楼主 #1 2020-05-20 23:37:45
luciferseva
已发帖子: 58
V3S 根文件系统之buildroot make出现问题,有没有大神帮助解答一下,安装官网流程,为啥下载下来编译会这样
编译log:
./../misc/create_inode.c:176:16: warning: implicit declaration of function ‘lgetxattr’; did you mean ‘getdate_r’? [-Wimplicit-function-declaration]
   value_size = lgetxattr(filename, name, NULL, 0);
                getdate_r
./../misc/create_inode.c: At top level:
./../misc/create_inode.c:399:18: error: conflicting types for ‘copy_file_range’
 static errcode_t copy_file_range(ext2_filsys fs, int fd, ext2_file_t e2_file,
In file included from ./../misc/create_inode.c:19:0:
/usr/include/unistd.h:1110:9: note: previous declaration of ‘copy_file_range’ was here
 ssize_t copy_file_range (int __infd, __off64_t *__pinoff,
Makefile:422: recipe for target 'create_inode.o' failed
make[3]: *** [create_inode.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[3]: Leaving directory '/home/lucifer/lizhe/buildroot-2017.08/output/build/host-e2fsprogs-1.43.4/debugfs'
Makefile:404: recipe for target 'all-progs-recursive' failed
make[2]: *** [all-progs-recursive] Error 1
make[2]: Leaving directory '/home/lucifer/lizhe/buildroot-2017.08/output/build/host-e2fsprogs-1.43.4'
Makefile:339: recipe for target 'all' failed
make[1]: *** [all] Error 2
make[1]: Leaving directory '/home/lucifer/lizhe/buildroot-2017.08/output/build/host-e2fsprogs-1.43.4'
package/pkg-generic.mk:227: recipe for target '/home/lucifer/lizhe/buildroot-2017.08/output/build/host-e2fsprogs-1.43.4/.stamp_built' failed
make: *** [/home/lucifer/lizhe/buildroot-2017.08/output/build/host-e2fsprogs-1.43.4/.stamp_built] Error 2
#2 2020-05-21 00:51:44
windcys
Re: V3S 根文件系统之buildroot make出现问题,有没有大神帮助解答一下,安装官网流程,为啥下载下来编译会这样
我的也是编译不成功,正在查找原因。
楼主 #3 2020-05-21 07:28:58
luciferseva
已发帖子: 58
windcys 说:
我的也是编译不成功,正在查找原因。
晕哥帮忙看看哇?
#4 2020-05-21 08:14:38
已发帖子: 3,391
https://www.cnblogs.com/dakewei/p/10573446.html
1. 详细报错信息
misc/create_inode.c:399:18: error: conflicting types for 'copy_file_range'
  /usr/include/unistd.h:1110:9: note: previous declaration of 'copy_file_range' was here
2. 解决办法
将copy_file_range改成copy_file_chunk
   cd build_dir/host/e2fsprogs-1.43.7
   vi misc/create_inode.c (将所有的copy_file_range改成copy_file_chunk)
#5 2020-05-21 09:04:11
bubailong
已发帖子: 104
你buildroot选择的不是EXT4吧
最近编辑记录 bubailong (2020-05-21 09:04:51)
楼主 #6 2020-05-21 09:20:36
luciferseva
已发帖子: 58
bubailong 说:
在哪里选择,在哪里看?
#7 2020-05-21 09:33:31
bubailong
已发帖子: 104
luciferseva 说:
在哪里选择,在哪里看?
你这个选择了吗?
楼主 #8 2020-05-21 09:38:53
luciferseva
已发帖子: 58
bubailong 说:
选了
楼主 #9 2020-05-21 15:13:26
luciferseva
已发帖子: 58
还有个疑问,网上的镜像,有区分flash的大小嘛?应该都可以把?因为在配置buildroot的时候,没有选择flash的大小啊?
