1. 下载最新版本 arm linux gcc 7.4.1
cd /usr/local/
wget https://releases.linaro.org/components/toolchain/binaries/7.4-2019.02/arm-linux-gnueabihf/gcc-linaro-7.4.1-2019.02-i686_arm-linux-gnueabihf.tar.xz
tar xvf gcc-linaro-7.4.1-2019.02-i686_arm-linux-gnueabihf.tar.xz
export PATH=/usr/local/gcc-linaro-7.4.1-2019.02-i686_arm-linux-gnueabihf/bin/:$PATH2. 克隆 u-boot 源码:
git clone https://github.com/u-boot/u-boot.git3. 编译:
###生成默认配置文件###
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make LicheePi_Zero_defconfig
###编译###
ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make离线
That's good
cd /usr/local/ wget https://releases.linaro.org/components/toolchain/binaries/7.4-2019.02/arm-linux-gnueabihf/gcc-linaro-7.4.1-2019.02-i686_arm-linux-gnueabihf.tar.xz tar xvf gcc-linaro-7.4.1-2019.02-i686_arm-linux-gnueabihf.tar.xz export PATH=/usr/local/gcc-linaro-7.4.1-2019.02-i686_arm-linux-gnueabihf/bin/:$PATH2. 克隆 u-boot 源码:
###生成默认配置文件### ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make LicheePi_Zero_defconfig ###编译### ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make
此版本打开usb host模式后编译不再报错
打开IIc后照常报错recipe for target 'spl/u-boot-spl' failed
@Hu187 I2C没有测试, USB试了, 改改可以编译成功, 但是仍然用不了。
确实,现在我只能把板子先跑起来(因为这板子是修过得)
硬件没问题(但卡住了)
U-Boot SPL 2019.04-00743-g7d99406742-dirty (Apr 27 2019 - 11:07:27 +0800)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2019.04-00743-g7d99406742-dirty (Apr 27 2019 - 11:07:27 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: mmc@01c0f000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
Net: No ethernet found.
No working controllers found
4006016 bytes read in 249 ms (15.3 MiB/s)
11904 bytes read in 5 ms (2.3 MiB/s)
Loading Device Tree to 42dfa000, end 42dffe7f ... OK
[ 1.359341] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 1.367606] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.14.14-licheepi-zero #2
[ 1.374822] Hardware name: Allwinner sun8i Family
[ 1.379560] [<c010e7b0>] (unwind_backtrace) from [<c010b458>] (show_stack+0x10/0x14)
[ 1.387309] [<c010b458>] (show_stack) from [<c066fd84>] (dump_stack+0x88/0x9c)
[ 1.394540] [<c066fd84>] (dump_stack) from [<c011b700>] (panic+0xdc/0x248)
[ 1.401420] [<c011b700>] (panic) from [<c09011dc>] (mount_block_root+0x194/0x268)
[ 1.408904] [<c09011dc>] (mount_block_root) from [<c09013d0>] (mount_root+0x120/0x128)
[ 1.416820] [<c09013d0>] (mount_root) from [<c0901528>] (prepare_namespace+0x150/0x198)
[ 1.424822] [<c0901528>] (prepare_namespace) from [<c0900e20>] (kernel_init_freeable+0x1c0/0x1d0)
[ 1.433693] [<c0900e20>] (kernel_init_freeable) from [<c0681ed0>] (kernel_init+0x8/0x110)
[ 1.441871] [<c0681ed0>] (kernel_init) from [<c0107788>] (ret_from_fork+0x14/0x2c)
[ 1.449452] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
最近编辑记录 Hu187 (2019-04-27 15:36:17)
这是一部分启动日志
[ 0.765594] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.772262] ehci-platform: EHCI generic platform driver
[ 0.777752] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.783430] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.791382] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.821152] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.828151] hub 1-0:1.0: USB hub found
[ 0.832102] hub 1-0:1.0: 1 port detected
[ 0.836562] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.842866] ohci-platform: OHCI generic platform driver
[ 0.848378] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.855097] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.863024] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 0.936028] hub 2-0:1.0: USB hub found
[ 0.939876] hub 2-0:1.0: 1 port detected
感觉usb控制器已经被识别了,但我现在进不去系统,也没法细看
晕哥 说:@Hu187 I2C没有测试, USB试了, 改改可以编译成功, 但是仍然用不了。
这是一部分启动日志
这个是 linux 的 usb 日志吧?和uboot没关系
你的根文件系统在哪里?
可以直接在 uboot menuconfig 里面设置 bootargs 的 root 参数指定根文件系统
装载sda2,ext4分区上,uboot找不到哪个选项
Hu187 说:晕哥 说:@Hu187 I2C没有测试, USB试了, 改改可以编译成功, 但是仍然用不了。
这是一部分启动日志
感觉usb控制器已经被识别了,但我现在进不去系统,也没法细看这个是 linux 的 usb 日志吧?和uboot没关系
确实是linux的日志,一会我进linux看能不能认到设备,uboot那边先不管他
Linux usb驱动和设备树一直没有问题。
那就好 估计这种芯片只能凑合用用,毕竟是个记录仪的控制器
你的根文件系统在哪里?
这个就尴尬了,我是第一次接触这种东西,根本找不到这个东西在哪,
Hu187 说:晕哥 说:你的根文件系统在哪里?
旧版的 uboot 更尴尬, 修改 bootargs 还得改源码。
我这问题就是多,一步一步照着教程搞,就是分区大小变了,结果文件系统挂不上。
怀疑是跟这个地址有关
"bootz 0x41000000 - 0x41800000;" //就是写在uboot里的
这块zero板子之前修的时候去掉了5V主线上的一颗滤波电容(去耦电容),现在断电后在短时间内上电,3V3可以达到3V8,V3s发热巨大且不能启动
晕哥 说:Hu187 说:这个就尴尬了,我是第一次接触这种东西,根本找不到这个东西在哪,
怀疑是跟这个地址有关
我觉得把这两个字符串改一下就能挂载上,然而不知道怎么把分区位置转化为16进制字符串
根文件系统不是这里改哦, 在 bootargs 里面.
如果用 initrd 根文件系统可以该这里: https://whycan.cn/t_2388.html
很好,工具不错我再摸索摸索吧
我的主机是Ubuntu实体单系统,现在更新内核后虚拟机跑不起来,说是个bug,再等等
各位大佬,我在编译2019 uboot版本遇到一个问题,提示gcc版本低于6,可我已经升级到7了,有哪位朋友也遇到过这个情况吗?ubuntu 14.04,手动升级GCC到7的
root@xxxU14:/home/xxx/ARM/V3S/u-boot# ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make
CHK include/config/uboot.release
CHK include/generated/version_autogenerated.h
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
*** Your GCC is older than 6.0 and is not supported
make: *** [checkgcc6] 错误 1
root@xxxU14:/home/xxx/ARM/V3S/u-boot# gcc --version
gcc (Ubuntu 7.4.0-1ubuntu1~14.04~ppa1) 7.4.0
Copyright (C) 2017 Free Software Foundation, Inc.
最新的uboot支持V3s的spi nor flash启动吗
最近编辑记录 fan12398 (2019-07-18 12:46:26)
fan12398 说:最新的uboot支持V3s的spi nor flash启动吗
看源码应该是支持的,当时我测试的是 usb 启动。
赞!
mark
$ gcc --version
gcc (Ubuntu 8.3.0-6ubuntu1) 8.3.0
Copyright (C) 2018 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
这是代表GCC版本 8.3.0
可不可以编译最新的uboot
git clone https://github.com/u-boot/u-boot.git 获取到最新的源码
VERSION = 2020
PATCHLEVEL = 04
SUBLEVEL =
EXTRAVERSION = -rc3
下面这是什么错误
ARCH=arm make menuconfig
YACC scripts/kconfig/zconf.tab.c
/bin/sh: 1: bison: not found
make[1]: *** [scripts/Makefile.lib:226:scripts/kconfig/zconf.tab.c] 错误 127
make: *** [Makefile:539:menuconfig] 错误 2
VERSION = 2020
PATCHLEVEL = 04
SUBLEVEL =
EXTRAVERSION = -rc3
下面这是什么错误
sudo apt-get install bison -y
谢谢,安装了;但还有错误
LEX scripts/kconfig/zconf.lex.c
/bin/sh: 1: flex: not found
make[1]: *** [scripts/Makefile.lib:218:scripts/kconfig/zconf.lex.c] 错误 127
谢谢,安装了;但还有错误
大佬你要补基础知识了:
sudo apt-get install flex -y
谢谢,安装了;但还有错误
已经可以了,看了看makefile需要flex
现在获取到的licheePi/u-boot里面怎么没有
LicheePi_Zero_800x480LCD_defconfig
LicheePi_Zero_480x272LCD_defconfig
这2个文件
这2个文件
v3s-current.zip 这个文件就有上面那两个.defconfig
最近编辑记录 sunbird606 (2020-05-24 13:25:58)
晕哥,我用你发的最新的uboot文件,编译的时候为什么会出现这个错误:
bison: /media/user1/V3SSDK_BUILDROOT/v3ssdk/buildroot/out/host/share/bison/m4sugar/m4sugar.m4:无法打开: 没有那个文件或目录
我的正常, 删掉重新来过吧.
我的正常, 删掉重新来过吧.
删掉后重新解压 编译,一样的问题,错误 中提示是 bison: /media/user1/V3SSDK_BUILDROOT/v3ssdk/buildroot/out/host/share/bison/m4sugar/m4sugar.m4:无法打开: 没有那个文件或目录
是不是要装个 V3SSDK 哈
请问这个版本的uboot中怎么启用以太网口?修改了uboot的sun8i-v3s-licheepi-zero.dts文件增加
aliases {
ethernet0 = &emac; // 添加
serial0 = &uart0;
// 文件末尾增加
&emac {
phy-handle = <&int_mii_phy>;
phy-mode = "mii";
allwinner,leds-active-low;
uboot起来后认不到网口,启动到linux可以认到。
U-Boot 2021.01-dirty (Jan 26 2021 - 14:38:25 +0800) Allwinner Technology
DRAM: 64 MiB
MMC: mmc@1c0f000: 0
Loading Environment from FAT... OK
In: serial@1c28000
Out: serial@1c28000
Err: serial@1c28000
折腾了两天终于搞定荔枝派zero uboot 2021.01版本的以太网口
要修改什么吗?
我也是这么修改的,能识别到但不能用?求大佬指点
最近编辑记录 xfdr0805 (2021-02-01 13:14:47)
