楼主 #1 2020-06-02 22:52:01
luciferseva
已发帖子: 58
zero 32mflash启动,是起来了,但是这些报错是哪里来的,怎么解决???
[    0.959402] using random host ethernet address
[    0.964953] usb0: HOST MAC e2:f0:c0:75:44:a3
[    0.969276] usb0: MAC 22:25:ab:57:04:a8
[    0.973156] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    0.980739] g_cdc gadget: g_cdc ready
[    0.984755] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:00:37 UTC (37)
[    0.992992] vcc3v0: disabling
[    0.996043] vcc5v0: disabling
[    0.999012] ALSA device list:
[    1.001974]   No soundcards found.
[    1.007502] random: fast init done
[    1.050037] random: crng init done
[    1.677847] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    1.684859] devtmpfs: mounted
[    1.688997] Freeing unused kernel memory: 1024K
Starting logging: OK
Starting mdev...
[    5.381577] ------------[ cut here ]------------
[    5.386298] WARNING: CPU: 0 PID: 86 at drivers/mtd/spi-nor/spi-nor.c:1182 spi_nor_write+0x138/0x1b4
[    5.395376] Writing at offset 100 into a NOR page. Writing partial pages may decrease reliability and increase wear of NOR flash.
[    5.395382] Modules linked in:
[    5.410089] CPU: 0 PID: 86 Comm: touch Not tainted 4.10.15-licheepi-zero #8
[    5.417038] Hardware name: Allwinner sun8i Family
[    5.421767] [<c010e2fc>] (unwind_backtrace) from [<c010b098>] (show_stack+0x10/0x14)
[    5.429509] [<c010b098>] (show_stack) from [<c03465c4>] (dump_stack+0x84/0x98)
[    5.436732] [<c03465c4>] (dump_stack) from [<c011b634>] (__warn+0xe8/0x100)
[    5.443689] [<c011b634>] (__warn) from [<c011b684>] (warn_slowpath_fmt+0x38/0x48)
[    5.451168] [<c011b684>] (warn_slowpath_fmt) from [<c0453094>] (spi_nor_write+0x138/0x1b4)
[    5.459426] [<c0453094>] (spi_nor_write) from [<c044b454>] (mtd_writev+0xa4/0xec)
[    5.466909] [<c044b454>] (mtd_writev) from [<c02fbec8>] (jffs2_flash_writev+0x414/0x4b0)
[    5.474995] [<c02fbec8>] (jffs2_flash_writev) from [<c02f4d48>] (jffs2_write_dnode+0xd4/0x328)
[    5.483598] [<c02f4d48>] (jffs2_write_dnode) from [<c02f9458>] (jffs2_do_setattr+0x280/0x558)
[    5.492114] [<c02f9458>] (jffs2_do_setattr) from [<c02f9754>] (jffs2_setattr+0x24/0x48)
[    5.500114] [<c02f9754>] (jffs2_setattr) from [<c020d990>] (notify_change+0x1c4/0x3d0)
[    5.508026] [<c020d990>] (notify_change) from [<c021e65c>] (utimes_common+0xa8/0x170)
[    5.515847] [<c021e65c>] (utimes_common) from [<c021e7d4>] (do_utimes+0xb0/0x144)
[    5.523322] [<c021e7d4>] (do_utimes) from [<c021ea10>] (SyS_futimesat+0xd0/0xfc)
[    5.530712] [<c021ea10>] (SyS_futimesat) from [<c0107580>] (ret_fast_syscall+0x0/0x3c)
[    5.538693] ---[ end trace 2eb92dd1d99ad103 ]---
Starting network: OK
#2 2020-06-02 23:06:36
我思故我在
已发帖子: 244
Re: zero 32mflash启动,是起来了,但是这些报错是哪里来的,怎么解决???
jffs2 文件系统有问题
楼主 #3 2020-06-02 23:30:00
luciferseva
已发帖子: 58
我思故我在 说:
jffs2 文件系统有问题
有没有解决方法啊?我就是下载网上的解压,然后制作啊,有什么问题吗?
#4 2020-06-03 00:00:25
已发帖子: 3,394
楼主 #5 2020-06-03 14:07:01
luciferseva
已发帖子: 58
这个是什么固件?
