楼主 #1 2020-10-27 17:55:19
tang6397
已发帖子: 95
make <buildroot-tiny200>报錯
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- -j8
configure: error: /bin/bash ../config.sub PATH:/opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi/bin  failed
make[1]: *** [/home/tlh/buildroot-tiny200-master/output/build/host-gcc-initial-7.5.0/.stamp_configured] Error 1
请教: 1. make <buildroot-tiny200>之前是否要在ubuntu里先安装QT
2. 为QT安装交义编译噐gcc那个版本合适, 安装路径, 配置文件里填写的格式.
楼主 #2 2020-10-27 19:20:01
tang6397
已发帖子: 95
Re: make <buildroot-tiny200>报錯
-threads --with-newlib --disable-largefile \PATH:/opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi/bin\ )
configure: WARNING: you should use --build, --host, --target
configure: WARNING: invalid host type: PATH:/opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi/bin
configure: loading site script /dev/null
checking build system type... Invalid configuration `PATH:/opt/gcc-linaro-7.2.1-2017.11-x86_64_arm-linux-gnueabi/bin': more than four components
