楼主 #1 2018-06-08 16:15:53
xinxiaoci
已发帖子: 71
u-boot 源码分析 第一阶段源码分析
《单片机小白转嵌入式Linux学习记录,基于S3C2440----目录》
分析 cpu/arm920t/start.s  文件
第一阶段都是硬件相关的初始化以及将u-boot代码拷贝到SDRAM:
1. 设置为管理模式
    mrs    r0,cpsr
    bic    r0,r0,#0x1f
    orr    r0,r0,#0xd3
    msr    cpsr,r0
2. 关闭看门狗
    ldr     r0, =pWTCON
    mov     r1, #0x0
    str     r1, [r0]
3. 屏蔽所有中断
    mov    r1, #0xffffffff
    ldr    r0, =INTMSK
    str    r1, [r0]
3. SDRAM初始化
    blne    cpu_init_crit
4. 是设置栈
    sub    sp, r0, #12
5. 时钟
    bl clock_init
6. 重定位
    bl  CopyCode2Ram
7. 清除bss段
    clear_bss:
    ldr    r0, _bss_start        /* find start of bss segment        */
    ldr    r1, _bss_end        /* stop here                        */
    mov     r2, #0x00000000        /* clear                            */
clbss_l:str    r2, [r0]        /* clear loop...                    */
    add    r0, r0, #4
    cmp    r0, r1
    ble    clbss_l
8. 调用 start_armboot 函数
    ldr    pc, _start_armboot
cpu/arm920t/start.s 简易注释
 *  armboot - Startup Code for ARM920 CPU-core
 *  Copyright (c) 2001	Marius Gr鰃er <mag@sysgo.de>
 *  Copyright (c) 2002	Alex Z黳ke <azu@sysgo.de>
 *  Copyright (c) 2002	Gary Jennejohn <gj@denx.de>
 * See file CREDITS for list of people who contributed to this
 * project.
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License as
 * published by the Free Software Foundation; either version 2 of
 * the License, or (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * You should have received a copy of the GNU General Public License
 * along with this program; if not, write to the Free Software
 * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
 * MA 02111-1307 USA
#include <config.h>
#include <version.h>
 * Jump vector table as in table 3.1 in [1]
.globl _start
_start:	b       reset
	ldr	pc, _undefined_instruction
	ldr	pc, _software_interrupt
	ldr	pc, _prefetch_abort
	ldr	pc, _data_abort
	ldr	pc, _not_used
	ldr	pc, _irq
	ldr	pc, _fiq
_undefined_instruction:	.word undefined_instruction
_software_interrupt:	.word software_interrupt
_prefetch_abort:	.word prefetch_abort
_data_abort:		.word data_abort
_not_used:		.word not_used
_irq:			.word irq
_fiq:			.word fiq
	.balignl 16,0xdeadbeef
 * Startup Code (reset vector)
 * do important init only if we don't start from memory!
 * relocate armboot to ram
 * setup stack
 * jump to second stage
_TEXT_BASE:
	.word	TEXT_BASE	/* EXT_BASE是代码执行的起始地址 由-Ttext $(TEXT_BASE) 传递进来 */
.globl _armboot_start
_armboot_start:
	.word _start
 * These are defined in the board-specific linker script.
.globl _bss_start
_bss_start:
	.word __bss_start
.globl _bss_end
_bss_end:
	.word _end
.globl FREE_RAM_END
FREE_RAM_END:
	.word	0x0badc0de
.globl FREE_RAM_SIZE
FREE_RAM_SIZE:
	.word	0x0badc0de
.globl PreLoadedONRAM
PreLoadedONRAM:
	.word	0
#ifdef CONFIG_USE_IRQ
/* IRQ stack memory (calculated at run-time) */
.globl IRQ_STACK_START
IRQ_STACK_START:
	.word	0x0badc0de
.globl FIQ_STACK_START
FIQ_STACK_START:
	.word 0x0badc0de
 * the actual reset code
reset:
	 * set the cpu to SVC32 mode
	 * 设置CPU为管理模式
	mrs	r0,cpsr
	bic	r0,r0,#0x1f
	orr	r0,r0,#0xd3
	msr	cpsr,r0
/* turn off the watchdog */
/* 关闭看门狗 */
#if defined(CONFIG_S3C2400)
# define pWTCON		0x15300000
# define INTMSK		0x14400008	/* Interupt-Controller base addresses */
# define CLKDIVN	0x14800014	/* clock divisor register */
#elif defined(CONFIG_S3C2410)
# define pWTCON		0x53000000
# define INTMOD     0X4A000004
# define INTMSK		0x4A000008	/* Interupt-Controller base addresses */
# define INTSUBMSK	0x4A00001C
# define CLKDIVN	0x4C000014	/* clock divisor register */
#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410)
	ldr     r0, =pWTCON
	mov     r1, #0x0
	str     r1, [r0]
	 * mask all IRQs by setting all bits in the INTMR - default
	 * 关闭所有中断
	mov	r1, #0xffffffff
	ldr	r0, =INTMSK
	str	r1, [r0]
# if defined(CONFIG_S3C2410)
	ldr	r1, =0x3ff
	ldr	r0, =INTSUBMSK
	str	r1, [r0]
# endif
#if 0
	/* FCLK:HCLK:PCLK = 1:2:4 */
	/* default FCLK is 120 MHz ! */
	ldr	r0, =CLKDIVN
	mov	r1, #3
	str	r1, [r0]
#endif	/* CONFIG_S3C2400 || CONFIG_S3C2410 */
	 * we do sys-critical inits only at reboot,
	 * not when booting from ram!
#ifndef CONFIG_SKIP_LOWLEVEL_INIT
	adr	r0, _start		/* r0 <- current position of code 当前位置   */
	ldr	r1, _TEXT_BASE		/* test if we run from flash or RAM 链接位置 */
	cmp     r0, r1                  /* don't reloc during debug  是否相等        */
	blne	cpu_init_crit			/* 不相等 执行内存控制器初始化 */
	/* Set up the stack						    */
stack_setup:
	ldr	r0, _TEXT_BASE		/* upper 128 KiB: relocated uboot _TEXT_BASE 0x33f80000 前面的是 uboot代码存放位置 */
	sub	r0, r0, #CFG_MALLOC_LEN	/* malloc area    减去  CFG_MALLOC_LEN 段 动态内存           */
	sub	r0, r0, #CFG_GBL_DATA_SIZE /* bdinfo       减去  CFG_GBL_DATA_SIZE 段 全局的系统初始化参数                */
	sub	r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ)/* 减去 中断和快速中断的栈 */
	sub	sp, r0, #12		/* leave 3 words for abort-stack  设置栈 sp= r0 - 12   */
    bl clock_init	/* 调用 c 函数初始化时钟 */
#ifndef CONFIG_SKIP_RELOCATE_UBOOT
/* 拷贝代码到内存 */
relocate:				/* relocate U-Boot to RAM	    */
	adr	r0, _start		/* r0 <- current position of code   */
	ldr	r1, _TEXT_BASE		/* test if we run from flash or RAM */
	cmp     r0, r1                  /* don't reloc during debug         */
	beq     clear_bss
	ldr	r2, _armboot_start
	ldr	r3, _bss_start
	sub	r2, r3, r2		/* r2 <- size of armboot            */
#if 1
	bl  CopyCode2Ram	/* r0: source, r1: dest, r2: size */
#else
	add	r2, r0, r2		/* r2 <- source end address         */
copy_loop:
	ldmia	r0!, {r3-r10}		/* copy from source address [r0]    */
	stmia	r1!, {r3-r10}		/* copy to   target address [r1]    */
	cmp	r0, r2			/* until source end addreee [r2]    */
	ble	copy_loop		/* r0 <r2 */
#endif	/* CONFIG_SKIP_RELOCATE_UBOOT */
/* 清除bss 段 */
clear_bss:
	add	r0, r0, #4
	cmp	r0, r1
	ble	clbss_l
SetLoadFlag:
	/* Set a global flag, PreLoadedONRAM */
	ldr r2, =PreLoadedONRAM
	mov r3, #1
	streq r3, [r2]
#if 0
	/* try doing this stuff after the relocation */
	ldr     r0, =pWTCON
	mov     r1, #0x0
	str     r1, [r0]
	mov	r1, #0xffffffff
	ldr	r0, =INTMR
	str	r1, [r0]
	ldr	r0, =CLKDIVN
	mov	r1, #3
	str	r1, [r0]
	/* END stuff after relocation */
	ldr	pc, _start_armboot	/* 调用start_armboot 函数 */
_start_armboot:	.word start_armboot
 * CPU_init_critical registers
 * setup important registers
 * setup memory timing
cpu_init_crit:
	 * flush v4 I/D caches
	 * 清空缓存
	mov	r0, #0
	mcr	p15, 0, r0, c7, c7, 0	/* flush v3/v4 cache */
	mcr	p15, 0, r0, c8, c7, 0	/* flush v4 TLB */
	 * disable MMU stuff and caches
	 * 关闭MMU 和 缓存
	mrc	p15, 0, r0, c1, c0, 0
	bic	r0, r0, #0x00002300	@ clear bits 13, 9:8 (--V- --RS)
	bic	r0, r0, #0x00000087	@ clear bits 7, 2:0 (B--- -CAM)
	orr	r0, r0, #0x00000002	@ set bit 2 (A) Align
	orr	r0, r0, #0x00001000	@ set bit 12 (I) I-Cache
	mcr	p15, 0, r0, c1, c0, 0
	 * before relocating, we have to setup RAM timing
	 * because memory timing is board-dependend, you will
	 * find a lowlevel_init.S in your board directory.
	mov	ip, lr
	bl	lowlevel_init	// board\100ask24x0 初始化SDRAM  lowlevel_init.s
	mov	lr, ip
	mov	pc, lr
#endif /* CONFIG_SKIP_LOWLEVEL_INIT */
 * Interrupt handling
@ IRQ stack frame.
#define S_FRAME_SIZE	72
#define S_OLD_R0	68
#define S_PSR		64
#define S_PC		60
#define S_LR		56
#define S_SP		52
#define S_IP		48
#define S_FP		44
#define S_R10		40
#define S_R9		36
#define S_R8		32
#define S_R7		28
#define S_R6		24
#define S_R5		20
#define S_R4		16
#define S_R3		12
#define S_R2		8
#define S_R1		4
#define S_R0		0
#define MODE_SVC 0x13
#define I_BIT	 0x80
 * use bad_save_user_regs for abort/prefetch/undef/swi ...
 * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling
	.macro	bad_save_user_regs
	sub	sp, sp, #S_FRAME_SIZE
	stmia	sp, {r0 - r12}			@ Calling r0-r12
	sub	r2, r2, #(CONFIG_STACKSIZE+CFG_MALLOC_LEN)
	sub	r2, r2, #(CFG_GBL_DATA_SIZE+8)  @ set base 2 words into abort stack
	ldmia	r2, {r2 - r3}			@ get pc, cpsr
	add	r0, sp, #S_FRAME_SIZE		@ restore sp_SVC
	add	r5, sp, #S_SP
	mov	r1, lr
	stmia	r5, {r0 - r3}			@ save sp_SVC, lr_SVC, pc, cpsr
	mov	r0, sp
	.endm
	.macro	irq_save_user_regs
	add     r8, sp, #S_PC
	stmdb   r8, {sp, lr}^                   @ Calling SP, LR
	str     lr, [r8, #0]                    @ Save calling PC
	mrs     r6, spsr
	str     r6, [r8, #4]                    @ Save CPSR
	str     r0, [r8, #8]                    @ Save OLD_R0
	mov	r0, sp
	.endm
	.macro	irq_restore_user_regs
	ldmia	sp, {r0 - lr}^			@ Calling r0 - lr
	mov	r0, r0
	ldr	lr, [sp, #S_PC]			@ Get PC
	add	sp, sp, #S_FRAME_SIZE
	subs	pc, lr, #4			@ return & move spsr_svc into cpsr
	.endm
	.macro get_bad_stack
	ldr	r13, _armboot_start		@ setup our mode stack
	sub	r13, r13, #(CONFIG_STACKSIZE+CFG_MALLOC_LEN)
	sub	r13, r13, #(CFG_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack
	str	lr, [r13]			@ save caller lr / spsr
	mrs	lr, spsr
	str     lr, [r13, #4]
	mov	r13, #MODE_SVC			@ prepare SVC-Mode
	@ msr	spsr_c, r13
	msr	spsr, r13
	mov	lr, pc
	movs	pc, lr
	.endm
	.macro get_irq_stack			@ setup IRQ stack
	ldr	sp, IRQ_STACK_START
	.endm
	.macro get_fiq_stack			@ setup FIQ stack
	ldr	sp, FIQ_STACK_START
	.endm
 * exception handlers
	.align  5
	get_bad_stack
	bad_save_user_regs
	bl 	do_undefined_instruction
	.align	5
software_interrupt:
	get_bad_stack
	bad_save_user_regs
	bl 	do_software_interrupt
	.align	5
prefetch_abort:
	get_bad_stack
	bad_save_user_regs
	bl 	do_prefetch_abort
	.align	5
data_abort:
	get_bad_stack
	bad_save_user_regs
	bl 	do_data_abort
	.align	5
not_used:
	get_bad_stack
	bad_save_user_regs
	bl 	do_not_used
@ thisway.diy, 2006.06.24
.globl Launch
    .align	4
Launch:
    mov r7, r0
    @ diable interrupt
	@ disable watch dog timer
	mov	r1, #0x53000000
	mov	r2, #0x0
	str	r2, [r1]
    ldr r1,=INTMSK
    ldr r2,=0xffffffff  @ all interrupt disable
    str r2,[r1]
    ldr r1,=INTSUBMSK
    ldr r2,=0x7ff       @ all sub interrupt disable
    str r2,[r1]
    ldr     r1, = INTMOD
    mov r2, #0x0        @ set all interrupt as IRQ (not FIQ)
    str     r2, [r1]
	mov	ip, #0
	mcr	p15, 0, ip, c13, c0, 0      @	/* zero PID */
	mcr	p15, 0, ip, c7, c7, 0       @	/* invalidate I,D caches */
	mcr	p15, 0, ip, c7, c10, 4      @	/* drain write buffer */
	mcr	p15, 0, ip, c8, c7, 0       @	/* invalidate I,D TLBs */
	mrc	p15, 0, ip, c1, c0, 0       @	/* get control register */
	bic	ip, ip, #0x0001             @	/* disable MMU */
	mcr	p15, 0, ip, c1, c0, 0       @	/* write control register */
    @ MMU_EnableICache
    @mrc p15,0,r1,c1,c0,0
    @orr r1,r1,#(1<<12)
    @mcr p15,0,r1,c1,c0,0
    @ clear SDRAM: the end of free mem(has wince on it now) to the end of SDRAM
    ldr     r3, FREE_RAM_END
    ldr     r4, =PHYS_SDRAM_1+PHYS_SDRAM_1_SIZE    @ must clear all the memory unused to zero
    mov     r5, #0
    ldr     r1, _armboot_start
    ldr     r2, =On_Steppingstone
    sub     r2, r2, r1
    mov     pc, r2
On_Steppingstone:
2:  stmia   r3!, {r5}
    cmp     r3, r4
    bne     2b
    @ set sp = 0 on sys mode
    mov sp, #0
    @ add by thisway.diy 2006.06.26, switch to SVC mode
	msr	cpsr_c,	#0xdf	@ set the I-bit = 1, diable the IRQ interrupt
	msr	cpsr_c,	#0xd3	@ set the I-bit = 1, diable the IRQ interrupt
    ldr sp, =0x31ff5800
    nop
	nop
    nop
	nop
	mov     pc, r7  @ Jump to PhysicalAddress
	nop
    mov pc, lr
	.align	5
irq:
/* add by www.100ask.net to use IRQ for USB and DMA */
	sub	lr, lr, #4			        @ the return address
	ldr	sp, IRQ_STACK_START	        @ the stack for irq
	stmdb	sp!, 	{ r0-r12,lr }	@ save registers
	ldr	lr,	=int_return		        @ set the return addr
	ldr	pc, =IRQ_Handle		        @ call the isr
int_return:
	ldmia	sp!, 	{ r0-r12,pc }^	@ return from interrupt
	.align	5
fiq:
	get_fiq_stack
	/* someone ought to write a more effiction fiq_save_user_regs */
	irq_save_user_regs
	bl 	do_fiq
#else
	.align	5
irq:
	get_bad_stack
	bad_save_user_regs
	bl 	do_irq
	.align	5
fiq:
	get_bad_stack
	bad_save_user_regs
	bl 	do_fiq
最近编辑记录 xinxiaoci (2018-06-08 16:25:50)
#2 2020-05-21 16:14:38
tianyun923
Re: u-boot 源码分析 第一阶段源码分析
uboot,源码我开了好久都卡不懂了,看韦东山了直接把我看懵逼了
#3 2020-05-21 21:31:00
xsxusen05
已发帖子: 22
还是看正点原子的好点吧!
