楼主 #1 2019-11-24 16:38:28
init
请教 debian 的 ps 命令如何显示完整的命令行?
root@SmallWit:~# ps -Af
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 08:00 ?        00:00:03 /sbin/init earlyprintk
root         2     0  0 08:00 ?        00:00:00 [kthreadd]
root         3     2  0 08:00 ?        00:00:00 [kworker/0:0]
root         4     2  0 08:00 ?        00:00:00 [kworker/0:0H]
root         6     2  0 08:00 ?        00:00:00 [mm_percpu_wq]
root         7     2  0 08:00 ?        00:00:00 [ksoftirqd/0]
root         8     2  0 08:00 ?        00:00:00 [rcu_sched]
root         9     2  0 08:00 ?        00:00:00 [rcu_bh]
root        10     2  0 08:00 ?        00:00:00 [migration/0]
root        11     2  0 08:00 ?        00:00:00 [cpuhp/0]
root        12     2  0 08:00 ?        00:00:00 [kdevtmpfs]
root        13     2  0 08:00 ?        00:00:00 [netns]
root        14     2  0 08:00 ?        00:00:00 [oom_reaper]
root        15     2  0 08:00 ?        00:00:00 [writeback]
root        16     2  0 08:00 ?        00:00:00 [kcompactd0]
root        17     2  0 08:00 ?        00:00:00 [crypto]
root        18     2  0 08:00 ?        00:00:00 [kblockd]
root        19     2  0 08:00 ?        00:00:00 [cfg80211]
root        20     2  0 08:00 ?        00:00:00 [kworker/0:1]
root        21     2  0 08:00 ?        00:00:00 [watchdogd]
root        22     2  0 08:00 ?        00:00:00 [rpciod]
root        23     2  0 08:00 ?        00:00:00 [xprtiod]
root        24     2  0 08:00 ?        00:00:00 [kswapd0]
root        25     2  0 08:00 ?        00:00:00 [nfsiod]
root        50     2  0 08:00 ?        00:00:00 [irq/47-ft6236]
root        51     2  0 08:00 ?        00:00:00 [irq/23-sunxi-mm]
root        52     2  0 08:00 ?        00:00:00 [irq/24-sunxi-mm]
root        57     2  0 08:00 ?        00:00:01 [mmcqd/0]
root        58     2  0 08:00 ?        00:00:00 [kworker/0:1H]
root        59     2  0 08:00 ?        00:00:00 [jbd2/mmcblk0p2-]
root        60     2  0 08:00 ?        00:00:00 [ext4-rsv-conver]
root        72     2  0 08:00 ?        00:00:00 [kworker/u2:1]
root        79     1  0 08:00 ?        00:00:00 /lib/systemd/systemd-journald
root        92     1  0 08:00 ?        00:00:00 /lib/systemd/systemd-udevd
root       114     2  0 08:00 ?        00:00:00 [brcmf_wq/mmc1:0]
root       115     2  0 08:00 ?        00:00:00 [brcmf_wdog/mmc1]
root       124     2  0 08:00 ?        00:00:00 [ksdioirqd/mmc1]
root       229     1  0 08:00 ?        00:00:00 /usr/sbin/sshd -D
root       230     1  0 08:00 ?        00:00:00 /usr/sbin/NetworkManager --no-da
root       232     1  0 08:00 ?        00:00:00 /usr/sbin/ModemManager
root       236     1  0 08:00 ?        00:00:00 /usr/sbin/cron -f
root       238     1  0 08:00 ?        00:00:00 /lib/systemd/systemd-logind
message+   240     1  0 08:00 ?        00:00:00 /usr/bin/dbus-daemon --system --
root       249     1  0 08:00 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
root       251     1  0 08:00 tty1     00:00:00 /sbin/agetty --noclear tty1 linu
root       254     1  0 08:00 ttyS0    00:00:00 /bin/login --
root       257     1  0 08:00 ?        00:00:00 /usr/sbin/lightdm
root       268   257  0 08:00 tty7     00:00:01 /usr/bin/X :0 -seat seat0 -auth
root       275     1  0 08:00 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /r
root       282   257  0 08:00 ?        00:00:00 lightdm --session-child 13 16
root       290     1  0 08:00 ?        00:00:00 /lib/systemd/systemd --user
root       293   290  0 08:00 ?        00:00:00 (sd-pam)
root       296   282  0 08:00 ?        00:00:00 /usr/bin/lxsession -s LXDE -e LX
root       311   296  0 08:00 ?        00:00:00 /usr/bin/ssh-agent x-session-man
root       320   296  0 08:00 ?        00:00:00 openbox --config-file /root/.con
root       323   296  0 08:00 ?        00:00:00 lxpolkit
root       325   296  0 08:00 ?        00:00:01 lxpanel --profile LXDE
root       326   296  0 08:00 ?        00:00:03 pcmanfm --desktop --profile LXDE
root       331     1  0 08:00 ?        00:00:00 /usr/bin/ssh-agent -s
root       340     1  0 08:00 ?        00:00:00 /usr/lib/menu-cache/menu-cached
root       352   254  0 08:00 ttyS0    00:00:00 -bash
root       358     2  0 08:06 ?        00:00:00 [kworker/u2:0]
root       365     2  0 08:08 ?        00:00:00 [kworker/0:2]
root       374     2  0 08:11 ?        00:00:00 [kworker/u2:2]
root       384   352  0 08:13 ttyS0    00:00:00 ps -Af
我用 ps -Af 有一半显示不出来.
楼主 #2 2019-11-24 16:43:22
init
Re: 请教 debian 的 ps 命令如何显示完整的命令行?
终于找到一个方法了, 先找到 pid, 然后 cat /proc/<pid>/cmdline
root@SmallWit:~# ps -Af |grep wpa
root       275     1  0 08:00 ?        00:00:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
root       406   352  0 08:24 ttyS0    00:00:00 grep wpa
root@SmallWit:~# cat /proc/275/cmdline
/sbin/wpa_supplicant-u-s-O/run/wpa_supplicant
root@SmallWit:~#
root@SmallWit:~#
这里: https://stackoverflow.com/questions/821837/how-to-get-the-command-line-args-passed-to-a-running-process-on-unix-linux-syste
楼主 #3 2019-11-24 16:46:23
init
奇怪了, 上面的命令行参数居然没有空格.
楼主 #4 2019-11-24 16:47:33
init
还是前面那个参考链接:
You can simply use:
ps -o args= -f -p ProcessPid
然后我再试了一下, 这次正常了.
root@SmallWit:~# ps -o args= -f -p 275
#5 2020-09-04 14:26:12
didi
ps显示不全,2楼方法正解。
