楼主 #1 2020-08-07 15:31:27
明月照我沟渠
已发帖子: 121
分享 littlevgl 检测 编辑器/编译器 是否支持utf-8编码的小技巧
代码: https://github.com/lvgl/lvgl/blob/master/src/lv_core/lv_obj.c
    /*Test if the IDE has UTF-8 encoding*/
    char * txt = "Á";
    uint8_t * txt_u8 = (uint8_t *) txt;
    if(txt_u8[0] != 0xc3 || txt_u8[1] != 0x81 || txt_u8[2] != 0x00) {
        LV_LOG_WARN("The strings has no UTF-8 encoding. Some characters won't be displayed.")
