楼主 #1 2020-06-20 17:23:42
piyush
所在地: India
已发帖子: 23
f1c100s spi cs gpios无效,如何设置具有多个cs的多个spi设备。
Hello All,
我尝试如下设置设备树,但CS信号仅在默认硬件引脚上
&spi1 {
	pinctrl-names = "default";
	pinctrl-0 = <&spi1_pins_a>;
	num_chipselect = <2>;
	cs_gpios = 	<&pio 3 2 GPIO_ACTIVE_LOW>,
			<&pio 3 14 GPIO_ACTIVE_LOW>,
	gpio1: gpio@0x00 {
		compatible = "fairchild,74hc595";
		reg = <0>;
		gpio-controller;
		#gpio-cells = <2>;
		registers-number = <2>;
		spi-max-frequency = <1000000>;
	gpio2: gpio@0x01 {
		compatible = "ti,sn65hvs882", "pisosr-gpio";
		gpio-controller;
		#gpio-cells = <1>;
		reg = <1>;
我注意到spi设备驱动程序未从设备树中读取任何现成的解决方案来支持多个CS?
#2 2020-06-20 17:31:58
所在地: 你猜
已发帖子: 3,381
Re: f1c100s spi cs gpios无效,如何设置具有多个cs的多个spi设备。
楼主 #3 2020-06-21 09:14:23
piyush
所在地: India
已发帖子: 23
非常感谢您提供宝贵的信息,
但这对我的情况不起作用。
&spi1 {
	pinctrl-0 = <&spi1_pins_a &spi1_pins_cs>;
	num_chipselect = <4>;
	cs_gpios = 	<&pio 3 2 GPIO_ACTIVE_LOW>, /*PD2 main lcd*/
			<&pio 3 14 GPIO_ACTIVE_LOW>, /*PD14 SR Latch*/
			<&pio 3 21 GPIO_ACTIVE_LOW>, /*PD21 rtc*/
			<0>;			     /*lcd2*/
	gpio1: gpio@0x01 {
		reg = <1>;
		gpio-controller;
		#gpio-cells = <2>;
		registers-number = <1>;
			spi1_pins_a: spi1-pins-pc {
				pins = "PA0", "PA1", "PA2", "A3";
				function = "spi1";
			spi1_pins_cs: spi1_pins_cs {
				pins = "PD2", "D14", "PD21";
				function = "gpio_out";
CS信号仍在默认端口PA0上
我检查了驱动程序代码,未找到此行devm_gpio_request
#4 2020-07-02 16:43:30
所在地: 你猜
已发帖子: 3,381
&pio {
        spi0_cs_pins: spi0_cs_pins {
                pins = "PC3", "PH6";
&spi0 {
        status ="okay";
        pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
        cs-gpios = <&pio 2 3 GPIO_ACTIVE_HIGH>, <&pio 7 6 GPIO_ACTIVE_HIGH>;
        mx25l25635e:mx25l25635e@0 {
                compatible = "jedec,spi-nor";
                reg = <0x0>;
                #address-cells = <1>;
                #size-cells = <1>;
    panel@0 {
            compatible = "sitronix,st7789v";
            reg = <1>;
            reset-gpios = <&pio 2 4 GPIO_ACTIVE_HIGH>;//PC4
            dc-gpios = <&pio 2 7 GPIO_ACTIVE_LOW>;//PC7
            /*backlight = <&pwm_bl>;*/
            led-gpios = <&pio 7 0 GPIO_ACTIVE_LOW>;//PH0
            spi-cpol;
            spi-cpha;
            buswidth = <8>;
            rotate = <270>;
            rgb;
            fps = <30>;
            debug = <1>;
亲测可用。
楼主 #5 2020-07-05 10:30:46
piyush
所在地: India
已发帖子: 23
非常感谢,它对我有用
主要更改是cs_gpios更改为cs-gpios
#6 2020-07-05 10:45:45
didi
piyush 说:
非常感谢,它对我有用
咦,好像是噢,居然能通过编译?
#7 2020-07-05 10:46:12
piyush 说:
非常感谢,它对我有用
现在可以了吗?
楼主 #8 2020-07-05 10:52:33
piyush
所在地: India
已发帖子: 23
smartcar 说:
现在可以了吗?
Yes, Now it's working
#9 2020-07-09 22:45:07
wwkkww1983
记录一下,后面会用到这个
#10 2020-07-25 04:36:01
羽剑天涯
&pio {
&spi0 {
        status ="okay";
                reg = <0x0>;
                #size-cells = <1>;
    panel@0 {
            reg = <1>;
            spi-cpol;
            spi-cpha;
            buswidth = <8>;
            rotate = <270>;
            rgb;
            fps = <30>;
            debug = <1>;
亲测可用。
对于f1c100s的spi0的cs应该默认为PC1
#11 2022-02-01 18:41:27
droptop
Hi @Yujian Tianya,
Do you know how to do this for the f1c200s spi1 controller ?? I'm using spidev, and it looks like cs is not working.
#12 2022-02-01 20:24:09
LinuxGo
已发帖子: 88
didi 说:
piyush 说:
非常感谢,它对我有用
咦,好像是噢,居然能通过编译?
肯定可以编译,那就是个标签
#13 2022-05-23 21:59:38
时空vsxx
使用不同的GPIO作为片选就可以,我也在一个项目中就是这样用的
