《单片机小白转嵌入式Linux学习记录,基于S3C2440----目录》
分析 cpu/arm920t/start.s 文件
第一阶段都是硬件相关的初始化以及将u-boot代码拷贝到SDRAM:
1. 设置为管理模式
mrs r0,cpsr
bic r0,r0,#0x1f
orr r0,r0,#0xd3
msr cpsr,r0
2. 关闭看门狗
ldr r0, =pWTCON
mov r1, #0x0
str r1, [r0]
3. 屏蔽所有中断
mov r1, #0xffffffff
ldr r0, =INTMSK
str r1, [r0]
3. SDRAM初始化
blne cpu_init_crit
4. 是设置栈
sub sp, r0, #12
5. 时钟
bl clock_init
6. 重定位
bl CopyCode2Ram
7. 清除bss段
clear_bss:
ldr r0, _bss_start /* find start of bss segment */
ldr r1, _bss_end /* stop here */
mov r2, #0x00000000 /* clear */
clbss_l:str r2, [r0] /* clear loop... */
add r0, r0, #4
cmp r0, r1
ble clbss_l
8. 调用 start_armboot 函数
ldr pc, _start_armboot
cpu/arm920t/start.s 简易注释
* armboot - Startup Code for ARM920 CPU-core
* Copyright (c) 2001 Marius Gr鰃er <mag@sysgo.de>
* Copyright (c) 2002 Alex Z黳ke <azu@sysgo.de>
* Copyright (c) 2002 Gary Jennejohn <gj@denx.de>
* See file CREDITS for list of people who contributed to this
* project.
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston,
* MA 02111-1307 USA
#include <config.h>
#include <version.h>
* Jump vector table as in table 3.1 in [1]
.globl _start
_start: b reset
ldr pc, _undefined_instruction
ldr pc, _software_interrupt
ldr pc, _prefetch_abort
ldr pc, _data_abort
ldr pc, _not_used
ldr pc, _irq
ldr pc, _fiq
_undefined_instruction: .word undefined_instruction
_software_interrupt: .word software_interrupt
_prefetch_abort: .word prefetch_abort
_data_abort: .word data_abort
_not_used: .word not_used
_irq: .word irq
_fiq: .word fiq
.balignl 16,0xdeadbeef
* Startup Code (reset vector)
* do important init only if we don't start from memory!
* relocate armboot to ram
* setup stack
* jump to second stage
_TEXT_BASE:
.word TEXT_BASE /* EXT_BASE是代码执行的起始地址 由-Ttext $(TEXT_BASE) 传递进来 */
.globl _armboot_start
_armboot_start:
.word _start
* These are defined in the board-specific linker script.
.globl _bss_start
_bss_start:
.word __bss_start
.globl _bss_end
_bss_end:
.word _end
.globl FREE_RAM_END
FREE_RAM_END:
.word 0x0badc0de
.globl FREE_RAM_SIZE
FREE_RAM_SIZE:
.word 0x0badc0de
.globl PreLoadedONRAM
PreLoadedONRAM:
.word 0
#ifdef CONFIG_USE_IRQ
/* IRQ stack memory (calculated at run-time) */
.globl IRQ_STACK_START
IRQ_STACK_START:
.word 0x0badc0de
.globl FIQ_STACK_START
FIQ_STACK_START:
.word 0x0badc0de
* the actual reset code
reset:
* set the cpu to SVC32 mode
* 设置CPU为管理模式
mrs r0,cpsr
bic r0,r0,#0x1f
orr r0,r0,#0xd3
msr cpsr,r0
/* turn off the watchdog */
/* 关闭看门狗 */
#if defined(CONFIG_S3C2400)
# define pWTCON 0x15300000
# define INTMSK 0x14400008 /* Interupt-Controller base addresses */
# define CLKDIVN 0x14800014 /* clock divisor register */
#elif defined(CONFIG_S3C2410)
# define pWTCON 0x53000000
# define INTMOD 0X4A000004
# define INTMSK 0x4A000008 /* Interupt-Controller base addresses */
# define INTSUBMSK 0x4A00001C
# define CLKDIVN 0x4C000014 /* clock divisor register */
#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410)
ldr r0, =pWTCON
mov r1, #0x0
str r1, [r0]
* mask all IRQs by setting all bits in the INTMR - default
* 关闭所有中断
mov r1, #0xffffffff
ldr r0, =INTMSK
str r1, [r0]
# if defined(CONFIG_S3C2410)
ldr r1, =0x3ff
ldr r0, =INTSUBMSK
str r1, [r0]
# endif
#if 0
/* FCLK:HCLK:PCLK = 1:2:4 */
/* default FCLK is 120 MHz ! */
ldr r0, =CLKDIVN
mov r1, #3
str r1, [r0]
#endif /* CONFIG_S3C2400 || CONFIG_S3C2410 */
* we do sys-critical inits only at reboot,
* not when booting from ram!
#ifndef CONFIG_SKIP_LOWLEVEL_INIT
adr r0, _start /* r0 <- current position of code 当前位置 */
ldr r1, _TEXT_BASE /* test if we run from flash or RAM 链接位置 */
cmp r0, r1 /* don't reloc during debug 是否相等 */
blne cpu_init_crit /* 不相等 执行内存控制器初始化 */
/* Set up the stack */
stack_setup:
ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot _TEXT_BASE 0x33f80000 前面的是 uboot代码存放位置 */
sub r0, r0, #CFG_MALLOC_LEN /* malloc area 减去 CFG_MALLOC_LEN 段 动态内存 */
sub r0, r0, #CFG_GBL_DATA_SIZE /* bdinfo 减去 CFG_GBL_DATA_SIZE 段 全局的系统初始化参数 */
sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ)/* 减去 中断和快速中断的栈 */
sub sp, r0, #12 /* leave 3 words for abort-stack 设置栈 sp= r0 - 12 */
bl clock_init /* 调用 c 函数初始化时钟 */
#ifndef CONFIG_SKIP_RELOCATE_UBOOT
/* 拷贝代码到内存 */
relocate: /* relocate U-Boot to RAM */
adr r0, _start /* r0 <- current position of code */
ldr r1, _TEXT_BASE /* test if we run from flash or RAM */
cmp r0, r1 /* don't reloc during debug */
beq clear_bss
ldr r2, _armboot_start
ldr r3, _bss_start
sub r2, r3, r2 /* r2 <- size of armboot */
#if 1
bl CopyCode2Ram /* r0: source, r1: dest, r2: size */
#else
add r2, r0, r2 /* r2 <- source end address */
copy_loop:
ldmia r0!, {r3-r10} /* copy from source address [r0] */
stmia r1!, {r3-r10} /* copy to target address [r1] */
cmp r0, r2 /* until source end addreee [r2] */
ble copy_loop /* r0 <r2 */
#endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* 清除bss 段 */
clear_bss:
add r0, r0, #4
cmp r0, r1
ble clbss_l
SetLoadFlag:
/* Set a global flag, PreLoadedONRAM */
ldr r2, =PreLoadedONRAM
mov r3, #1
streq r3, [r2]
#if 0
/* try doing this stuff after the relocation */
ldr r0, =pWTCON
mov r1, #0x0
str r1, [r0]
mov r1, #0xffffffff
ldr r0, =INTMR
str r1, [r0]
ldr r0, =CLKDIVN
mov r1, #3
str r1, [r0]
/* END stuff after relocation */
ldr pc, _start_armboot /* 调用start_armboot 函数 */
_start_armboot: .word start_armboot
* CPU_init_critical registers
* setup important registers
* setup memory timing
cpu_init_crit:
* flush v4 I/D caches
* 清空缓存
mov r0, #0
mcr p15, 0, r0, c7, c7, 0 /* flush v3/v4 cache */
mcr p15, 0, r0, c8, c7, 0 /* flush v4 TLB */
* disable MMU stuff and caches
* 关闭MMU 和 缓存
mrc p15, 0, r0, c1, c0, 0
bic r0, r0, #0x00002300 @ clear bits 13, 9:8 (--V- --RS)
bic r0, r0, #0x00000087 @ clear bits 7, 2:0 (B--- -CAM)
orr r0, r0, #0x00000002 @ set bit 2 (A) Align
orr r0, r0, #0x00001000 @ set bit 12 (I) I-Cache
mcr p15, 0, r0, c1, c0, 0
* before relocating, we have to setup RAM timing
* because memory timing is board-dependend, you will
* find a lowlevel_init.S in your board directory.
mov ip, lr
bl lowlevel_init // board\100ask24x0 初始化SDRAM lowlevel_init.s
mov lr, ip
mov pc, lr
#endif /* CONFIG_SKIP_LOWLEVEL_INIT */
* Interrupt handling
@ IRQ stack frame.
#define S_FRAME_SIZE 72
#define S_OLD_R0 68
#define S_PSR 64
#define S_PC 60
#define S_LR 56
#define S_SP 52
#define S_IP 48
#define S_FP 44
#define S_R10 40
#define S_R9 36
#define S_R8 32
#define S_R7 28
#define S_R6 24
#define S_R5 20
#define S_R4 16
#define S_R3 12
#define S_R2 8
#define S_R1 4
#define S_R0 0
#define MODE_SVC 0x13
#define I_BIT 0x80
* use bad_save_user_regs for abort/prefetch/undef/swi ...
* use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling
.macro bad_save_user_regs
sub sp, sp, #S_FRAME_SIZE
stmia sp, {r0 - r12} @ Calling r0-r12
sub r2, r2, #(CONFIG_STACKSIZE+CFG_MALLOC_LEN)
sub r2, r2, #(CFG_GBL_DATA_SIZE+8) @ set base 2 words into abort stack
ldmia r2, {r2 - r3} @ get pc, cpsr
add r0, sp, #S_FRAME_SIZE @ restore sp_SVC
add r5, sp, #S_SP
mov r1, lr
stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr
mov r0, sp
.endm
.macro irq_save_user_regs
add r8, sp, #S_PC
stmdb r8, {sp, lr}^ @ Calling SP, LR
str lr, [r8, #0] @ Save calling PC
mrs r6, spsr
str r6, [r8, #4] @ Save CPSR
str r0, [r8, #8] @ Save OLD_R0
mov r0, sp
.endm
.macro irq_restore_user_regs
ldmia sp, {r0 - lr}^ @ Calling r0 - lr
mov r0, r0
ldr lr, [sp, #S_PC] @ Get PC
add sp, sp, #S_FRAME_SIZE
subs pc, lr, #4 @ return & move spsr_svc into cpsr
.endm
.macro get_bad_stack
ldr r13, _armboot_start @ setup our mode stack
sub r13, r13, #(CONFIG_STACKSIZE+CFG_MALLOC_LEN)
sub r13, r13, #(CFG_GBL_DATA_SIZE+8) @ reserved a couple spots in abort stack
str lr, [r13] @ save caller lr / spsr
mrs lr, spsr
str lr, [r13, #4]
mov r13, #MODE_SVC @ prepare SVC-Mode
@ msr spsr_c, r13
msr spsr, r13
mov lr, pc
movs pc, lr
.endm
.macro get_irq_stack @ setup IRQ stack
ldr sp, IRQ_STACK_START
.endm
.macro get_fiq_stack @ setup FIQ stack
ldr sp, FIQ_STACK_START
.endm
* exception handlers
.align 5
get_bad_stack
bad_save_user_regs
bl do_undefined_instruction
.align 5
software_interrupt:
get_bad_stack
bad_save_user_regs
bl do_software_interrupt
.align 5
prefetch_abort:
get_bad_stack
bad_save_user_regs
bl do_prefetch_abort
.align 5
data_abort:
get_bad_stack
bad_save_user_regs
bl do_data_abort
.align 5
not_used:
get_bad_stack
bad_save_user_regs
bl do_not_used
@ thisway.diy, 2006.06.24
.globl Launch
.align 4
Launch:
mov r7, r0
@ diable interrupt
@ disable watch dog timer
mov r1, #0x53000000
mov r2, #0x0
str r2, [r1]
ldr r1,=INTMSK
ldr r2,=0xffffffff @ all interrupt disable
str r2,[r1]
ldr r1,=INTSUBMSK
ldr r2,=0x7ff @ all sub interrupt disable
str r2,[r1]
ldr r1, = INTMOD
mov r2, #0x0 @ set all interrupt as IRQ (not FIQ)
str r2, [r1]
mov ip, #0
mcr p15, 0, ip, c13, c0, 0 @ /* zero PID */
mcr p15, 0, ip, c7, c7, 0 @ /* invalidate I,D caches */
mcr p15, 0, ip, c7, c10, 4 @ /* drain write buffer */
mcr p15, 0, ip, c8, c7, 0 @ /* invalidate I,D TLBs */
mrc p15, 0, ip, c1, c0, 0 @ /* get control register */
bic ip, ip, #0x0001 @ /* disable MMU */
mcr p15, 0, ip, c1, c0, 0 @ /* write control register */
@ MMU_EnableICache
@mrc p15,0,r1,c1,c0,0
@orr r1,r1,#(1<<12)
@mcr p15,0,r1,c1,c0,0
@ clear SDRAM: the end of free mem(has wince on it now) to the end of SDRAM
ldr r3, FREE_RAM_END
ldr r4, =PHYS_SDRAM_1+PHYS_SDRAM_1_SIZE @ must clear all the memory unused to zero
mov r5, #0
ldr r1, _armboot_start
ldr r2, =On_Steppingstone
sub r2, r2, r1
mov pc, r2
On_Steppingstone:
2: stmia r3!, {r5}
cmp r3, r4
bne 2b
@ set sp = 0 on sys mode
mov sp, #0
@ add by thisway.diy 2006.06.26, switch to SVC mode
msr cpsr_c, #0xdf @ set the I-bit = 1, diable the IRQ interrupt
msr cpsr_c, #0xd3 @ set the I-bit = 1, diable the IRQ interrupt
ldr sp, =0x31ff5800
nop
nop
nop
nop
mov pc, r7 @ Jump to PhysicalAddress
nop
mov pc, lr
.align 5
irq:
/* add by www.100ask.net to use IRQ for USB and DMA */
sub lr, lr, #4 @ the return address
ldr sp, IRQ_STACK_START @ the stack for irq
stmdb sp!, { r0-r12,lr } @ save registers
ldr lr, =int_return @ set the return addr
ldr pc, =IRQ_Handle @ call the isr
int_return:
ldmia sp!, { r0-r12,pc }^ @ return from interrupt
.align 5
fiq:
get_fiq_stack
/* someone ought to write a more effiction fiq_save_user_regs */
irq_save_user_regs
bl do_fiq
#else
.align 5
irq:
get_bad_stack
bad_save_user_regs
bl do_irq
.align 5
fiq:
get_bad_stack
bad_save_user_regs
bl do_fiq
#endif最近编辑记录 xinxiaoci (2018-06-08 16:25:50)
uboot,源码我开了好久都卡不懂了,看韦东山了直接把我看懵逼了
还是看正点原子的好点吧!
