楼主 #1 2017-12-02 15:36:05
bugfix
已发帖子: 125
全志Allwinner V3s我想用以太网使用tftp下载zImage和设备树,使用nfs根文件系统,可是u-boot如何启用以太网呢?
使用nfs根文件系统,
可是u-boot如何启用以太网Ehernet呢?
#2 2017-12-02 15:42:51
已发帖子: 9,520
Re: 全志Allwinner V3s我想用以太网使用tftp下载zImage和设备树,使用nfs根文件系统,可是u-boot如何启用以太网呢?
参考这篇文章: Licheepi Zero Ethernet适配指南 可以搞定u-boot使用以太网。
一、U-Boot适配Ethernet
U-Boot 2017已经支持了sun8i-emac的驱动,只需要在编译时选上并且修改dts就行。
进入u-boot源码目录:
$ make LicheePi_Zero_defconfig
$ make menuconfig
选择 Device Drivers --->
选择 Network device support ---> 并选中 Allwinner Sun8i Ethernet MAC support
修改dts
sun8i-v3s-licheepi-zero.dts:
diff --git a/arch/arm/dts/sun8i-v3s-licheepi-zero.dts b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts
index 3d9168c..b8b9fc3 100644
--- a/arch/arm/dts/sun8i-v3s-licheepi-zero.dts
+++ b/arch/arm/dts/sun8i-v3s-licheepi-zero.dts
@@ -49,6 +49,7 @@
compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
aliases {
  • ethernet0 = &emac;
    serial0 = &uart0;
@@ -81,3 +82,14 @@
usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
+&emac {
  • phy = <&phy0>;
  • phy-mode = "mii";
  • allwinner,use-internal-phy;
  • allwinner,leds-active-low;
  • status = "okay";
  • phy0: ethernet-phy@0 {
  • reg = <1>;
    sun8i-v3s.dtsi:
diff --git a/arch/arm/dts/sun8i-v3s.dtsi b/arch/arm/dts/sun8i-v3s.dtsi
index ebefc0f..cb81dd5 100644
--- a/arch/arm/dts/sun8i-v3s.dtsi
+++ b/arch/arm/dts/sun8i-v3s.dtsi
@@ -96,6 +96,11 @@
#size-cells = <1>;
ranges;
  • syscon: syscon@01c00000 {
  • compatible = "allwinner,sun8i-h3-syscon","syscon";
  • reg = <0x01c00000 0x34>;
    mmc0: mmc@01c0f000 {
    compatible = "allwinner,sun7i-a20-mmc";
    reg = <0x01c0f000 0x1000>;
    @@ -208,6 +213,17 @@
    interrupt-controller;
    #interrupt-cells = <3>;
  • emac_rgmii_pins: emac0@0 {
  • allwinner,pins = "PD0", "PD1", "PD2", "PD3",
  • "PD4", "PD5", "PD7",
  • "PD8", "PD9", "PD10",
  • "PD12", "PD13", "PD15",
  • "PD16", "PD17";
  • allwinner,function = "emac";
  • allwinner,drive = <SUN4I_PINCTRL_40_MA>;
  • allwinner,pull = <SUN4I_PINCTRL_NO_PULL>;
    uart0_pins_a: uart0@0 {
    pins = "PB8", "PB9";
    function = "uart0";
    @@ -270,6 +286,20 @@
    status = "disabled";
  • emac: ethernet@1c30000 {
  • compatible = "allwinner,sun8i-h3-emac";
  • reg = <0x01c30000 0x104>, <0x01c00030 0x4>;
  • reg-names = "emac", "syscon";
  • interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>;
  • resets = <&ccu RST_BUS_EMAC>, <&ccu RST_BUS_EPHY>;
  • reset-names = "ahb", "ephy";
  • clocks = <&ccu CLK_BUS_EMAC>, <&ccu CLK_BUS_EPHY>;
  • clock-names = "ahb", "ephy";
  • #address-cells = <1>;
  • #size-cells = <0>;
  • status = "disabled";
    gic: interrupt-controller@01c81000 {
    compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic";
    reg = <0x01c81000 0x1000>,
    编译:
    $ make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf-
    烧写:
    $ dd if=u-boot-sunxi-with-spl.bin of=${card} bs=1024 seek=8
    使用Ethernet:
#3 2017-12-06 14:06:53
已发帖子: 9,520
这是我编译好的带以太网的u-boot: u-boot-sunxi-with-splethernet.7z
能不能用都可以到本帖反馈。
#4 2018-02-06 11:27:59
bigbug
能不能用都可以到本帖反馈。
跟着教程走了一遍,也用了你提供的u-boot试了下
都不能使用以太网
都是这样的
#5 2018-02-06 11:55:39
已发帖子: 9,520
感觉好像是你的设备树或者驱动没配置好?
还有你用u-boot哪个分支?
#6 2018-02-06 11:59:56
bigbug
感觉好像是你的设备树或者驱动没配置好?
还有你用u-boot哪个分支?
v3s-current
这个,如果是像你说的那样就好了
#7 2018-02-06 14:03:43
已发帖子: 9,520
我用的是 v3s-spi-experimental,
你可以试一试这个。
#8 2018-02-06 14:52:02
bigbug
你可以试一试这个。
大佬大佬,还是不行
#9 2018-02-06 21:59:31
已发帖子: 9,520
你可以试一试这个。
大佬大佬,还是不行
改天有空我再仔细测试
#10 2018-10-03 19:26:45
john78
已发帖子: 223
git clone https://github.com/Lichee-Pi/u-boot.git -b v3s-spi-experimental
选择 Network device support ---> 并选中 Allwinner Sun8i Ethernet MAC support 没有这个选项
#11 2018-10-03 20:34:29
已发帖子: 9,520
可以的哦,刚刚重新试过一次:
cd u-boot/
make menuconfig
#12 2018-10-03 20:44:52
john78
已发帖子: 223
git pull 就有了,谢谢
#13 2018-10-04 21:17:39
audiomonster
能不能用都可以到本帖反馈。
我的V3S CPU坏吗?
#14 2018-10-04 22:09:03
已发帖子: 9,520
荔枝派zero核心板pdf:
/files/20171005/11/lichee_zero(核心板).pdf
荔枝派zero底板pdf:
/files/20171005/11/lichee_base(底板).pdf
全志V3s手册V1.0: Allwinner_V3s_Datasheet_V1.0.pdf
全志S3手册V0.2: Allwinner_S3_Datasheet_V0_2.pdf (索智S3手册)
这个新款的板子我没有,但是从原理图看那个短路的地方貌似正常。
显示 0M DDR 可能是硬件出问题了, 参考一下这个帖子: https://whycan.cn/t_1702_1.html#p9734
#15 2018-11-05 09:44:44
605364021
已发帖子: 251
能不能用都可以到本帖反馈。
都不能使用以太网
都是这样的
/files/members/449/QQ20180206112609.png
我安装流程走,在编译u-boot的时候dts文件出现警告,不知道有没有影响,也是u-boot ping不通,kernel可以ping通
#16 2019-05-08 21:06:45
晕哥小弟
已发帖子: 311
晕哥,请教你一个问题,我看这个主题中。u-boot居然也有dts。
那么我的问题是,dts在u-boot编译make之前生效的,还是之后生效的。
因为我看最后的步骤都是
而这个命令,都没有提到dts。
难道是make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 就把dts文件
编译到-boot-sunxi-with-spl.bin 中么?
最近编辑记录 晕哥小弟 (2019-05-08 21:07:42)
#17 2019-05-08 21:24:26
已发帖子: 9,520
对,这个uboot的 dtb 是和 u-boot二进制文件一起打包的,应该是通过某些机制自己能找到 dtb的位置,然后自行加载。
#18 2019-05-08 21:30:32
晕哥小弟
已发帖子: 311
这个机制和kernel的不一样,kernel并未把dts的打包到uImage或者zImage之类的系统镜像内。
#19 2019-05-08 21:37:15
已发帖子: 9,520
对,我记得 openwrt 默认就是把设备树和 kernel一起打包的,你可以搜索证实并研究一下。
#20 2019-05-08 21:47:25
晕哥小弟
已发帖子: 311
好的,听你这么一说,感觉是这样的,因为在树莓派上运行openwrt我尝试过。编译出来的直接是打包好的镜像文件。比如xxx.img。所以我猜测这里面就应该有dts文件。
#21 2019-05-08 21:56:24
已发帖子: 9,520
所以,我觉得kernel的 menuconfig也应该有这样的选项
#22 2019-05-08 22:22:23
晕哥小弟
已发帖子: 311
晕哥,我想从u-boot,启动内核和文件系统。有这个命令么? lichepi zero平台。
我目前是按照这个思路折腾,首先按照这个主题把u-boot的网口连同,可能还要设置tftp。然后通过tftp下载内核。当然这个rootfs是编译进kernel里面。
如果不正确烦请指出。谢谢。
#23 2019-05-08 22:43:18
已发帖子: 9,520
  1. rootfs 和 kernel 一起打包是可以的, 在 menuconfig 的 initramfs 指定文件系统目录即可, 然后再 bootargs 设置 rdinit 参数:
    https://whycan.cn/t_1634.html#p18197
  2. u-boot驱动了网卡的前提下, 可以通过 tftp 下载 zImage, dtb 等文件
  3. 不如直接用 sunxi-fel 下载, 比 tftp 优秀多了:
    https://whycan.cn/t_2388.html
#24 2019-05-09 09:59:59
晕哥小弟
已发帖子: 311
我在平台licheepi zero的u-boot上开通网口,按照上述步骤,遇到一个问题:
1、saveenv 报错
=> saveenv
Saving Environment to SPI Flash...
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
himport_r: can't insert "stdin=serial,usbkbd" into hash table
himport_r: can't insert "stdout=serial,vga" into hash table
himport_r: can't insert "stderr=serial,vga" into hash table
这个是怎么回事呢?我是把u-boot.bin dd到SD卡中的。 另外板子上也焊接了SPI-FLASH。
2、setenv ipaddr xxx.xxx.xxx.xxx
既然保存不了,我就不保存吧。直接使用ping
Using ethernet@1c30000 device
data abort
pc : [<43d9cd3c>] lr : [<43d9e230>]
reloc pc : [<42e3bd3c>] lr : [<42e3d230>]
sp : 43b55de8 ip : 000000ed fp : 43d68f74
r10: 43ded430 r9 : 43b58ee8 r8 : 43ded430
r7 : 00000001 r6 : 00000000 r5 : 0000002a r4 : 43ded48e
r3 : 14000045 r2 : 07aad672 r1 : 43b55df0 r0 : 43ded48e
Flags: nZCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
直接重启了。
我使用的 u-boot为: https://github.com/Lichee-Pi/u-boot.git v3s-spi-experimental
#25 2019-05-09 10:30:42
已发帖子: 9,520
  1. 你的 flash 是什么型号?
CONFIG_SPI_FLASH_BAR
CONFIG_SPI_FLASH_ATMEL
CONFIG_SPI_FLASH_EON
CONFIG_SPI_FLASH_GIGADEVI
CONFIG_SPI_FLASH_MACRONIX
CONFIG_SPI_FLASH_SPANSION
CONFIG_SPI_FLASH_STMICRO
CONFIG_SPI_FLASH_SST
CONFIG_SPI_FLASH_WINBOND
这是具体的 SPI 厂家, 你看下有没有开起来.
  1. 你设备树没有开启 网卡吧?
#26 2019-05-09 11:24:15
晕哥小弟
已发帖子: 311
1、我的SPI-FLASH选择的是W25Q128FVFIG 是WINBOND的。
我也打开了
2、设备树修改两个文件。一个是liche.dts 一个v3s.dtsi,都是按照这个主题上的方法来。也核对了一遍。
#27 2019-05-09 11:59:22
已发帖子: 9,520
  1. 这也是同样的问题, 开启那个选项解决了, 要不你换 MX 的 flash试一试?
https://whycan.cn/t_499.html#p1341
  1. https://whycan.cn/t_591.html
#28 2019-05-10 16:10:17
晕哥小弟
已发帖子: 311
U-Boot 2017.01-rc2-00073-gdd6e874-dirty (May 10 2019 - 16:04:10 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
Net: phy interface0
eth0: ethernet@1c30000
No controllers found
=> dhcp
BOOTP broadcast 1
data abort
pc : [<43d9a5c8>] lr : [<43d9bf68>]
reloc pc : [<42e3a5c8>] lr : [<42e3bf68>]
sp : 43b54da0 ip : 000000ed fp : 43dec83c
r10: 43dec38c r9 : 43b57ee8 r8 : 0000000e
r7 : 00000000 r6 : 43dee6d0 r5 : 00000000 r4 : 43dec88e
r3 : 00060101 r2 : 00000008 r1 : 43dec842 r0 : 0000000e
Resetting CPU ...
resetting ...
网卡是不是没有配置成功?
#29 2019-05-10 16:33:43
已发帖子: 9,520
看起来像是, 我记得当时测试 u-boot 里面操作网卡是没有问题的。
#30 2019-05-10 16:43:15
晕哥小弟
已发帖子: 311
我这个没有任何把内核的dts放到SD卡中,是否有影响?
#31 2019-05-10 16:44:42
晕哥小弟
已发帖子: 311
另外你上面的操作有个错误,针对我的licheepi zero
aliases {
52 serial0 = &uart0;
53 spi0 = &spi0;
54 ethernet0 = &emac;
55 };
spi0这项你没有写,那么spi-flash不能生效。
#32 2019-05-10 16:45:58
已发帖子: 9,520
没有关系, 现在是 u-boot 有问题,还没到 linux dtb 那里。
你看下 u-boot 下面自行 ping, tftp 等命令是否正常。
#33 2019-05-10 16:47:31
晕哥小弟
已发帖子: 311
=> ping
ping - send ICMP ECHO_REQUEST to network host
Usage:
ping pingAddress
Usage:
ping pingAddress
=> tftp
*** ERROR: `serverip' not set
#34 2019-05-10 16:53:07
已发帖子: 9,520
命令要加参数,百毒搜索一下
#35 2019-05-10 16:57:01
晕哥小弟
已发帖子: 311
一旦使用这些命令,就会导致重启
=> setenv ipaddr 192.168.0.100
=> ping 192.168.0.100
data abort
pc : [<43d9c054>] lr : [<43d9d548>]
reloc pc : [<42e3c054>] lr : [<42e3d548>]
sp : 43b54de8 ip : 000000ed fp : 43d67f74
r10: 43dec830 r9 : 43b57ee8 r8 : 43dec830
r7 : 00000001 r6 : 00000000 r5 : 0000002a r4 : 43dec88e
r3 : 14000045 r2 : 6400a8c0 r1 : 43b54df0 r0 : 43dec88e
Resetting CPU ...
resetting ...
U-Boot SPL 2017.01-rc2-00073-gdd6e874-dirty (May 10 2019 - 16:04:10)
DRAM: 64 MiB
Trying to boot from MMC1
DRAM: 64 MiB
In: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: phy interface0
#36 2019-05-10 17:27:49
已发帖子: 9,520
这就尴尬了,到荔枝派群附件里面翻下,看有没有别人编译好的固件。
#37 2019-05-10 17:31:21
晕哥小弟
已发帖子: 311
能不能用都可以到本帖反馈。
晕哥啊,晕哥,我就奇怪了。为什么你这个可以呢?你到底改啥了啊?????????????????
#38 2019-05-10 17:42:43
已发帖子: 9,520
能不能用都可以到本帖反馈。
是嘛,我都忘记有这玩意了。
#39 2019-05-10 17:46:23
晕哥小弟
已发帖子: 311
能否在百忙之中,重新来过一次,感觉这个很重要。
#40 2019-05-10 17:51:17
已发帖子: 9,520
这个应该是你的编译环境问题,重新克隆代码试一试
#41 2019-05-10 17:57:16
晕哥小弟
已发帖子: 311
我已经试过
1、我克隆 https://github.com/Lichee-Pi/u-boot.git v3s-spi-experimental
2、make LicheePi_Zero_defconfig
2、改dts 和dtsi
3、make menuconfig
4、最后make,产生u-boot.bin文件。
结果还是一样。一ping就重启
#42 2019-05-10 18:53:43
已发帖子: 9,520
那我有空再试一试
#43 2019-05-11 18:40:32
晕哥小弟
已发帖子: 311
那我有空再试一试
晕哥,有尝试么? 坐等指导。如果有时间的麻烦,折腾下nfs。使用主线kernel.希望晕哥开坛讲法,卡在这了。
#44 2019-05-11 18:56:01
已发帖子: 9,520
晕哥小弟 wrote:
那我有空再试一试
还没有测试呢,如果只是用NFS根文件系统,没有必要在uboot驱动网卡。
#45 2019-08-05 10:24:22
xiaopeng12342
2019-08-05
额。。。。为什么
git下来的
make menuconfig
Device Drivers>Network device support下面什么选项都没有啊。。。还需要做什么其他操作码 ?
#46 2020-01-16 09:54:37
gengyanjun
晕哥 这个问题有办法解决了吗,我的也是uboot网卡 执行dhcp就是重启。
#47 2020-01-16 10:00:20
已发帖子: 9,520
uboot里面只ping过,没有玩过dhcp呢。
#48 2020-09-17 10:01:46
shawn.d
已发帖子: 164
收藏,这种方式比较好。
#49 2020-12-08 17:06:49
hackett
会重启吗 我用这修改设备树方法启动不来
[    1.067291] ALSA device list:
[    1.070260]   #0: V3s Audio Codec
[    1.075917] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.085431] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.196040] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in b_idle (80, <SessEnd), retry #0, port1 00000100
[    2.224738] random: fast init done
[   11.764150] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[   11.770505] sunxi-mmc 1c0f000.mmc: send stop command failed
[   11.776163] mmcblk0: error -110 sending status command, retrying
[   11.782208] mmcblk0: error -110 sending status command, retrying
[   11.788296] mmcblk0: error -110 sending status command, aborting
[   11.794604] mmc0: card 5048 removed
[   11.804082] EXT4-fs (mmcblk0p2): recovery complete
[   11.809187] JBD2: Error -5 detected when updating journal superblock for mmcblk0p2-8.
[   11.817069] Aborting journal on device mmcblk0p2-8.
[   11.821994] JBD2: Error -5 detected when updating journal superblock for mmcblk0p2-8.
[   11.829859] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[   11.838051] VFS: Mounted root (ext4 filesystem) on device 179:2.
[   11.844345] devtmpfs: mounted
#50 2020-12-31 17:07:10
crolin
我也是遇到这个问题,ping IP地址就会重启
#51 2021-03-11 10:14:34
xfdr0805
已发帖子: 350
我也遇到这个问题,一ping就重启
#52 2021-07-21 21:33:14
PeterCui
知道是什么原因了,是编译器版本问题,必须要用文档中那个版本的编译器,换了就好了,太坑了!
#53 2023-03-17 20:25:09
你在卖萌吗
是用的哪个版本的工具链方便分享一下吗,我试了好几个都有一样的问题
#54 2023-03-18 17:02:47
你在卖萌吗
终于解决了,果然是工具链的问题,我用的是这个(gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf-develop-11.0)版本的工具链。
原来文档中的链接似乎是失效了,我是网上翻到的,上传在这,需要的自取。
/files/members/9611/gcc-linaro-6.3.1-2017.05-x86_64_arm-linux-gnueabihf-develop-11.0.zip
最近编辑记录 你在卖萌吗 (2023-03-18 17:30:10)
#55 2023-05-04 17:42:49
wj8331585
已发帖子: 44
也遇到同样的问题,正在用这个版本的编译器编译。
#56 2023-09-25 19:20:36
ljw
@晕哥小弟
data abort 问题, 是armv7 什么字节不能对齐
