stm32f407,从rtc的结构体转换为时间戳代码如下,注意包含头文件#include <time.h>
* @file rtc.c
* @author yedasheng
* @version V1.0
* @date 20200512
* @brief rtc
* @attention
/* Includes ------------------------------------------------------------------*/
#include <time.h>
#include "rtc.h"
RTC_DateTypeDef Sdatestructure;
RTC_TimeTypeDef Stimestructure;
RTC_HandleTypeDef hrtc;
extern uint32_t ErrorCode;
extern SYSPARA GSystemPara; // ??????
/* RTC init function */
void MX_RTC_Init(void)
RTC_DateTypeDef Sdate;
RTC_TimeTypeDef Stime;
/* Enable Power Clock*/
__HAL_RCC_PWR_CLK_ENABLE();
/* Allow Access to RTC Backup domaine */
HAL_PWR_EnableBkUpAccess();
hrtc.Instance = RTC;
/* Check if Pin Reset flag is set */
if ( (__HAL_RCC_GET_FLAG(RCC_FLAG_IWDGRST) != RESET))
print(0, "\n reset \n ");
/**Initialize RTC and set the Time and Date
hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
hrtc.Init.AsynchPrediv = RTC_ASYNCH_PREDIV;
hrtc.Init.SynchPrediv = RTC_SYNCH_PREDIV;
hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
if (HAL_RTC_Init(&hrtc) != HAL_OK)
/* Initialization Error */
ErrorCode |= ERRORMASK_RTC;
print(0, "\r\nHAL_RTC_Init Fail hrtc.State=%u\n", hrtc.State );
/*##-2- Check if Data stored in BackUp register0: No Need to reconfigure RTC#*/
/* Read the Back Up Register 0 Data */
if (HAL_RTCEx_BKUPRead(&hrtc, RTC_BKP_DR0) != 0x32F2)
/*##-1- Configure the Date #################################################*/
/* Set Date: Tuesday February 18th 2015*/
Sdate.Year = 16;
Sdate.Month = RTC_MONTH_MARCH;
Sdate.Date = 2;
Sdate.WeekDay = RTC_WEEKDAY_WEDNESDAY;
/*##-2- Configure the Time #################################################*/
/* Set Time: 02:00:00 */
Stime.Hours = 14;
Stime.Minutes = 17;
Stime.Seconds = 41;
Stime.TimeFormat = RTC_HOURFORMAT12_PM;
Stime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE ;
Stime.StoreOperation = RTC_STOREOPERATION_RESET;
/* Configure RTC Calendar */
RTC_CalendarConfig(Sdate, Stime, RTC_FORMAT_BIN);
/* Check if the Power On Reset flag is set */
if (__HAL_RCC_GET_FLAG(RCC_FLAG_PORRST) != RESET)
if (__HAL_RCC_GET_FLAG(RCC_FLAG_PINRST) != RESET)
/* Clear source Reset Flag */
__HAL_RCC_CLEAR_RESET_FLAGS();
* @brief Configure the current time and date.
* @param None
* @retval None
void RTC_CalendarConfig( RTC_DateTypeDef sdatestructure, RTC_TimeTypeDef stimestructure, uint32_t Format)
if(HAL_RTC_SetDate(&hrtc, &sdatestructure, Format) != HAL_OK)
print(0, "\r\nHAL_RTC_SetDate Fail");
if (HAL_RTC_SetTime(&hrtc, &stimestructure, Format) != HAL_OK)
print(0, "\r\nHAL_RTC_SetTime Fail");
/*##-3- Writes a data in a RTC Backup data Register0 #######################*/
HAL_RTCEx_BKUPWrite(&hrtc, RTC_BKP_DR0, 0x32F2);
* @brief Display the current time and date.
* @retval None
void RTC_CalendarShow(void)
/* Get the RTC current Time */
HAL_RTC_GetTime(&hrtc, &Stimestructure, RTC_FORMAT_BIN);
/* Get the RTC current Date */
HAL_RTC_GetDate(&hrtc, &Sdatestructure, RTC_FORMAT_BIN);
/* Display time Format : hh:mm:ss */
//print(0, "\r\n%02u-%02u-%02u %02u:%02u:%02u", Sdatestructure.Year, Sdatestructure.Month, Sdatestructure.Date, Stimestructure.Hours, Stimestructure.Minutes, Stimestructure.Seconds);
// print(0, " %02u:%02u:%02u\n", Stimestructure.Hours, Stimestructure.Minutes, Stimestructure.Seconds);
* Function Name : Time_ConvCalendarToUnix(struct tm t)
* Description : 写入RTC时钟当前时间
* Input : struct tm t
* Output : None
* Return : time_t
uint32_t Time_ConvCalendarToUnix(void)
struct tm time_now;
uint32_t now;
// t.tm_year -= 1900; //外部tm结构体存储的年份为2008格式
//而time.h中定义的年份格式为1900年开始的年份
//所以,在日期转换时要考虑到这个因素。
time_now.tm_year=Sdatestructure.Year+2000-1900;
time_now.tm_mon=Sdatestructure.Month-1;
time_now.tm_mday=Sdatestructure.Date;
time_now.tm_wday= Sdatestructure.WeekDay-1;
time_now.tm_hour=Stimestructure.Hours;
time_now.tm_min=Stimestructure.Minutes;
time_now.tm_sec=Stimestructure.Seconds;
now= mktime(&time_now)-8*60*60; /* 标准时间戳和北京时间差值 8小时 */
print(0,"time:%04u-%02u-%02u %02u:%02u:%02u", Sdatestructure.Year + 2000, Sdatestructure.Month, Sdatestructure.Date, Stimestructure.Hours, Stimestructure.Minutes, Stimestructure.Seconds);
print(0,"uinix: %u\n", now);
return now;
}离线
这个有用,输出日志的时候可以使用这个,很方便
