rst:0x1 (POWERON_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:5536
ho 0 tail 12 room 4
load:0x40078000,len:0
load:0x40078000,len:13756
entry 0x40078fb4
I (30) boot: ESP-IDF v3.0-rc1-257-g489e98cf-dirty 2nd stage bootloader
I (30) boot: compile time 21:58:53
I (33) boot: Enabling RNG early entropy source...
I (36) boot: SPI Speed : 40MHz
I (40) boot: SPI Mode : DIO
I (44) boot: SPI Flash Size : 8MB
I (48) boot: Partition Table:
I (52) boot: ## Label Usage Type ST Offset Length
I (59) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (67) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (74) boot: 2 factory factory app 00 00 00010000 00100000
I (82) boot: End of partition table
I (86) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1d4c0 (120000) map
I (137) esp_image: segment 1: paddr=0x0002d4e8 vaddr=0x3ffb0000 size=0x02b28 ( 11048) load
I (141) esp_image: segment 2: paddr=0x00030018 vaddr=0x400d0018 size=0x7fe70 (523888) map
0x400d0018: _stext at ??:?I (327) esp_image: segment 3: paddr=0x000afe90 vaddr=0x3ffb2b28 size=0x006ec ( 1772) load
I (328) esp_image: segment 4: paddr=0x000b0584 vaddr=0x40080000 size=0x00400 ( 1024) load
0x40080000: _iram_start at C:/esp-adf/esp-idf/components/freertos/xtensa_vectors.S:1685I (334) esp_image: segment 5: paddr=0x000b098c vaddr=0x40080400 size=0x1282c ( 75820) load
I (374) esp_image: segment 6: paddr=0x000c31c0 vaddr=0x400c0000 size=0x00000 ( 0) load
I (385) boot: Loaded app from partition at offset 0x10000
I (385) boot: Disabling RNG early entropy source...
I (386) cpu_start: Pro cpu up.
I (389) cpu_start: Starting app cpu, entry point is 0x40080ff8
0x40080ff8: call_start_cpu1 at C:/esp-adf/esp-idf/components/esp32/cpu_start.c:215I (0) cpu_start: App cpu up.
I (400) heap_init: Initializing. RAM available for dynamic allocation:
I (407) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (413) heap_init: At 3FFB9568 len 00026A98 (154 KiB): DRAM
I (419) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (425) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (432) heap_init: At 40092C2C len 0000D3D4 (52 KiB): IRAM
I (438) cpu_start: Pro cpu start user code
I (120) cpu_start: Starting scheduler on PRO CPU.
I (0) cpu_start: Starting scheduler on APP CPU.
I (148) BAIDU_SPEECH_EXAMPLE: [ 0 ] Start and wait for Wi-Fi network
I (148) wifi: wifi firmware version: 7ff2a2a
I (148) wifi: config NVS flash: enabled
I (158) wifi: config nano formating: disabled
I (158) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUS
E
I (168) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUS
E
I (198) wifi: Init dynamic tx buffer num: 32
I (198) wifi: Init data frame dynamic rx buffer num: 32
I (198) wifi: Init management frame dynamic rx buffer num: 32
I (208) wifi: wifi driver task: 3ffc0d80, prio:23, stack:4096
I (208) wifi: Init static rx buffer num: 10
I (208) wifi: Init dynamic rx buffer num: 32
I (218) wifi: wifi power manager task: 0x3ffc59c0 prio: 21 stack: 2560
I (248) phy: phy_version: 366.0, ba9923d, Dec 29 2017, 14:25:06, 0, 0
I (248) wifi: mode : sta (30:ae:a4:46:ac:a8)
I (618) wifi: n:3 0, o:1 0, ap:255 255, sta:3 0, prof:1
I (1598) wifi: state: init -> auth (b0)
I (1598) wifi: state: auth -> assoc (0)
I (1608) wifi: state: assoc -> run (10)
I (1708) wifi: connected with lingtel.cn, channel 3
I (2608) event: sta ip: 192.168.9.124, mask: 255.255.255.0, gw: 192.168.9.1
I (2608) BAIDU_SPEECH_EXAMPLE: [ 1 ] Start audio codec chip
I (2618) ES8388_DRIVER: init,out:02, in:00
I (2628) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (2628) AUDIO_HAL: Codec mode is 2, Ctrl:1
I (2638) BAIDU_SPEECH_EXAMPLE: [2.0] Create audio pipeline for playback
I (2638) BAIDU_SPEECH_EXAMPLE: [2.1] Create http stream to read data
I (2648) BAIDU_SPEECH_EXAMPLE: [2.2] Create i2s stream to write data to codec chip
I (2658) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3
I (2668) I2S: APLL: Req RATE: 44100, real rate: 43945.016, BITS: 16, CLKM: 1, BCK: 8, MCLK: 1128
9966.924, SCLK: 1406240.500000, diva: 1, divb: 0
I (2678) BAIDU_SPEECH_EXAMPLE: [2.3] Create mp3 decoder to decode mp3 file
I (2688) BAIDU_SPEECH_EXAMPLE: [2.4] Register all elements to audio pipeline
I (2698) BAIDU_SPEECH_EXAMPLE: [2.5] Link it together http_stream-->mp3_decoder-->i2s_stream-->[
codec_chip]
I (2708) BAIDU_SPEECH_EXAMPLE: [2.6] Setup uri (http as http_stream, mp3 as mp3 decoder, and def
ault output is i2s)
I (2718) BAIDU_SPEECH_EXAMPLE: [ 4 ] Setup event listener
I (2728) BAIDU_SPEECH_EXAMPLE: [4.1] Listening event from all elements of pipeline
I (2738) BAIDU_SPEECH_EXAMPLE: [4.2] Listening event from peripherals
I (2738) BAIDU_SPEECH_EXAMPLE: [ 5 ] Start audio_pipeline
I (2748) AUDIO_ELEMENT: [http] Element task created
I (2748) AUDIO_ELEMENT: [mp3] Element task created
I (2758) AUDIO_ELEMENT: [i2s] Element task created
I (2758) AUDIO_PIPELINE: Func:audio_pipeline_run, Line:253, MEM Total:182768 BytesW (2768) AUDIO_ELEMENT: [http] RESUME:Element has not running,state:3,task_run:1
I (2778) AUDIO_ELEMENT: [http] AEL_MSG_CMD_RESUME,state:3
W (2798) AUDIO_ELEMENT: [mp3] RESUME:Element has not running,state:3,task_run:1
I (2798) AUDIO_ELEMENT: [mp3] AEL_MSG_CMD_RESUME,state:3
I (2798) MP3_DECODER: MP3 opened
W (2808) AUDIO_ELEMENT: [i2s] RESUME:Element has not running,state:3,task_run:1
I (2808) AUDIO_ELEMENT: [i2s] AEL_MSG_CMD_RESUME,state:3
I (2818) I2S_STREAM: AUDIO_STREAM_WRITER
I (2828) AUDIO_PIPELINE: Pipeline started
I (3658) I2S: APLL: Req RATE: 16000, real rate: 15999.022, BITS: 16, CLKM: 1, BCK: 8, MCLK: 4096
000.000, SCLK: 511968.718750, diva: 1, divb: 0
W (3658) AUDIO_ELEMENT: [i2s] RESUME:Element has not running,state:3,task_run:1
I (3668) AUDIO_ELEMENT: [i2s] AEL_MSG_CMD_RESUME,state:3
I (3668) I2S_STREAM: AUDIO_STREAM_WRITER
I (3818) BAIDU_AUTH: Access token=24.a4b6e6b604319fd37c097fae886a687f.2592000.1527689504.282335-11175544
I (4108) HTTP_STREAM: Content-Type = application/json
W (4108) HTTP_STREAM: No more data,errno:9
I (4108) AUDIO_ELEMENT: IN-[http] AEL_IO_DONE,0
I (4118) AUDIO_ELEMENT: IN-[mp3] AEL_IO_DONE,-2
Encountered error reading when MP3 init
E (4118) AUDIO_ELEMENT: [mp3] AEL_STATUS_ERROR_OPEN
I (4128) MP3_DECODER: Closed
E (4128) AUDIO_ELEMENT: [mp3] AEL_MSG_CMD_ERROR
W (4148) AUDIO_ELEMENT: IN-[i2s] AEL_IO_ABORT
W (4368) BAIDU_SPEECH_EXAMPLE: [ * ] Stop event received
I (4368) BAIDU_SPEECH_EXAMPLE: [ 6 ] Stop audio_pipeline
I (4368) AUDIO_PIPELINE: audio_pipeline_unlinked
I (4388) wifi: state: run -> init (0)
I (4388) wifi: n:3 0, o:3 0, ap:255 255, sta:3 0, prof:1
W (4388) PERIPH_WIFI: Wi-Fi disconnected from SSID lingtel.cn, auto-reconnect enabled, reconnect after 5000 ms
I (4398) wifi: flush txq
I (4398) wifi: stop sw txq
I (4398) wifi: lmac stop hw txq
I (4398) wifi: Deinit lldesc rx mblock:10
E (9398) wifi: esp_wifi_connect 858 wifi is not init
https://github.com/espressif/esp-adf/tree/master/examples/cloud_services/pipeline_baidu_speech_mp3
创建应用的界面 好像和你的不一样喔, 你第三步 有 确定的按钮, 但是现在的没有确定 按钮,直接是下一步下一步~~~还要选择平台~~~~
esp32下载完 pipeline_baidu_speech_mp3 的程序,最后运行起来 还这样~~~ 我觉得应该 是wifi 设置连接不上的问题吧!!!
load:0x3fff001c,len:5604
entry 0x40078fb4
I (28) boot: ESP-IDF v3.0-rc1-257-g489e98cf 2nd stage bootloader
I (28) boot: compile time 13:43:47
I (34) boot: Enabling RNG early entropy source...
I (34) boot: SPI Speed : 40MHz
I (38) boot: SPI Mode : DIO
I (42) boot: SPI Flash Size : 8MB
I (46) boot: Partition Table:
I (50) boot: ## Label Usage Type ST Offset Length
I (57) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (64) boot: 1 phy_init RF data 01 01 0000f000 00001000
I (72) boot: 2 factory factory app 00 00 00010000 00100000
I (79) boot: End of partition table
I (83) esp_image: segment 0: paddr=0x00010020 vaddr=0x3f400020 size=0x1dcec (122
092) map
I (135) esp_image: segment 1: paddr=0x0002dd14 vaddr=0x3ffb0000 size=0x022fc (
8956) load
I (139) esp_image: segment 2: paddr=0x00030018 vaddr=0x400d0018 size=0x7fe70 (52
3888) map
I (325) esp_image: segment 3: paddr=0x000afe90 vaddr=0x3ffb22fc size=0x00f64 (
3940) load
I (327) esp_image: segment 4: paddr=0x000b0dfc vaddr=0x40080000 size=0x00400 (
1024) load
0x40080000: _iram_start at F:/msys32/home/11022259/esp/esp-adf/esp-idf/component
I (332) esp_image: segment 5: paddr=0x000b1204 vaddr=0x40080400 size=0x1282c ( 7
5820) load
I (372) esp_image: segment 6: paddr=0x000c3a38 vaddr=0x400c0000 size=0x00000 (
0) load
I (384) boot: Loaded app from partition at offset 0x10000
I (384) boot: Disabling RNG early entropy source...
I (384) cpu_start: Pro cpu up.
I (388) cpu_start: Starting app cpu, entry point is 0x40080ff8
0x40080ff8: call_start_cpu1 at F:/msys32/home/11022259/esp/esp-adf/esp-idf/compo
I (398) heap_init: Initializing. RAM available for dynamic allocation:
I (405) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (411) heap_init: At 3FFB95B0 len 00026A50 (154 KiB): DRAM
I (417) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (424) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (430) heap_init: At 40092C2C len 0000D3D4 (52 KiB): IRAM
I (436) cpu_start: Pro cpu start user code
I (119) cpu_start: Starting scheduler on PRO CPU.
I (182) BAIDU_SPEECH_EXAMPLE: [ 0 ] Start and wait for Wi-Fi network
I (182) wifi: wifi firmware version: 7ff2a2a
I (182) wifi: config NVS flash: enabled
I (182) wifi: config nano formating: disabled
I (192) system_api: Base MAC address is not set, read default base MAC address f
rom BLK0 of EFUSE
rom BLK0 of EFUSE
I (232) wifi: Init dynamic tx buffer num: 32
I (232) wifi: Init data frame dynamic rx buffer num: 32
I (232) wifi: Init management frame dynamic rx buffer num: 32
I (232) wifi: wifi driver task: 3ffc0ec8, prio:23, stack:4096
I (242) wifi: Init static rx buffer num: 10
I (242) wifi: Init dynamic rx buffer num: 32
I (252) wifi: wifi power manager task: 0x3ffc5b08 prio: 21 stack: 2560
I (322) phy: phy_version: 366.0, ba9923d, Dec 29 2017, 14:25:06, 0, 0
I (322) wifi: mode : sta (30:ae:a4:45:e6:b4)
I (562) wifi: n:2 0, o:1 0, ap:255 255, sta:2 0, prof:1
I (1542) wifi: state: init -> auth (b0)
I (1552) wifi: state: auth -> assoc (0)
I (1562) wifi: state: assoc -> run (10)
I (1592) wifi: connected with ASUS_2.4, channel 2
I (4562) wifi: pm start, type:0
I (5622) event: sta ip: 192.168.50.7, mask: 255.255.255.0, gw: 192.168.50.1
I (5622) BAIDU_SPEECH_EXAMPLE: [ 1 ] Start audio codec chip
I (5632) ES8388_DRIVER: init,out:02, in:00
I (5642) gpio: GPIO[21]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulld
own: 0| Intr:0
I (5642) AUDIO_HAL: Codec mode is 2, Ctrl:1
I (5652) BAIDU_SPEECH_EXAMPLE: [2.0] Create audio pipeline for playback
I (5652) BAIDU_SPEECH_EXAMPLE: [2.1] Create http stream to read data
I (5662) BAIDU_SPEECH_EXAMPLE: [2.2] Create i2s stream to write data to codec ch
ip
I (5672) I2S: DMA Malloc info, datalen=blocksize=1200, dma_buf_count=3
I (5682) I2S: APLL: Req RATE: 44100, real rate: 43945.016, BITS: 16, CLKM: 1, BC
K: 8, MCLK: 11289966.924, SCLK: 1406240.500000, diva: 1, divb: 0
I (5692) BAIDU_SPEECH_EXAMPLE: [2.3] Create mp3 decoder to decode mp3 file
I (5702) BAIDU_SPEECH_EXAMPLE: [2.4] Register all elements to audio pipeline
I (5712) BAIDU_SPEECH_EXAMPLE: [2.5] Link it together http_stream-->mp3_decoder-
->i2s_stream-->[codec_chip]
I (5722) BAIDU_SPEECH_EXAMPLE: [2.6] Setup uri (http as http_stream, mp3 as mp3
decoder, and default output is i2s)
I (5732) BAIDU_SPEECH_EXAMPLE: [ 4 ] Setup event listener
I (5742) BAIDU_SPEECH_EXAMPLE: [4.1] Listening event from all elements of pipeli
ne
I (5742) BAIDU_SPEECH_EXAMPLE: [4.2] Listening event from peripherals
I (5752) BAIDU_SPEECH_EXAMPLE: [ 5 ] Start audio_pipeline
I (5762) AUDIO_ELEMENT: [http] Element task created
I (5762) AUDIO_ELEMENT: [mp3] Element task created
I (5772) AUDIO_ELEMENT: [i2s] Element task created
I (5772) AUDIO_PIPELINE: audio_pipeline_run,253,MEM,Total:182448
W (5782) AUDIO_ELEMENT: [http] RESUME:Element has not running,state:3,task_run:1
I (5792) AUDIO_ELEMENT: [http] AEL_MSG_CMD_RESUME,state:3
W (5802) AUDIO_ELEMENT: [mp3] RESUME:Element has not running,state:3,task_run:1
I (5802) AUDIO_ELEMENT: [mp3] AEL_MSG_CMD_RESUME,state:3
I (5812) MP3_DECODER: MP3 opened
W (5812) AUDIO_ELEMENT: [i2s] RESUME:Element has not running,state:3,task_run:1
I (5822) AUDIO_ELEMENT: [i2s] AEL_MSG_CMD_RESUME,state:3
I (5832) I2S_STREAM: AUDIO_STREAM_WRITER
I (5832) AUDIO_PIPELINE: Pipeline started
I (5872) I2S: APLL: Req RATE: 16000, real rate: 15999.022, BITS: 16, CLKM: 1, BC
K: 8, MCLK: 4096000.000, SCLK: 511968.718750, diva: 1, divb: 0
W (5872) AUDIO_ELEMENT: [i2s] RESUME:Element has not running,state:3,task_run:1
I (5882) AUDIO_ELEMENT: [i2s] AEL_MSG_CMD_RESUME,state:3
I (5882) I2S_STREAM: AUDIO_STREAM_WRITER
E (9342) BAIDU_SPEECH_EXAMPLE: Error issuing access token
E (9342) HTTP_STREAM: Failed to process user callback
E (9342) AUDIO_ELEMENT: [http] AEL_STATUS_ERROR_OPEN
W (9352) AUDIO_ELEMENT: IN-[mp3] AEL_IO_ABORT
E (9362) AUDIO_ELEMENT: [http] AEL_MSG_CMD_ERROR
E (9362) AUDIO_ELEMENT: [mp3] AEL_STATUS_ERROR_OPEN
I (9362) MP3_DECODER: Closed
E (9372) AUDIO_ELEMENT: [mp3] AEL_MSG_CMD_ERROR
I (9392) AUDIO_ELEMENT: IN-[i2s] AEL_IO_DONE,-2
W (9622) BAIDU_SPEECH_EXAMPLE: [ * ] Stop event received
I (9622) BAIDU_SPEECH_EXAMPLE: [ 6 ] Stop audio_pipeline
I (9622) AUDIO_PIPELINE: audio_pipeline_unlinked
I (9632) wifi: state: run -> init (0)
I (9632) wifi: pm stop, total sleep time: 0/5069325
I (9632) wifi: n:2 0, o:2 0, ap:255 255, sta:2 0, prof:1
W (9642) PERIPH_WIFI: Wi-Fi disconnected from SSID ASUS_2.4, auto-reconnect enab
led, reconnect after 1000 ms
I (9652) wifi: flush txq
I (9652) wifi: stop sw txq
I (9652) wifi: lmac stop hw txq
I (9662) wifi: Deinit lldesc rx mblock:10
E (10652) wifi: esp_wifi_connect 858 wifi is not init
I (128842) event: station ip lost 离线
@ 晕哥!!!
创建应用 如下图所示
ps:论坛贴个图片 好绕啊, 上传 然后再复制地址 加img ~~~~
看下log:
I (4562) wifi: pm start, type:0I (5622) event: sta ip: 192.168.50.7, mask: 255.255.255.0, gw: 192.168.50.1
wifi连接没有问题,
确认耳机有没有问题?
感觉应该播放语音了。
发图那个问题我得想想怎样才能方便解决。
看下log:
...wifi连接没有问题,
确认耳机有没有问题?
感觉应该播放语音了。发图那个问题我得想想怎样才能方便解决。
E (10872) BAIDU_SPEECH_EXAMPLE: Error issuing access token
E (10872) HTTP_STREAM: Failed to process user callback
E (10872) AUDIO_ELEMENT: [http] AEL_STATUS_ERROR_OPEN
W (10882) AUDIO_ELEMENT: IN-[mp3] AEL_IO_ABORT
E (10882) AUDIO_ELEMENT: [http] AEL_MSG_CMD_ERROR
E (10892) AUDIO_ELEMENT: [mp3] AEL_STATUS_ERROR_OPEN
I (10902) MP3_DECODER: Closed
E (10902) AUDIO_ELEMENT: [mp3] AEL_MSG_CMD_ERROR
I (10922) AUDIO_ELEMENT: IN-[i2s] AEL_IO_DONE,-2
W (11152) BAIDU_SPEECH_EXAMPLE: [ * ] Stop event received
I (11152) BAIDU_SPEECH_EXAMPLE: [ 6 ] Stop audio_pipeline
I (11152) AUDIO_PIPELINE: audio_pipeline_unlinked
I (11162) wifi: state: run -> init (0)
I (11162) wifi: pm stop, total sleep time: 0/6607872
...应该还是wifi 连 接 的问题, 我试过play_mp3 的例子 是可以播放音乐的~~~
这个例子 的readme 太简短了 都不清楚 配置好wifi SSID 和相关 秘钥之后 要做些啥~~~~ 直接说请参考百度云~~~
百度云 又是云里雾里的 ~~~
还是晕哥牛!!!!
另外这个插图的事 你也有办法解决? 网站是你建立维护的??? 太厉害了~~~
这个语音合成的demo 我弄成功了,
但是log没有贴出,
我回去帮你把log 贴出来,
然后你对比一下看是什么问题.
我感觉你那个问题应该不大,
接近真相了。
