楼主 #1 2020-06-12 15:46:55
cccsk
荔枝派zero v3s无限重启 新人求助。第一次发帖,有什么不对的请指教,谢谢
U-Boot SPL 2017.01-rc2 (Jun 10 2020 - 17:59:52)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2 (Jun 10 2020 - 17:59:52 -0700) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
dotclock: 10000kHz = 10000kHz: (1 3MHz 20) / 6
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
290 bytes read in 15 ms (18.6 KiB/s)
Executing script at 41900000
reading uImage
2433992 bytes read in 225 ms (10.3 MiB/s)
reading script.bin
35240 bytes read in 27 ms (1.2 MiB/s)
Booting kernel from Legacy Image at 41000000 ...
Image Name: Linux-3.4.39
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2433928 Bytes = 2.3 MiB
Load Address: 40008000
Entry Point: 40008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
Using machid 0x1029 from environment
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.4.39 (kerson@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02) ) #1 Fri Jun 12 00:09:25 PDT 2020
[ 0.000000] Initialized persistent memory from 41d20800-41d307ff
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[ 0.000000] Memory: 64MB = 64MB total
[ 0.000000] Memory: 30428k/30428k available, 35108k reserved, 0K highmem
[ 0.000000] vmalloc : 0xc4800000 - 0xff000000 ( 936 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0470000 (4512 kB)
[ 0.000000] .init : 0xc0470000 - 0xc0493000 ( 140 kB)
[ 0.000000] .data : 0xc0494000 - 0xc04d8750 ( 274 kB)
[ 0.000000] .bss : 0xc04d8774 - 0xc057320d ( 619 kB)
[ 0.000000] NR_IRQS:544
[ 0.000000] Architected local timer running at 24.00MHz.
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000151] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[ 0.000168] pid_max: default: 32768 minimum: 301
[ 0.000301] Mount-cache hash table entries: 512
[ 0.000850] CPU: Testing write buffer coherency: ok
[ 0.001114] Setting up static identity map for 0x4034c130 - 0x4034c188
[ 0.001785] devtmpfs: initialized
[ 0.003403] pinctrl core: initialized pinctrl subsystem
[ 0.003871] NET: Registered protocol family 16
[ 0.004174] DMA: preallocated 128 KiB pool for atomic coherent allocations
[ 0.004227] script_sysfs_init success
[ 0.004971] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[ 0.005863] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[ 0.006234] gpiochip_add: registered GPIOs 1024 to 1031 on device: axp-pinctrl
[ 0.006963] persistent_ram: found existing buffer, size 18878, start 18878
[ 0.089672] console [ram-1] enabled
[ 0.090597] Not Found clk pll_isp in script
[ 0.090728] Not Found clk pll_video in script
[ 0.090849] Not Found clk pll_ve in script
[ 0.091070] Not Found clk pll_periph0 in script
[ 0.091189] Not Found clk pll_de in script
[ 0.094994] bio: create slab <bio-0> at 0
[ 0.095375] pwm module init!
[ 0.097539] SCSI subsystem initialized
[ 0.097886] usbcore: registered new interface driver usbfs
[ 0.098172] usbcore: registered new interface driver hub
[ 0.098428] usbcore: registered new device driver usb
[ 0.098789] twi_chan_cfg()340 - [twi0] has no twi_regulator.
[ 0.098916] twi_chan_cfg()340 - [twi1] has no twi_regulator.
[ 0.099818] sunxi_i2c_do_xfer()985 - [i2c0] incomplete xfer (status: 0x20, dev addr: 0x34)
[ 0.100024] axp20_board 0-0034: failed reading at 0x03
[ 0.100173] axp20_board: probe of 0-0034 failed with error -70
[ 0.100440] Linux video capture interface: v2.00
[ 0.100645] gpiochip_add: gpios 1024..1028 (axp_pin) failed to register
[ 0.101187] Advanced Linux Sound Architecture Driver Version 1.0.25.
[ 0.101944] Switching to clocksource arch_sys_counter
[ 0.109737] NET: Registered protocol family 2
[ 0.109737] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.109826] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.109995] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.110288] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.110415] TCP: reno registered
[ 0.110641] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.110774] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.111268] NET: Registered protocol family 1
[ 0.111718] standby_mode = 1.
[ 0.111842] wakeup src cnt is : 3.
[ 0.112081] pmu1_enable = 0x1.
[ 0.112201] pmux_id = 0x1.
[ 0.112330] config_pmux_para: script_parser_fetch err.
[ 0.112551] pmu2_enable = 0x0.
[ 0.112674] add_sys_pwr_dm: get ldo name failed
[ 0.112794] add_sys_pwr_dm: get ldo name failed
[ 0.113015] add_sys_pwr_dm: get ldo name failed
[ 0.113134] add_sys_pwr_dm: get ldo name failed
[ 0.113254] add_sys_pwr_dm: get ldo name failed
[ 0.113472] add_sys_pwr_dm: get ldo name failed
[ 0.113591] add_sys_pwr_dm: get ldo name failed
[ 0.113811] add_sys_pwr_dm: get ldo name failed
[ 0.113931] add_sys_pwr_dm: get ldo name failed
[ 0.114051] add_sys_pwr_dm: get ldo name failed
[ 0.114270] after inited: sys_mask config = 0x0.
[ 0.114391] dynamic_standby enalbe = 0x0.
[ 0.114658] sunxi_reg_init enter
[ 0.116680] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.116856] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.117266] msgmni has been set to 59
[ 0.118303] io scheduler noop registered
[ 0.118537] io scheduler deadline registered
[ 0.118725] io scheduler cfq registered (default)
[ 0.119225] [DISP]disp_module_init
[ 0.119830] cmdline,disp=
[ 0.120546] [DISP] disp_get_rotation_sw,line:68:disp 0 out of range? g_rot_sw=0
[ 0.120890] [DISP] disp_init_connections,line:288:NULL pointer: 0, 0
[ 0.123427] [DISP] Fb_map_kernel_logo,line:924:Fb_map_kernel_logo failed!
[ 0.126093] [DISP] disp_sys_power_enable,line:387:some error happen, fail to get regulator
[ 0.127178] [DISP]disp_module_init finish
[ 0.127577] sw_uart_get_devinfo()1503 - uart0 has no uart_regulator.
[ 0.128057] uart0: ttyS0 at MMIO 0x1c28000 (irq = 32) is a SUNXI
[ 0.128288] sw_uart_pm()890 - uart0 clk is already enable
[ 0.128421] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[ 0.241886] console [ttyS0] enabled
[ 0.759425] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[ 0.767377] spi spi0: master is unqueued, this is deprecated
[ 0.773944] m25p_probe()982 - Use the Dual Mode Read.
[ 0.779893] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.786739] partitions_register()869 - Invalid partitions count: -1
[ 0.794391] Creating 4 MTD partitions on "spi0.0":
[ 0.799843] 0x000000000000-0x000000080000 : "u-boot"
[ 0.806431] 0x000000080000-0x000000100000 : "sys_config"
[ 0.813471] 0x000000100000-0x000000400000 : "kernel"
[ 0.819912] 0x000000400000-0x000001000000 : "rootfs"
[ 0.828197] Failed to alloc md5
[ 0.831899] eth0: Use random mac address
[ 0.836427] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.864117] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.873279] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[ 0.881935] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[ 0.900035] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[ 0.907420] hub 1-0:1.0: USB hub found
[ 0.911880] hub 1-0:1.0: 1 port detected
[ 0.916781] sunxi-ehci sunxi-ehci.1: remove, state 1
[ 0.922552] usb usb1: USB disconnect, device number 1
[ 0.929788] sunxi-ehci sunxi-ehci.1: USB bus 1 deregistered
[ 0.946236] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.973437] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 0.982195] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 1
[ 0.990759] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[ 1.054780] hub 1-0:1.0: USB hub found
[ 1.059079] hub 1-0:1.0: 1 port detected
[ 1.064116] sunxi-ohci sunxi-ohci.1: remove, state 1
[ 1.069753] usb usb1: USB disconnect, device number 1
[ 1.076063] sunxi-ohci sunxi-ohci.1: USB bus 1 deregistered
[ 1.092598] Initializing USB Mass Storage driver...
[ 1.098218] usbcore: registered new interface driver usb-storage
[ 1.105112] USB Mass Storage support registered.
[ 1.110757] file system registered
[ 1.116266] android_usb gadget: Mass Storage Function, version: 2009/09/11
[ 1.124076] android_usb gadget: Number of LUNs=1
[ 1.129438] lun0: LUN: removable file: (no medium)
[ 1.135444] android_usb gadget: android_usb ready
[ 1.140936] sunxikbd_script_init: key para not found, used default para.
[ 1.149585] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[ 1.158015] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[ 1.166932] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[ 1.175860] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[ 1.184600] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[ 1.193230] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[ 1.201965] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[ 1.210687] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[ 1.219601] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[ 1.226945] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[ 1.238379] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[ 1.246080] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[ 1.252486] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[ 1.264384] no led_3, ignore it!
[ 1.268111] no led_4, ignore it!
[ 1.271838] no led_5, ignore it!
[ 1.275529] no led_6, ignore it!
[ 1.279241] no led_7, ignore it!
[ 1.284884] usbcore: registered new interface driver usbhid
[ 1.291334] usbhid: USB HID core driver
[ 1.296418] ashmem: initialized
[ 1.300414] logger: created 256K log 'log_main'
[ 1.305774] logger: created 32K log 'log_events'
[ 1.311161] logger: created 32K log 'log_radio'
[ 1.316448] logger: created 32K log 'log_system'
[ 1.323361] script_get_item return type err, consider it no ldo
[ 1.334195] **Try sdio**
[ 1.340870] asoc: sndcodec <-> sunxi-codec mapping ok
[ 1.348774] TCP: cubic registered
[ 1.352771] NET: Registered protocol family 17
[ 1.357839] **Try sd **
[ 1.364123] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 1.372984] ThumbEE CPU extension supported.
[ 1.377861] Registering SWP/SWPB emulation handler
[ 1.387948] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[ 1.397140] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[ 1.405742] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[ 1.414422] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[ 1.423096] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[ 1.431682] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[ 1.440558] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[ 1.449471] sunxi-rtc sunxi-rtc: setting system clock to 1970-01-01 00:08:30 UTC (510)
[ 1.460431] mmc0: new SDHC card at address 0001
[ 1.466236] ALSA device list:
[ 1.469652] #0: audiocodec
[ 1.473056] mmcblk0: mmc0:0001 SD16G 14.4 GiB
[ 1.479901] mmcblk0: p1 p2
[ 1.483923] mmcblk mmc0:0001: Card claimed for testing.
[ 1.489853] mmc0:0001: SD16G 14.4 GiB
[ 1.494373] platform reg-20-cs-dcdc2: Driver reg-20-cs-dcdc2 requests probe deferral
[ 1.503164] **sd init ok**
[ 1.510273] platform reg-20-cs-dcdc3: Driver reg-20-cs-dcdc3 requests probe deferral
[ 1.519222] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.528453] platform reg-20-cs-ldo1: Driver reg-20-cs-ldo1 requests probe deferral
[ 1.537523] platform reg-20-cs-ldo2: Driver reg-20-cs-ldo2 requests probe deferral
[ 1.546264] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 1.555495] platform reg-20-cs-ldo3: Driver reg-20-cs-ldo3 requests probe deferral
[ 1.564561] platform reg-20-cs-ldo4: Driver reg-20-cs-ldo4 requests probe deferral
[ 1.573489] platform reg-20-cs-ldoio0: Driver reg-20-cs-ldoio0 requests probe deferral
[ 1.604372] EXT4-fs (mmcblk0p2): recovery complete
[ 1.609936] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.619157] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.629402] devtmpfs: mounted
[ 1.633163] Freeing init memory: 140K
[ 1.654844] Kernel panic - not syncing: No init found. Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[ 1.668941] Backtrace:
[ 1.671925] [<c0013134>] (dump_backtrace+0x0/0x104) from [<c0343ff8>] (dump_stack+0x18/0x1c)
[ 1.681557] r7:c0491f78 r6:c04d8780 r5:00000096 r4:c04d9930
[ 1.688424] [<c0343fe0>] (dump_stack+0x0/0x1c) from [<c03443c4>] (panic+0x78/0x1bc)
[ 1.697154] [<c034434c>] (panic+0x0/0x1bc) from [<c0343fbc>] (init_post+0xa4/0xc8)
[ 1.705780] r3:0000000c r2:00000009 r1:c0574000 r0:c03f56e7
[ 1.712637] r7:c0491f78
[ 1.715694] [<c0343f18>] (init_post+0x0/0xc8) from [<c0470964>] (kernel_init+0x150/0x1a4)
[ 1.725000] [<c0470814>] (kernel_init+0x0/0x1a4) from [<c0031c68>] (do_exit+0x0/0x658)
[ 1.734021] Rebooting in 5 seconds..
#2 2020-06-12 16:05:17
已发帖子: 3,408
Re: 荔枝派zero v3s无限重启 新人求助。第一次发帖,有什么不对的请指教,谢谢
tf卡第二个分区的根文件系统有问题。
