楼主 #1 2021-01-27 17:36:26
已发帖子: 857
在esp32上运行unix
理论上来说只要是cpu都可以运行linux或unix,只要ram和falsh够大,原理是在单片机(无论是8bit,16bit,32bit,即使不带mmu)上模拟可以运行linux的cpu。
https://www-cnx--software-com.cdn.ampproject.org/v/s/www.cnx-software.com/2021/01/27/mini-replica-of-dec-pdp-11-computer-runs-2-11-bsd-unix-on-esp32-soc/amp/?amp_js_v=a6&amp_gsa=1&usqp=mq331AQFKAGwASA%3D#aoh=16117396025712&csi=0&referrer=https%3A%2F%2Fwww.google.com&amp_tf=From%20%251%24s&ampshare=https%3A%2F%2Fwww.cnx-software.com%2F2021%2F01%2F27%2Fmini-replica-of-dec-pdp-11-computer-runs-2-11-bsd-unix-on-esp32-soc%2F
The relatively popular Digital Equipment Corporation (DEC) PDP-11 16-bit minicomputers started selling in the 70s, and were still available in the earlier 90s. While being stuck in Europe due to COVID-19 restrictions, Jeroen Domburg (aka Sprite_tm) decided to design a tiny replica of a DEC VT102 PDP-11 terminal based on ESP32 wireless SoC and running 2.11 BSD UNIX through SimH PDP11 emulator.
#2 2021-01-28 14:48:53
yangsen
Re: 在esp32上运行unix
理论是可以,前提是你要耗得起。若干年前有个老外用AVR跑linux,2,3个小时进到bash
#3 2023-03-08 22:31:57
landlde
Re: 在esp32上运行unix
楼主成功了吗?
#4 2023-03-24 16:05:00
blacksolar
Re: 在esp32上运行unix
可以跑早期的版本,新版本耗时太长
