楼主 #1 2020-08-25 22:11:59
tang6397
已发帖子: 95
<starting USB No controllers found>介决办法
1. f1c100s linux bsp 到licheepi nano logo 信息显示 <starting USB No controllers found>介决办法
2. git clone https://github.com/Icenowy/u-boot.git -b f1c100s-spiflash  加快下载速度办法
#2 2020-08-25 22:20:20
起个名字好难
Re: <starting USB No controllers found>介决办法
git clone https://hub.fastgit.org/Icenowy/u-boot.git
楼主 #3 2020-08-26 09:45:04
tang6397
已发帖子: 95
sudo sunxi-fel -p spiflash-write 0  u-boot-spi-flash.bin
sudo sunxi-fel -p spiflash-write 0x100000 zImage
sudo sunxi-fel -p spiflash-write 0x350000 suniv-f1c100s-licheepi-nano.dtb
sudo sunxi-fel -p spiflash-write 0x400000 rootfs.cpio.gz
楼主 #4 2020-08-26 09:54:41
tang6397
已发帖子: 95
[09:54:05.440]ÊÕ¡û¡ô
U-Boot SPL 2018.01-05676-g00188782ee-dirty (May 19 2018 - 15:47:49)
DRAM: 64 MiB
SPL: Unsupported Boot Device!
Trying to boot from sunxi SPI
[09:54:05.944]ÊÕ¡û¡ô
U-Boot 2018.01-05676-g00188782ee-dirty (May 19 2018 - 15:47:49 +0800) Allwinner Technology
CPU:   Allwinner F Series (SUNIV)
Model: Lichee Pi Nano
DRAM:  64 MiB
[09:54:06.476]ÊÕ¡û¡ôUsing default environment
[09:54:06.576]ÊÕ¡û¡ôIn:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
Hit any key to stop autoboot:  2
[09:54:07.595]ÊÕ¡û¡ô 1
[09:54:08.596]ÊÕ¡û¡ô 0
SF: Detected w25q128bv with page size 256 Bytes, erase size 64 KiB, total 16 MiB
[09:54:10.405]ÊÕ¡û¡ôSF: 4194304 bytes @ 0x110000 Read: OK
楼主 #5 2020-08-26 20:22:28
tang6397
已发帖子: 95
#6 2020-08-26 22:03:43
awfans
已发帖子: 264
tang6397 说:
ARCH=arm make menuconfig
把USB选项都关了就行.
