楼主 #1 2020-12-11 18:00:43
muxi01
已发帖子: 57
[R3 nand] USB wifi RTL8188EUS 驱动移植<暂时不以package的方式加入>
1.修改设备树  /board/widora/mangopi/r3/devicetree/linux/devicetree.dts
&usb_otg {
        dr_mode = "host"; /* host peripheral */
2.下载驱动源码https://codeload.github.com/aircrack-ng/rtl8188eus/zip/v5.3.9
解压后拷贝到 /output/build/linux-5.4.66/drivers/net/wireless/realtek/rtl8188eus
2.1修改/output/build/linux-5.4.66/drivers/net/wireless/realte/Kconfig,加入
source "drivers/net/wireless/realtek/rtl8188eus/Kconfig"
2.2修改/output/build/linux-5.4.66/drivers/net/wireless/realte/Makefile,加入
obj-$(CONFIG_RTL8188EU)         += rtl8188eus/
2.3修改 rtl8188eus/include/osdep_service_bsd.h,第120行改为
#define LINUX_VERSION_CODE KERNEL_VERSION(5, 4, 66)
3.加入wpa_supplicant工具
make menuconfig
localtion
	->Target pckages
		->Networking applications
			[*] wpa_supplicant
4.make linux-menuconfig 配置网络
localtion
	 -*-   Wireless  --->
		<*>   cfg80211 - wireless configuration API
		[*]   support CRDA
		[*]   cfg80211 wireless extensions compatibility
		<*>   Generic IEEE 802.11 Networking Stack (mac80211)
        [*]   Minstrel
	[*] Networking support  --->
		 <*>   RF switch subsystem support  --->
	->Device Drivers
		[*]   Network device support  --->
			[*]   Network core driver support
			<*>   IEEE 802.1AE MAC-level encryption (MACsec)
  			 [*]  Wireless LAN  --->
				[*]   mac80211-based legacy WDS support
				[*]   Ralink devices
				<*>   Ralink driver support  --->
					[*]   Realtek devices
					<M>   Realtek 8188E USB WiFi
		[*] USB support  --->
			<*>   Support for Host-side USB
			*** USB Host Controller Drivers ***
			<*>   EHCI HCD (USB 2.0) support
			<*>   Generic EHCI driver for a platform device
			<*>   OHCI HCD (USB 1.1) support
			<*>   Generic OHCI driver for a platform device
			       MUSB Mode Selection (Host only mode)  ---> #别错过这里,否则USB模式可能会出错
			<*>   Inventra Highspeed Dual Role Controller
			<*>   ChipIdea Highspeed Dual Role Controller
			[*]   ChipIdea host controller
5.编译,刷机。
6.安装驱动,启动网卡,创建运行需要的临时文件夹
	insmod ./lib/modules/5.4.66/kernel/drivers/net/wireless/realtek/rtl8188eus/8188eu.ko
	ifconfig wlan0 up
	mkdir -p /var/run/wpa_supplicant
7.新建配置文件 /etc/wpa_supplicant/wpa_supplicant.conf
ap_scan=1
network={
	ssid="mishare"  #wifi名字
	psk="qwer1234" #wifi密码
8.链接网络
	wpa_supplicant -B -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
9.配置IP地址<暂时没有使用udhcpc工具>
ifconfig wlan0 192.168.137.202
楼主 #2 2020-12-11 18:02:44
muxi01
已发帖子: 57
Re: [R3 nand] USB wifi RTL8188EUS 驱动移植<暂时不以package的方式加入>
有时间了,再发布一个以package方式的驱动移植,完善脚本。
#3 2020-12-13 18:33:07
lonerwolf
已发帖子: 59
支持8723BS吗这个驱动
#4 2022-06-11 23:10:37
资本家大善人
已发帖子: 189
哪个板子,全志F1C200?
#5 2023-04-01 11:12:15
tanfengnan
请问我编译的时候总是报:ERROR unregister_inetaddr_notifier" undefined! 是怎么回事?是make menuconfig缺少了什么配置吗?
