楼主 #1 2020-09-29 16:07:33
Iron
已发帖子: 65
通过 v3s openwrt 上网发个帖
cool USB WiFi 依然没搞定,先用 USB ethernet 上网试试。。
WiFi 的故障日志:
Tue Sep 29 07:42:36 2020 user.notice mac80211: Failed command: iw phy phy0 set antenna 0xffffffff 0xffffffff
Tue Sep 29 07:42:36 2020 daemon.notice netifd: radio0 (4089): command failed: Not supported (-95)
Tue Sep 29 07:42:36 2020 user.notice mac80211: Failed command: iw phy phy0 set distance 0
Tue Sep 29 07:42:36 2020 user.notice mac80211: Failed command: iw phy phy0 interface add wlan0 type __ap
Tue Sep 29 07:42:36 2020 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Tue Sep 29 07:42:36 2020 daemon.err hostapd: Could not read interface wlan0 flags: No such device
Tue Sep 29 07:42:36 2020 daemon.notice hostapd: nl80211: Driver does not support authentication/association or connect commands
Tue Sep 29 07:42:36 2020 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Tue Sep 29 07:42:36 2020 daemon.err hostapd: nl80211 driver initialization failed.
Tue Sep 29 07:42:36 2020 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->DISABLED
Tue Sep 29 07:42:36 2020 daemon.notice hostapd: wlan0: AP-DISABLED
Tue Sep 29 07:42:36 2020 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Tue Sep 29 07:42:36 2020 daemon.err hostapd: hostapd_free_hapd_data: Interface wlan0 wasn't started
Tue Sep 29 07:42:36 2020 daemon.notice netifd: radio0 (4089): cat: can't open '/var/run/wifi-phy0.pid': No such file or directory
Tue Sep 29 07:42:36 2020 daemon.notice netifd: radio0 (4089): WARNING (wireless_add_process): executable path /usr/sbin/wpad does not match process  path (/proc/exe)
Tue Sep 29 07:42:36 2020 daemon.notice netifd: radio0 (4089): Command failed: Invalid argument
Tue Sep 29 07:42:36 2020 daemon.notice netifd: radio0 (4089): Device setup failed: HOSTAPD_START_FAILED
下班继续研究。。。
最近编辑记录 Iron (2020-09-29 16:08:37)
#2 2020-09-29 16:14:40
阿黄
已发帖子: 299
Re: 通过 v3s openwrt 上网发个帖
你用的什么型号的USB WIFI,回头我也试一下
楼主 #3 2020-09-29 16:22:08
Iron
已发帖子: 65
阿黄 说:
openwrt 19.07.4 首先要重新编译内核,使能 v3s 的 musb, 另外必须用 openwrt 源码编译,内核要打补丁。。
买了两种
MT7601u / RTL8818CUS
#4 2020-09-29 16:34:26
jujiaqi
即便搞定了wifi,性能也不会太好。我也在用openwrt,但只用了两个以太网口,把这个openwrt串在另外两个路由之间。
#5 2020-09-29 16:42:33
jujiaqi
楼主的usb网卡是rtl8152b吗
楼主 #6 2020-09-29 17:02:28
Iron
已发帖子: 65
jujiaqi 说:
楼主的usb网卡是rtl8152b吗
ASIX AX88772 USB 2.0 Ethernet
10 多块钱的百兆那种。。热的烫手。。。
性能好不好再说,先研究学习下,后续考虑试试 imx6ull 工业级的芯片
#7 2020-09-29 17:56:08
jujiaqi
Iron 说:
jujiaqi 说:
楼主的usb网卡是rtl8152b吗
ASIX 应该比较稳定,rtl8152b每隔一段时间,可能有十几天,就会断网,需要重新插拔。v3s跑openwrt 还挺合适的,期待楼主更多测试。
#8 2020-09-30 09:17:21
myxiaonia
已发帖子: 83
有没有用f1c100s整个openwrt接usb wifi
楼主 #9 2020-09-30 10:46:11
Iron
已发帖子: 65
myxiaonia 说:
有兴趣可以看看这个,我只烧录运行过。。
https://github.com/qinfengling/openwrt/tree/licheepi-nano
Build OpenWrt Image for Lichee Pi Nano @qinfengling - 荔枝派社区_Sipeed BBS.pdf
#10 2020-09-30 11:36:52
阿黄
已发帖子: 299
jujiaqi 说:
其中一个网口是USB转的吗?
最近编辑记录 阿黄 (2020-09-30 11:37:21)
楼主 #11 2020-09-30 11:55:58
Iron
已发帖子: 65
是的,简单测试迅雷下载点东西,只有 300K~500K 每秒,直接用WiFi有 1~2M,v3s 应该可以用外置千兆 PHY,USB 估计性能有线,另外 USB 接 WiFi, 要给 V3S 接外部电源,之前用电脑的 USB,开启 WiFi 直接,系统直接挂掉了,电脑 U 口供电不足。。。
阿黄 说:
jujiaqi 说:
其中一个网口是USB转的吗?
#12 2020-10-08 23:13:09
阿黄
已发帖子: 299
今天回到南京,终于拿到了MT7601的USB网卡,抓紧测试了无线。速度还行
注意要禁用无线中的Master才行。。
楼主 #13 2020-10-09 08:20:51
Iron
已发帖子: 65
意思是不能用作 AP 模式?你这测试的是 station 模式吧。
最近编辑记录 Iron (2020-10-09 08:21:04)
#14 2020-10-09 08:22:21
阿黄
已发帖子: 299
Iron 说:
是的,做ap我还没测试,至少确定的一点是ap和 sta只能启用一个
最近编辑记录 阿黄 (2020-10-09 08:23:25)
楼主 #15 2020-10-09 09:49:57
Iron
已发帖子: 65
hmm 可能还是驱动问题,感觉坑越来越深。。。十一全在搬家了,东西都找不到了,感觉要弃坑了。
阿黄 说:
Iron 说:
最近编辑记录 Iron (2020-10-09 09:50:18)
#16 2020-10-09 09:55:07
阿黄
已发帖子: 299
Iron 说:
阿黄 说:
Iron 说:
别啊,好不容易找到个一起玩V3S的OP的,我这个就是用的自带的MT7601u驱动,一开始报的信息和你截出来的一模一样,无线里面80211bgn没有信号强度,显示设备未激活,但是能搜到其他热点。后来把master禁用掉就好了。
你是要当AP热点?
楼主 #17 2020-10-09 10:18:21
Iron
已发帖子: 65
是啊,主要做了 AP 测试,MT7601u / RTL8818CUS 模块出现的问题是一样的。刚重新用 19.07 源码编译了,下午看看。。
阿黄 说:
Iron 说:
阿黄 说:
你是要当AP热点?
#18 2020-10-09 17:23:28
阿黄
已发帖子: 299
晚上我再试试AP
#19 2020-10-10 08:50:42
阿黄
已发帖子: 299
昨晚我看了,openwrt自带的MT7601u驱动应该是不支持ap模式的,在系统中,使用iw list也表明了没有支持APmode,从github上找了一个 https://github.com/Anthony96922/mt7601u-ap ,还没编译成功
楼主 #20 2020-10-10 14:20:47
Iron
已发帖子: 65
https://wireless.wiki.kernel.org/en/users/drivers
确实是自带的 MT7601u 和 rtl8xxxu 驱动都不支持 AP 模式,再研究下,或者换个 WiFi 模块看看
阿黄 说:
#21 2020-10-10 14:27:52
sy373466062
已发帖子: 130
这几款长期(7*24)使用稳定吗? RTL的很多都是用一段时间需要重启一下才行。
Iron 说:
阿黄 说:
Iron 说:
你是要当AP热点?
楼主 #22 2020-10-10 14:39:38
Iron
已发帖子: 65
估计 AP6181 系列会好很多,例如 BCM43362 这种芯片貌似是工业级温度的。MT7601u / RTL8818CUS 应该都是商业级的,内核集成了驱动部分,主要是便宜拿来学习学习...
sy373466062 说:
Iron 说:
阿黄 说:
你是要当AP热点?
#23 2020-10-11 17:29:58
阿黄
已发帖子: 299
你看一下这个支持列表 https://wireless.wiki.kernel.org/en/users/drivers
我感觉RTL8192CU和RT2800系列支持的比较好。
楼主 #24 2020-10-11 20:34:51
Iron
已发帖子: 65
今天默默的买了 RTL8192CU 研究看看。。20块一个
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.2da72e8dl1QvOE&id=588404509123&_u=b8lev2867f8
阿黄 说:
楼主 #25 2020-10-12 21:36:07
Iron
已发帖子: 65
换上 RTL8192CU 确实可以配置成 AP 了,构建一个可用的根文件系统还是挺难的,buildroot 编译感觉要一整天。。openwrt 的 imagebuilder 瞬间就可以输出一个可用的镜像文件了,官网的 openwrt sunxi 没使能 musb 驱动,需要 git clone openwrt 重新编译下内核就可以了。(前后研究了20天,主要是对 linux 驱动和WiFi驱动知识不了解,发给后来人看..)
Iron 说:
阿黄 说:
#26 2020-10-14 09:17:38
阿黄
已发帖子: 299
jujiaqi 说:
Iron 说:
jujiaqi 说:
楼主的usb网卡是rtl8152b吗
想请教下 V3S使用USB接LAN,速度能跑满吗?能跑到多少带宽?
楼主 #27 2020-10-15 17:09:27
Iron
已发帖子: 65
不太会测试性能,弃坑了。。AP 模式用手机下载数据只有 100K/s 左右,用买的路由器差不多 10M/s, 专业的人做专业的事。。不继续深入了。
阿黄 说:
jujiaqi 说:
Iron 说:
#28 2020-10-15 17:10:32
阿黄
已发帖子: 299
用iperf3可以测试的。 openwrt里面可以直接装ipk
楼主 #29 2020-10-15 17:30:02
Iron
已发帖子: 65
感觉是 lichee pi USB PCB 线路设计可能有问题,WiFi 和 USB 以太网速度都不快,下载测试只有 100K/s 到 300K/s 晚点再试下。
阿黄 说:
楼主 #30 2020-10-16 01:26:50
Iron
已发帖子: 65
EMAC 测试, 百兆路由器口
$ iperf3 -c 192.168.10.182 -p 10000
Connecting to host 192.168.10.182, port 10000
[  4] local 192.168.10.202 port 39739 connected to 192.168.10.182 port 10000
[ ID] Interval           Transfer     Bandwidth
[  4]   0.00-1.00   sec  11.5 MBytes  96.3 Mbits/sec
[  4]   1.00-2.00   sec  11.4 MBytes  95.3 Mbits/sec
[  4]   2.00-3.01   sec  11.2 MBytes  94.0 Mbits/sec
[  4]   3.01-4.00   sec  11.4 MBytes  95.8 Mbits/sec
[  4]   4.00-5.01   sec  11.4 MBytes  94.9 Mbits/sec
[  4]   5.01-6.00   sec  11.2 MBytes  94.9 Mbits/sec
[  4]   6.00-7.00   sec  11.2 MBytes  94.7 Mbits/sec
[  4]   7.00-8.00   sec  11.2 MBytes  94.2 Mbits/sec
[  4]   8.00-9.00   sec  11.4 MBytes  95.3 Mbits/sec
[  4]   9.00-10.01  sec  11.2 MBytes  94.0 Mbits/sec
[  4]   0.00-10.01  sec   113 MBytes  94.9 Mbits/sec                  sender
[  4]   0.00-10.01  sec   113 MBytes  94.9 Mbits/sec                  receiver
iperf Done.
EMAC 测试, 千兆交换机接口
[  4] local 192.168.10.202 port 40120 connected to 192.168.10.182 port 10000
[  4]   1.00-2.00   sec  11.4 MBytes  95.5 Mbits/sec
[  4]   2.00-3.01   sec  11.4 MBytes  94.9 Mbits/sec
[  4]   3.01-4.00   sec  11.2 MBytes  94.9 Mbits/sec
[  4]   5.01-6.01   sec  11.4 MBytes  95.0 Mbits/sec
[  4]   6.01-7.00   sec  11.1 MBytes  94.1 Mbits/sec
[  4]   7.00-8.00   sec  11.4 MBytes  95.2 Mbits/sec
[  4]   8.00-9.00   sec  11.4 MBytes  95.5 Mbits/sec
[  4]   9.00-10.01  sec  11.4 MBytes  94.9 Mbits/sec
[  4]   0.00-10.01  sec   114 MBytes  95.1 Mbits/sec                  sender
[  4]   0.00-10.01  sec   113 MBytes  95.1 Mbits/sec                  receiver
iperf Done.
ASIX AX88772 USB 2.0 Ethernet 普通网线
$ iperf3 -c 192.168.2.1 -p 10000
Connecting to host 192.168.2.1, port 10000
[  4] local 192.168.2.157 port 39252 connected to 192.168.2.1 port 10000
[  4]   0.00-1.00   sec  5.25 MBytes  44.0 Mbits/sec
[  4]   1.00-2.00   sec  7.25 MBytes  60.7 Mbits/sec
[  4]   2.00-3.01   sec  7.50 MBytes  62.8 Mbits/sec
[  4]   3.01-4.01   sec  7.25 MBytes  60.8 Mbits/sec
[  4]   4.01-5.01   sec  7.25 MBytes  60.8 Mbits/sec
[  4]   5.01-6.02   sec  7.38 MBytes  61.3 Mbits/sec
[  4]   6.02-7.00   sec  7.12 MBytes  60.6 Mbits/sec
[  4]   7.00-8.01   sec  7.38 MBytes  61.7 Mbits/sec
[  4]   8.01-9.01   sec  7.25 MBytes  60.6 Mbits/sec
[  4]   9.01-10.01  sec  7.38 MBytes  61.7 Mbits/sec
[  4]   0.00-10.01  sec  71.0 MBytes  59.5 Mbits/sec                  sender
[  4]   0.00-10.01  sec  70.8 MBytes  59.4 Mbits/sec                  receiver
iperf Done.
ASIX AX88772 USB 2.0 Ethernet 千兆网线
[  4] local 192.168.2.157 port 39894 connected to 192.168.2.1 port 10000
[  4]   0.00-1.00   sec  7.50 MBytes  62.8 Mbits/sec
[  4]   2.00-3.01   sec  7.25 MBytes  60.6 Mbits/sec
[  4]   3.01-4.01   sec  7.38 MBytes  61.9 Mbits/sec
[  4]   4.01-5.01   sec  7.50 MBytes  62.6 Mbits/sec
[  4]   5.01-6.00   sec  7.25 MBytes  61.5 Mbits/sec
[  4]   6.00-7.00   sec  7.38 MBytes  62.0 Mbits/sec
[  4]   7.00-8.01   sec  7.38 MBytes  61.4 Mbits/sec
[  4]   8.01-9.01   sec  7.25 MBytes  61.0 Mbits/sec
[  4]   9.01-10.00  sec  7.25 MBytes  61.1 Mbits/sec
[  4]   0.00-10.00  sec  73.4 MBytes  61.5 Mbits/sec                  sender
[  4]   0.00-10.00  sec  73.2 MBytes  61.4 Mbits/sec                  receiver
iperf Done.
USB rtl8192cu AP Mode
信道11,无密码
[  4] local 192.168.2.185 port 40950 connected to 192.168.2.1 port 10000
[  4]   0.00-1.00   sec   256 KBytes  2.09 Mbits/sec
[  4]   1.00-2.00   sec   512 KBytes  4.18 Mbits/sec
[  4]   2.00-3.01   sec   512 KBytes  4.18 Mbits/sec
[  4]   3.01-4.01   sec   512 KBytes  4.18 Mbits/sec
[  4]   4.01-5.01   sec   256 KBytes  2.09 Mbits/sec
[  4]   5.01-6.02   sec   384 KBytes  3.14 Mbits/sec
[  4]   6.02-7.00   sec   256 KBytes  2.12 Mbits/sec
[  4]   7.00-8.01   sec   512 KBytes  4.18 Mbits/sec
[  4]   8.01-9.01   sec   384 KBytes  3.14 Mbits/sec
[  4]   9.01-10.01  sec   384 KBytes  3.14 Mbits/sec
[  4]   0.00-10.01  sec  3.88 MBytes  3.25 Mbits/sec                  sender
[  4]   0.00-10.01  sec  3.83 MBytes  3.21 Mbits/sec                  receiver
iperf Done.
信道4,无密码
[  4] local 192.168.2.185 port 41112 connected to 192.168.2.1 port 10000
[  4]   0.00-1.00   sec   640 KBytes  5.24 Mbits/sec
[  4]   1.00-2.01   sec   512 KBytes  4.17 Mbits/sec
[  4]   2.01-3.01   sec   512 KBytes  4.18 Mbits/sec
[  4]   4.01-5.02   sec   384 KBytes  3.13 Mbits/sec
[  4]   5.02-6.00   sec   384 KBytes  3.19 Mbits/sec
[  4]   6.00-7.00   sec   256 KBytes  2.09 Mbits/sec
[  4]   7.00-8.01   sec   384 KBytes  3.13 Mbits/sec
[  4]   9.01-10.01  sec   256 KBytes  2.09 Mbits/sec
[  4]   0.00-10.01  sec  4.12 MBytes  3.46 Mbits/sec                  sender
[  4]   0.00-10.01  sec  4.12 MBytes  3.46 Mbits/sec                  receiver
iperf Done.
USB rtl8192cu Station Mode
root@OpenWrt:/# iperf3 -c 192.168.10.174 -p 10000
Connecting to host 192.168.10.174, port 10000
[  5] local 192.168.10.176 port 47004 connected to 192.168.10.174 port 10000
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec   617 KBytes  5.05 Mbits/sec    0   91.9 KBytes
[  5]   1.00-2.00   sec   868 KBytes  7.11 Mbits/sec    0    106 KBytes
[  5]   2.00-3.00   sec  1.02 MBytes  8.54 Mbits/sec    0    116 KBytes
[  5]   3.00-4.00   sec  1.03 MBytes  8.64 Mbits/sec    0    133 KBytes
[  5]   4.00-5.00   sec   755 KBytes  6.18 Mbits/sec    0    133 KBytes
[  5]   5.00-6.00   sec   419 KBytes  3.43 Mbits/sec    0    133 KBytes
[  5]   6.00-7.00   sec   950 KBytes  7.78 Mbits/sec    0    208 KBytes
[  5]   7.00-8.03   sec  4.07 MBytes  33.3 Mbits/sec    0    253 KBytes
[  5]   8.03-9.00   sec  3.92 MBytes  33.6 Mbits/sec    0    253 KBytes
[  5]   9.00-10.00  sec  3.78 MBytes  31.7 Mbits/sec    0    253 KBytes
[  5]   0.00-10.00  sec  17.3 MBytes  14.5 Mbits/sec    0             sender
[  5]   0.00-10.00  sec  17.3 MBytes  14.5 Mbits/sec                  receiver
iperf Done.
#31 2020-10-16 01:29:44
阿黄
已发帖子: 299
你这无线速度也忒慢了
楼主 #32 2020-10-16 01:31:19
Iron
已发帖子: 65
看起来 WiFi AP 模式的速度较低还是,问题可能还是驱动或者 WiFi 芯片性能上。。
楼主 #33 2020-10-16 01:34:43
Iron
已发帖子: 65
可能附近无线信道繁忙,或者我的无线路由器性能不行。。改天再试下别的 wifi 性能。。
阿黄 说:
你这无线速度也忒慢了
最近编辑记录 Iron (2020-10-16 01:36:00)
#34 2020-10-16 08:25:58
jujiaqi
阿黄 说:
jujiaqi 说:
Iron 说:
我没用v3s测过,用的全志H3。
用iperf测过百兆网卡rtl8252b和千兆网卡ax88179。
百兆网卡可以跑满。
千兆网卡可以跑到300M,主要是受usb2.0接口限制,而且CPU使用率很高,相当于把四个核里的一个核跑满了,所以v3s更适合挂百兆,千兆的用途不是太大。
#35 2020-10-16 10:12:23
阿黄
已发帖子: 299
Iron 说:
AP和STA模式都慢,这也太慢了,我之前用MT7601U作为STA,速度也能到30Mbps
#36 2021-01-04 15:25:19
crolin
嗨  你这个V3S 选择的是那个openwrt , 我在里面没找到这个Model
#37 2021-01-07 19:18:09
crolin
你好请问下,我移植openwrt的时候,init那边内核panic了,  可以分享下你的移植么 Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004
楼主 #38 2021-01-26 10:35:09
Iron
已发帖子: 65
crolin 说:
参考这个: https://whycan.com/t_5308.html
#39 2022-06-06 11:05:47
lsy512
编译V3S版本的OPENWRT有没有参考资料怎么搞呢
