amixer做的相关配置
# amixer contents
numid=25,iface=MIXER,name='Headphone Source Playback Route'
  ; type=ENUMERATED,access=rw------,values=2,items=2
  ; Item #0 'DAC'
  ; Item #1 'Mixer'
  : values=0,0
numid=3,iface=MIXER,name='Headphone Playback Switch'
  ; type=BOOLEAN,access=rw------,values=2
  : values=off,off
numid=2,iface=MIXER,name='Headphone Playback Volume'
  ; type=INTEGER,access=rw---R--,values=1,min=0,max=63,step=0
  : values=0
  | dBscale-min=-63.00dB,step=1.00dB,mute=1
numid=5,iface=MIXER,name='FM In Playback Volume'
  ; type=INTEGER,access=rw---R--,values=1,min=0,max=7,step=0
  : values=0
  | dBscale-min=-4.50dB,step=1.50dB,mute=0
numid=4,iface=MIXER,name='Line In Playback Volume'
  : values=0
numid=7,iface=MIXER,name='Mic Boost Volume'
  : values=4
  | dBrange-
    rangemin=0,,rangemax=0
      | dBscale-min=0.00dB,step=0.00dB,mute=0
    rangemin=1,,rangemax=7
      | dBscale-min=24.00dB,step=3.00dB,mute=0
numid=6,iface=MIXER,name='Mic In Playback Volume'
  : values=3
numid=13,iface=MIXER,name='ADC Mixer Left FM In Capture Switch'
  ; type=BOOLEAN,access=rw------,values=1
  : values=off
numid=10,iface=MIXER,name='ADC Mixer Left Out Capture Switch'
  : values=off
numid=11,iface=MIXER,name='ADC Mixer Line In Capture Switch'
  : values=off
numid=14,iface=MIXER,name='ADC Mixer Mic Capture Switch'
  : values=off
numid=12,iface=MIXER,name='ADC Mixer Right FM In Capture Switch'
  : values=off
numid=9,iface=MIXER,name='ADC Mixer Right Out Capture Switch'
  : values=off
numid=8,iface=MIXER,name='ADC Capture Volume'
  : values=3
numid=1,iface=MIXER,name='DAC Playback Volume'
  : values=62
  | dBscale-min=-73.08dB,step=1.16dB,mute=0
numid=17,iface=MIXER,name='Left Mixer FM In Playback Switch'
  : values=off
numid=16,iface=MIXER,name='Left Mixer Left DAC Playback Switch'
  : values=on
numid=18,iface=MIXER,name='Left Mixer Line In Playback Switch'
  : values=off
numid=19,iface=MIXER,name='Left Mixer Mic In Playback Switch'
  : values=off
numid=15,iface=MIXER,name='Left Mixer Right DAC Playback Switch'
  : values=on
numid=22,iface=MIXER,name='Right Mixer FM In Playback Switch'
  : values=off
numid=20,iface=MIXER,name='Right Mixer Left DAC Playback Switch'
  : values=on
numid=23,iface=MIXER,name='Right Mixer Line In Playback Switch'
  : values=off
numid=24,iface=MIXER,name='Right Mixer Mic In Playback Switch'
  : values=off
numid=21,iface=MIXER,name='Right Mixer Right DAC Playback Switch'
  : values=on使用播放命名播放音乐
# aplay on_phone.wav
Playing WAVE 'on_phone.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
#我在OUT+和OUT-两端接了一个4W喇叭
这是一首5秒的音乐,播放时间是正常的,但是没有声音
最近编辑记录 秦皇岛岛主 (2020-09-16 20:57:58)
改成这样,可以播放了
# amixer contents
  ; Item #0 'DAC'
  ; Item #1 'Mixer'
  : values=0,0
  : values=on,on
  : values=63
  : values=0
  : values=0
  : values=4
  | dBrange-
  : values=3
  : values=off
  : values=off
  : values=off
  : values=off
  : values=off
  : values=off
  : values=3
  : values=63
  : values=off
  : values=off
  : values=off
  : values=off
  : values=off
  : values=off
  : values=off
  : values=off
  : values=off
  : values=off离线
如何使用tiny200 录音和放音(内容虽然简单,献给向我一样的小白)
0. 在OUT+和OUT-两端接一个小喇叭
1. 在buildroot中打开tinyalsa(aodzip大佬推荐tinyalsa,tinyalsa用起来确实比较简单)
2. 使用tinyalsa的tinymix配置输入输出通道和音量,效果如下
# tinymix contents
Number of controls: 25
ctl     type    num     name                                    value
0       INT     1       DAC Playback Volume                     63 (range 0->63)
1       INT     1       Headphone Playback Volume               63 (range 0->63)
2       BOOL    2       Headphone Playback Switch               On, On
3       INT     1       Line In Playback Volume                 0 (range 0->7)
4       INT     1       FM In Playback Volume                   0 (range 0->7)
5       INT     1       Mic In Playback Volume                  3 (range 0->7)
6       INT     1       Mic Boost Volume                        4 (range 0->7)
7       INT     1       ADC Capture Volume                      3 (range 0->7)
8       BOOL    1       ADC Mixer Right Out Capture Switch      Off
9       BOOL    1       ADC Mixer Left Out Capture Switch       Off
10      BOOL    1       ADC Mixer Line In Capture Switch        Off
11      BOOL    1       ADC Mixer Right FM In Capture Switch    Off
12      BOOL    1       ADC Mixer Left FM In Capture Switch     Off
13      BOOL    1       ADC Mixer Mic Capture Switch            On
14      BOOL    1       Left Mixer Right DAC Playback Switch    Off
15      BOOL    1       Left Mixer Left DAC Playback Switch     Off
16      BOOL    1       Left Mixer FM In Playback Switch        Off
17      BOOL    1       Left Mixer Line In Playback Switch      Off
18      BOOL    1       Left Mixer Mic In Playback Switch       Off
19      BOOL    1       Right Mixer Left DAC Playback Switch    Off
20      BOOL    1       Right Mixer Right DAC Playback Switch   Off
21      BOOL    1       Right Mixer FM In Playback Switch       Off
22      BOOL    1       Right Mixer Line In Playback Switch     Off
23      BOOL    1       Right Mixer Mic In Playback Switch      Off
24      ENUM    2       Headphone Source Playback Route         , DACMixer, , DACMixer3. 测试播放成功
# tinyplay on_phone.wav
playing 'on_phone.wav': 2 ch, 48000 hz, 16 bit
#测试录音成功
#tinycap 1.wav -d 0 -c 1 -r 44100 -b 16离线
# tinymix contents
1       INT     1       Headphone Playback Volume               32 (range 0->63)
6       INT     1       Mic Boost Volume                        7 (range 0->7)
18      BOOL    1       Left Mixer Mic In Playback Switch       On
# tinycap /tmp/test.wav
Capturing sample: 2 ch, 48000 hz, 16 bit
^CCaptured 421920 frames
# tinyplay  /tmp/test.wav
playing '/tmp/test.wav': 2 ch, 48000 hz, 16 bit
#搞定, 感谢楼主, 只是底噪声音有点大, 不知道是F1C200s声卡本身问题, 还是PCB的滤波没做好?
您好,您是直接使用的从aodzip/buildroot-tiny200下载的sdk吗,这个sdk是不是音频驱动已经写好了,使用alsa工具就可以直接播放了
@cube
是的,我也是这样,使用a大的sdk按照上面设置就可以直接捕获和播放了
