楼主 #1 2020-12-09 16:38:57
muxi01
已发帖子: 53
[R3 nand]dropbear的使用
1.make linux-menuconfig使能pty字符型设备,使能RNDIS设备
  -> Device Drivers
       -> Character devices
            [ ]   Unix98 PTY support 取消掉这个
            [*]   Legacy (BSD) PTY support   使用这个
            (5)     Maximum number of legacy PTY in use
  ->Device Drivers
         -> USB support
         -> USB Gadget Support
          <M>   USB Gadget functions configurable through configfs
                  [*]     Network Control Model (CDC NCM)
                  [*]     Ethernet Control Model (CDC ECM)
                  [*]     Ethernet Control Model (CDC ECM) subset
                  [*]     RNDIS
                  [*]     Ethernet Emulation Model (EEM)
          <M>   USB Gadget precomposed configurations
          <M>     Ethernet Gadget (with CDC Ethernet support)
           [*]       RNDIS support
          <M>     CDC Composite Device (Ethernet and ACM)
           <M>     CDC Composite Device (ACM and mass storage
2.修改pacakge\dropbear\dropbear.mk,屏蔽掉如下内容,否则无法创建dropbear文件夹
#ln -snf /var/run/dropbear $(TARGET_DIR)/etc/dropbear
3.替换S50dropbear
#!/bin/sh
# Starts dropbear sshd.
# Allow a few customizations from a config file
test -r /etc/default/dropbear && . /etc/default/dropbear
start() {
	DROPBEAR_ARGS="$DROPBEAR_ARGS -r /etc/dropbear/dropbear_rsa_host_key"
	# If /etc/dropbear is a symlink to /var/run/dropbear, and
	#   - the filesystem is RO (i.e. we can not rm the symlink),
	#     create the directory pointed to by the symlink.
	#   - the filesystem is RW (i.e. we can rm the symlink),
	#     replace the symlink with an actual directory
	if [ -L /etc/dropbear \
	     -a "$(readlink /etc/dropbear)" = "/var/run/dropbear" ]
	then
		if rm -f /etc/dropbear >/dev/null 2>&1; then
			mkdir -p /etc/dropbear
			echo "No persistent location to store SSH host keys. New keys will be"
			echo "generated at each boot. Are you sure this is what you want to do?"
			mkdir -p "$(readlink /etc/dropbear)"
		fi
		if [ ! -d /etc/dropbear ]; then
		fi
		if [ ! -e /etc/dropbear/dropbear_rsa_host_key ]; then
			/usr/bin/dropbearkey -t rsa -f /etc/dropbear/dropbear_rsa_host_key
		fi
	fi
	printf "Starting dropbear sshd: "
	umask 077
	start-stop-daemon -S -q -p /var/run/dropbear.pid \
		--exec /usr/sbin/dropbear -- $DROPBEAR_ARGS
	[ $? = 0 ] && echo "OK" || echo "FAIL"
stop() {
	printf "Stopping dropbear sshd: "
	start-stop-daemon -K -q -p /var/run/dropbear.pid
restart() {
	stop
	start
case "$1" in
  start)
  	start
  stop)
  	stop
  restart|reload)
  	restart
	echo "Usage: $0 {start|stop|restart}"
	exit 1
esac
exit $?
4.make menuconfig 使能dropbear
location
  ->Target packages
      -> networking applications
        [*]  dropbear
6.usb网卡启动脚本S40network  拷贝到./widora/mangopi/r3/rootfs/etc/init.d/S40network
#!/bin/sh
# Start the network....
# Debian ifupdown needs the /run/network lock directory
mkdir -p /run/network
installRNDIS()
        modprobe g_ether
        if [ $? -eq 0 ]
        then
                /sbin/ifconfig usb0 up
                /sbin/ifconfig usb0 '192.168.5.100'
                [ $? = 0 ] && echo 'Starting network: OK' || echo "Starting network:FAIL"
                echo 'failed to install RNDIS(ethernet over usb)'
        fi
case "$1" in
  start)
        installRNDIS
        # printf "Starting network: "
        # /sbin/ifup -a
        # [ $? = 0 ] && echo "OK" || echo "FAIL"
  stop)
        printf "Stopping network: "
        /sbin/ifdown -a
  restart|reload)
        "$0" stop
        "$0" start
        exit 1
esac
exit $?
7.编译
编译完成后output/target下会多出很多ko文件,find -name *.ko来查看
./lib/modules/5.4.66/kernel/drivers/input/touchscreen/goodix.ko
./lib/modules/5.4.66/kernel/drivers/input/touchscreen/tsc2007.ko
./lib/modules/5.4.66/kernel/drivers/media/i2c/ov5640.ko
./lib/modules/5.4.66/kernel/drivers/media/i2c/ov2640.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_eem.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/u_serial.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_obex.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_ecm_subset.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_rndis.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/u_ether.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_acm.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_ss_lb.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_serial.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_ecm.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_fs.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_ncm.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/function/usb_f_mass_storage.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/legacy/g_cdc.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/legacy/g_acm_ms.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/legacy/g_serial.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/legacy/gadgetfs.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/legacy/g_mass_storage.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/legacy/g_ether.ko
./lib/modules/5.4.66/kernel/drivers/usb/gadget/libcomposite.ko
8.驱动安装,压缩包里面有readme文件 https://download.csdn.net/download/Seeker_ZeroOne/13087112
9.驱动安装完成后,需要在控制面板\网络和 Internet\网络连接 中修改RNDIS网卡的IP为 :192.168.5.xxx
最近编辑记录 muxi01 (2020-12-09 18:08:00)
