楼主 #1 2020-07-11 10:40:09
myxiaonia
已发帖子: 82
f1c100s自带usb phy是全速吗
我们知道f1c100s自带usb phy,那么这个phy是全速的,还是高速的
#2 2020-07-11 11:06:46
有梦的地方
已发帖子: 284
Re: f1c100s自带usb phy是全速吗
full speed
#3 2020-07-11 12:12:41
zhjerry
已发帖子: 44
很懂英文的样子,问题和回答都很有形。
最近编辑记录 zhjerry (2020-07-11 12:14:22)
#4 2020-07-11 13:52:07
已发帖子: 645
高速的
#5 2020-07-11 17:41:45
EE道来
已发帖子: 35
zhjerry 说:
很懂英文的样子,问题和回答都很有形。
不说phy, 不说usb。 hi speed, full speed 都不让说。。。如果说“通用串行总线端口物理层”不绕口吗
#6 2020-07-15 17:01:42
cheung2019
应该是全速的,高速phy置入应该成本比较高,感觉速度也没有达到高速的指标把
#7 2020-07-15 22:18:34
村民
已发帖子: 43
The USB is a Dual-Role Device (DRD) controller, which supports both device and host functions
and is full compliant with the On-The-Go Supplement to the USB 2.0 Specification, Revision 1.0a.
It can also be configured as a Host-only or Device-only controller, full compliant with the USB 2.0
Specification. It can support high-speed (HS, 480-Mbps), full-speed (FS, 12-Mbps), and low-speed
(LS, 1.5-Mbps) transfers in Host mode. It can support high-speed (HS, 480-Mbps), and full-speed
(FS,  12-Mbps)  in  Device  mode
截一段f1c100的手册
