楼主 #1 2021-01-14 15:24:23
sawgsxiao
全志 f1200s ADC问题
全志 f1200s ADC问题,adc 怎么用,没有相关的资料,请大神指点,求助
#2 2021-01-14 18:13:05
sjshe3326
已发帖子: 125
Re: 全志 f1200s ADC问题
可用的测试代码如下
    // ADC input test
    #if(0)
        adc_init();
        printf("adc test init OK. \n\r");
        delay_s();
        i = 0;
        while(1)
            delay_s();
            u32_t v1 = adc_f1c100s_read(ADC_CHANNEL_FMINL);
            delay_s();
            u32_t v2 = adc_f1c100s_read(ADC_CHANNEL_FMINR);
            delay_s();
            u32_t v3 = adc_f1c100s_read(ADC_CHANNEL_LINL);
            delay_s();
            u32_t v4 = adc_f1c100s_read(ADC_CHANNEL_MIC);
            printf("ADC: %08X, %08X, %08X, %08X \n\r", v1,v2,v3,v4);
u32_t adc_f1c100s_read(int channel)
    u32_t mixerReg = read32(ADC_BAISADDR + ADC_MIXER_CTRL) & ~(0x1f << 8);
    switch (channel)
        case ADC_CHANNEL_FMINL:
            write32(ADC_BAISADDR + ADC_MIXER_CTRL, mixerReg | (1 << 12));
            break;
        case ADC_CHANNEL_FMINR:
            write32(ADC_BAISADDR + ADC_MIXER_CTRL, mixerReg | (1 << 11));
            break;
        case ADC_CHANNEL_LINL:
            write32(ADC_BAISADDR + ADC_MIXER_CTRL, mixerReg | (1 << 10));
            break;
        case ADC_CHANNEL_MIC:
            write32(ADC_BAISADDR + ADC_MIXER_CTRL, mixerReg | (1 << 13));
            break;
        default:
            // mute all
            break;
    udelay();  // wait for internal filter to be stable
    // FIFO flush
    write32(ADC_BAISADDR + ADC_FIFOC, read32(ADC_BAISADDR + ADC_FIFOC) | (1 << 0));
    while( (read32(ADC_BAISADDR + ADC_FIFOS) & (1 <<23))==0);
    // by default, 0V = -24000 and VRA = 0.
    // make 0V = 0 and vreference = 65535.
    int val = (read32(ADC_BAISADDR + ADC_RXDATA));// >> 16);
    return (u32_t)val;
void adc_init(void)
    // ADC打开时钟 //
    write32( 0x01C20008, (read32(0x01C20008) | (1<<31)) );
    write32( 0x01C20068, (read32(0x01C20068) | (1<<0)) );
    write32( 0x01C20140, (read32(0x01C20140) | (1<<31)) );
    udelay();
    write32( 0x01C202D0, (read32(0x01C202D0) | (1<<0)) );
    udelay();
    //24kHz采样率 ,// digital enable // fifo mode 0 delay 0 8fifo 16bit mono
	u32_t regVal = 	(2 << 29) | (1 <<28) | (0xf << 8) | (1 << 7);
    write32(ADC_BAISADDR + ADC_FIFOC, regVal);
    // ADC enable gain 0  all mute
	regVal = (1 << 31) | (3<<24) | (3<<16)| (1 <<14) | (1<<7) | (1<<3) | (0 << 0);
    write32(ADC_BAISADDR + ADC_MIXER_CTRL, regVal);
#3 2021-01-14 18:27:57
david
已发帖子: 390
Re: 全志 f1200s ADC问题
还有个adc读键盘的 触屏应该也是adc
楼主 #4 2021-01-15 02:04:31
sawgsxiao
Re: 全志 f1200s ADC问题
sjshe3326 说:
可用的测试代码如下
    // ADC input test
    #if(0)
        adc_init();
        delay_s();
        i = 0;
        while(1)
            delay_s();
            delay_s();
            delay_s();
            delay_s();
    switch (channel)
            break;
            break;
            break;
            break;
        default:
            // mute all
            break;
    // FIFO flush
    return (u32_t)val;
void adc_init(void)
    // ADC打开时钟 //
    udelay();
    udelay();
感谢大神,我试试下
楼主 #5 2021-01-15 02:08:20
sawgsxiao
Re: 全志 f1200s ADC问题
david 说:
我没找到相关的案例的,试试楼上看看
