RTC debug support
RTC non volatile storage support
RTC interfaces
/sys/class/rtc/rtcN (sysfs)
/proc/driver/rtc (procfs for rtcN)
/dev/rtcN (character devices)
on-CPU RTC drivers
Allwinner A31 RTC
< > Faraday Technology FTRTC010 RTC
< > Freescale SNVS RTC support
< > EPSON TOYOCOM RTC-7301SF/DG
log:
[ 0.000000] Linux version 4.20.0-dirty (root@le-desktop) (gcc version 7.5.0 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)) #60 SMP Sat Oct 17 14:43:06 CST 2020
[ 0.000000] OF: fdt: Machine model: Sinlinx SinA33
[ 0.000000] cma: Reserved 16 MiB at 0x45c00000
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] random: get_random_bytes called from start_kernel+0xa0/0x3f4 with crng_init=0
[ 0.000000] percpu: Embedded 16 pages/cpu @(ptrval) s34444 r8192 d22900 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32046
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait panic=10
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 101432K/129196K available (6144K kernel code, 352K rwdata, 1564K rodata, 1024K init, 242K bss, 11380K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc8000000 - 0xff800000 ( 888 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc7e2b000 ( 126 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (7136 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 353 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 243 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000014] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000041] Switching to timer-based delay loop, resolution 41ns
[ 0.000844] Console: colour dummy device 80x30
[ 0.000939] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000971] pid_max: default: 32768 minimum: 301
[ 0.001316] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001348] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002652] CPU: Testing write buffer coherency: ok
[ 0.003406] /cpus/cpu@0 missing clock-frequency property
[ 0.003451] /cpus/cpu@1 missing clock-frequency property
[ 0.003487] /cpus/cpu@2 missing clock-frequency property
[ 0.003523] /cpus/cpu@3 missing clock-frequency property
[ 0.003550] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004629] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.004915] rcu: Hierarchical SRCU implementation.
[ 0.006383] smp: Bringing up secondary CPUs ...
[ 0.007876] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009601] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.011283] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.011472] smp: Brought up 1 node, 4 CPUs
[ 0.011520] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.011535] CPU: All CPU(s) started in HYP mode.
[ 0.011548] CPU: Virtualization extensions available.
[ 0.013312] devtmpfs: initialized
[ 0.026257] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.026688] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026739] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.028532] pinctrl core: initialized pinctrl subsystem
[ 0.030568] NET: Registered protocol family 16
[ 0.033344] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.035500] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.035525] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.066962] SCSI subsystem initialized
[ 0.067383] usbcore: registered new interface driver usbfs
[ 0.067486] usbcore: registered new interface driver hub
[ 0.067655] usbcore: registered new device driver usb
[ 0.068108] pps_core: LinuxPPS API ver. 1 registered
[ 0.068127] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.068172] PTP clock support registered
[ 0.068613] Advanced Linux Sound Architecture Driver Initialized.
[ 0.070386] clocksource: Switched to clocksource arch_sys_counter
[ 0.071652] simple-framebuffer 47e2b000.framebuffer: framebuffer at 0x47e2b000, 0x1d4c00 bytes, mapped to 0x(ptrval)
[ 0.071687] simple-framebuffer 47e2b000.framebuffer: format=x8r8g8b8, mode=800x600x32, linelength=3200
[ 0.091193] Console: switching to colour frame buffer device 100x37
[ 0.108262] simple-framebuffer 47e2b000.framebuffer: fb0: simplefb registered!
[ 0.124277] NET: Registered protocol family 2
[ 0.125445] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[ 0.125504] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.125557] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.125609] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.125832] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.125923] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.126338] NET: Registered protocol family 1
[ 0.127526] RPC: Registered named UNIX socket transport module.
[ 0.127554] RPC: Registered udp transport module.
[ 0.127569] RPC: Registered tcp transport module.
[ 0.127582] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.131230] Initialise system trusted keyrings
[ 0.131641] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.147164] NFS: Registering the id_resolver key type
[ 0.147237] Key type id_resolver registered
[ 0.147254] Key type id_legacy registered
[ 0.147337] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.153969] Key type asymmetric registered
[ 0.154002] Asymmetric key parser 'x509' registered
[ 0.154154] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.154178] io scheduler noop registered
[ 0.154568] io scheduler cfq registered (default)
[ 0.156924] sun4i-usb-phy 1c19400.phy: Linked as a consumer to regulator.3
[ 0.159152] sun8i-a23-r-pinctrl 1f02c00.pinctrl: Reset controller missing
[ 0.165517] sun8i-a33-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.273513] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.278438] printk: console [ttyS0] disabled
[ 0.298782] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 37, base_baud = 1500000) is a U6_16550A
[ 0.979965] printk: console [ttyS0] enabled
[ 0.993221] drivers/gpu/drm/panel/panel-ilitek-ili9881c.c 429 ili9881c_dsi_probe
[ 1.000905] ili9881c-dsi 1ca0000.dsi.0: Linked as a consumer to regulator.2
[ 1.007876] drivers/gpu/drm/panel/panel-ilitek-ili9881c.c 445 ili9881c_dsi_probe
[ 1.015360] ili9881c-dsi 1ca0000.dsi.0: Couldn't get our reset GPIO
[ 1.021826] ili9881c-dsi 1ca0000.dsi.0: Dropping the link to regulator.2
[ 1.033633] libphy: Fixed MDIO Bus: probed
[ 1.037756] CAN device driver interface
[ 1.043364] usbcore: registered new interface driver r8152
[ 1.048943] usbcore: registered new interface driver cdc_ether
[ 1.054926] usbcore: registered new interface driver cdc_eem
[ 1.060687] usbcore: registered new interface driver dm9601
[ 1.066323] usbcore: registered new interface driver rndis_host
[ 1.072406] usbcore: registered new interface driver cdc_ncm
[ 1.078071] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.084635] ehci-platform: EHCI generic platform driver
[ 1.090277] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 1.095952] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 1.104876] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
[ 1.140402] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.148198] hub 1-0:1.0: USB hub found
[ 1.152094] hub 1-0:1.0: 1 port detected
[ 1.157138] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.163404] ohci-platform: OHCI generic platform driver
[ 1.169058] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.175765] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.183913] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
[ 1.255852] hub 2-0:1.0: USB hub found
[ 1.259696] hub 2-0:1.0: 1 port detected
[ 1.264929] usbcore: registered new interface driver cdc_wdm
[ 1.270818] usbcore: registered new interface driver usb-storage
[ 1.277508] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.288383] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
[ 1.299215] drivers/rtc/rtc-sun6i.c 521 sun6i_rtc_probe
[ 1.304679] i2c /dev entries driver
[ 1.313574] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.2
[ 1.360421] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.368028] sunxi-mmc 1c10000.mmc: Linked as a consumer to regulator.2
[ 1.375734] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[ 1.420430] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[ 1.428074] sunxi-mmc 1c11000.mmc: Linked as a consumer to regulator.2
[ 1.470431] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
[ 1.479594] usbcore: registered new interface driver usbhid
[ 1.485213] usbhid: USB HID core driver
[ 1.490621] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.496817] NET: Registered protocol family 17
[ 1.497851] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.501364] can: controller area network core (rev 20170425 abi 9)
[ 1.508383] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.513198] NET: Registered protocol family 29
[ 1.521338] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.522985] can: raw protocol (rev 20170425)
[ 1.528480] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.532731] can: broadcast manager protocol (rev 20170425 t)
[ 1.532753] can: netlink gateway (rev 20170425) max_hops=1
[ 1.533281] Key type dns_resolver registered
[ 1.543940] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[ 1.546662] Registering SWP/SWPB emulation handler
[ 1.552255] mmc0: new high speed SDHC card at address aaaa
[ 1.571302] Loading compiled-in X.509 certificates
[ 1.573179] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[ 1.585973] mmcblk0: p1 p2
[ 1.593805] sun8i-a23-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[ 1.602957] drivers/gpu/drm/panel/panel-ilitek-ili9881c.c 429 ili9881c_dsi_probe
[ 1.610587] ili9881c-dsi 1ca0000.dsi.0: Linked as a consumer to regulator.2
[ 1.617557] drivers/gpu/drm/panel/panel-ilitek-ili9881c.c 445 ili9881c_dsi_probe
[ 1.624129] random: fast init done
[ 1.625099] drivers/gpu/drm/panel/panel-ilitek-ili9881c.c 451 ili9881c_dsi_probe
[ 1.635765] drivers/gpu/drm/panel/panel-ilitek-ili9881c.c 462 ili9881c_dsi_probe
[ 1.643179] drivers/gpu/drm/panel/panel-ilitek-ili9881c.c 470 ili9881c_dsi_probe
[ 1.645618] mmc2: new DDR MMC card at address 0001
[ 1.650608] sun6i-mipi-dsi 1ca0000.dsi: Attached device lhr050h41
[ 1.660971] gpio gpiochip1: (1f02c00.pinctrl): gpiochip_lock_as_irq: tried to flag a GPIO set as output for IRQ
[ 1.662840] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB
[ 1.671646] sun8i-a23-r-pinctrl 1f02c00.pinctrl: unable to lock HW IRQ 5 for IRQ
[ 1.676978] mmcblk2boot0: mmc2:0001 8GTF4R partition 1 4.00 MiB
[ 1.683593] genirq: Failed to request resources for tsc2007 (irq 125) on irqchip sunxi_pio_edge
[ 1.683803] tsc2007 0-0048: Failed to request irq 125: -5
[ 1.690421] mmcblk2boot1: mmc2:0001 8GTF4R partition 2 4.00 MiB
[ 1.698569] tsc2007: probe of 0-0048 failed with error -5
[ 1.705727] mmcblk2: p1 p2
[ 1.724030] asoc-simple-card sound: sun8i <-> 1c22c00.dai mapping ok
[ 1.737812] vcc3v0: disabling
[ 1.740877] ALSA device list:
[ 1.743854] #0: sun8i-a33-audio
[ 1.753567] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.753907] mmc1: new high speed SDIO card at address 0001
[ 1.760933] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.829585] EXT4-fs (mmcblk0p2): recovery complete
[ 1.836913] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.845141] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.854388] devtmpfs: mounted
[ 1.860133] Freeing unused kernel memory: 1024K
[ 1.865074] Run /sbin/init as init process
[ 1.930490] usb 2-1: new full-speed USB device number 2 using ohci-platform
[ 1.952868] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
设备树节点:
rtc: rtc@1f00000 {
compatible = "allwinner,sun8i-a23-rtc";
reg = <0x01f00000 0x400>;
interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
clock-output-names = "osc32k", "osc32k-out";
clocks = <&ext_osc32k>;
#clock-cells = <1>;
注册设备那地方加一些调试语句
注册设备那地方加一些调试语句
感觉是驱动不对,在probe函数的第二个printk之前就死了!
static int sun6i_rtc_probe(struct platform_device *pdev)
struct sun6i_rtc_dev *chip = sun6i_rtc;
int ret;
printk("%s %d %s\n",__FILE__,__LINE__,__FUNCTION__);
if (!chip)
return -ENODEV;
platform_set_drvdata(pdev, chip);
chip->dev = &pdev->dev;
chip->irq = platform_get_irq(pdev, 0);
if (chip->irq < 0) {
dev_err(&pdev->dev, "No IRQ resource\n");
return chip->irq;
ret = devm_request_irq(&pdev->dev, chip->irq, sun6i_rtc_alarmirq,
0, dev_name(&pdev->dev), chip);
if (ret) {
dev_err(&pdev->dev, "Could not request IRQ\n");
return ret;
/ clear the alarm counter value /
writel(0, chip->base + SUN6I_ALRM_COUNTER);
/ disable counter alarm /
writel(0, chip->base + SUN6I_ALRM_EN);
/ disable counter alarm interrupt /
writel(0, chip->base + SUN6I_ALRM_IRQ_EN);
/ disable week alarm /
writel(0, chip->base + SUN6I_ALRM1_EN);
/ disable week alarm interrupt /
writel(0, chip->base + SUN6I_ALRM1_IRQ_EN);
/ clear counter alarm pending interrupts /
writel(SUN6I_ALRM_IRQ_STA_CNT_IRQ_PEND,
chip->base + SUN6I_ALRM_IRQ_STA);
/ clear week alarm pending interrupts /
writel(SUN6I_ALRM1_IRQ_STA_WEEK_IRQ_PEND,
chip->base + SUN6I_ALRM1_IRQ_STA);
/ disable alarm wakeup /
writel(0, chip->base + SUN6I_ALARM_CONFIG);
clk_prepare_enable(chip->losc);
chip->rtc = devm_rtc_device_register(&pdev->dev, "rtc-sun6i",
&sun6i_rtc_ops, THIS_MODULE);
if (IS_ERR(chip->rtc)) {
dev_err(&pdev->dev, "unable to register device\n");
return PTR_ERR(chip->rtc);
dev_info(&pdev->dev, "RTC enabled\n");
那可能是同文件夹下面的全志其他rtc驱动程序?
我使用的是主线的内核4.20的,目录下支持的RTC驱动的兼容属性:
rtc-sun6i:
{ .compatible = "allwinner,sun6i-a31-rtc" },
rtc-sunxi:
{ .compatible = "allwinner,sun4i-a10-rtc", .data = &data_year_param[0] },
{ .compatible = "allwinner,sun7i-a20-rtc", .data = &data_year_param[1] },
没有a33或者a23的兼容属性,这是不是代表目前主线还不支持X3芯片内置的RTC了,那就需要移植了,请问您有什么好的建议吗?
