各位坑友好,最近折腾V3S的板子,要上一块4.3寸,分辨率480x272的触摸屏,型号为KD043WQTPA035-01,控制IC:ST7282,RGB接口,文档上的timing参数如下:
请问如何设置以下参数呢?(下面的是我设置的其中一套参数,但是会出现花屏的现象)
;lcd0 configuration
;lcd_if: 0:hv(sync+de); 1:8080; 2:ttl; 3:lvds; 4:dsi; 5:edp; 6:extend dsi
;lcd_x: lcd horizontal resolution
;lcd_y: lcd vertical resolution
;lcd_width: width of lcd in mm
;lcd_height: height of lcd in mm
;lcd_dclk_freq: in MHZ unit
;lcd_pwm_freq: in HZ unit
;lcd_pwm_pol: lcd backlight PWM polarity
;lcd_pwm_max_limit lcd backlight PWM max limit(<=255)
;lcd_hbp: hsync back porch
;lcd_ht: hsync total cycle
;lcd_vbp: vsync back porch
;lcd_vt: vysnc total cycle
;lcd_hspw: hsync plus width
;lcd_vspw: vysnc plus width
;lcd_lvds_if: 0:single link; 1:dual link
;lcd_lvds_colordepth: 0:8bit; 1:6bit
;lcd_lvds_mode: 0:NS mode; 1:JEIDA mode
;lcd_frm: 0:disable; 1:enable rgb666 dither; 2:enable rgb656 dither
;lcd_io_phase: 0:noraml; 1:intert phase(0~3bit: vsync phase; 4~7bit:hsync phase;
; 8~11bit:dclk phase; 12~15bit:de phase)
;lcd_gamma_en lcd gamma correction enable
;lcd_bright_curve_en lcd bright curve correction enable
;lcd_cmap_en lcd color map function enable
;deu_mode 0:smoll lcd screen; 1:large lcd screen(larger than 10inch)
;lcdgamma4iep: Smart Backlight parameter, lcd gamma vale * 10;
; decrease it while lcd is not bright enough; increase while lcd is too bright
;smart_color 90:normal lcd screen 65:retina lcd screen(9.7inch)
[lcd0_para]
lcd_used = 1
lcd_driver_name = "vs043con08v0"
lcd_if = 0
lcd_x = 480
lcd_y = 272
lcd_width = 0
lcd_height = 0
lcd_dclk_freq = 9
lcd_pwm_used = 1
lcd_pwm_ch = 0
lcd_pwm_freq = 50000
lcd_pwm_pol = 1
lcd_pwm_max_limit = 255
lcd_hbp = 2
lcd_ht = 525
lcd_hspw = 41
lcd_vbp = 2
lcd_vt = 286
lcd_vspw = 2
lcd_frm = 0
lcd_hv_clk_phase = 0
lcd_hv_sync_polarity = 0
lcd_gamma_en = 0
lcd_bright_curve_en = 1
lcd_cmap_en = 0
lcdgamma4iep = 22花屏实拍:
请坑友门帮我看看应该怎样设置正确的参数,或者推荐一款好用的屏也是极好的,谢谢!:)
检查连接线问题, 是不是很长?有多长?
检查连接线问题, 是不是很长?有多长?
并不长,就是用的屏自带的排线。也不应该是板子的问题,有朋友同样板子接5寸的电容屏是OK的。
检查一下焊接,看有无短路断路,再不行de引脚中间串一个电阻,电阻值大小都调一下。
感谢各位坑友。可能是板子焊接的问题,我又换了一个上古时代的荔枝派zero,用的https://whycan.com/t_3400.html第20楼的固件,发现屏能跑起来,除了分辨率不对(固件是800x480的),屏背光有点闪,触摸没有以外都还挺好,请问分辨率在哪里改呢?
dtb内容如下:
/dts-v1/;
#address-cells = <0x1>;
#size-cells = <0x1>;
interrupt-parent = <0x1>;
model = "Lichee Pi Zero with Dock";
compatible = "licheepi,licheepi-zero-dock", "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
chosen {
ranges;
framebuffer@0 {
compatible = "allwinner,simple-framebuffer", "simple-framebuffer";
allwinner,pipeline = "de0-lcd0";
clocks = <0x2 0x21 0x3 0x0 0x3 0x6 0x2 0x40>;
status = "disabled";
cpus {
#size-cells = <0x0>;
cpu@0 {
compatible = "arm,cortex-a7";
device_type = "cpu";
reg = <0x0>;
clocks = <0x2 0xe>;
display-engine {
compatible = "allwinner,sun8i-v3s-display-engine";
allwinner,pipelines = <0x4>;
timer {
compatible = "arm,armv7-timer";
interrupts = <0x1 0xd 0xf08 0x1 0xe 0xf08 0x1 0xb 0xf08 0x1 0xa 0xf08>;
clocks {
ranges;
osc24M_clk {
#clock-cells = <0x0>;
compatible = "fixed-clock";
clock-frequency = <0x16e3600>;
linux,phandle = <0xc>;
phandle = <0xc>;
osc32k_clk {
clock-frequency = <0x8000>;
linux,phandle = <0xd>;
phandle = <0xd>;
soc {
compatible = "simple-bus";
ranges;
clock@1000000 {
compatible = "allwinner,sun8i-v3s-de2-clk";
reg = <0x1000000 0x100000>;
clocks = <0x2 0x3f 0x2 0x23>;
clock-names = "mod", "bus";
resets = <0x2 0x22>;
#clock-cells = <0x1>;
#reset-cells = <0x1>;
linux,phandle = <0x3>;
phandle = <0x3>;
mixer@1100000 {
compatible = "allwinner,sun8i-v3s-de2-mixer";
reg = <0x1100000 0x100000>;
clocks = <0x3 0x0 0x3 0x6>;
clock-names = "bus", "mod";
resets = <0x3 0x0>;
assigned-clocks = <0x3 0x6>;
assigned-clock-rates = <0x8f0d180>;
linux,phandle = <0x4>;
phandle = <0x4>;
ports {
port@1 {
reg = <0x1>;
endpoint@0 {
reg = <0x0>;
remote-endpoint = <0x5>;
linux,phandle = <0x6>;
phandle = <0x6>;
syscon@1c00000 {
compatible = "allwinner,sun8i-v3s-system-controller", "syscon";
reg = <0x1c00000 0x1000>;
linux,phandle = <0x16>;
phandle = <0x16>;
lcd-controller@1c0c000 {
compatible = "allwinner,sun8i-v3s-tcon";
reg = <0x1c0c000 0x1000>;
interrupts = <0x0 0x56 0x4>;
clocks = <0x2 0x21 0x2 0x40>;
clock-names = "ahb", "tcon-ch0";
clock-output-names = "tcon-pixel-clock";
resets = <0x2 0x1b>;
reset-names = "lcd";
ports {
port@0 {
reg = <0x0>;
endpoint@0 {
reg = <0x0>;
remote-endpoint = <0x6>;
linux,phandle = <0x5>;
phandle = <0x5>;
port@1 {
reg = <0x1>;
dma-controller@01c02000 {
compatible = "allwinner,sun8i-v3s-dma";
reg = <0x1c02000 0x1000>;
interrupts = <0x0 0x32 0x4>;
clocks = <0x2 0x15>;
resets = <0x2 0x6>;
#dma-cells = <0x1>;
linux,phandle = <0x10>;
phandle = <0x10>;
mmc@01c0f000 {
compatible = "allwinner,sun7i-a20-mmc";
reg = <0x1c0f000 0x1000>;
clocks = <0x2 0x16 0x2 0x2d 0x2 0x2f 0x2 0x2e>;
clock-names = "ahb", "mmc", "output", "sample";
resets = <0x2 0x7>;
reset-names = "ahb";
interrupts = <0x0 0x3c 0x4>;
pinctrl-0 = <0x7>;
pinctrl-names = "default";
broken-cd;
bus-width = <0x4>;
vmmc-supply = <0x8>;
mmc@01c10000 {
reg = <0x1c10000 0x1000>;
clocks = <0x2 0x17 0x2 0x30 0x2 0x32 0x2 0x31>;
resets = <0x2 0x8>;
interrupts = <0x0 0x3d 0x4>;
pinctrl-0 = <0x9>;
broken-cd;
bus-width = <0x4>;
mmc@01c11000 {
reg = <0x1c11000 0x1000>;
clocks = <0x2 0x18 0x2 0x33 0x2 0x35 0x2 0x34>;
resets = <0x2 0x9>;
interrupts = <0x0 0x3e 0x4>;
usb@01c19000 {
compatible = "allwinner,sun8i-h3-musb";
reg = <0x1c19000 0x400>;
clocks = <0x2 0x1d>;
resets = <0x2 0x11>;
interrupts = <0x0 0x47 0x4>;
interrupt-names = "mc";
phys = <0xa 0x0>;
phy-names = "usb";
extcon = <0xa 0x0>;
dr_mode = "otg";
phy@01c19400 {
compatible = "allwinner,sun8i-v3s-usb-phy";
reg = <0x1c19400 0x2c 0x1c1a800 0x4>;
reg-names = "phy_ctrl", "pmu0";
clocks = <0x2 0x38>;
clock-names = "usb0_phy";
resets = <0x2 0x0>;
reset-names = "usb0_reset";
#phy-cells = <0x1>;
usb0_id_det-gpio = <0xb 0x5 0x6 0x0>;
linux,phandle = <0xa>;
phandle = <0xa>;
usb@01c1a000 {
compatible = "allwinner,sun8i-v3s-ehci", "generic-ehci";
reg = <0x1c1a000 0x100>;
interrupts = <0x0 0x48 0x4>;
clocks = <0x2 0x1e 0x2 0x1f>;
resets = <0x2 0x12 0x2 0x16>;
usb@01c1a400 {
compatible = "allwinner,sun8i-v3s-ohci", "generic-ohci";
reg = <0x1c1a400 0x100>;
interrupts = <0x0 0x49 0x4>;
clocks = <0x2 0x1e 0x2 0x1f 0x2 0x39>;
clock@01c20000 {
compatible = "allwinner,sun8i-v3s-ccu";
reg = <0x1c20000 0x400>;
clocks = <0xc 0xd>;
clock-names = "hosc", "losc";
linux,phandle = <0x2>;
phandle = <0x2>;
rtc@01c20400 {
compatible = "allwinner,sun6i-a31-rtc";
reg = <0x1c20400 0x54>;
interrupts = <0x0 0x28 0x4 0x0 0x29 0x4>;
pinctrl@01c20800 {
compatible = "allwinner,sun8i-v3s-pinctrl";
reg = <0x1c20800 0x400>;
interrupts = <0x0 0xf 0x4 0x0 0x11 0x4>;
clocks = <0x2 0x25 0xc 0xd>;
gpio-controller;
#gpio-cells = <0x3>;
interrupt-controller;
#interrupt-cells = <0x3>;
linux,phandle = <0xb>;
phandle = <0xb>;
i2c0 {
pins = "PB6", "PB7";
function = "i2c0";
linux,phandle = <0x15>;
phandle = <0x15>;
uart0@0 {
pins = "PB8", "PB9";
function = "uart0";
linux,phandle = <0x12>;
phandle = <0x12>;
uart1@0 {
pins = "PE21", "PE22";
function = "uart1";
linux,phandle = <0x13>;
phandle = <0x13>;
uart2@0 {
pins = "PB0", "PB1";
function = "uart2";
linux,phandle = <0x14>;
phandle = <0x14>;
lcd-rgb666-pe {
pins = "PE0", "PE1", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11", "PE12", "PE13", "PE14", "PE15", "PE16", "PE17", "PE18", "PE19", "PE23", "PE24";
function = "lcd0";
mmc0@0 {
pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
function = "mmc0";
drive-strength = <0x1e>;
bias-pull-up;
linux,phandle = <0x7>;
phandle = <0x7>;
mmc1 {
pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5";
function = "mmc1";
bias-pull-up;
linux,phandle = <0x9>;
phandle = <0x9>;
spi0 {
function = "spi0";
linux,phandle = <0x18>;
phandle = <0x18>;
pwm0 {
pins = "PB4";
function = "pwm0";
linux,phandle = <0xe>;
phandle = <0xe>;
pwm1 {
pins = "PB5";
function = "pwm1";
timer@01c20c00 {
compatible = "allwinner,sun4i-a10-timer";
reg = <0x1c20c00 0xa0>;
interrupts = <0x0 0x12 0x4 0x0 0x13 0x4>;
clocks = <0xc>;
watchdog@01c20ca0 {
reg = <0x1c20ca0 0x20>;
interrupts = <0x0 0x19 0x4>;
pwm@1c21400 {
compatible = "allwinner,sun8i-v3s-pwm", "allwinner,sun7i-a20-pwm";
reg = <0x1c21400 0x400>;
clocks = <0xc>;
#pwm-cells = <0x3>;
pinctrl-0 = <0xe>;
linux,phandle = <0x19>;
phandle = <0x19>;
lradc@1c22800 {
compatible = "allwinner,sun4i-a10-lradc-keys";
reg = <0x1c22800 0x400>;
interrupts = <0x0 0x1e 0x4>;
vref-supply = <0xf>;
button@200 {
label = "Volume Up";
linux,code = <0x73>;
channel = <0x0>;
voltage = <0x30d40>;
button@400 {
label = "Volume Down";
linux,code = <0x72>;
channel = <0x0>;
voltage = <0x61a80>;
button@600 {
label = "Select";
linux,code = <0x161>;
channel = <0x0>;
voltage = <0x927c0>;
button@800 {
label = "Start";
linux,code = <0x160>;
channel = <0x0>;
voltage = <0xc3500>;
codec@01c22c00 {
#sound-dai-cells = <0x0>;
compatible = "allwinner,sun8i-v3s-codec";
reg = <0x1c22c00 0x400>;
interrupts = <0x0 0x1d 0x4>;
clocks = <0x2 0x24 0x2 0x46>;
clock-names = "apb", "codec";
resets = <0x2 0x28>;
dmas = <0x10 0xf 0x10 0xf>;
dma-names = "rx", "tx";
allwinner,codec-analog-controls = <0x11>;
allwinner,audio-routing = "Headphone", "HP", "Headphone", "HPCOM", "MIC1", "Mic", "Mic", "HBIAS";
codec-analog@01c23000 {
compatible = "allwinner,sun8i-v3s-codec-analog";
reg = <0x1c23000 0x4>;
linux,phandle = <0x11>;
phandle = <0x11>;
serial@01c28000 {
reg = <0x1c28000 0x400>;
interrupts = <0x0 0x0 0x4>;
reg-shift = <0x2>;
reg-io-width = <0x4>;
clocks = <0x2 0x28>;
resets = <0x2 0x31>;
pinctrl-0 = <0x12>;
serial@01c28400 {
reg = <0x1c28400 0x400>;
interrupts = <0x0 0x1 0x4>;
reg-shift = <0x2>;
clocks = <0x2 0x29>;
resets = <0x2 0x32>;
pinctrl-0 = <0x13>;
serial@01c28800 {
reg = <0x1c28800 0x400>;
interrupts = <0x0 0x2 0x4>;
reg-shift = <0x2>;
clocks = <0x2 0x2a>;
resets = <0x2 0x33>;
pinctrl-0 = <0x14>;
i2c@01c2ac00 {
compatible = "allwinner,sun6i-a31-i2c";
reg = <0x1c2ac00 0x400>;
interrupts = <0x0 0x6 0x4>;
clocks = <0x2 0x26>;
resets = <0x2 0x2e>;
pinctrl-0 = <0x15>;
tsc2007@48 {
compatible = "ti,tsc2007";
reg = <0x48>;
interrupt-parent = <0xb>;
interrupts = <0x1 0x2 0x2>;
gpios = <0xb 0x1 0x2 0x0>;
pendown-gpio = <0xb 0x1 0x2 0x0>;
ti,x-plate-ohms = <0x294>;
wakeup-source;
i2c@01c2b000 {
reg = <0x1c2b000 0x400>;
interrupts = <0x0 0x7 0x4>;
clocks = <0x2 0x27>;
resets = <0x2 0x2f>;
ethernet@1c30000 {
compatible = "allwinner,sun8i-v3s-emac";
syscon = <0x16>;
reg = <0x1c30000 0x10000>;
interrupts = <0x0 0x52 0x4>;
interrupt-names = "macirq";
resets = <0x2 0xc>;
reset-names = "stmmaceth";
clocks = <0x2 0x1a>;
clock-names = "stmmaceth";
phy-handle = <0x17>;
phy-mode = "mii";
mdio {
ethernet-phy@1 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <0x1>;
clocks = <0x2 0x2b>;
resets = <0x2 0x27>;
phy-is-integrated;
linux,phandle = <0x17>;
phandle = <0x17>;
spi@1c68000 {
compatible = "allwinner,sun8i-h3-spi";
reg = <0x1c68000 0x1000>;
interrupts = <0x0 0x41 0x4>;
clocks = <0x2 0x1c 0x2 0x37>;
clock-names = "ahb", "mod";
pinctrl-0 = <0x18>;
resets = <0x2 0xf>;
mx25l25635e@0 {
compatible = "jedec,spi-nor";
reg = <0x0>;
spi-max-frequency = <0x2faf080>;
interrupt-controller@01c81000 {
compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic";
reg = <0x1c81000 0x1000 0x1c82000 0x1000 0x1c84000 0x2000 0x1c86000 0x2000>;
interrupts = <0x1 0x9 0xf04>;
linux,phandle = <0x1>;
phandle = <0x1>;
ahci-5v {
regulator-name = "ahci-5v";
regulator-min-microvolt = <0x4c4b40>;
regulator-max-microvolt = <0x4c4b40>;
regulator-boot-on;
enable-active-high;
gpio = <0xb 0x1 0x8 0x0>;
usb0-vbus {
regulator-name = "usb0-vbus";
enable-active-high;
gpio = <0xb 0x1 0x9 0x0>;
usb1-vbus {
regulator-name = "usb1-vbus";
regulator-boot-on;
enable-active-high;
gpio = <0xb 0x7 0x6 0x0>;
usb2-vbus {
regulator-name = "usb2-vbus";
regulator-boot-on;
enable-active-high;
gpio = <0xb 0x7 0x3 0x0>;
vcc3v0 {
regulator-name = "vcc3v0";
regulator-min-microvolt = <0x2dc6c0>;
regulator-max-microvolt = <0x2dc6c0>;
linux,phandle = <0xf>;
phandle = <0xf>;
vcc3v3 {
regulator-name = "vcc3v3";
regulator-min-microvolt = <0x325aa0>;
regulator-max-microvolt = <0x325aa0>;
linux,phandle = <0x8>;
phandle = <0x8>;
vcc5v0 {
regulator-name = "vcc5v0";
aliases {
serial0 = "/soc/serial@01c28000";
ethernet0 = "/soc/ethernet@1c30000";
leds {
compatible = "gpio-leds";
blue_led {
label = "licheepi:blue:usr";
gpios = <0xb 0x6 0x1 0x1>;
green_led {
label = "licheepi:green:usr";
gpios = <0xb 0x6 0x0 0x1>;
default-state = "on";
red_led {
label = "licheepi:red:usr";
gpios = <0xb 0x6 0x2 0x1>;
backlight {
compatible = "pwm-backlight";
pwms = <0x19 0x0 0xf4240 0x0>;
brightness-levels = <0x0 0x1e 0x28 0x32 0x3c 0x46 0x64>;
default-brightness-level = <0x6>;
};离线
如果linux用simplefb驱动,那么在uboot改分辨率,本站有帖子。
非常感谢,已经正常驱动该LCD,接下来需要去掉电阻触摸屏。我看这个屏上的电阻板没有芯片,直接连过来的,应该是要使用荔枝派zero上面自带的电阻触摸控制芯片,那么这个应该如何配置呢,还望赐教,非常感谢!
