楼主 #1 2020-07-08 14:04:14
小熊猫
已发帖子: 71
f1c100s 文件系统reboot Reboot failed -- System halted
# reboot
# Saving random seed... done.
Stopping logging: start-stop-daemon: warning: killing process 88: No such process
OK
umount: devtmpfs busy - remounted read-only
[  780.611576] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
[  782.637801] reboot: Restarting system
[  783.646223] Reboot failed -- System halted
#2 2020-07-08 14:06:54
已发帖子: 3,394
Re: f1c100s 文件系统reboot Reboot failed -- System halted
@wupaul2001 关于F1C100s打开watchdog后仍然无法重启的解决办法: https://whycan.cn/t_3832.html
#3 2020-07-08 14:27:12
Joey_Tian
mark it
楼主 #4 2020-07-08 15:38:55
小熊猫
已发帖子: 71
https://whycan.cn/t_3275.html
dts修改的同时,需要打开watchdog 使能 (TF 卡启动,5.2 kernel)
只要修改sunxi-f1c100s.dtsi
把wdt: watchdog@1c20ca0 {
   compatible = "allwinner, suniv-f1c100s-wdt",
                       "allwinner, sun4i-a10-wdt";
   reg = <0x1c20ca0 0x20>;
改为
                       "allwinner, sun6i-a31-wdt";
这样就能正常重启了,我使用的是5.2的内核
试了,可以reboot
# reboot
Stopping logging: start-stop-daemon: warning: killing process 89: No such process
OK
[   16.596397] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   18.642314] reboot: Restarting system
U-Boot SPL 2018.01-05676-g00188782ee (Apr 08 2018 - 16:10:25)
DRAM: 32 MiB
Trying to boot from MMC1
U-Boot 2018.01-05676-g00188782ee (Apr 08 2018 - 16:10:25 +0800) Allwinner Technology
CPU:   Allwinner F Series (SUNIV)
Model: Lichee Pi Nano
DRAM:  32 MiB
最近编辑记录 小熊猫 (2020-07-08 15:39:46)
#5 2020-07-08 16:40:23
get !感谢分享宝贵经验
#6 2022-07-23 22:02:59
a932265643
@小熊猫 给力啊,感谢答主,可以重启了
