[ 0.000000] Linux version 4.15.0-rc8-licheepi-nano (wings@ubuntu) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #9 Thu Jun 4 14:06:06 CST 2020
[ 0.000000] random: fast init done
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=jffs2
[ 0.000000] Memory: 22668K/32768K available (6144K kernel code, 241K rwdata, 1424K rodata, 1024K init, 246K bss, 10100K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc2800000 - 0xff800000 ( 976 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (7136 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 242 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 247 kB)
[ 0.000044] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000105] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000628] Console: colour dummy device 80x30
[ 0.000706] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070227] pid_max: default: 32768 minimum: 301
[ 0.070529] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070569] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.071945] CPU: Testing write buffer coherency: ok
[ 0.073547] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076041] devtmpfs: initialized
[ 0.082511] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.082580] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.082824] pinctrl core: initialized pinctrl subsystem
[ 0.084789] NET: Registered protocol family 16
[ 0.086153] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.087915] cpuidle: using governor menu
[ 0.113244] SCSI subsystem initialized
[ 0.113583] usbcore: registered new interface driver usbfs
[ 0.113730] usbcore: registered new interface driver hub
[ 0.113927] usbcore: registered new device driver usb
[ 0.114339] pps_core: LinuxPPS API ver. 1 registered
[ 0.114365] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.114423] PTP clock support registered
[ 0.114916] Advanced Linux Sound Architecture Driver Initialized.
[ 0.116396] clocksource: Switched to clocksource timer
[ 0.142284] NET: Registered protocol family 2
[ 0.143666] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.143743] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.143794] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.144056] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.144115] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.144568] NET: Registered protocol family 1
[ 0.145733] RPC: Registered named UNIX socket transport module.
[ 0.145775] RPC: Registered udp transport module.
[ 0.145793] RPC: Registered tcp transport module.
[ 0.145809] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.147695] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.149474] Initialise system trusted keyrings
[ 0.149984] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.167233] NFS: Registering the id_resolver key type
[ 0.167325] Key type id_resolver registered
[ 0.167347] Key type id_legacy registered
[ 0.167458] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.181633] Key type asymmetric registered
[ 0.181673] Asymmetric key parser 'x509' registered
[ 0.181869] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.181901] io scheduler noop registered
[ 0.181921] io scheduler deadline registered
[ 0.182675] io scheduler cfq registered (default)
[ 0.182708] io scheduler mq-deadline registered
[ 0.182727] io scheduler kyber registered
[ 0.183838] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.193261] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.360192] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.366825] console [ttyS0] disabled
[ 0.387048] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[ 0.860541] console [ttyS0] enabled
[ 0.870971] panel-simple panel: panel supply power not found, using dummy regulator
[ 0.880360] SCSI Media Changer driver v0.25
[ 0.888232] m25p80 spi0.0: xt25f128b (16384 Kbytes)
[ 0.893185] 4 ofpart partitions found on MTD device spi0.0
[ 0.898775] Creating 4 MTD partitions on "spi0.0":
[ 0.903587] 0x000000000000-0x000000100000 : "u-boot"
[ 0.911195] 0x000000100000-0x000000110000 : "dtb"
[ 0.918472] 0x000000110000-0x000000510000 : "kernel"
[ 0.925827] 0x000000510000-0x000001000000 : "rootfs"
[ 0.933853] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.940511] ehci-platform: EHCI generic platform driver
[ 0.946022] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.952320] ohci-platform: OHCI generic platform driver
[ 0.958029] usbcore: registered new interface driver usb-storage
[ 0.964919] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.973955] i2c /dev entries driver
[ 1.036514] sunxi-mmc 1c0f000.mmc: base:0x298e3574 irq:19
[ 1.043941] usbcore: registered new interface driver usbhid
[ 1.049631] usbhid: USB HID core driver
[ 1.071174] NET: Registered protocol family 17
[ 1.075861] Key type dns_resolver registered
[ 1.082542] Loading compiled-in X.509 certificates
[ 1.097676] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0739c38)
[ 1.106616] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0738f1c)
[ 1.114280] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.120954] [drm] No driver support for vblank timestamp query.
[ 1.174869] Console: switching to colour frame buffer device 60x34
[ 1.198266] sun4i-drm display-engine: fb0: frame buffer device
[ 1.205447] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.214645] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.226654] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.232451] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.242595] hub 1-0:1.0: USB hub found
[ 1.246653] hub 1-0:1.0: 1 port detected
[ 1.252146] using random self ethernet address
[ 1.256780] using random host ethernet address
[ 1.263026] usb0: HOST MAC 5e:a8:cb:00:f2:64
[ 1.267545] usb0: MAC 82:3d:d4:27:63:74
[ 1.271547] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.279110] g_cdc gadget: g_cdc ready
[ 1.283785] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.301375] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.308234] vcc3v3: disabling
[ 1.311216] ALSA device list:
[ 1.314181] #0: Loopback 1
[ 1.318032] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.326785] cfg80211: failed to load regulatory.db
[ 1.472118] random: crng init done
[ 5.194233] jffs2: Cowardly refusing to erase blocks on filesystem with no valid JFFS2 nodes
[ 5.202804] jffs2: empty_blocks 0, bad_blocks 0, c->nr_blocks 175
[ 5.209271] VFS: Cannot open root device "mtdblock3" or unknown-block(31,3): error -5
[ 5.217202] Please append a correct "root=" boot option; here are the available partitions:
[ 5.225558] 1f00 1024 mtdblock0
[ 5.225567] (driver?)
[ 5.232193] 1f01 64 mtdblock1
[ 5.232203] (driver?)
[ 5.238789] 1f02 4096 mtdblock2
[ 5.238796] (driver?)
[ 5.245331] 1f03 11200 mtdblock3
[ 5.245337] (driver?)
[ 5.251935] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[ 5.260276] CPU: 0 PID: 1 Comm: swapper Not tainted 4.15.0-rc8-licheepi-nano #9
[ 5.267562] Hardware name: Allwinner suniv Family
[ 5.272340] [<c010e550>] (unwind_backtrace) from [<c010b6a8>] (show_stack+0x10/0x14)
[ 5.280093] [<c010b6a8>] (show_stack) from [<c0116878>] (panic+0xb8/0x230)
[ 5.286981] [<c0116878>] (panic) from [<c0901130>] (mount_block_root+0x170/0x250)
[ 5.294460] [<c0901130>] (mount_block_root) from [<c0901304>] (mount_root+0xf4/0x120)
[ 5.302284] [<c0901304>] (mount_root) from [<c090144c>] (prepare_namespace+0x11c/0x17c)
[ 5.310283] [<c090144c>] (prepare_namespace) from [<c0900d60>] (kernel_init_freeable+0x174/0x1b8)
[ 5.319159] [<c0900d60>] (kernel_init_freeable) from [<c066f6f0>] (kernel_init+0x8/0x10c)
[ 5.327340] [<c066f6f0>] (kernel_init) from [<c0107dc0>] (ret_from_fork+0x14/0x34)
[ 5.334902] Rebooting in 5 seconds..
[ 11.314135] Reboot failed -- System halted
所以应该是内核里MTD设备驱动的问题吗?
谢谢啦,我先去确认一下根文件系统生成的镜像
搞定啦,谢谢啦
脚本的文件路径搞错了
