楼主 #1 2021-01-27 22:37:44
uuid
已发帖子: 45
写了一个简单的Linux memcpy 测试函数, 大家可以看看各种平台的memcpy拷贝速度
memtest.c
#include <string.h>
#include <sys/time.h>
#include <stdlib.h>
#include <time.h>
#include <stdint.h>
#include <stdio.h>
#define ONE_MILLION   1000000
#define MEM_TEST_SIZE (100 * ONE_MILLION)
int main(int argc, char* argv[])
        if (argc < 2)
                printf("usage: %s n (test n mega bytes)\n", argv[0]);
                exit(-1);
        int n = abs(atoi(argv[1]));
        printf("now test copy %dM bytes.\n", n);
        uint8_t *src = (uint8_t *)malloc(n * ONE_MILLION);
        uint8_t *dst = (uint8_t *)malloc(n * ONE_MILLION);
        if(!src || !dst)
                printf("alloc memory error!\n");
                exit(-2);
        struct  timeval time_start;
        struct  timeval time_end;
        gettimeofday(&time_start,NULL);
        memcpy(dst, src, (n * ONE_MILLION));
        gettimeofday(&time_end,NULL);
        printf("calculate time: %ld us \n",
                (ONE_MILLION * time_end.tv_sec + time_end.tv_usec)-(ONE_MILLION*time_start.tv_sec + time_start.tv_usec)
        free(dst);
        free(src);
VMWARE + Ubuntu 18.04 测试:
$ ./memtest 1
now test copy 1M bytes.
calculate time: 665 us
$ ./memtest 10
now test copy 10M bytes.
calculate time: 6692 us
$ ./memtest 100
now test copy 100M bytes.
calculate time: 67354 us
楼主 #2 2021-01-27 22:45:33
uuid
已发帖子: 45
Re: 写了一个简单的Linux memcpy 测试函数, 大家可以看看各种平台的memcpy拷贝速度
V3s DDR2
CPU 1GHz, DDR CLK 360MHz
# memtest 1
calculate time: 4300 us
# memtest 10
calculate time: 50673 us
# memtest 15
now test copy 15M bytes.
calculate time: 82828 us
楼主 #3 2021-01-27 22:49:57
uuid
已发帖子: 45
V3s DDR3 (相当于S3)
# memtest 1
calculate time: 2458 us
# memtest 10
calculate time: 24788 us
# memtest 15
calculate time: 37431 us
# memtest 3
now test copy 3M bytes.
calculate time: 7528 us
# memtest 3
calculate time: 7294 us
# memtest 3
calculate time: 7329 us
同频率下,DDR2比DDR3快了一倍多.
#4 2021-01-27 23:53:25
已发帖子: 646
还有这回事,ddr3为什么会慢过ddr2
楼主 #5 2021-01-28 09:09:25
uuid
已发帖子: 45
微凉VeiLiang 说:
不好意思, 前面写错了。应该是同频率下,DDR3比DDR2快了一倍多.
楼主 #6 2021-01-28 19:12:49
uuid
已发帖子: 45
# ./memtest 1
calculate time: 4373 us
# ./memtest 2
now test copy 2M bytes.
calculate time: 9216 us
# ./memtest 3
calculate time: 13578 us
# ./memtest 10
calculate time: 44411 us
# ./memtest 15
calculate time: 67031 us
# ./memtest 30
now test copy 30M bytes.
calculate time: 133734 us
# ./memtest 50
now test copy 50M bytes.
calculate time: 221139 us
奇怪, 为什么X3 比 V3s DDR3版本(S3) 更慢?
CONFIG_DRAM_CLK=552
CONFIG_DRAM_ZQ=15291
# CONFIG_DRAM_ODT_EN is not set
CONFIG_SYS_CLK_FREQ=1008000000
最近编辑记录 uuid (2021-01-28 19:15:59)
