楼主 #1 2018-12-27 12:47:26
C-starm
PN532 与树莓派连接时报pn53x_check_communication error
最近想把PN532通过ttl连接到树莓派上,通过Google上的一些教学贴,已经安装好了libnfc和libusb等,但是在执行nfc-list,nfc-scan-device -v时报错
nfc-scan-device -v报错如下:
debug libnfc.general log_level is set to 3
debug libnfc.general allow_autoscan is set to true
debug libnfc.general allow_intrusive_scan is set to false
debug libnfc.general 1 device(s) defined by user
debug libnfc.general #0 name: "Itead_PN532_SPI", connstring: "pn532_uart:/dev/ttyAMA0"
nfc-scan-device uses libnfc 1.7.1
1 NFC device(s) found:
debug libnfc.driver.pn532_uart Attempt to open: /dev/ttyAMA0 at 115200 bauds.
debug libnfc.bus.uart Serial port speed requested to be set to 115200 bauds.
debug libnfc.chip.pn53x Diagnose
debug libnfc.chip.pn53x Timeout value: 500
debug libnfc.bus.uart TX: 55 55 00 00 00 00 00 00 00 00 00 00 00 00 00 00
error libnfc.driver.pn532_uart pn53x_check_communication error
debug libnfc.chip.pn53x InRelease
debug libnfc.bus.uart TX: 00 00 ff 03 fd d4 52 00 da 00
error libnfc.driver.pn532_uart Unable to transmit data. (TX)
debug libnfc.general Unable to open "pn532_uart:/dev/ttyAMA0".
nfc_open failed for pn532_uart:/dev/ttyAMA0
libnfc.conf内容:
Allow device auto-detection (default: true)
Note: if this auto-detection is disabled, user has to set manually a device
configuration using file or environment variable
allow_autoscan = true
Allow intrusive auto-detection (default: false)
Warning: intrusive auto-detection can seriously disturb other devices
This option is not recommended, user should prefer to add manually his device.
allow_intrusive_scan = false
Set log level (default: error)
Valid log levels are (in order of verbosity): 0 (none), 1 (error), 2 (info), 3 (debug)
Note: if you compiled with --enable-debug option, the default log level is "debug"
log_level = 3
Manually set default device (no default)
To set a default device, you must set both name and connstring for your device
Note: if autoscan is enabled, default device will be the first device available in device list.
device.name = "Itead_PN532_SPI"
device.connstring = "pn532_uart:/dev/ttyAMA0"
求助各位dalao,万分感谢
最近编辑记录 C-starm (2018-12-27 12:51:07)
#2 2018-12-27 13:36:10
Re: PN532 与树莓派连接时报pn53x_check_communication error
PN532通过ttl连接到树莓派上
这个 TTL 怎么与树莓派连接的?是树莓派自带的UART? USB转TTL的串口线?
楼主 #3 2018-12-27 14:23:50
C-starm
树莓派上自带的TTL设备,rx、tx反接
#4 2018-12-27 14:26:26
自带的串口是 /dev/ttyS0 ttyS1 这种格式,但是你的配置文件不是这种格式。
首先确认一下你接的那组串口的设备号
楼主 #5 2018-12-27 14:36:01
C-starm
修改为ttyS0之后,执行nfc-list报错:
nfc-list uses libnfc 1.7.1
nfc_initiator_init: Timeout
#6 2018-12-27 14:43:17
ttyS0 一般是 Linux的调试终端吧?
还有没有其他 /dev/ttyS* 设备?
如果没有,那么看下原理图和芯片手册, 在设备树里面把 其他串口开起来, 然后用串口测试软件确保自发自收(RX, TX短路)正常.
楼主 #7 2018-12-27 14:49:40
C-starm
这上面只有一个ttyS0,我把剩下的发出来,您看一下:
/dev/tty /dev/tty19 /dev/tty3 /dev/tty40 /dev/tty51 /dev/tty62
/dev/tty0 /dev/tty2 /dev/tty30 /dev/tty41 /dev/tty52 /dev/tty63
/dev/tty1 /dev/tty20 /dev/tty31 /dev/tty42 /dev/tty53 /dev/tty7
/dev/tty10 /dev/tty21 /dev/tty32 /dev/tty43 /dev/tty54 /dev/tty8
/dev/tty11 /dev/tty22 /dev/tty33 /dev/tty44 /dev/tty55 /dev/tty9
/dev/tty12 /dev/tty23 /dev/tty34 /dev/tty45 /dev/tty56 /dev/ttyAMA0
/dev/tty13 /dev/tty24 /dev/tty35 /dev/tty46 /dev/tty57 /dev/ttyprintk
/dev/tty14 /dev/tty25 /dev/tty36 /dev/tty47 /dev/tty58 /dev/ttyS0
/dev/tty15 /dev/tty26 /dev/tty37 /dev/tty48 /dev/tty59
/dev/tty16 /dev/tty27 /dev/tty38 /dev/tty49 /dev/tty6
/dev/tty17 /dev/tty28 /dev/tty39 /dev/tty5 /dev/tty60
/dev/tty18 /dev/tty29 /dev/tty4 /dev/tty50 /dev/tty61
#8 2018-12-27 14:52:53
那肯定是设备树没开了,谷歌搜索一下,树莓派资料挺多的
楼主 #9 2018-12-27 15:12:26
C-starm
那我去看一下,有问题再提问
楼主 #10 2019-01-15 22:03:16
C-starm
成功解决问题,解决方法,接5V电(慎行)
#11 2020-07-09 15:12:25
lun
学习学习
