楼主 #1 2020-05-13 10:06:45
BugActiveDaughter
已发帖子: 118
MD5
大小写切换只需修改char    *MD5_Encode(const char *data, int len, char *buf)
 * MD5C.C - RSA Data Security, Inc., MD5 message-digest algorithm
#include <stdio.h>
#include <string.h>
void	Data(const unsigned char *data, int len, unsigned char digest[16]);
char	*MD5_Encode(const char *data, int len, char *buf);
static	void	Transform_64(const unsigned char x[64]);
static	void	Transform_16(const unsigned long x[16]);
static	void	Encode(unsigned char *output, const unsigned long *input, int len);
static	void	Decode(unsigned long *output, const unsigned char *input, int len);
static	void	Init(void);
static	void	Update(const unsigned char *input, int inputLen);
static	void	Final(unsigned char digest[16]);
unsigned long	state[4];	/* state (ABCD) */
unsigned long	count[2];	/* number of bits, modulo 2^64 (lsb first) */
unsigned char	buffer[64];	/* input buffer */
/** F, G, H and I are basic MD5 functions. */
static	unsigned long	F(unsigned long x, unsigned long y, unsigned long z)
    return	(((x) & (y)) | ((~x) & (z)));
static	unsigned long	G(unsigned long x, unsigned long y, unsigned long z)
    return	(((x) & (z)) | ((y) & (~z)));
static	unsigned long	H(unsigned long x, unsigned long y, unsigned long z)
    return	((x) ^ (y) ^ (z));
static	unsigned long	I(unsigned long x, unsigned long y, unsigned long z)
    return	((y) ^ ((x) | (~z)));
/** ROTATE_LEFT rotates x left n bits. */
static	unsigned long	ROTATE_LEFT(unsigned long x, int n)
    return	(((x) << (n)) | ((x) >> (32-(n))));
/** FF, GG, HH, and II transformations for rounds 1, 2, 3, and 4.
 *  Rotation is separate from addition to prevent recomputation.
static	void	FF(unsigned long &a, unsigned long b, unsigned long c, unsigned long d, unsigned long x, int s, unsigned long ac) {
		(a) += F ((b), (c), (d)) + (x) + (ac);
		(a) = ROTATE_LEFT ((a), (s));
		(a) += (b);
static	void	GG(unsigned long &a, unsigned long b, unsigned long c, unsigned long d, unsigned long x, int s, unsigned long ac) {
		(a) += G ((b), (c), (d)) + (x) + (ac);
		(a) += (b);
static	void	HH(unsigned long &a, unsigned long b, unsigned long c, unsigned long d, unsigned long x, int s, unsigned long ac) {
		(a) += H ((b), (c), (d)) + (x) + (ac);
		(a) += (b);
static	void	II(unsigned long &a, unsigned long b, unsigned long c, unsigned long d, unsigned long x, int s, unsigned long ac) {
		(a) += I ((b), (c), (d)) + (x) + (ac);
		(a) += (b);
#define FF(a, b, c, d, x, s, ac) \
		(a) += F ((b), (c), (d)) + (x) + (ac);\
		(a) = ROTATE_LEFT ((a), (s));\
		(a) += (b);
#define GG(a, b, c, d, x, s, ac) \
		(a) += G ((b), (c), (d)) + (x) + (ac);\
		(a) += (b);
#define HH(a, b, c, d, x, s, ac) \
		(a) += H ((b), (c), (d)) + (x) + (ac);\
		(a) += (b);
#define II(a, b, c, d, x, s, ac) \
		(a) += I ((b), (c), (d)) + (x) + (ac);\
		(a) += (b);
 * Constants for MD5Transform routine.
const	int	S[4][4] =
    { 7, 12, 17, 22,},
    { 5,  9, 14, 20,},
    { 4, 11, 16, 23,},
    { 6, 10, 15, 21,},
const	unsigned long	ac[64] =
    0xd76aa478l, 0xe8c7b756l, 0x242070dbl, 0xc1bdceeel,
    0xf57c0fafl, 0x4787c62al, 0xa8304613l, 0xfd469501l,
    0x698098d8l, 0x8b44f7afl, 0xffff5bb1l, 0x895cd7bel,
    0x6b901122l, 0xfd987193l, 0xa679438el, 0x49b40821l,
    0xf61e2562l, 0xc040b340l, 0x265e5a51l, 0xe9b6c7aal,
    0xd62f105dl, 0x02441453l, 0xd8a1e681l, 0xe7d3fbc8l,
    0x21e1cde6l, 0xc33707d6l, 0xf4d50d87l, 0x455a14edl,
    0xa9e3e905l, 0xfcefa3f8l, 0x676f02d9l, 0x8d2a4c8al,
    0xfffa3942l, 0x8771f681l, 0x6d9d6122l, 0xfde5380cl,
    0xa4beea44l, 0x4bdecfa9l, 0xf6bb4b60l, 0xbebfbc70l,
    0x289b7ec6l, 0xeaa127fal, 0xd4ef3085l, 0x04881d05l,
    0xd9d4d039l, 0xe6db99e5l, 0x1fa27cf8l, 0xc4ac5665l,
    0xf4292244l, 0x432aff97l, 0xab9423a7l, 0xfc93a039l,
    0x655b59c3l, 0x8f0ccc92l, 0xffeff47dl, 0x85845dd1l,
    0x6fa87e4fl, 0xfe2ce6e0l, 0xa3014314l, 0x4e0811a1l,
    0xf7537e82l, 0xbd3af235l, 0x2ad7d2bbl, 0xeb86d391l,
const	unsigned char	PADDING[64] =
    0x80, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
    0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
 * Encodes input (unsigned long) into output (unsigned char). Assumes len is a
 * multiple of 4.
void
    int    i, j;
    //assert((len % 4) == 0);
    for (i = 0, j = 0; j < len; i++, j += 4)
        output[j] = (unsigned char) (input[i] & 0xff);
        output[j + 1] = (unsigned char) ((input[i] >> 8) & 0xff);
        output[j + 2] = (unsigned char) ((input[i] >> 16) & 0xff);
        output[j + 3] = (unsigned char) ((input[i] >> 24) & 0xff);
 * Decodes input (unsigned char) into output (unsigned long). Assumes len is a
 * multiple of 4.
void
    int    i, j;
        output[i] = ((unsigned long) input[j]) | (((unsigned long) input[j + 1]) << 8) |
                    (((unsigned long) input[j + 2]) << 16) | (((unsigned long) input[j + 3]) << 24);
 * MD5 basic transformation. Transforms state based on block.
void
Transform_64(const unsigned char block[64])
    unsigned long	x[16];
    Decode(x, block, 64);
    Transform_16(x);
    /** Zeroize sensitive information. */
    //memset((unsigned char *) x, 0, sizeof(x));
void
    unsigned long	a = state[0], b = state[1],
                    c = state[2], d = state[3];
    /* Round 1 */
    FF(a, b, c, d, x[ 0], S[0][0], 0xd76aa478l);	/* 1 */
    FF(d, a, b, c, x[ 1], S[0][1], 0xe8c7b756l);	/* 2 */
    FF(c, d, a, b, x[ 2], S[0][2], 0x242070dbl);	/* 3 */
    FF(b, c, d, a, x[ 3], S[0][3], 0xc1bdceeel);	/* 4 */
    FF(a, b, c, d, x[ 4], S[0][0], 0xf57c0fafl);	/* 5 */
    FF(d, a, b, c, x[ 5], S[0][1], 0x4787c62al);	/* 6 */
    FF(c, d, a, b, x[ 6], S[0][2], 0xa8304613l);	/* 7 */
    FF(b, c, d, a, x[ 7], S[0][3], 0xfd469501l);	/* 8 */
    FF(a, b, c, d, x[ 8], S[0][0], 0x698098d8l);	/* 9 */
    FF(d, a, b, c, x[ 9], S[0][1], 0x8b44f7afl);	/* 10 */
    FF(c, d, a, b, x[10], S[0][2], 0xffff5bb1l);	/* 11 */
    FF(b, c, d, a, x[11], S[0][3], 0x895cd7bel);	/* 12 */
    FF(a, b, c, d, x[12], S[0][0], 0x6b901122l);	/* 13 */
    FF(d, a, b, c, x[13], S[0][1], 0xfd987193l);	/* 14 */
    FF(c, d, a, b, x[14], S[0][2], 0xa679438el);	/* 15 */
    FF(b, c, d, a, x[15], S[0][3], 0x49b40821l);	/* 16 */
    /* Round 2 */
    GG(a, b, c, d, x[ 1], S[1][0], 0xf61e2562l);	/* 17 */
    GG(d, a, b, c, x[ 6], S[1][1], 0xc040b340l);	/* 18 */
    GG(c, d, a, b, x[11], S[1][2], 0x265e5a51l);	/* 19 */
    GG(b, c, d, a, x[ 0], S[1][3], 0xe9b6c7aal);	/* 20 */
    GG(a, b, c, d, x[ 5], S[1][0], 0xd62f105dl);	/* 21 */
    GG(d, a, b, c, x[10], S[1][1], 0x02441453l);	/* 22 */
    GG(c, d, a, b, x[15], S[1][2], 0xd8a1e681l);	/* 23 */
    GG(b, c, d, a, x[ 4], S[1][3], 0xe7d3fbc8l);	/* 24 */
    GG(a, b, c, d, x[ 9], S[1][0], 0x21e1cde6l);	/* 25 */
    GG(d, a, b, c, x[14], S[1][1], 0xc33707d6l);	/* 26 */
    GG(c, d, a, b, x[ 3], S[1][2], 0xf4d50d87l);	/* 27 */
    GG(b, c, d, a, x[ 8], S[1][3], 0x455a14edl);	/* 28 */
    GG(a, b, c, d, x[13], S[1][0], 0xa9e3e905l);	/* 29 */
    GG(d, a, b, c, x[ 2], S[1][1], 0xfcefa3f8l);	/* 30 */
    GG(c, d, a, b, x[ 7], S[1][2], 0x676f02d9l);	/* 31 */
    GG(b, c, d, a, x[12], S[1][3], 0x8d2a4c8al);	/* 32 */
    /* Round 3 */
    HH(a, b, c, d, x[ 5], S[2][0], 0xfffa3942l);	/* 33 */
    HH(d, a, b, c, x[ 8], S[2][1], 0x8771f681l);	/* 34 */
    HH(c, d, a, b, x[11], S[2][2], 0x6d9d6122l);	/* 35 */
    HH(b, c, d, a, x[14], S[2][3], 0xfde5380cl);	/* 36 */
    HH(a, b, c, d, x[ 1], S[2][0], 0xa4beea44l);	/* 37 */
    HH(d, a, b, c, x[ 4], S[2][1], 0x4bdecfa9l);	/* 38 */
    HH(c, d, a, b, x[ 7], S[2][2], 0xf6bb4b60l);	/* 39 */
    HH(b, c, d, a, x[10], S[2][3], 0xbebfbc70l);	/* 40 */
    HH(a, b, c, d, x[13], S[2][0], 0x289b7ec6l);	/* 41 */
    HH(d, a, b, c, x[ 0], S[2][1], 0xeaa127fal);	/* 42 */
    HH(c, d, a, b, x[ 3], S[2][2], 0xd4ef3085l);	/* 43 */
    HH(b, c, d, a, x[ 6], S[2][3], 0x04881d05l);	/* 44 */
    HH(a, b, c, d, x[ 9], S[2][0], 0xd9d4d039l);	/* 45 */
    HH(d, a, b, c, x[12], S[2][1], 0xe6db99e5l);	/* 46 */
    HH(c, d, a, b, x[15], S[2][2], 0x1fa27cf8l);	/* 47 */
    HH(b, c, d, a, x[ 2], S[2][3], 0xc4ac5665l);	/* 48 */
    /* Round 4 */
    II(a, b, c, d, x[ 0], S[3][0], 0xf4292244l);	/* 49 */
    II(d, a, b, c, x[ 7], S[3][1], 0x432aff97l);	/* 50 */
    II(c, d, a, b, x[14], S[3][2], 0xab9423a7l);	/* 51 */
    II(b, c, d, a, x[ 5], S[3][3], 0xfc93a039l);	/* 52 */
    II(a, b, c, d, x[12], S[3][0], 0x655b59c3l);	/* 53 */
    II(d, a, b, c, x[ 3], S[3][1], 0x8f0ccc92l);	/* 54 */
    II(c, d, a, b, x[10], S[3][2], 0xffeff47dl);	/* 55 */
    II(b, c, d, a, x[ 1], S[3][3], 0x85845dd1l);	/* 56 */
    II(a, b, c, d, x[ 8], S[3][0], 0x6fa87e4fl);	/* 57 */
    II(d, a, b, c, x[15], S[3][1], 0xfe2ce6e0l);	/* 58 */
    II(c, d, a, b, x[ 6], S[3][2], 0xa3014314l);	/* 59 */
    II(b, c, d, a, x[13], S[3][3], 0x4e0811a1l);	/* 60 */
    II(a, b, c, d, x[ 4], S[3][0], 0xf7537e82l);	/* 61 */
    II(d, a, b, c, x[11], S[3][1], 0xbd3af235l);	/* 62 */
    II(c, d, a, b, x[ 2], S[3][2], 0x2ad7d2bbl);	/* 63 */
    II(b, c, d, a, x[ 9], S[3][3], 0xeb86d391l);	/* 64 */
    state[0] += a;
    state[1] += b;
    state[2] += c;
    state[3] += d;
 * Initializes MD5 context for the start of message digest computation.
void
Init()
    count[0] = count[1] = 0;
    /* Load magic initialization constants.  */
    state[0] = 0x67452301l;
    state[1] = 0xefcdab89l;
    state[2] = 0x98badcfel;
    state[3] = 0x10325476l;
 * @input: pointer to data to be fed into MD5 algorithm.
 * @inputLen: size of @input data in bytes.
 * MD5 block update operation. Continues an MD5 message-digest operation,
 * processing another message block, and updating the context.
void
    int    i, index, partLen;
    /* Compute number of bytes mod 64 */
    index = (unsigned int) ((count[0] >> 3) & 0x3F);
    /* Update number of bits */
    if ((count[0] += ((unsigned long) inputLen << 3)) < ((unsigned long) inputLen << 3))
        count[1]++;
    count[1] += ((unsigned long) inputLen >> 29);
    partLen = 64 - index;
    /* Transform as many times as possible.  */
    if (inputLen >= partLen)
        memcpy(&buffer[index], input, partLen);
        Transform_64(buffer);
        for (i = partLen; i + 63 < inputLen; i += 64)
            Transform_64(&input[i]);
        index = 0;
        i = 0;
    /* Buffer remaining input */
    if ((inputLen - i) != 0)
        memcpy(&buffer[index], &input[i], inputLen - i);
 * @digest: 16-byte buffer to write MD5 checksum.
 * Ends an MD5 message-digest operation, writing the the message
 * digest and zeroing the context.  The context must be initialized
 * with Init() before being used for other MD5 checksum calculations.
void
    unsigned char   bits[8];
    int	index, padLen;
    /* Save number of bits */
    Encode(bits, count, 8);
    /** Pad out to 56 mod 64. */
    index =(int) ((count[0] >> 3) & 0x3f);
    padLen = (index < 56) ? (56 - index) : (120 - index);
    Update(PADDING, padLen);
    /* Append length (before padding) */
    Update(bits, 8);
    /* Store state in digest */
    Encode(digest, state, 16);
    //memset((unsigned char *)this, 0, sizeof(*this));
 * @data: pointer to data to be fed into MD5 algorithm.
 * @len: size of @data in bytes.
 * calculate the MD5 checksum.
void
    Init();
    Update(data, len);
    Final(digest);
    unsigned char	digest[16];
    Data((const unsigned char *)data, len, digest);
    char	*p = buf;
    for (int i = 0; i < 16; i++)
    {//注意大小写输出改这边  @yeqingugi  20200513
    //大写如下:
        *p++ = "0123456789ABCDEF"[digest[i] >> 4];
        *p++ = "0123456789ABCDEF"[digest[i] & 0x0f];
//小写如下:
       //  *p++ = "0123456789abcdef"[digest[i] >> 4];
       // *p++ = "0123456789abcdef"[digest[i] & 0x0f];
    *p = 0;
    return	buf;
#2 2020-05-13 11:13:55
zhjerry
已发帖子: 44
Re: MD5
这个写法有意思: *p++ = "0123456789ABCDEF"[];
#3 2020-05-27 17:15:33
wxw_1983
Re: MD5
看下,我们也会用这个
