楼主 #1 2020-09-18 13:09:19
Iron
已发帖子: 65
采用 openwrt imagebuilder 构建 v3s cpio-rootfs 运行测试
系统环境:Debian/Ubuntu
参考文档:
    https://openwrt.org/docs/guide-user/additional-software/imagebuilder
    The Image Builder runs only in 64bit linux. You can however run a 64bit linux in VM (i.e. virtualbox) even from 32bit windows.
清华镜像:
    https://mirrors.tuna.tsinghua.edu.cn/help/openwrt/
    https://mirrors.tuna.tsinghua.edu.cn/openwrt/
下载文件:
    https://mirrors.tuna.tsinghua.edu.cn/openwrt/releases/19.07.4/targets/sunxi/cortexa7/openwrt-imagebuilder-19.07.4-sunxi-cortexa7.Linux-x86_64.tar.xz
1. Debian/Ubuntu 环境配置
apt-get install build-essential libncurses5-dev libncursesw5-dev zlib1g-dev gawk git gettext libssl-dev xsltproc wget unzip python
2. 解压 openwrt-imagebuilder-19.07.4-sunxi-cortexa7.Linux-x86_64.tar.xz 到指定目录
tar -xvf openwrt-imagebuilder-19.07.4-sunxi-cortexa7.Linux-x86_64.tar.xz
cd openwrt-imagebuilder-19.07.4-sunxi-cortexa7.Linux-x86_64
3. 修改 repositories.conf, 指定镜像地址,加快下载速度
# rootfs  sed -i 's_downloads.openwrt.org_mirrors.tuna.tsinghua.edu.cn/openwrt_' /etc/opkg/distfeeds.conf
sed -i 's_downloads.openwrt.org_mirrors.tuna.tsinghua.edu.cn/openwrt_' repositories.conf
3. 修改 .config 文件, 添加 cpio 格式 rootfs
CONFIG_TARGET_ROOTFS_CPIOGZ=y
4. 'make image'
     默认会输出所有 PROFILE 配置的镜像文件,因为测试只需要 cpio 格式 rootfs, 可以指定 PROFILE 节省输出时间
# make image # 生成所有 PROFILE 镜像
make image PROFILE=sun8i-h2-plus-orangepi-zero # 指定 PROFILE
# make image PROFILE=sun8i-h2-plus-orangepi-zero PACKAGES="luci" FILES="<path>" # 指定 PROFILE,添加 PACKAGES, 添加文件到 rootfs,如网络配置等
5. make image 完成
   在 .\bin\targets\sunxi\cortexa7 目录下生成了 openwrt-19.07.4-sunxi-cortexa7-rootfs.cpio.gz 镜像文件
6. Windows sunxi-fel USB 下载运行测试,由于默认生成的 openwrt rootfs 里没有 /init 文件, kernel 命令参数需要指定 'rdinit=/sbin/init'。
_sunxi-fel_v3s_run_openwrt.bat
:: _sunxi-fel_v3s_run_openwrt.bat
:: make image PROFILE=sun8i-v3s-lichee-pi-zero PACKAGES="luci" FILES="./target/linux/sunxi/base-files" # add "/init"
:: openwrt-19.07.4-sunxi-cortexa7-rootfs_target-base-filse.cpio (2247520字节)
:: "setenv bootargs console=ttyS0,115200 initrd=0x41B00000,2247520 rdinit=/sbin/init; bootz 0x41000000 - 0x41800000"
sunxi-fel.exe -p uboot u-boot-sunxi-with-spl.bin write 0x41000000 zImage write 0x41800000 sun8i-v3s-licheepi-ethernet.dtb write 0x41B00000 openwrt-19.07.4-sunxi-cortexa7-rootfs.cpio.gz
测试文件:
https://whycan.com/files/members/1206/openwrt_v3s_usb-run-test_20200918-1316.rar
运行日志
U-Boot SPL 2020.07 (Jul 31 2020 - 15:28:00 +0800)
DRAM: 64 MiB
Trying to boot from FEL
U-Boot 2020.07 (Jul 31 2020 - 15:28:00 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   mmc@01c0f000: 0
Loading Environment from FAT... Card did not respond to voltage select!
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
Net:   No ethernet found.
No working controllers found
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
=> setenv bootargs console=ttyS0,115200 initrd=0x41B00000,2247520 rdinit=/sbin/init; bootz 0x41000000 - 0x41800000
   Loading Device Tree to 42dfa000, end 42dff574 ... OK
[    0.000000] Linux version 5.4.61-g6070742d3 (iron@d0483bbb7ad2) (gcc version 8.3.0 (Debian 8.3.0-2)) #1 SMP Fri Sep 18 11:33:30 CST 2020
[    0.000000] OF: fdt: Machine model: Lichee Pi Zero Ethernet
[    0.000000] cma: Failed to reserve 16 MiB
[    0.000000] percpu: Embedded 15 pages/cpu s30604 r8192 d22644 u61440
[    0.000000] Kernel command line: console=ttyS0,115200 initrd=0x41B00000,2247520 rdinit=/sbin/init
[    0.000000] Memory: 52724K/65536K available (6144K kernel code, 436K rwdata, 1700K rodata, 1024K init, 246K bss, 12812K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[    0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[    0.000000] random: get_random_bytes called from start_kernel+0x2b0/0x448 with crng_init=0
[    0.000239] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000496] Console: colour dummy device 80x30
[    0.000559] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000575] pid_max: default: 32768 minimum: 301
[    0.000745] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.000759] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001637] CPU: Testing write buffer coherency: ok
[    0.002170] /cpus/cpu@0 missing clock-frequency property
[    0.002196] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.003024] Setting up static identity map for 0x40100000 - 0x40100060
[    0.003255] rcu: Hierarchical SRCU implementation.
[    0.003770] smp: Bringing up secondary CPUs ...
[    0.003792] smp: Brought up 1 node, 1 CPU
[    0.003801] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.003808] CPU: All CPU(s) started in HYP mode.
[    0.003813] CPU: Virtualization extensions available.
[    0.004436] devtmpfs: initialized
[    0.007443] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.007803] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.007832] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.008050] pinctrl core: initialized pinctrl subsystem
[    0.009245] NET: Registered protocol family 16
[    0.009692] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.011038] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.011057] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.025031] SCSI subsystem initialized
[    0.025733] usbcore: registered new interface driver usbfs
[    0.025788] usbcore: registered new interface driver hub
[    0.025888] usbcore: registered new device driver usb
[    0.026150] pps_core: LinuxPPS API ver. 1 registered
[    0.026160] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.026182] PTP clock support registered
[    0.026451] Advanced Linux Sound Architecture Driver Initialized.
[    0.027671] clocksource: Switched to clocksource arch_sys_counter
[    0.039278] thermal_sys: Registered thermal governor 'step_wise'
[    0.039626] NET: Registered protocol family 2
[    0.040309] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.040343] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.040367] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.040389] TCP: Hash tables configured (established 1024 bind 1024)
[    0.040540] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.040594] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.040852] NET: Registered protocol family 1
[    0.041761] RPC: Registered named UNIX socket transport module.
[    0.041783] RPC: Registered udp transport module.
[    0.041790] RPC: Registered tcp transport module.
[    0.041796] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.042108] Unpacking initramfs...
[    0.263620] Freeing initrd memory: 2196K
[    0.265264] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.273734] NFS: Registering the id_resolver key type
[    0.273794] Key type id_resolver registered
[    0.273802] Key type id_legacy registered
[    0.273923] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.273934] io scheduler mq-deadline registered
[    0.273942] io scheduler kyber registered
[    0.274841] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.278922] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.346723] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.349361] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.350481] printk: console [ttyS0] disabled
[    0.370788] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 30, base_baud = 1500000) is a U6_16550A
[    0.942089] printk: console [ttyS0] enabled
[    0.971572] libphy: Fixed MDIO Bus: probed
[    0.975684] CAN device driver interface
[    0.980120] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
[    0.986479] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
[    0.992607] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.998467] dwmac-sun8i 1c30000.ethernet: No regulator found
[    1.004677] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 38000 (expect 58000)
[    1.014087] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[    1.021327] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[    1.028558] dwmac-sun8i 1c30000.ethernet: COE Type 2
[    1.033519] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[    1.040313] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[    1.045965] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[    1.051648] dwmac-sun8i 1c30000.ethernet: device MAC address e6:14:67:11:c5:ab
[    1.059155] libphy: stmmac: probed
[    1.063271] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[    1.069625] libphy: mdio_mux: probed
[    1.073227] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[    1.079626] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[    1.089726] libphy: mdio_mux: probed
[    1.093637] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.100291] ehci-platform: EHCI generic platform driver
[    1.105636] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.111906] ohci-platform: OHCI generic platform driver
[    1.119030] sun6i-rtc 1c20400.rtc: registered as rtc0
[    1.124096] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.128938] i2c /dev entries driver
[    1.133779] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.142518] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.178964] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.186438] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    1.197998] usbcore: registered new interface driver usbhid
[    1.203578] usbhid: USB HID core driver
[    1.209514] NET: Registered protocol family 17
[    1.213997] can: controller area network core (rev 20170425 abi 9)
[    1.220424] NET: Registered protocol family 29
[    1.224876] can: raw protocol (rev 20170425)
[    1.229192] can: broadcast manager protocol (rev 20170425 t)
[    1.234854] can: netlink gateway (rev 20190810) max_hops=1
[    1.240706] Key type dns_resolver registered
[    1.245083] Registering SWP/SWPB emulation handler
[    1.259261] usb_phy_generic usb_phy_generic.1.auto: usb_phy_generic.1.auto supply vcc not found, using dummy regulator
[    1.270932] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[    1.276718] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
[    1.286183] hub 1-0:1.0: USB hub found
[    1.290281] hub 1-0:1.0: 1 port detected
[    1.295849] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:17:45 UTC (1065)
[    1.304408] ALSA device list:
[    1.307386]   No soundcards found.
[    1.312971] Freeing unused kernel memory: 1024K
[    1.317881] Run /sbin/init as init process
[    1.326567] cgroup1: Need name or subsystem set
[    1.362120] init: Console is alive
[    1.365821] init: - watchdog -
[    1.380092] init: - preinit -
[    1.521345] random: jshn: uninitialized urandom read (4 bytes read)
[    1.555949] random: jshn: uninitialized urandom read (4 bytes read)
[    1.581226] random: jshn: uninitialized urandom read (4 bytes read)
[    1.605149] dwmac-sun8i 1c30000.ethernet eth0: PHY [0.1:01] driver [Generic PHY]
[    1.613929] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found
[    1.621313] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    1.628991] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[    1.635522] dwmac-sun8i 1c30000.ethernet eth0: configuring for phy/mii link mode
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[    4.761984] mount_root: mounting /dev/root
[    4.771340] urandom-seed: Seed file not found (/etc/urandom.seed)
[    4.804367] procd: - early -
[    4.807386] procd: - watchdog -
[    5.636054] procd: - watchdog -
[    5.639612] procd: - ubus -
[    5.647248] urandom_read: 1 callbacks suppressed
[    5.647261] random: ubusd: uninitialized urandom read (4 bytes read)
[    5.692897] random: ubusd: uninitialized urandom read (4 bytes read)
[    5.699824] random: ubusd: uninitialized urandom read (4 bytes read)
[    5.707025] procd: - init -
Please press Enter to activate this console.
[    6.003990] urngd: v1.0.2 started.
[    6.052981] random: crng init done
[    6.056393] random: 3 urandom warning(s) missed due to ratelimiting
BusyBox v1.30.1 () built-in shell (ash)
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
 OpenWrt 19.07.4, r11208-ce6496d796
=== WARNING! =====================================
There is no root password defined on this device!
Use the "passwd" command to set up a new password
in order to prevent unauthorized SSH logins.
root@OpenWrt:/#
最近编辑记录 Iron (2020-09-18 13:19:12)
#2 2020-09-21 22:32:02
checkout
已发帖子: 173
Re: 采用 openwrt imagebuilder 构建 v3s cpio-rootfs 运行测试
请问使用这个打包工具打包镜像,和直接使用openwrt有哪些异同?
是不是可以使用openwrt上的一些工具,例如sysupgrade升级系统?
最近编辑记录 checkout (2020-09-21 22:33:09)
楼主 #3 2020-09-22 09:35:31
Iron
已发帖子: 65
checkout 说:
OpenWRT Imagebuilder 最终生成的就是 SD 镜像文件。
cpio rootfs 可以通过 sunx-fel USB 下载到 SDRAM 里运行测试,我的目的是测试根文件系统和驱动时不需要烧写 SD 卡。
'sysupgrade' 功能应该是可以的,应该需要把镜像烧录到 SD 卡运行,目前也在摸索学习中。。
楼主 #4 2020-09-25 09:58:09
Iron
已发帖子: 65
改个错误,rdinit 应该采用 rdinit=/etc/preinit
setenv bootargs console=ttyS0,115200 initrd=0x41B00000,2247520 rdinit=/etc/preinit ; bootz 0x41000000 - 0x41800000
#5 2022-05-25 21:08:07
neiseng
[    1.323131] VFS: Cannot open root device "(null)" or unknown-block(0,0): erro
r -6
[    1.330767] Please append a correct "root=" boot option; here are the availab
le partitions:
[    1.339148] Kernel panic - not syncing: VFS: Unable to mount root fs on unkno
wn-block(0,0)
出现了这个问题,请问是哪里不对?
#7 2024-01-24 14:07:28
wl989898
已发帖子: 35
现在openwrt好像用的很少了
