楼主 #1 2020-11-23 11:55:58
xinxin
Opengl EGL初始化失败,返回EGL_NO_DISPLAY
A33用mali OpenGL错误,有没有遇到过
测试代码如下:
egl_dpy = eglGetDisplay(EGL_DEFAULT_DISPLAY);
   if (egl_dpy == EGL_NO_DISPLAY)
      egl_fatal("failed to get a display");
   if (!eglInitialize(egl_dpy, &major, &minor))
      egl_fatal("failed to initialize EGL");
用默认显示器,eglGetDisplay可以过,eglInitialize会错误,返回EGL_NO_DISPLAY
char *fbdev = "/dev/fb0";
   fd = open(fbdev, O_RDWR);
   if (fd < 0)
      egl_fatal("failed to open %s", fbdev);
   egl_dpy = eglGetDisplay((EGLNativeDisplayType)fd);
如果先打开/dev/fb0
则eglGetDisplay会错误,返回EGL_NO_DISPLAY
ls
egl*
[root@dragonboard /root]# ./egl
open /dev/fb0
UMP: ump_arch_open() failed to open UMP device driver
Aborted
[root@dragonboard /root]# insmod /lib/modules/3.4.39/ump.ko
[   62.165246] UMP: UMP device driver  loaded
open /dev/fb0
Aborted
[root@dragonboard /root]# insmod /lib/modules/3.4.39/mali.ko
[   84.345159] axp22_dcdc2: Failed to create debugfs directory
[   84.351573] =========================================================
[   84.358719]        Mali GPU Information
[   84.363970] voltage             : 1140 mV
[   84.368417] initial frequency   : 408000000 MHz
[   84.373469] frame buffer address: 0x58c00000 - 0x78c00000
[   84.379466] frame buffer size   : 512 MB
[   84.383834] =========================================================
[   84.393913] Mali: Mali device driver loaded
open /dev/fb0
Aborted
楼主 #2 2020-11-23 11:59:01
xinxin
Re: Opengl EGL初始化失败,返回EGL_NO_DISPLAY
这个是fb的参数,开启了双缓冲,测试双缓冲也正常
the framebuffer device was opended successfully.
id
smem_start                1488977920
smem_len                  3072000
type                      0
type_aux                  0
visual                    2
xpanstep                  1
ypanstep                  1
line_length               3200
mmio_start                0
mmio_len                  0
accel                     0
xres                      800
yres                      480
xres_virturl              800
yres_virtual              960
xoffset                   0
yoffset                   0
bits_per_pixel            32
grayscale                 0
fb_bitfield red.offset    16
fb_bitfield    .length    8
fb_bitfield    .msb_right 0
fb_bitfield green.offset  8
fb_bitfield blue.offset   0
fb_bitfield transp.offset 24
nonstd                    0
activate                  0
height                    0
widht                     0
accel_flags               0
pixclock                  30303
left_margin               46
right_margin              209
upper_margin              18
lower_margin              22
hsync_len                 0
vsync_len                 5
sync                      0
vmode                     0
rotate                    0
the framebuffer devices was mapped to memory successfully
bye the framebuffer
最近编辑记录 xinxin (2020-11-23 11:59:42)
楼主 #3 2020-11-23 12:26:33
xinxin
通过eglGetError取到的错误是EGL_BAD_ALLOC
#4 2020-11-23 14:02:52
你是用全志的库还是LIMA驱动?
