楼主 #1 2021-03-09 16:13:38
jkl
已发帖子: 266
请问一下,X3开发板录音有人弄出来了吗?
现在x3的播放已经正常了,但是录音一直有问题:
# tinymix contents
Number of controls: 21
ctl     type    num     name                                    value
0       INT     1       Headphone Playback Volume               30 (range 0->63)
1       BOOL    2       Headphone Playback Switch               On, On
2       INT     1       Line In Playback Volume                 0 (range 0->7)
3       INT     1       Mic2 Playback Volume                    3 (range 0->7)
4       INT     1       Mic2 Boost Volume                       7 (range 0->7)
5       INT     1       Mic1 Playback Volume                    7 (range 0->7)
6       INT     1       Mic1 Boost Volume                       4 (range 0->7)
7       INT     1       ADC Gain Capture Volume                 3 (range 0->7)
8       BOOL    2       AIF1 Slot 0 Digital DAC Playback Switch On, On
9       BOOL    2       AIF1 Data Digital ADC Capture Switch    On, On
10      BOOL    2       DAC Playback Switch                     On, On
11      BOOL    2       DAC Reversed Playback Switch            On, On
12      BOOL    2       Line In Playback Switch                 On, On
13      BOOL    2       Mic1 Playback Switch                    On, On
14      BOOL    2       Mic2 Playback Switch                    On, On
15      BOOL    2       Mixer Capture Switch                    On, On
16      BOOL    2       Mixer Reversed Capture Switch           On, On
17      BOOL    2       Line In Capture Switch                  On, On
18      BOOL    2       Mic1 Capture Switch                     On, On
19      BOOL    2       Mic2 Capture Switch                     On, On
20      ENUM    2       Headphone Source Playback Route         DAC, Mixer, DAC, Mixer
# tinycap 1111.wav -d 0 -c 2 -r 44100 -b 16
Capturing sample: 2 ch, 44100 hz, 16 bit
Error capturing sample
Captured 4294967295 frames
论坛的帖子我也参考过了,一直解决不了,麻烦知道的给点意见,非常感谢!!!
#2 2021-03-11 17:18:45
JasonWoo
已发帖子: 84
Re: 请问一下,X3开发板录音有人弄出来了吗?
采样率的问题,你试试看 8000 16000 等采样率。
楼主 #3 2021-03-12 15:31:00
jkl
已发帖子: 266
JasonWoo 说:
好的,我试试
楼主 #4 2021-03-12 15:35:35
jkl
已发帖子: 266
JasonWoo 说:
还是不行,感觉不是这个问题:
# tinycap jkl.wav -D 1 -d 0 -c 2 -r 48000 -b 16
Capturing sample: 2 ch, 48000 hz, 16 bit
# tinycap jkl.wav -D 1 -d 0 -c 2 -r 8000 -b 16
Capturing sample: 2 ch, 8000 hz, 16 bit
# tinycap jkl.wav -D 1 -d 0 -c 2 -r 16000 -b 16
Capturing sample: 2 ch, 16000 hz, 16 bit
