楼主 #1 2020-12-04 16:49:11
yinkel
hi3516ev300 更换sensor ,sample_venc 报 get venc stream time out
1. 修改/ko/loadhi3516ev300文件,改为./load3516ev200 -i -sensor gc2053 -osmem 32 -total 128
2. 编译SDK的sample_venc。
3. 把sample_venc拷贝到板子上,运行./sample_venc 5
4. 出现打印信息:[SAMPLE_COMM_VENC_GetVencStreamProc]-2025: get venc stream time out, exit thread
5. 没有拍照
#2 2020-12-10 11:41:00
cijliu
已发帖子: 59
Re: hi3516ev300 更换sensor ,sample_venc 报 get venc stream time out
驱动加载错误,应该是执行/ko/loadhi3516ev300这个文件,MIPI电压选择为1.8V
#3 2020-12-11 19:00:21
JasonWoo
已发帖子: 84
lsmod看下
#4 2021-03-09 15:28:19
chenpeng1210
请问问题解决了吗?我是在EV200上换用GC2053运行./sample_venc 5也是报一样的错误,不知道该怎么分析?
#5 2021-03-09 18:27:11
libc0607
已发帖子: 25
chenpeng1210 说:
照着媒体处理软件开发参考那个文档里  Proc调试信息那章 看下哪里没起来
#6 2021-03-09 18:49:21
chenpeng1210
libc0607 说:
chenpeng1210 说:
GC2053里面添加了读取ID功能从log上看ID是正确读取到了,但是从mpp log上看应该是ISP没有中断:
<6>[   sys] [Func]:sys_user_exit [Line]:233 [Info]:sys exit again!
<6>[    vb] [Func]:vb_do_vb_exit [Line]:2388 [Info]:vb already exited!
<6>[    vb] [Func]:create_pool [Line]:221 [Info]:mmzname:!
<7>[    vb] [Func]:create_pool [Line]:438 [Info]:created pool 0!
<7>[    vb] [Func]:create_pool [Line]:438 [Info]:created pool 1!
<7>[    vb] [Func]:create_pool [Line]:438 [Info]:created pool 2!
<7>[    vb] [Func]:vb_do_vb_init [Line]:2349 [Info]:vb init ok!
<7>[(null)] [Func]:sys_user_init [Line]:223 [Info]:sys init ok!
<7>[    vi] [func]:vi_drv_dev_clock_enable [line]:141 [info]:VIU: g_delay_time is 100
<7>[    vi] [func]:vi_drv_set_data_layout [line]:5563 [info]:VI: g_delay_time is 100
<4>[   isp] [Func]:vreg_drv_get_addr [Line]:129 [Info]:The vreg of base_addr 0x600000 has not registerd!
<7>[    vb] [Func]:vb_get_blk_handle_by_pool_id [Line]:636 [Info]:Uid: [10] blk [0] in pool[0]:is allocated!
<7>[    vb] [Func]:vb_get_blk_handle_by_pool_id [Line]:636 [Info]:Uid: [10] blk [0] in pool[1]:is allocated!
<7>[  vpss] [func]:vpss_drv_prepare3dnr_info [line]:2813 [info]:first ref frame(1) or cfg lost(0), disable 3dnr temporarily!
<4>[   isp] [Func]:isp_get_frame_edge [Line]:213 [Info]:Get Interrupt timeout failed!
<5>[  venc] [Func]:venc_start_recv_frame [Line]:6006 [Info]:venc 0 start recv pic ok
<4>[  venc] [Func]:venc_inq_task [Line]:3162 [Info]:venc 1 has stopped to receive pic.
#7 2021-05-15 22:54:58
银河PUMA
请问更改load3516ev300文件的时候是不是只需要更改里面的sensor名字就可以了?
