自动挂载 sd卡脚本不稳定,时好时不行
#! /bin/sh
echo "MDEV=$1 : ACTION=$2 : SUBSYSTEM=$SUBSYSTEM : DEVPATH=$DEVPATH : DEVNAME=$DEVNAME" >> /dev/console
if [ "$1" == "" ]; then
echo "parameter is none" > /tmp/error.txt
exit 1
fi
MNT=$1
#if [ $(echo $1 | grep mmcblk) ]; then
#elif [ $(echo $1 | grep sd) ]; then
#fi
if [ "$2" = "X" ]; then
mounted=mount | grep $1 | wc -l
if [ $mounted -ge 1 ]; then
#ACT=Xremove
ACT=Xadd
ACT=Xadd
fi
ACT=$2
fi
if [ "$ACT" = "Xremove" ]; then
echo "$ACT /mnt/udisk" >> /tmp/mdev.log
if ! umount -l "/mnt/udisk"; then
exit 1
rm -f "/mnt/udisk"
echo "[Umount FS]: /dev/$1 -X-> /mnt/udisk" > /dev/console
fi
if ! rmdir "/mnt/udisk"; then
exit 1
fi
echo "par=$1,mounted=$mounted,MNT=$MNT" > /dev/console
echo "device $1 is already mounted" > /dev/console
exit 0
fi
if ! mkdir -p "/mnt/udisk"; then
echo "mkdir -p /mnt/udisk err" > /dev/console
exit 1
fi
if [ $(echo $1 | grep mtd) ]; then
if mount -t jffs2 "/dev/$1" "/mnt/udisk"; then
echo "[Mount JFFS2]: /dev/$1 --> /mnt/udisk" > /dev/console
elif mount -t yaffs2 -o"inband-tags" "/dev/$1" "/mnt/$1"; then
echo "[Mount YAFFS2]: /dev/$1 --> /mnt/udisk" > /dev/console
echo "$ACT /mnt/$1" >> /tmp/mdev.log
elif mount -t ubifs "/dev/$1" "/mnt/udisk"; then
echo "[Mount UBIFS]: /dev/$1 --> /mnt/udisk" > /dev/console
echo "failed to mount, clean up mountpoint0" > /dev/console
exit 1
fi
fi
if mount -t vfat -o noatime,shortname=mixed,utf8 "/dev/$1" "/mnt/udisk"; then
echo "[Mount VFAT]: /dev/$1 --> /mnt/udisk" > /dev/console
echo "failed to mount, clean up mountpoint" > /dev/console
exit 1
fi
exit 1
fi
fi
fi
MDEV=mmcblk0p1 : ACTION=Xremove : SUBSYSTEM=block : DEVPATH=/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1 : DEVNAME=mmcblk0p1
[ 822.870781] mmc0: host does not support reading read-only switch, assuming write-enable
[ 822.880670] mmc0: new high speed SDHC card at address 0001
[ 822.894261] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 822.907082] mmcblk0: p1
MDEV=mmcblk0 : ACTION=Xadd : SUBSYSTEM=block : DEVPATH=/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0 : DEVNAME=mmcblk0
MDEV=mmcblk0p1 : ACTION=Xadd : SUBSYSTEM=block : DEVPATH=/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1 : DEVNAME=mmcblk0p1
par=mmcblk0,mounted=0,MNT=mmcblk0
par=mmcblk0p1,mounted=0,MNT=mmcblk0p1
[ 823.064747] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 823.124543] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[ 824.164652] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 826.004244] mmc0: card 0001 removed
MDEV=mmcblk0 : ACTION=Xremove : SUBSYSTEM=block : DEVPATH=/devices/platform/soc/1c0f000.mmc/mmc_host/mmc0/mmc0:0001/block/mmcblk0 : DEVNAME=mmcblk0
[ 830.390786] mmc0: host does not support reading read-only switch, assuming write-enable
[ 830.400668] mmc0: new high speed SDHC card at address 0001
[ 830.407732] mmcblk0: mmc0:0001 00000 29.8 GiB
[ 830.434593] mmcblk0: p1
[ 831.444609] dwmac-sun8i 1c30000.ethernet eth0: Link is Down
[ 832.484669] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
