05ff
#define   FM25CL64BG_WRSR  0x0100
#define   FM25CL64BG_READ  0x030000FF
#define   FM25CL64BG_WRITE 0x02000000
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
void FM25CL64BG_Init(void);
void FM25CL64BG_Read (uint32_t addr, uint8_t *buf, uint32_t len);
void FM25CL64BG_Write(uint32_t addr, uint8_t *buf, uint32_t len);
void FM25CL64BG_Write_Byte(uint32_t addr,uint8_t wrdata);
void FM25CL64BG_Write_Status_Register(uint8_t wrdata);
uint8_t FM25CL64BG_Read_Byte(uint32_t addr);
uint8_t FM25CL64BG_Read_Status_Register(void);
void SPI1_Send_Data(uint32_t wrdata,uint8_t bits);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
void FM25CL64BG_Test(void)
 uint32_t i;
 /* Configure the FM25CL64BG */
 FM25CL64BG_Init();
 while(0)
//  SPI1_Send_Data(0x55, 8);
//  SPI_SET_SS0(SPI1); SPI1_Send_Data(0x55, 8);SPI_CLR_SS0(SPI1); //写0x55测试SPI接口
//  FM25CL64BG_Write_Byte(0xCC, 0x55);
//  FM25CL64BG_Read_Byte (0xCC);
//  FM25CL64BG_Read_Status_Register();
 FM25CL64BG_Write_Status_Register(0x00);
 printf("FM25CL64BG_Read_Status_Register() = 0x%02x \n\r",FM25CL64BG_Read_Status_Register());
 FM25CL64BG_Write_Byte(0xAA, 0x55);
 FM25CL64BG_Write_Byte(0x55, 0xAA);
 printf("FM25CL64BG_Read_Byte(0xAA) = 0x%02x \n\r",FM25CL64BG_Read_Byte(0xAA));
 printf("FM25CL64BG_Read_Byte(0x55) = 0x%02x \n\r",FM25CL64BG_Read_Byte(0x55));
 while(1)
  for(i=0;i<FM25CL64BG_SIZE;i++)
  {FM25CL64BG_Write_Byte(i, i&0xff);}
  CLK_SysTickDelay(300000);
   //for display
   if((i%16)== 0){printf("\n\r%08xh:",i);}
   printf(" %02x",FM25CL64BG_Read_Byte(i));
   if((i%16)==15){printf(" ;");}
   //display  end
// SPI1_Send_Data(FM25640C_WREN,8);
// SPI1_Send_Data(FM25640C_WRDI,8);
void FM25CL64BG_Read(uint32_t addr, uint8_t *buf, uint32_t len)
 uint32_t i;
 for(i=0;i<len;i++)
 {buf[i] = FM25CL64BG_Read_Byte(addr+i);}
 uint32_t i;
 for(i=0;i<len;i++)
 {FM25CL64BG_Write_Byte(addr+i,buf[i]);}
 uint32_t rddata,tmpdata=FM25CL64BG_READ;
 tmpdata |= (addr << 8);
 SPI1_Send_Data(tmpdata,32);
 rddata = SPI_READ_RX0(SPI1);
 return (uint8_t)rddata;
void FM25CL64BG_Write_Byte(uint32_t addr, uint8_t wrdata)
 uint32_t tmpdata=FM25CL64BG_WRITE;
 SPI1_Send_Data(FM25CL64BG_WREN,8);    //中:使能写操作//Write Enable
 tmpdata |= (addr << 8) + wrdata;
 uint32_t rddata;
 SPI1_Send_Data(FM25CL64BG_RDSR,16);
 uint16_t dat=FM25CL64BG_WRSR | wrdata;
 SPI1_Send_Data(dat,16);
void SPI1_Send_Data(uint32_t wrdata, uint8_t bits)
 SPI1->CNTRL = (SPI1->CNTRL&0xFFFFFF07) | ((bits&0x1f) << SPI_CNTRL_TX_BIT_LEN_Pos);
 /* Write to TX register */
 SPI_WRITE_TX0(SPI1, wrdata);
 /* Trigger SPI1 data transfer */
 SPI_TRIGGER(SPI1);
 /* Check SPI1 busy status */
 while(SPI_IS_BUSY(SPI1));
void SPI1_Init(void)
 /* Select HCLK as the clock source of SPI1 */
    CLK_SetModuleClock(SPI1_MODULE, CLK_CLKSEL1_SPI1_S_HCLK, MODULE_NoMsk);
    /* Enable SPI1 peripheral clock */
    CLK_EnableModuleClock(SPI1_MODULE);
    /* Setup SPI1 multi-function pins */
 SYS->GPC_MFP &= ~(SYS_GPC_MFP_PC8_Msk | SYS_GPC_MFP_PC9_Msk | SYS_GPC_MFP_PC10_Msk | SYS_GPC_MFP_PC11_Msk);
 SYS->GPC_MFP |= SYS_GPC_MFP_PC8_SPI1_SS0 | SYS_GPC_MFP_PC9_SPI1_CLK | SYS_GPC_MFP_PC10_SPI1_MISO0 | SYS_GPC_MFP_PC11_SPI1_MOSI0;
 SYS->ALT_MFP1 &= ~(SYS_ALT_MFP1_PC8_Msk | SYS_ALT_MFP1_PC9_Msk | SYS_ALT_MFP1_PC10_Msk | SYS_ALT_MFP1_PC11_Msk);
 SYS->ALT_MFP1 |= SYS_ALT_MFP1_PC8_SPI1_SS0 | SYS_ALT_MFP1_PC9_SPI1_CLK | SYS_ALT_MFP1_PC10_SPI1_MISO0 | SYS_ALT_MFP1_PC11_SPI1_MOSI0;
    /* Init SPI        */
    /* Configure as a master, clock idle low, 32-bit transaction, drive output on falling clock edge and latch input on rising edge. */
    /* Set IP clock divider. SPI clock rate = 36MHz */
    SPI_Open(SPI1, SPI_MASTER, SPI_MODE_0, 32, 36000000);
    /* Enable the automatic hardware slave select function. Select the SS pin and configure as low-active. */
    SPI_EnableAutoSS(SPI1, SPI_SS0, SPI_SS_ACTIVE_LOW);
 SPI1_Init();
//源码完毕
