楼主 #1 2020-05-09 20:53:36
缥缈九哥
已发帖子: 88
测试基于linux-2.6.27的9G9260开发板MTD驱动 --缥缈九哥
1,修改内核源码:
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260# vi arch/arm/mach-at91/board-sam9260ek.c
在第174行修改成如下:
  * NAND flash
 static struct mtd_partition __initdata ek_nand_partition[] = {
   .name   = "Bootstrap",
   .offset = 0,
   .size   = 0x20000,
   .name   = "U-boot",
   .offset = 0x20000,
   .size   = 0xe0000,
   .name   = "uImage",
   .offset = 0x100000,
   .size   = 0x200000,
   .name   = "ramdisk",
   .offset = 0x300000,
   .size   = 0x400000,
   .name   = "rootfs",
   .offset = 0x700000,
   .size   = 0x900000,
   .name   = "data",
   .offset = 16 * 1024 * 1024,
   .size   = MTDPART_SIZ_FULL,
2,修改内核配置:
 root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260# make menuconfig
    Boot options  --->
  (mem=64M console=ttyS0,115200 root=/dev/mtdblock4 rootfstype=jffs2 init=/linuxrc)
 Device Drivers  --->
 <*> Memory Technology Device (MTD) support  --->
 <*>   MTD concatenating support
 [*]   MTD partitioning support
 [*]     Command line partition table parsing
 <*>   Direct char device access to MTD devices
 -*-   Common interface to block layer for MTD 'translation layers'
 <*>   Caching block device access to MTD devices
 <*>   NAND Device Support  --->
 <*>   Support for NAND Flash / SmartMedia on AT91 and AVR32
         ECC management for NAND Flash / SmartMedia on AT91 / AVR32 (Software ECC)  --->
 File systems  --->
 <*> Second extended fs support
 Miscellaneous filesystems  --->
 <*> Journalling Flash File System v2 (JFFS2) support
 (0)   JFFS2 debugging verbosity (0 = quiet, 2 = noisy)
 [*]   JFFS2 write-buffering support
 [*]   JFFS2 summary support (EXPERIMENTAL)
默认就是如此,不作修改。
3,编译内核:
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260# make uImage
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260# cp arch/arm/boot/uImage uImage-2.6.27-9g9260.bin
root@yuanxh-desktop:/home/yuanxh/sam9260/linux-2.6.27-9g9260# sz  uImage-2.6.27-9g9260.bin
4,生成JFFS2文件系统:
root@yuanxh-desktop:/nfsboot# ./mkfs.jffs2 -d rootfs -o jffs2-2.6.27-9g9260.bin -n --pagesize=0x800 --eraseblock=0x20000 --pad=0x900000
root@yuanxh-desktop:/nfsboot# sz jffs2-2.6.27-9g9260.bin
5,测试MTD驱动
# cat /proc/mtd
# flash_eraseall /dev/mtd5
# mount -t jffs2 /dev/mtdblock5 /mnt
# cd /app
# touch yuanxihua
# vi yuanxhua
掉电后重新启动,看到文件及内容还存在。
