楼主 #1 2020-07-06 18:20:43
小熊猫
已发帖子: 71
buildroot 交叉编译的f1c100s 的配置谁能贴一个基于7.2的交叉编译器
自己制作了一个,tf 卡启动的,加载失败。。
[    1.309175] random: fast init done
[    1.392239] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.409673] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.430905] devtmpfs: mounted
[    1.449141] Freeing unused kernel memory: 1024K
[    1.462800] Run /sbin/init as init process
[    1.507532] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[    1.524115] CPU: 0 PID: 1 Comm: init Not tainted 5.2.0-licheepi-nano+ #8
[    1.539435] Hardware name: Allwinner suniv Family
[    1.552620] [<c010e3f8>] (unwind_backtrace) from [<c010b9dc>] (show_stack+0x10/0x14)
[    1.569095] [<c010b9dc>] (show_stack) from [<c0116db4>] (panic+0xe8/0x2e4)
[    1.584758] [<c0116db4>] (panic) from [<c01185e8>] (do_exit+0x9dc/0xa18)
[    1.600117] [<c01185e8>] (do_exit) from [<c0119184>] (do_group_exit+0x3c/0xb4)
[    1.615993] [<c0119184>] (do_group_exit) from [<c0122d3c>] (get_signal+0x10c/0x7bc)
[    1.632223] [<c0122d3c>] (get_signal) from [<c010af4c>] (do_work_pending+0x1a8/0x558)
[    1.648678] [<c010af4c>] (do_work_pending) from [<c0101068>] (slow_work_pending+0xc/0x20)
[    1.665503] Exception stack(0xc1831fb0 to 0xc1831ff8)
[    1.679064] 1fa0:                                     be841f10 00000000 00000000 00000000
[    1.695964] 1fc0: 00000940 00000000 00000000 00000000 00000000 00000000 000275e4 00000000
[    1.712794] 1fe0: 00000000 be841f10 b6f90b53 b6f91000 00000030 ffffffff
[    1.727783] Rebooting in 5 seconds..
[    7.719715] Reboot failed -- System halted
#2 2020-07-06 18:48:51
已发帖子: 3,392
Re: buildroot 交叉编译的f1c100s 的配置谁能贴一个基于7.2的交叉编译器
根文件系统有问题,本站搜  exitcode=0x0000000b 应该很多答案
