https://whycan.cn/files/members/3162/h3-spiflash8m_bin.gz
[ 0.141840][ T1] NET: Registered protocol family 2
[ 0.143509][ T1] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.143613][ T1] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.143703][ T1] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.143791][ T1] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.144102][ T1] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.144207][ T1] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.144733][ T1] NET: Registered protocol family 1
[ 0.149020][ T1] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.167464][ T1] jffs2: version 2.2. (NAND) 2001-2006 Red Hat, Inc.
[ 0.168943][ T1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.168985][ T1] io scheduler mq-deadline registered
[ 0.169012][ T1] io scheduler kyber registered
[ 0.186821][ T1] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.192118][ T1] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[ 0.376655][ T1] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.382524][ T1] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
[ 0.384937][ T1] printk: console [ttyS0] disabled
[ 0.385147][ T1] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 35, base_baud = 1500000) is a 16550A
[ 1.028890][ T1] printk: console [ttyS0] enabled
[ 1.043667][ T1] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
[ 1.056040][ T1] spi-nor spi0.0: w25q128 (16384 Kbytes)
[ 1.061663][ T1] 4 fixed-partitions partitions found on MTD device spi0.0
[ 1.068807][ T1] Creating 4 MTD partitions on "spi0.0":
[ 1.074325][ T1] 0x000000000000-0x000000100000 : "u-boot"
[ 1.084379][ T1] ftl_cs: FTL header not found.
[ 1.092428][ T1] 0x000000100000-0x000000110000 : "dtb"
[ 1.099595][ T1] ftl_cs: FTL header not found.
[ 1.107455][ T1] 0x000000110000-0x000000510000 : "kernel"
[ 1.117461][ T1] ftl_cs: FTL header not found.
[ 1.125361][ T1] 0x000000510000-0x000001000000 : "rootfs"
[ 1.133174][ C0] random: fast init done
[ 1.139675][ T1] ftl_cs: FTL header not found.
[ 1.150193][ T1] libphy: Fixed MDIO Bus: probed
[ 1.155142][ T1] CAN device driver interface
[ 1.161282][ T1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.168595][ T1] ehci-platform: EHCI generic platform driver
[ 1.175205][ T1] ehci-platform 1c1b000.usb: EHCI Host Controller
[ 1.181576][ T1] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 1
[ 1.190511][ T1] ehci-platform 1c1b000.usb: irq 24, io mem 0x01c1b000
[ 1.224993][ T1] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[ 1.234215][ T1] hub 1-0:1.0: USB hub found
[ 1.238880][ T1] hub 1-0:1.0: 1 port detected
[ 1.245390][ T1] ehci-platform 1c1c000.usb: EHCI Host Controller
[ 1.251745][ T1] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
[ 1.260595][ T1] ehci-platform 1c1c000.usb: irq 26, io mem 0x01c1c000
[ 1.294976][ T1] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[ 1.303980][ T1] hub 2-0:1.0: USB hub found
[ 1.308631][ T1] hub 2-0:1.0: 1 port detected
[ 1.314993][ T1] ehci-platform 1c1d000.usb: EHCI Host Controller
[ 1.321351][ T1] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 3
[ 1.330186][ T1] ehci-platform 1c1d000.usb: irq 28, io mem 0x01c1d000
[ 1.364975][ T1] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[ 1.373924][ T1] hub 3-0:1.0: USB hub found
[ 1.378575][ T1] hub 3-0:1.0: 1 port detected
[ 1.384675][ T1] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.391667][ T1] ohci-platform: OHCI generic platform driver
[ 1.398158][ T1] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[ 1.405603][ T1] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
[ 1.414368][ T1] ohci-platform 1c1b400.usb: irq 25, io mem 0x01c1b400
[ 1.492179][ T1] hub 4-0:1.0: USB hub found
[ 1.496833][ T1] hub 4-0:1.0: 1 port detected
[ 1.503134][ T1] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[ 1.510588][ T1] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 5
[ 1.519404][ T1] ohci-platform 1c1c400.usb: irq 27, io mem 0x01c1c400
[ 1.601075][ T1] hub 5-0:1.0: USB hub found
[ 1.606004][ T1] hub 5-0:1.0: 1 port detected
[ 1.612289][ T1] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[ 1.619763][ T1] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 6
[ 1.628576][ T1] ohci-platform 1c1d400.usb: irq 29, io mem 0x01c1d400
[ 1.711068][ T1] hub 6-0:1.0: USB hub found
[ 1.715978][ T1] hub 6-0:1.0: 1 port detected
[ 1.725875][ T1] sun6i-rtc 1f00000.rtc: registered as rtc0
[ 1.731750][ T1] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T02:06:21 UTC (7581)
[ 1.740710][ T1] sun6i-rtc 1f00000.rtc: RTC enabled
[ 1.746227][ T1] i2c /dev entries driver
[ 1.751075][ T1] IR NEC protocol handler initialized
[ 1.756387][ T1] IR RC5(x/sz) protocol handler initialized
[ 1.762150][ T1] IR RC6 protocol handler initialized
[ 1.767427][ T1] IR JVC protocol handler initialized
[ 1.772667][ T1] IR Sony protocol handler initialized
[ 1.778038][ T1] IR SANYO protocol handler initialized
[ 1.783454][ T1] IR Sharp protocol handler initialized
[ 1.788902][ T1] IR MCE Keyboard/mouse protocol handler initialized
[ 1.795487][ T1] IR XMP protocol handler initialized
[ 1.802879][ T1] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.811893][ T1] cpu cpu0: failed to get clock: -2
[ 1.817072][ T1] cpufreq-dt: probe of cpufreq-dt failed with error -2
[ 1.825434][ T1] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[ 1.836520][ T1] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[ 1.867612][ T1] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.876396][ T1] sun8i-h3-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
[ 1.889069][ T1] usbcore: registered new interface driver usbhid
[ 1.895444][ T1] usbhid: USB HID core driver
[ 1.903590][ T1] NET: Registered protocol family 17
[ 1.908916][ T1] can: controller area network core (rev 20170425 abi 9)
[ 1.916116][ T1] NET: Registered protocol family 29
[ 1.921286][ T1] can: raw protocol (rev 20170425)
[ 1.926353][ T1] can: broadcast manager protocol (rev 20170425 t)
[ 1.932748][ T1] can: netlink gateway (rev 20190810) max_hops=1
[ 1.939532][ T1] Key type dns_resolver registered
[ 1.944914][ T1] Registering SWP/SWPB emulation handler
[ 1.980428][ T1] ALSA device list:
[ 1.984154][ T1] No soundcards found.
[ 2.180169][ C0] random: crng init done
[ 2.894074][ T1] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 2.902980][ T1] devtmpfs: mounted
[ 2.911206][ T1] Freeing unused kernel memory: 1024K
[ 2.917124][ T1] Run /sbin/init as init process
Starting logging: OK
Starting network: OK
Welcome to Buildroot
buildroot login: root
# uname -a
Linux buildroot 5.7.0-g8dcbf7e #2 SMP Wed Jun 10 21:19:56 CST 2020 armv7l GNU/Linux
果然水, 坐等教程吧
最近也在用H3,你自己画的板子?
最近也在用H3,你自己画的板子?
en, 是的
板子裸照发出来大家看看:)
en, 是的
最近编辑记录 checkout (2020-06-10 23:44:00)
板子裸照发出来大家看看:)
之前有在一位大神的贴子跟帖发过,大概长这样
围观,板子很漂亮
六层的吗?复位那块咋飞线了
最近编辑记录 yangshuwei (2020-06-13 00:06:42)
大佬,我的那个emmc好了,已经可以正常启动了。
大神你好,我的板子预留了emmc,但是没有焊.理由
1,感觉用不上这么大的空间
2,emmc贵,大神你比较有钱
3,TF 卡也挺好
1,感觉用不上这么大的空间
2,emmc贵,大神你比较有钱
3,TF 卡也挺好
哈哈 还好啦8G的好像36一片
哈哈 还好啦8G的好像36一片
有钱yin
事实上,如果要做产品,真的没有必要背个8G。我发的BIN是8M。易谦多背
请问两边板子用的PMIC是一样的吗,什么型号的呀?
