楼主 #1 2020-12-09 18:34:53
muxi01
已发帖子: 63
[R3 nand]tinyplay 的使用方法
1.tinymix 打开播放器通道
tinymix set 3 1
tinymix set 1 63
2.查看配置
# tinymix contents
Number of controls: 25
ctl     type    num     name                                    value
0       INT     1       DAC Playback Volume                     63 (range 0->63)
1       INT     1       Headphone Playback Volume               63 (range 0->63)
2       BOOL    2       Headphone Playback Switch               On, On
3       INT     1       Line In Playback Volume                 0 (range 0->7)
4       INT     1       FM In Playback Volume                   0 (range 0->7)
5       INT     1       Mic In Playback Volume                  3 (range 0->7)
6       INT     1       Mic Boost Volume                        4 (range 0->7)
7       INT     1       ADC Capture Volume                      3 (range 0->7)
8       BOOL    1       ADC Mixer Right Out Capture Switch      On
9       BOOL    1       ADC Mixer Left Out Capture Switch       Off
10      BOOL    1       ADC Mixer Line In Capture Switch        Off
11      BOOL    1       ADC Mixer Right FM In Capture Switch    Off
12      BOOL    1       ADC Mixer Left FM In Capture Switch     Off
13      BOOL    1       ADC Mixer Mic Capture Switch            Off
14      BOOL    1       Left Mixer Right DAC Playback Switch    On
15      BOOL    1       Left Mixer Left DAC Playback Switch     Off
16      BOOL    1       Left Mixer FM In Playback Switch        Off
17      BOOL    1       Left Mixer Line In Playback Switch      Off
18      BOOL    1       Left Mixer Mic In Playback Switch       Off
19      BOOL    1       Right Mixer Left DAC Playback Switch    On
20      BOOL    1       Right Mixer Right DAC Playback Switch   Off
21      BOOL    1       Right Mixer FM In Playback Switch       Off
22      BOOL    1       Right Mixer Line In Playback Switch     Off
23      BOOL    1       Right Mixer Mic In Playback Switch      Off
24      ENUM    2       Headphone Source Playback Route         , DACMixer, , DACMixer
3.tinyplay 播放
tinyplay startup.wav
