楼主 #1 2021-02-01 15:22:34
大帅
已发帖子: 169
【解决】但不知原因,Nano主线uboot增加LCD和BMP启动卡在Starting kernel ...
问题现象描述:
主线是TF卡启动(系统可以正常),
uboot不带bmp命令,增加指令,做开机logo,
打开uboot几个相关配置之后开机一直卡在Starting kernel ...
不修改uboot之前正常开机log:
U-Boot SPL 2018.01 (Jan 31 2021 - 20:25:53)
DRAM: 32 MiB
Trying to boot from MMC1
U-Boot 2018.01 (Jan 31 2021 - 20:25:53 -0500) Allwinner Technology
CPU:   Allwinner F Series (SUNIV)
Model: Lichee Pi Nano
DRAM:  32 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
Net:   No ethernet found.
No controllers found
reading zImage
4043624 bytes read in 286 ms (13.5 MiB/s)
385078 bytes read in 52 ms (7.1 MiB/s)
Unknown command 'bmp' - try 'help'
reading dtb.bin
11834 bytes read in 34 ms (339.8 KiB/s)
   Loading Device Tree to 816fa000, end 816ffe39 ... OK
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.15.0-rc8-licheepi-nano (root@osboxes) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #34 Fri Jan 29 03:05:50 EST 2021
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[    0.000000] CPU: VIVT data cache, VIVT instruction cache
[    0.000000] OF: fdt: Machine model: Lichee Pi Nano
[    0.000000] Memory policy: Data cache writeback
修改uboot,使之增加bmp:
1.
-> ARM architecture
     [ * ] Enable graphical uboot console on HDMI, LCD or VGA
     LCD panel timing details:
            x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:40,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0
     (PE6) LCD panel backlight pwm pin
2.
      -> Device Drivers
    - > Graphics support
             [ * ]   Enable colour frame buffer console
3.
    -> Command line interface
                -> Misc commands
                                [ * ] Enable 'bmp' command
编译uboot,烧写到tf卡8k偏移,开机log:
U-Boot SPL 2018.01 (Feb 01 2021 - 01:53:16)
DRAM: 32 MiB
U-Boot 2018.01 (Feb 01 2021 - 01:53:16 -0500) Allwinner Technology
DRAM:  32 MiB
In:    serial@1c25000
Out:   serial@1c25000
Err:   serial@1c25000
reading zImage
4043624 bytes read in 287 ms (13.4 MiB/s)
reading dtb.bin
   Loading Device Tree to 80e01000, end 80e06e39 ... OK
运行在这里系统就卡住了。。。
对比发现
修改前后设备树的地址相差很大,
求大佬指点!!!
【已解决】见下面
最近编辑记录 大帅 (2021-02-02 11:01:38)
#2 2021-02-01 15:25:45
hzqlz
已发帖子: 170
Re: 【解决】但不知原因,Nano主线uboot增加LCD和BMP启动卡在Starting kernel ...
坐等楼下的大佬
楼主 #3 2021-02-01 15:30:29
大帅
已发帖子: 169
在这里淫侵多年,只发现路漫漫的固件里面的uboot有bmp命令,但不知道uboot的配置。
经过一番搜索学习,增加上面的几个配置,开机进入uboot,使用指令是可以显示bmp,
fatload mmc 0:1 0x80C00000 logo.bmp
bmp display 0x80C00000
屏幕可以显示,但是开机不知道为什么会卡在Starting kernel ...???
#4 2021-02-01 15:41:31
raspberryman
已发帖子: 503
是不是bmp把dtb或者zImage的地址覆盖了?
楼主 #5 2021-02-01 15:49:10
大帅
已发帖子: 169
raspberryman 说:
bootcmd=fatload mmc 0:1 0x80008000 zImage;fatload mmc 0:1 0x80C00000 logo.bmp;bmp display 0x80C00000;fatload mmc 0:1 0x80C00000 dtb.bin;bootz 0x80008000 - 0x80C00000
bootdelay=0
把bootcmd里面的
去掉也是不能启动。。。
楼主 #6 2021-02-01 15:57:20
大帅
已发帖子: 169
uboot里面lcd的显存地址在哪里看?
楼主 #7 2021-02-02 11:05:45
大帅
已发帖子: 169
修改configs/suniv.h
屏蔽下面两句
#define CONFIG_VIDEO_LOGO
#define CONFIG_VIDEO_BMP_LOGO
系统可以正常启动了,开机先显示一个linux企鹅,然后是我的logo.bmp。
不屏蔽上面两句,uboot默认显示的是licheepi的800*480的logo,
虽然问题解决,但是不知道卡死在Starting kernel ...的具体原因是什么???
#8 2021-02-10 15:51:21
1053dd
大帅 说:
修改configs/suniv.h
屏蔽下面两句
和你同样的问题,我用的是SPI flash,也是卡内核,设备树也是会变,目前也找不到原因是啥
