楼主 #1 2021-01-22 23:58:34
TeveT
已发帖子: 149
LVGL6.0的linux_frame_buffer项目支持PNG解码
下载下来的linux_frame_buffer 跑在V3S tina
跑起来没有支持png解码,图片啥的程序从单片机那边过来,都是bin啊啥的,ARGB8888 数据超大还占磁盘,很难受啊。
tina环境已经支持了libpng,这里边默认是调用了libpng里边的接口。
话不多说,上代码:
 * @file lv_img_decoder.c
 *      INCLUDES
#include "lv_img_decoder.h"
#include "../lv_core/lv_debug.h"
#include "../lv_draw/lv_draw_img.h"
#include "../lv_misc/lv_ll.h"
#include "../lv_misc/lv_color.h"
#include "../lv_misc/lv_gc.h"
#if defined(LV_GC_INCLUDE)
#include LV_GC_INCLUDE
#endif /* LV_ENABLE_GC */
 *      DEFINES
#define CF_BUILT_IN_FIRST LV_IMG_CF_TRUE_COLOR
#define CF_BUILT_IN_LAST LV_IMG_CF_ALPHA_8BIT
#define USE_PNG 1
 *      TYPEDEFS
typedef struct
#if LV_USE_FILESYSTEM
    lv_fs_file_t * f;
    lv_color_t * palette;
    lv_opa_t * opa;
} lv_img_decoder_built_in_data_t;
 *  STATIC PROTOTYPES
static lv_res_t lv_img_decoder_built_in_line_true_color(lv_img_decoder_dsc_t * dsc, lv_coord_t x, lv_coord_t y,
                                                        lv_coord_t len, uint8_t * buf);
static lv_res_t lv_img_decoder_built_in_line_alpha(lv_img_decoder_dsc_t * dsc, lv_coord_t x, lv_coord_t y,
static lv_res_t lv_img_decoder_built_in_line_indexed(lv_img_decoder_dsc_t * dsc, lv_coord_t x, lv_coord_t y,
 *  STATIC VARIABLES
 *      MACROS
 *   GLOBAL FUNCTIONS
 * Initialize the image decoder module
void lv_img_decoder_init(void)
    lv_ll_init(&LV_GC_ROOT(_lv_img_defoder_ll), sizeof(lv_img_decoder_t));
    lv_img_decoder_t * decoder;
    /*Create a decoder for the built in color format*/
    decoder = lv_img_decoder_create();
    if(decoder == NULL) {
        LV_LOG_WARN("lv_img_decoder_init: out of memory");
        LV_ASSERT_MEM(decoder);
        return;
    lv_img_decoder_set_info_cb(decoder, lv_img_decoder_built_in_info);
    lv_img_decoder_set_open_cb(decoder, lv_img_decoder_built_in_open);
    lv_img_decoder_set_read_line_cb(decoder, lv_img_decoder_built_in_read_line);
    lv_img_decoder_set_close_cb(decoder, lv_img_decoder_built_in_close);
 * Get information about an image.
 * Try the created image decoder one by one. Once one is able to get info that info will be used.
 * @param src the image source. E.g. file name or variable.
 * @param header the image info will be stored here
 * @return LV_RES_OK: success; LV_RES_INV: wasn't able to get info about the image
lv_res_t lv_img_decoder_get_info(const char * src, lv_img_header_t * header)
    header->always_zero = 0;
    lv_res_t res = LV_RES_INV;
    lv_img_decoder_t * d;
    LV_LL_READ(LV_GC_ROOT(_lv_img_defoder_ll), d)
        res = LV_RES_INV;
        if(d->info_cb) {
            res = d->info_cb(d, src, header);
            if(res == LV_RES_OK) break;
    return res;
 * Open an image.
 * Try the created image decoder one by one. Once one is able to open the image that decoder is save in `dsc`
 * @param dsc describe a decoding session. Simply a pointer to an `lv_img_decoder_dsc_t` variable.
 * @param src the image source. Can be
 *  1) File name: E.g. "S:folder/img1.png" (The drivers needs to registered via `lv_fs_add_drv()`)
 *  2) Variable: Pointer to an `lv_img_dsc_t` variable
 *  3) Symbol: E.g. `LV_SYMBOL_OK`
 * @param style the style of the image
 * @return LV_RES_OK: opened the image. `dsc->img_data` and `dsc->header` are set.
 *         LV_RES_INV: none of the registered image decoders were able to open the image.
lv_res_t lv_img_decoder_open(lv_img_decoder_dsc_t * dsc, const void * src, const lv_style_t * style)
    dsc->style     = style;
    dsc->src_type  = lv_img_src_get_type(src);
    dsc->user_data = NULL;
    if(dsc->src_type == LV_IMG_SRC_FILE) {
        size_t fnlen = strlen(src);
        dsc->src = lv_mem_alloc(fnlen + 1);
        strcpy((char *)dsc->src, src);
    } else {
        dsc->src       = src;
        /*Info an Open callbacks are required*/
        if(d->info_cb == NULL || d->open_cb == NULL) continue;
        res = d->info_cb(d, src, &dsc->header);
        if(res != LV_RES_OK) continue;
        dsc->error_msg = NULL;
        dsc->img_data  = NULL;
        dsc->decoder   = d;
        res = d->open_cb(d, dsc);
        /*Opened successfully. It is a good decoder to for this image source*/
    return res;
 * Read a line from an opened image
 * @param dsc pointer to `lv_img_decoder_dsc_t` used in `lv_img_decoder_open`
 * @param x start X coordinate (from left)
 * @param y start Y coordinate (from top)
 * @param len number of pixels to read
 * @param buf store the data here
 * @return LV_RES_OK: success; LV_RES_INV: an error occurred
lv_res_t lv_img_decoder_read_line(lv_img_decoder_dsc_t * dsc, lv_coord_t x, lv_coord_t y, lv_coord_t len, uint8_t * buf)
    if(dsc->decoder->read_line_cb) res = dsc->decoder->read_line_cb(dsc->decoder, dsc, x, y, len, buf);
    return res;
 * Close a decoding session
void lv_img_decoder_close(lv_img_decoder_dsc_t * dsc)
    if(dsc->decoder) {
        if(dsc->decoder->close_cb) dsc->decoder->close_cb(dsc->decoder, dsc);
            lv_mem_free(dsc->src);
            dsc->src = NULL;
 * Create a new image decoder
 * @return pointer to the new image decoder
lv_img_decoder_t * lv_img_decoder_create(void)
    decoder = lv_ll_ins_head(&LV_GC_ROOT(_lv_img_defoder_ll));
    if(decoder == NULL) return NULL;
    memset(decoder, 0, sizeof(lv_img_decoder_t));
    return decoder;
 * Delete an image decoder
 * @param decoder pointer to an image decoder
void lv_img_decoder_delete(lv_img_decoder_t * decoder)
    lv_ll_rem(&LV_GC_ROOT(_lv_img_defoder_ll), decoder);
    lv_mem_free(decoder);
 * Set a callback to get information about the image
 * @param info_cb a function to collect info about an image (fill an `lv_img_header_t` struct)
void lv_img_decoder_set_info_cb(lv_img_decoder_t * decoder, lv_img_decoder_info_f_t info_cb)
    decoder->info_cb = info_cb;
 * Set a callback to open an image
 * @param open_cb a function to open an image
void lv_img_decoder_set_open_cb(lv_img_decoder_t * decoder, lv_img_decoder_open_f_t open_cb)
    decoder->open_cb = open_cb;
 * Set a callback to a decoded line of an image
 * @param read_line_cb a function to read a line of an image
void lv_img_decoder_set_read_line_cb(lv_img_decoder_t * decoder, lv_img_decoder_read_line_f_t read_line_cb)
    decoder->read_line_cb = read_line_cb;
 * Set a callback to close a decoding session. E.g. close files and free other resources.
 * @param close_cb a function to close a decoding session
void lv_img_decoder_set_close_cb(lv_img_decoder_t * decoder, lv_img_decoder_close_f_t close_cb)
    decoder->close_cb = close_cb;
 * Get info about a built-in image
 * @param decoder the decoder where this function belongs
 * @param src the image source: pointer to an `lv_img_dsc_t` variable, a file path or a symbol
 * @param header store the image data here
 * @return LV_RES_OK: the info is successfully stored in `header`; LV_RES_INV: unknown format or other error.
lv_res_t lv_img_decoder_built_in_info(lv_img_decoder_t * decoder, const void * src, lv_img_header_t * header)
    (void)decoder; /*Unused*/
    lv_img_src_t src_type = lv_img_src_get_type(src);
    if(src_type == LV_IMG_SRC_VARIABLE) {
        lv_img_cf_t cf = ((lv_img_dsc_t *)src)->header.cf;
        if(cf < CF_BUILT_IN_FIRST || cf > CF_BUILT_IN_LAST) return LV_RES_INV;
        header->w  = ((lv_img_dsc_t *)src)->header.w;
        header->h  = ((lv_img_dsc_t *)src)->header.h;
        header->cf = ((lv_img_dsc_t *)src)->header.cf;
    else if(src_type == LV_IMG_SRC_FILE) {
        lv_fs_file_t file;
        lv_fs_res_t res;
        uint32_t rn;
        unsigned short readx = 0,ready = 0;
     #if USE_PNG
        if(fh_png_getsize(src,&readx,&ready) == 0)//libpng的接口
            header->w = readx;
            header->h = ready;
            header->cf = LV_IMG_CF_RAW_ALPHA;
    #else
        res = lv_fs_open(&file, src, LV_FS_MODE_RD);
         if(res == LV_FS_RES_OK) {
            res = lv_fs_read(&file, header, sizeof(lv_img_header_t), &rn);
            //very very important, here copy header , but this file now is png, not bin, so header should modify in pcfs_read
            lv_fs_close(&file);
        if(header->cf < CF_BUILT_IN_FIRST || header->cf > CF_BUILT_IN_LAST) return LV_RES_INV;
    else if(src_type == LV_IMG_SRC_SYMBOL) {
        /*The size depend on the font but it is unknown here. It should be handled outside of the
         * function*/
        header->w = 1;
        header->h = 1;
        /* Symbols always have transparent parts. Important because of cover check in the design
         * function. The actual value doesn't matter because lv_draw_label will draw it*/
        header->cf = LV_IMG_CF_ALPHA_1BIT;
    } else {
        LV_LOG_WARN("Image get info found unknown src type");
        return LV_RES_INV;
    return LV_RES_OK;
 * Open a built in image
 * @param dsc pointer to decoder descriptor. `src`, `style` are already initialized in it.
lv_res_t lv_img_decoder_built_in_open(lv_img_decoder_t * decoder, lv_img_decoder_dsc_t * dsc)
    /*Open the file if it's a file*/
    #if USE_PNG
     /*Support only "*.bin" files*/
        if(strcmp(lv_fs_get_ext(dsc->src), "png")) return LV_RES_INV;
 //       lv_fs_file_t f;
 //       lv_fs_res_t res = lv_fs_open(&f, dsc->src, LV_FS_MODE_RD);
 //       if(res != LV_FS_RES_OK) {
 //           LV_LOG_WARN("Built-in image decoder can't open the file");
 //           return LV_RES_INV;
        /*If the file was open successfully save the file descriptor*/
  //      if(dsc->user_data == NULL) {
  //          dsc->user_data = lv_mem_alloc(sizeof(lv_img_decoder_built_in_data_t));
  //              LV_LOG_ERROR("img_decoder_built_in_open: out of memory");
  //              LV_ASSERT_MEM(dsc->user_data);
 //           memset(dsc->user_data, 0, sizeof(lv_img_decoder_built_in_data_t));
 //       lv_img_decoder_built_in_data_t * user_data = dsc->user_data;
 //       user_data->f                               = lv_mem_alloc(sizeof(f));
 //       if(user_data->f == NULL) {
 //           LV_ASSERT_MEM(user_data->f);
 //       memcpy(user_data->f, &f, sizeof(f));
    #else
        if(strcmp(lv_fs_get_ext(dsc->src), "bin")) return LV_RES_INV;
        lv_fs_file_t f;
            return LV_RES_INV;
#else
        LV_LOG_WARN("Image built-in decoder cannot read file because LV_USE_FILESYSTEM = 0");
        return LV_RES_INV;
    lv_img_cf_t cf = dsc->header.cf;
    /*Process true color formats*/
    if(cf == LV_IMG_CF_TRUE_COLOR || cf == LV_IMG_CF_TRUE_COLOR_ALPHA || cf == LV_IMG_CF_TRUE_COLOR_CHROMA_KEYED) {
        if(dsc->src_type == LV_IMG_SRC_VARIABLE) {
            /* In case of uncompressed formats the image stored in the ROM/RAM.
             * So simply give its pointer*/
            dsc->img_data = ((lv_img_dsc_t *)dsc->src)->data;
            return LV_RES_OK;
        } else {
            /*If it's a file it need to be read line by line later*/
            return LV_RES_OK;
    /*Process indexed images. Build a palette*/
    else if(cf == LV_IMG_CF_INDEXED_1BIT || cf == LV_IMG_CF_INDEXED_2BIT || cf == LV_IMG_CF_INDEXED_4BIT ||
            cf == LV_IMG_CF_INDEXED_8BIT) {
#if LV_IMG_CF_INDEXED
        uint8_t px_size       = lv_img_color_format_get_px_size(cf);
        uint32_t palette_size = 1 << px_size;
        /*Allocate the palette*/
        user_data->palette                         = lv_mem_alloc(palette_size * sizeof(lv_color_t));
        user_data->opa                             = lv_mem_alloc(palette_size * sizeof(lv_opa_t));
        if(user_data->palette == NULL || user_data->opa == NULL) {
            LV_ASSERT_MEM(user_data->palette);
            LV_ASSERT_MEM(user_data->opa);
            /*Read the palette from file*/
            lv_fs_seek(user_data->f, 4); /*Skip the header*/
            lv_color32_t cur_color;
            uint32_t i;
            for(i = 0; i < palette_size; i++) {
                lv_fs_read(user_data->f, &cur_color, sizeof(lv_color32_t), NULL);
                user_data->palette[i] = lv_color_make(cur_color.ch.red, cur_color.ch.green, cur_color.ch.blue);
                user_data->opa[i]     = cur_color.ch.alpha;
#else
            LV_LOG_WARN("Image built-in decoder can read the palette because LV_USE_FILESYSTEM = 0");
            return LV_RES_INV;
        } else {
            /*The palette begins in the beginning of the image data. Just point to it.*/
            lv_color32_t * palette_p = (lv_color32_t *)((lv_img_dsc_t *)dsc->src)->data;
            uint32_t i;
                user_data->palette[i] = lv_color_make(palette_p[i].ch.red, palette_p[i].ch.green, palette_p[i].ch.blue);
                user_data->opa[i]     = palette_p[i].ch.alpha;
        return LV_RES_OK;
#else
        LV_LOG_WARN("Indexed (palette) images are not enabled in lv_conf.h. See LV_IMG_CF_INDEXED");
        return LV_RES_INV;
    /*Alpha indexed images. */
    else if(cf == LV_IMG_CF_ALPHA_1BIT || cf == LV_IMG_CF_ALPHA_2BIT || cf == LV_IMG_CF_ALPHA_4BIT ||
            cf == LV_IMG_CF_ALPHA_8BIT) {
#if LV_IMG_CF_ALPHA
        return LV_RES_OK; /*Nothing to process*/
#else
        LV_LOG_WARN("Alpha indexed images are not enabled in lv_conf.h. See LV_IMG_CF_ALPHA");
        return LV_RES_INV;
#if USE_PNG
    else if(cf == LV_IMG_CF_RAW_ALPHA)
       // uint8_t *pbuf;
        int file_size;
        file_size = (dsc->header.w)*(dsc->header.h)*(LV_COLOR_DEPTH/8);
        dsc->img_data = lv_mem_alloc(file_size);
        fh_png_load(dsc->src,dsc->img_data,dsc->header.w,dsc->header.h);//libpng的接口
        printf("lv_img_decoder_built_in_open  fh_png_load src = %s file_size = %d \n",dsc->src,file_size);
		return LV_RES_OK;
    /*Unknown format. Can't decode it.*/
    else {
        /*Free the potentially allocated memories*/
        lv_img_decoder_built_in_close(decoder, dsc);
        LV_LOG_WARN("Image decoder open: unknown color format")
        return LV_RES_INV;
 * Decode `len` pixels starting from the given `x`, `y` coordinates and store them in `buf`.
 * Required only if the "open" function can't return with the whole decoded pixel array.
 * @param decoder pointer to the decoder the function associated with
 * @param x start x coordinate
 * @param y start y coordinate
 * @param len number of pixels to decode
 * @param buf a buffer to store the decoded pixels
 * @return LV_RES_OK: ok; LV_RES_INV: failed
lv_res_t lv_img_decoder_built_in_read_line(lv_img_decoder_t * decoder, lv_img_decoder_dsc_t * dsc, lv_coord_t x,
    if(dsc->header.cf == LV_IMG_CF_TRUE_COLOR || dsc->header.cf == LV_IMG_CF_TRUE_COLOR_ALPHA ||
       dsc->header.cf == LV_IMG_CF_TRUE_COLOR_CHROMA_KEYED) {
        /* For TRUE_COLOR images read line required only for files.
         * For variables the image data was returned in `open`*/
            res = lv_img_decoder_built_in_line_true_color(dsc, x, y, len, buf);
    } else if(dsc->header.cf == LV_IMG_CF_ALPHA_1BIT || dsc->header.cf == LV_IMG_CF_ALPHA_2BIT ||
              dsc->header.cf == LV_IMG_CF_ALPHA_4BIT || dsc->header.cf == LV_IMG_CF_ALPHA_8BIT) {
        res = lv_img_decoder_built_in_line_alpha(dsc, x, y, len, buf);
    } else if(dsc->header.cf == LV_IMG_CF_INDEXED_1BIT || dsc->header.cf == LV_IMG_CF_INDEXED_2BIT ||
              dsc->header.cf == LV_IMG_CF_INDEXED_4BIT || dsc->header.cf == LV_IMG_CF_INDEXED_8BIT) {
        res = lv_img_decoder_built_in_line_indexed(dsc, x, y, len, buf);
    } else {
        LV_LOG_WARN("Built-in image decoder read not supports the color format");
        return LV_RES_INV;
    return res;
 * Close the pending decoding. Free resources etc.
void lv_img_decoder_built_in_close(lv_img_decoder_t * decoder, lv_img_decoder_dsc_t * dsc)
#if USE_PNG
    if(dsc->img_data)
      lv_mem_free(dsc->img_data);
    if(user_data) {
        if(user_data->f) {
            lv_fs_close(user_data->f);
            lv_mem_free(user_data->f);
        if(user_data->palette) lv_mem_free(user_data->palette);
        if(user_data->opa) lv_mem_free(user_data->opa);
        lv_mem_free(user_data);
 *   STATIC FUNCTIONS
    lv_fs_res_t res;
    uint8_t px_size = lv_img_color_format_get_px_size(dsc->header.cf);
    uint32_t pos = ((y * dsc->header.w + x) * px_size) >> 3;
    pos += 4; /*Skip the header*/
    res = lv_fs_seek(user_data->f, pos);
        LV_LOG_WARN("Built-in image decoder seek failed");
        return LV_RES_INV;
    uint32_t btr = len * (px_size >> 3);
    uint32_t br  = 0;
    lv_fs_read(user_data->f, buf, btr, &br);
    if(res != LV_FS_RES_OK || btr != br) {
        LV_LOG_WARN("Built-in image decoder read failed");
        return LV_RES_INV;
    return LV_RES_OK;
#else
    return LV_RES_INV;
#if LV_IMG_CF_ALPHA
    const lv_opa_t alpha1_opa_table[2]  = {0, 255};          /*Opacity mapping with bpp = 1 (Just for compatibility)*/
    const lv_opa_t alpha2_opa_table[4]  = {0, 85, 170, 255}; /*Opacity mapping with bpp = 2*/
    const lv_opa_t alpha4_opa_table[16] = {0,  17, 34,  51,  /*Opacity mapping with bpp = 4*/
                                           68, 85, 102, 119, 136, 153, 170, 187, 204, 221, 238, 255};
    /*Simply fill the buffer with the color. Later only the alpha value will be modified.*/
    lv_color_t bg_color = dsc->style->image.color;
    lv_coord_t i;
    for(i = 0; i < len; i++) {
#if LV_COLOR_DEPTH == 8 || LV_COLOR_DEPTH == 1
        buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE] = bg_color.full;
#elif LV_COLOR_DEPTH == 16
        /*Because of Alpha byte 16 bit color can start on odd address which can cause crash*/
        buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE] = bg_color.full & 0xFF;
        buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE + 1] = (bg_color.full >> 8) & 0xFF;
#elif LV_COLOR_DEPTH == 32
        *((uint32_t *)&buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE]) = bg_color.full;
#else
#error "Invalid LV_COLOR_DEPTH. Check it in lv_conf.h"
    const lv_opa_t * opa_table = NULL;
    uint16_t mask              = (1 << px_size) - 1; /*E.g. px_size = 2; mask = 0x03*/
    lv_coord_t w = 0;
    uint32_t ofs = 0;
    int8_t pos   = 0;
    switch(dsc->header.cf) {
        case LV_IMG_CF_ALPHA_1BIT:
            w = (dsc->header.w >> 3); /*E.g. w = 20 -> w = 2 + 1*/
            if(dsc->header.w & 0x7) w++;
            ofs += w * y + (x >> 3); /*First pixel*/
            pos       = 7 - (x & 0x7);
            opa_table = alpha1_opa_table;
            break;
        case LV_IMG_CF_ALPHA_2BIT:
            w = (dsc->header.w >> 2); /*E.g. w = 13 -> w = 3 + 1 (bytes)*/
            if(dsc->header.w & 0x3) w++;
            ofs += w * y + (x >> 2); /*First pixel*/
            pos       = 6 - ((x & 0x3) * 2);
            opa_table = alpha2_opa_table;
            break;
        case LV_IMG_CF_ALPHA_4BIT:
            w = (dsc->header.w >> 1); /*E.g. w = 13 -> w = 6 + 1 (bytes)*/
            if(dsc->header.w & 0x1) w++;
            ofs += w * y + (x >> 1); /*First pixel*/
            pos       = 4 - ((x & 0x1) * 4);
            opa_table = alpha4_opa_table;
            break;
        case LV_IMG_CF_ALPHA_8BIT:
            w = dsc->header.w; /*E.g. x = 7 -> w = 7 (bytes)*/
            ofs += w * y + x;  /*First pixel*/
            pos = 0;
            break;
    uint8_t fs_buf[LV_HOR_RES_MAX];
    const uint8_t * data_tmp = NULL;
        const lv_img_dsc_t * img_dsc = dsc->src;
        data_tmp = img_dsc->data + ofs;
    } else {
        lv_fs_seek(user_data->f, ofs + 4); /*+4 to skip the header*/
        lv_fs_read(user_data->f, fs_buf, w, NULL);
        data_tmp = fs_buf;
#else
        LV_LOG_WARN("Image built-in alpha line reader can't read file because LV_USE_FILESYSTEM = 0");
        data_tmp = NULL; /*To avoid warnings*/
        return LV_RES_INV;
    uint8_t byte_act = 0;
    uint8_t val_act;
        val_act = (data_tmp[byte_act] & (mask << pos)) >> pos;
        buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE + LV_IMG_PX_SIZE_ALPHA_BYTE - 1] =
            dsc->header.cf == LV_IMG_CF_ALPHA_8BIT ? val_act : opa_table[val_act];
        pos -= px_size;
        if(pos < 0) {
            pos = 8 - px_size;
            data_tmp++;
    return LV_RES_OK;
#else
    LV_LOG_WARN("Image built-in alpha line reader failed because LV_IMG_CF_ALPHA is 0 in lv_conf.h");
    return LV_RES_INV;
    lv_coord_t w = 0;
    int8_t pos   = 0;
    uint32_t ofs = 0;
        case LV_IMG_CF_INDEXED_1BIT:
            ofs += 8;                /*Skip the palette*/
            break;
        case LV_IMG_CF_INDEXED_2BIT:
            ofs += 16;               /*Skip the palette*/
            break;
        case LV_IMG_CF_INDEXED_4BIT:
            ofs += 64;               /*Skip the palette*/
            break;
        case LV_IMG_CF_INDEXED_8BIT:
            ofs += 1024;       /*Skip the palette*/
            pos = 0;
            break;
    } else {
        data_tmp = fs_buf;
#else
        LV_LOG_WARN("Image built-in indexed line reader can't read file because LV_USE_FILESYSTEM = 0");
        return LV_RES_INV;
    uint8_t val_act;
    lv_coord_t i;
        val_act = (*data_tmp & (mask << pos)) >> pos;
        lv_color_t color = user_data->palette[val_act];
        buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE] = color.full;
        buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE] = color.full & 0xFF;
        buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE + 1] = (color.full >> 8) & 0xFF;
        *((uint32_t *)&buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE]) = color.full;
#else
        buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE + LV_IMG_PX_SIZE_ALPHA_BYTE - 1] = user_data->opa[val_act];
        pos -= px_size;
        if(pos < 0) {
            pos = 8 - px_size;
            data_tmp++;
    return LV_RES_OK;
#else
    LV_LOG_WARN("Image built-in indexed line reader failed because LV_IMG_CF_INDEXED is 0 in lv_conf.h");
    return LV_RES_INV;
注意看一下宏定义USE_PNG 下添加的代码,其实添加的东西很少。
主要3个处理:
1、返回图像的大小和类型
2、读取PNG的元数据(直接解出来后的)
3、关闭解码器的时候释放掉解出来的时候申请的内存
当前这个操作的情况下,可以直接在初始化的时候加入图片列表png文件:
形如:
lv_img_dsc_t *image;
image->header.cf = LV_IMG_CF_RAW_ALPHA;
image->header.always_zero = 0;
image->data = file_name;//file_name 就是png文件路径
能调用Png解码到内存显示后,可以调整:
lv_conf.h的
#  define LV_MEM_SIZE    (2U * 1024U * 1024U)
可以限制LVGL使用的内存大小,然后和cache配合使用,在下面:
lv_conf.h的
#define LV_IMG_CACHE_DEF_SIZE       5
可以约束调用解码显示到当前页面的缓冲图片源数量,减少访问图片源文件次数
完结,撒花~
最近编辑记录 TeveT (2021-01-23 18:30:02)
#2 2021-01-23 00:57:49
uuid
已发帖子: 45
Re: LVGL6.0的linux_frame_buffer项目支持PNG解码
牛, 向楼主学习! Makefile 也要修改一下对吧?
楼主 #3 2021-01-23 08:15:04
TeveT
已发帖子: 149
这个一定要改的,不改就没拿到png的库接口
这个其实也挺好摸索的,lvgl的参考手册写得很清楚,就改这个文件
uuid 说:
#4 2021-01-23 09:01:14
拉轰的脚踏车
已发帖子: 288
https://raw.githubusercontent.com/lvgl/lvgl/release/v6/src/lv_draw/lv_img_decoder.c
楼主干得漂亮, 顺便用beyond compare 对比了一下。
#5 2021-01-23 09:24:02
dgtg
已发帖子: 257
楼主厉害!正需要呢!!楼主威武!!!
楼主 #6 2021-01-23 09:33:22
TeveT
已发帖子: 149
试一下哈,ligpng可以用其他的png库替代,有就行,LVGL也有版本支持了png , lodepng
链接在这里:
https://github.com/lvgl/lv_lib_png
dgtg 说:
楼主厉害!正需要呢!!楼主威武!!!
