楼主 #1 2020-07-17 10:08:25
varzhou
已发帖子: 109
hello,各位挖坑大佬,请教一个V3S更换nand后出现系统配置分区不生效
平台:V3S + tina
修改sys_partition.fex文件后,系统启动后查看df和实际的配置不一致
###################我是分界线#############################
[partition_start]
[partition]
name         = bootlogo
size         = 3328
downloadfile = "bootlogo.fex"
user_type    = 0x8000
[partition]
    name         = boot-res
    size         = 512
    downloadfile = "boot-resource.fex"
    user_type    = 0x8000
[partition]
    name         = env
    size         = 512
    downloadfile = "env.fex"
    user_type    = 0x8000
[partition]
    name         = boot
    size         = 8192
    downloadfile = "boot.fex"
    user_type    = 0x8000
[partition]
    name         = rootfs
    size         = 81920
    downloadfile = "rootfs.fex"
    user_type    = 0x8000
[partition]
    name         = rootfs_data
    size         = 81920
    user_type    = 0x8000
[partition]
    name         = misc
    size         = 128
    user_type    = 0x8000
[partition]
    name         = private
    size         = 512
    user_type    = 0x8000
root@None:/# cat /proc/partitions
major minor  #blocks  name
  93        0        256 nanda
  93        8        256 nandb
  93       16       4096 nandc
  93       24      40960 nandd
  93       32      40960 nande
  93       40         64 nandf
  93       48        256 nandg
  93       56      25536 nandh
 179        0   15558144 mmcblk0
 179        1   15554048 mmcblk0p1
root@None:/# df
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/root                 2048      2048         0 100% /
devtmpfs                 11040         0     11040   0% /dev
tmpfs                    27936        20     27916   0% /tmp
楼主 #2 2020-07-20 19:44:40
varzhou
已发帖子: 109
Re: hello,各位挖坑大佬,请教一个V3S更换nand后出现系统配置分区不生效
仔细研究了一下,上层配置的分区参数从log来看是ok的。
-total partitions:9-
-name-        -start-       -size-
bootlogo    : 200000        1a0000
boot-res    : 3a0000        40000
env         : 3e0000        40000
boot        : 420000        400000
rootfs      : 820000        c800000
rootfs_data : d020000       c800000
misc        : 19820000      10000
private     : 19830000      40000
UDISK       : 19870000      0
set root to /dev/nande
[NE]parameter error 606976,4 !
disable nand error: FDT_ERR_BADPATH
## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
PowerBus = 2( 2:vBus 3:acBus other: not exist)
从这里来看,是uboot没有识别到nand。但是kernel是识别到了nand的各项参数。
===========================我是分界线==================================
总结:有点晕,kernel中以及识别成功了nand的各项参数,并且mbr也ok了。这里用的是tina的全志的nand静态库,很多东西都看不到,有没有可以移植到bsp的spinand可以替代???
[    2.453877] [NAND]nand probe
[    2.457131] kernel:nand version: 2 8 20190408 1958
[    2.466256] NAND_ReadPhyArch: get old physic arch ok, use old cfg, now:0x2 0x6d - old:0x2 0x6d!
[    2.506207] [NAND]nand0_cache_level is no used
[    2.511608] [NAND]nand_capacity_level is no used
[    2.520351] [NE]mbr read 12
[    2.524225] [NE]mbr read ok!
[    2.527441] [NE]mbr read end!
[    2.530850] [NE]mbr partition start!
[    2.535887] [NE]mbr partition ok!
[    2.539617] [NE]mbr partition end!
[    2.543395] [NE]new nand info init!!
[    2.547639] [NE]mbr read 12
[    2.551542] [NE]mbr read ok!
[    2.554755] [NE]mbr read end!
[    2.558048] [NE]get mbr_data table
[    2.562983] [ND]ok  get factory_bad_block table!
[    2.569284] [NE]new_bad_block table new format!
[    2.575129] [ND]ok get a new bad table!
[    2.580580] [ND]build all_phy partition start!
[    2.585528] [NE]mbr partition start!
[    2.590278] [NE]mbr partition ok!
[    2.593972] [NE]mbr partition end!
楼主 #3 2020-07-23 17:49:51
varzhou
已发帖子: 109
此贴结束:tina被索智使用软件模拟spi方式来驱动spi nand,而且提供给我们的是静态库,没得搞头
#4 2020-07-23 17:52:57
湘楚浪子
varzhou 说:
gpio模拟spi?感觉不可能
