楼主 #1 2020-11-15 20:06:52
ylhljo555
hi35xx 能只编码一路vga分辨率的h264吗?摄像头是720p@30fps的。
小白刚入坑,设置一路vga就报 SAMPLE_PRT("get venc stream time out, exit thread\n");
#2 2020-11-16 09:21:44
cijliu
已发帖子: 59
Re: hi35xx 能只编码一路vga分辨率的h264吗?摄像头是720p@30fps的。
可以的,如果其他编码正常,说明程序哪里配置有问题导致超时
#3 2020-11-16 11:33:03
ylhljo
还是没试出来.看看高人能否看出破绽?
HI_S32 SAMPLE_VENC_720P_CLASSICvga(HI_VOID)
    PAYLOAD_TYPE_E enPayLoad[3]= {PT_H264, PT_H264,PT_H264};
    PIC_SIZE_E enSize[3] = {PIC_HD720, PIC_VGA,PIC_QVGA};
    //PIC_SIZE_E enSize[2] = {PIC_VGA,PIC_QVGA};
    HI_U32 u32Profile = 0;
    VB_CONF_S stVbConf;
    SAMPLE_VI_CONFIG_S stViConfig = {0};
    VPSS_GRP VpssGrp;
    VPSS_CHN VpssChn;
    VPSS_GRP_ATTR_S stVpssGrpAttr;
    VPSS_CHN_ATTR_S stVpssChnAttr;
    VPSS_CHN_MODE_S stVpssChnMode;
    VENC_CHN VencChn;
    SAMPLE_RC_E enRcMode= SAMPLE_RC_FIXQP;
    HI_S32 s32ChnNum=1;
    HI_S32 s32Ret = HI_SUCCESS;
    HI_U32 u32BlkSize;
    SIZE_S stSize;
     step  1: init sys variable
    memset(&stVbConf,0,sizeof(VB_CONF_S));
    printf("s32ChnNum = %d\n",s32ChnNum);
    stVbConf.u32MaxPoolCnt = 128;
    /*video buffer*/
    u32BlkSize = SAMPLE_COMM_SYS_CalcPicVbBlkSize(gs_enNorm,\
                enSize[0], SAMPLE_PIXEL_FORMAT, SAMPLE_SYS_ALIGN_WIDTH);
    stVbConf.astCommPool[0].u32BlkSize = u32BlkSize;
    stVbConf.astCommPool[0].u32BlkCnt = g_u32BlkCnt;
     step 2: mpp system init.
    s32Ret = SAMPLE_COMM_SYS_Init(&stVbConf);
    if (HI_SUCCESS != s32Ret)
        SAMPLE_PRT("system init failed with %d!\n", s32Ret);
        goto END_VENC_720P_CLASSIC_0;
     step 3: start vi dev & chn to capture
    stViConfig.enViMode   = SENSOR_TYPE;
    stViConfig.enRotate   = ROTATE_NONE;
    stViConfig.enNorm     = VIDEO_ENCODING_MODE_AUTO;
    stViConfig.enViChnSet = VI_CHN_SET_NORMAL;
    stViConfig.enWDRMode  = WDR_MODE_NONE;
    s32Ret = SAMPLE_COMM_VI_StartVi(&stViConfig);
        SAMPLE_PRT("start vi failed!\n");
        goto END_VENC_720P_CLASSIC_1;
     step 4: start vpss and vi bind vpss
    s32Ret = SAMPLE_COMM_SYS_GetPicSize(gs_enNorm, enSize[0], &stSize);
        SAMPLE_PRT("SAMPLE_COMM_SYS_GetPicSize failed!\n");
    VpssGrp = 0;
    stVpssGrpAttr.u32MaxW = stSize.u32Width;
    stVpssGrpAttr.u32MaxH = stSize.u32Height;
    stVpssGrpAttr.bIeEn = HI_FALSE;
    stVpssGrpAttr.bNrEn = HI_TRUE;
    stVpssGrpAttr.bHistEn = HI_FALSE;
    stVpssGrpAttr.bDciEn = HI_FALSE;
    stVpssGrpAttr.enDieMode = VPSS_DIE_MODE_NODIE;
    stVpssGrpAttr.enPixFmt = PIXEL_FORMAT_YUV_SEMIPLANAR_420;
    s32Ret = SAMPLE_COMM_VPSS_StartGroup(VpssGrp, &stVpssGrpAttr);
        SAMPLE_PRT("Start Vpss failed!\n");
        goto END_VENC_720P_CLASSIC_2;
    s32Ret = SAMPLE_COMM_VI_BindVpss(stViConfig.enViMode);//vga vi02vpss1
        SAMPLE_PRT("Vi bind Vpss failed!\n");
        goto END_VENC_720P_CLASSIC_3;
    s32Ret = SAMPLE_COMM_SYS_GetPicSize(gs_enNorm, enSize[1], &stSize);
        SAMPLE_PRT("SAMPLE_COMM_SYS_GetPicSize failed!\n");//vga
    VpssChn = 1;
    stVpssChnMode.enChnMode      = VPSS_CHN_MODE_USER;
    stVpssChnMode.bDouble        = HI_FALSE;
    stVpssChnMode.enPixelFormat  = PIXEL_FORMAT_YUV_SEMIPLANAR_420;
    stVpssChnMode.u32Width       = stSize.u32Width;
    stVpssChnMode.u32Height      = stSize.u32Height;
    stVpssChnMode.enCompressMode = COMPRESS_MODE_SEG;
    memset(&stVpssChnAttr, 0, sizeof(stVpssChnAttr));
    stVpssChnAttr.s32SrcFrameRate = -1;
    stVpssChnAttr.s32DstFrameRate = -1;
    enRcMode = SAMPLE_RC_VBR;
    s32Ret = SAMPLE_COMM_VPSS_EnableChn(VpssGrp, VpssChn, &stVpssChnAttr, &stVpssChnMode, HI_NULL);
        SAMPLE_PRT("Enable vpss chn failed!\n");
        goto END_VENC_720P_CLASSIC_4;
    step 5: start stream venc
    /*** enSize[0] **/
    VpssGrp = 0;
    VpssChn = 1;
    VencChn = 1;
    s32Ret = SAMPLE_COMM_VENC_Start(VencChn, enPayLoad[0],\
                                   gs_enNorm, enSize[1], enRcMode,u32Profile);
        SAMPLE_PRT("Start Venc failed!\n");
        goto END_VENC_720P_CLASSIC_5;
    s32Ret = SAMPLE_COMM_VENC_BindVpss(VencChn, VpssGrp, VpssChn);
     step 6: stream venc process -- get stream, then save it to file.
    s32Ret = SAMPLE_COMM_VENC_StartGetStream(s32ChnNum);
    printf("please press twice ENTER to exit this sample\n");
    //getchar();
    //getchar();
    goto END_VENC;
     step 7: exit process
    SAMPLE_COMM_VENC_StopGetStream();
END_VENC_720P_CLASSIC_5:
    VpssGrp = 0;
    VpssChn = 0;
    VencChn = 0;
    SAMPLE_COMM_VENC_UnBindVpss(VencChn, VpssGrp, VpssChn);
    SAMPLE_COMM_VENC_Stop(VencChn);
    SAMPLE_COMM_VI_UnBindVpss(stViConfig.enViMode);
END_VENC_720P_CLASSIC_4:    //vpss stop
    VpssGrp = 0;
    VpssChn = 0;
    SAMPLE_COMM_VPSS_DisableChn(VpssGrp, VpssChn);
END_VENC_720P_CLASSIC_3:    //vpss stop
END_VENC_720P_CLASSIC_2:    //vpss stop
    SAMPLE_COMM_VPSS_StopGroup(VpssGrp);
END_VENC_720P_CLASSIC_1:    //vi stop
    SAMPLE_COMM_VI_StopVi(&stViConfig);
END_VENC_720P_CLASSIC_0:    //system exit
        SAMPLE_COMM_SYS_Exit();
END_VENC:
    return s32Ret;
#4 2020-11-17 01:56:56
ylhljo
cijliu 说:
次码流不能独立存在?
SXM19940913sxm
关注
嵌入式 视频编码(H264)hi3518 sample流程及API 原创
一、重要概念
主次码流
主次码流是指硬件逻辑单元启动一次同时产生的 2 路码流,即 1 路主码流和 1 路次码流。主码流和次码流可以为不同的编码协议,但其宽高比例都必须满足 1:1、1:2 或 1:4,次码流不能单独存在(必须和 1 路主码流在同一个通道组中) 。
#5 2020-11-17 09:47:31
whyabc666
封禁
已发帖子: 378
海思的RTSP推流服务器,PC用ffmpeg解码显示no existing PPS 0 reference,no frame,有什么办法?还有PC端的ffmpeg不能解码720p以上分辨率的,invalid UE holomb code!得用海思的PC 解码库?
