楼主 #1 2021-04-05 16:42:23
MagicKind
已发帖子: 41
tina编译错误
  │ │                         --- USB Gadget Support        │ │
  │ │                         [ ]   Debugging messages (DEVELOPMENT)                                                         │ │
  │ │                         [ ]   Debugging information files (DEVELOPMENT)                                                │ │
  │ │                         [ ]   Debugging information files in debugfs (DEVELOPMENT)                                     │ │
  │ │                         (2)   Maximum VBUS Power usage (2-500 mA)                                                      │ │
  │ │                         (2)   Number of storage pipeline buffers                                                       │ │
  │ │                               USB Peripheral Controller  --->                                                          │ │
  │ │                         <*>   USB Gadget Drivers (Ethernet Gadget (with CDC Ethernet support))  --->                   │ │
  │ │                                 Ethernet Gadget (with CDC Ethernet support)                                            │ │
  │ │                         【*】       RNDIS support        │ │
  │ │                         [ ]       Ethernet Emulation Model (EEM) support                                               │ │
RNDIS support这个选项一选上就报错,请问一下大佬知道是什么问题吗
In file included from drivers/usb/gadget/ether.c:106:0:
drivers/usb/gadget/f_rndis.c:70:41: error: expected ')' before 'uint'
 module_param(rndis_dl_max_pkt_per_xfer, uint, S_IRUGO | S_IWUSR);
drivers/usb/gadget/f_rndis.c:72:2: error: expected ')' before string constant
  "Maximum packets per transfer for DL aggregation");
drivers/usb/gadget/f_rndis.c:75:41: error: expected ')' before 'uint'
 module_param(rndis_ul_max_pkt_per_xfer, uint, S_IRUGO | S_IWUSR);
drivers/usb/gadget/f_rndis.c:77:8: error: expected ')' before string constant
        "Maximum packets per transfer for UL aggregation");
scripts/Makefile.build:308: recipe for target 'drivers/usb/gadget/ether.o' failed
make[8]: *** [drivers/usb/gadget/ether.o] Error 1
scripts/Makefile.build:455: recipe for target 'drivers/usb/gadget' failed
make[7]: *** [drivers/usb/gadget] Error 2
scripts/Makefile.build:455: recipe for target 'drivers/usb' failed
make[6]: *** [drivers/usb] Error 2
Makefile:797: recipe for target 'drivers' failed
make[5]: *** [drivers] Error 2
#2 2021-04-05 20:35:37
九重天
已发帖子: 28
Re: tina编译错误
很明显, 已经提示你是编译错误了, 找一下 module_param 的定义
#3 2021-04-05 21:04:36
cube
已发帖子: 288
Re: tina编译错误
cat: checkout: No such file or directory
 * f_rndis.c -- RNDIS link function driver
 * Copyright (C) 2003-2005,2008 David Brownell
 * Copyright (C) 2003-2004 Robert Schwebel, Benedikt Spranger
 * Copyright (C) 2008 Nokia Corporation
 * Copyright (C) 2009 Samsung Electronics
 *                    Author: Michal Nazarewicz (mina86@mina86.com)
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
/* #define VERBOSE_DEBUG */
#include <linux/slab.h>
#include <linux/kernel.h>
#include <linux/device.h>
#include <linux/etherdevice.h>
#include <linux/atomic.h>
#include "u_ether.h"
#include "rndis.h"
 * This function is an RNDIS Ethernet port -- a Microsoft protocol that's
 * been promoted instead of the standard CDC Ethernet.  The published RNDIS
 * spec is ambiguous, incomplete, and needlessly complex.  Variants such as
 * ActiveSync have even worse status in terms of specification.
 * In short:  it's a protocol controlled by (and for) Microsoft, not for an
 * Open ecosystem or markets.  Linux supports it *only* because Microsoft
 * doesn't support the CDC Ethernet standard.
 * The RNDIS data transfer model is complex, with multiple Ethernet packets
 * per USB message, and out of band data.  The control model is built around
 * what's essentially an "RNDIS RPC" protocol.  It's all wrapped in a CDC ACM
 * (modem, not Ethernet) veneer, with those ACM descriptors being entirely
 * useless (they're ignored).  RNDIS expects to be the only function in its
 * configuration, so it's no real help if you need composite devices; and
 * it expects to be the first configuration too.
 * There is a single technical advantage of RNDIS over CDC Ethernet, if you
 * discount the fluff that its RPC can be made to deliver: it doesn't need
 * a NOP altsetting for the data interface.  That lets it work on some of the
 * "so smart it's stupid" hardware which takes over configuration changes
 * from the software, and adds restrictions like "no altsettings".
 * Unfortunately MSFT's RNDIS drivers are buggy.  They hang or oops, and
 * have all sorts of contrary-to-specification oddities that can prevent
 * them from working sanely.  Since bugfixes (or accurate specs, letting
 * Linux work around those bugs) are unlikely to ever come from MSFT, you
 * may want to avoid using RNDIS on purely operational grounds.
 * Omissions from the RNDIS 1.0 specification include:
 *   - Power management ... references data that's scattered around lots
 *     of other documentation, which is incorrect/incomplete there too.
 *   - There are various undocumented protocol requirements, like the need
 *     to send garbage in some control-OUT messages.
 *   - MS-Windows drivers sometimes emit undocumented requests.
struct f_rndis {
        struct gether                   port;
        u8                              ctrl_id, data_id;
        u8                              ethaddr[ETH_ALEN];
        u32                             vendorID;
        const char                      *manufacturer;
        int                             config;
        struct usb_ep                   *notify;
        struct usb_request              *notify_req;
        atomic_t                        notify_count;
static inline struct f_rndis *func_to_rndis(struct usb_function *f)
        return container_of(f, struct f_rndis, port.func);
/* peak (theoretical) bulk transfer rate in bits-per-second */
static unsigned int bitrate(struct usb_gadget *g)
        if (gadget_is_superspeed(g) && g->speed == USB_SPEED_SUPER)
                return 13 * 1024 * 8 * 1000 * 8;
        else if (gadget_is_dualspeed(g) && g->speed == USB_SPEED_HIGH)
                return 13 * 512 * 8 * 1000 * 8;
                return 19 * 64 * 1 * 1000 * 8;
#define RNDIS_STATUS_INTERVAL_MS        32
#define STATUS_BYTECOUNT                8       /* 8 bytes data */
/* interface descriptor: */
static struct usb_interface_descriptor rndis_control_intf = {
        .bLength =              sizeof rndis_control_intf,
        .bDescriptorType =      USB_DT_INTERFACE,
        /* .bInterfaceNumber = DYNAMIC */
        /* status endpoint is optional; this could be patched later */
        .bNumEndpoints =        1,
        .bInterfaceClass =      USB_CLASS_COMM,
        .bInterfaceSubClass =   USB_CDC_SUBCLASS_ACM,
        .bInterfaceProtocol =   USB_CDC_ACM_PROTO_VENDOR,
        /* .iInterface = DYNAMIC */
static struct usb_cdc_header_desc header_desc = {
        .bLength =              sizeof header_desc,
        .bDescriptorType =      USB_DT_CS_INTERFACE,
        .bDescriptorSubType =   USB_CDC_HEADER_TYPE,
        .bcdCDC =               cpu_to_le16(0x0110),
static struct usb_cdc_call_mgmt_descriptor call_mgmt_descriptor = {
        .bLength =              sizeof call_mgmt_descriptor,
        .bDescriptorSubType =   USB_CDC_CALL_MANAGEMENT_TYPE,
        .bmCapabilities =       0x00,
        .bDataInterface =       0x01,
static struct usb_cdc_acm_descriptor rndis_acm_descriptor = {
        .bLength =              sizeof rndis_acm_descriptor,
        .bDescriptorSubType =   USB_CDC_ACM_TYPE,
static struct usb_cdc_union_desc rndis_union_desc = {
        .bLength =              sizeof(rndis_union_desc),
        .bDescriptorSubType =   USB_CDC_UNION_TYPE,
        /* .bMasterInterface0 = DYNAMIC */
        /* .bSlaveInterface0 =  DYNAMIC */
/* the data interface has two bulk endpoints */
static struct usb_interface_descriptor rndis_data_intf = {
        .bLength =              sizeof rndis_data_intf,
        .bNumEndpoints =        2,
        .bInterfaceClass =      USB_CLASS_CDC_DATA,
        .bInterfaceSubClass =   0,
        .bInterfaceProtocol =   0,
static struct usb_interface_assoc_descriptor
rndis_iad_descriptor = {
        .bLength =              sizeof rndis_iad_descriptor,
        .bDescriptorType =      USB_DT_INTERFACE_ASSOCIATION,
        .bFirstInterface =      0, /* XXX, hardcoded */
        .bInterfaceCount =      2,      // control + data
        .bFunctionClass =       USB_CLASS_COMM,
        .bFunctionSubClass =    USB_CDC_SUBCLASS_ETHERNET,
        .bFunctionProtocol =    USB_CDC_PROTO_NONE,
        /* .iFunction = DYNAMIC */
/* full speed support: */
static struct usb_endpoint_descriptor fs_notify_desc = {
        .bLength =              USB_DT_ENDPOINT_SIZE,
        .bDescriptorType =      USB_DT_ENDPOINT,
        .bEndpointAddress =     USB_DIR_IN,
        .bmAttributes =         USB_ENDPOINT_XFER_INT,
        .wMaxPacketSize =       cpu_to_le16(STATUS_BYTECOUNT),
        .bInterval =            RNDIS_STATUS_INTERVAL_MS,
static struct usb_endpoint_descriptor fs_in_desc = {
        .bmAttributes =         USB_ENDPOINT_XFER_BULK,
static struct usb_endpoint_descriptor fs_out_desc = {
        .bEndpointAddress =     USB_DIR_OUT,
static struct usb_descriptor_header *eth_fs_function[] = {
        (struct usb_descriptor_header *) &rndis_iad_descriptor,
        /* control interface matches ACM, not Ethernet */
        (struct usb_descriptor_header *) &rndis_control_intf,
        (struct usb_descriptor_header *) &header_desc,
        (struct usb_descriptor_header *) &call_mgmt_descriptor,
        (struct usb_descriptor_header *) &rndis_acm_descriptor,
        (struct usb_descriptor_header *) &rndis_union_desc,
        (struct usb_descriptor_header *) &fs_notify_desc,
        /* data interface has no altsetting */
        (struct usb_descriptor_header *) &rndis_data_intf,
        (struct usb_descriptor_header *) &fs_in_desc,
        (struct usb_descriptor_header *) &fs_out_desc,
        NULL,
/* high speed support: */
static struct usb_endpoint_descriptor hs_notify_desc = {
        .bInterval =            USB_MS_TO_HS_INTERVAL(RNDIS_STATUS_INTERVAL_MS)
static struct usb_endpoint_descriptor hs_in_desc = {
        .wMaxPacketSize =       cpu_to_le16(512),
static struct usb_endpoint_descriptor hs_out_desc = {
static struct usb_descriptor_header *eth_hs_function[] = {
        (struct usb_descriptor_header *) &hs_notify_desc,
        (struct usb_descriptor_header *) &hs_in_desc,
        (struct usb_descriptor_header *) &hs_out_desc,
        NULL,
/* super speed support: */
static struct usb_endpoint_descriptor ss_notify_desc = {
static struct usb_ss_ep_comp_descriptor ss_intr_comp_desc = {
        .bLength =              sizeof ss_intr_comp_desc,
        .bDescriptorType =      USB_DT_SS_ENDPOINT_COMP,
        /* the following 3 values can be tweaked if necessary */
        /* .bMaxBurst =         0, */
        /* .bmAttributes =      0, */
        .wBytesPerInterval =    cpu_to_le16(STATUS_BYTECOUNT),
static struct usb_endpoint_descriptor ss_in_desc = {
        .wMaxPacketSize =       cpu_to_le16(1024),
static struct usb_endpoint_descriptor ss_out_desc = {
static struct usb_ss_ep_comp_descriptor ss_bulk_comp_desc = {
        .bLength =              sizeof ss_bulk_comp_desc,
        /* the following 2 values can be tweaked if necessary */
static struct usb_descriptor_header *eth_ss_function[] = {
        (struct usb_descriptor_header *) &ss_notify_desc,
        (struct usb_descriptor_header *) &ss_intr_comp_desc,
        (struct usb_descriptor_header *) &ss_in_desc,
        (struct usb_descriptor_header *) &ss_bulk_comp_desc,
        (struct usb_descriptor_header *) &ss_out_desc,
        NULL,
/* string descriptors: */
static struct usb_string rndis_string_defs[] = {
        [0].s = "RNDIS Communications Control",
        [1].s = "RNDIS Ethernet Data",
        [2].s = "RNDIS",
        {  } /* end of list */
static struct usb_gadget_strings rndis_string_table = {
        .language =             0x0409, /* en-us */
        .strings =              rndis_string_defs,
static struct usb_gadget_strings *rndis_strings[] = {
        &rndis_string_table,
        NULL,
static struct sk_buff *rndis_add_header(struct gether *port,
                                        struct sk_buff *skb)
        struct sk_buff *skb2;
        skb2 = skb_realloc_headroom(skb, sizeof(struct rndis_packet_msg_type));
        if (skb2)
                rndis_add_hdr(skb2);
        dev_kfree_skb_any(skb);
        return skb2;
static void rndis_response_available(void *_rndis)
        struct f_rndis                  *rndis = _rndis;
        struct usb_request              *req = rndis->notify_req;
        struct usb_composite_dev        *cdev = rndis->port.func.config->cdev;
        __le32                          *data = req->buf;
        int                             status;
        if (atomic_inc_return(&rndis->notify_count) != 1)
                return;
        /* Send RNDIS RESPONSE_AVAILABLE notification; a
         * USB_CDC_NOTIFY_RESPONSE_AVAILABLE "should" work too
         * This is the only notification defined by RNDIS.
        data[0] = cpu_to_le32(1);
        data[1] = cpu_to_le32(0);
        status = usb_ep_queue(rndis->notify, req, GFP_ATOMIC);
        if (status) {
                atomic_dec(&rndis->notify_count);
                DBG(cdev, "notify/0 --> %d\n", status);
static void rndis_response_complete(struct usb_ep *ep, struct usb_request *req)
        struct f_rndis                  *rndis = req->context;
        int                             status = req->status;
        /* after TX:
         *  - USB_CDC_GET_ENCAPSULATED_RESPONSE (ep0/control)
         *  - RNDIS_RESPONSE_AVAILABLE (status/irq)
        switch (status) {
        case -ECONNRESET:
        case -ESHUTDOWN:
                /* connection gone */
                atomic_set(&rndis->notify_count, 0);
                break;
        default:
                DBG(cdev, "RNDIS %s response error %d, %d/%d\n",
                        ep->name, status,
                        req->actual, req->length);
                /* FALLTHROUGH */
        case 0:
                if (ep != rndis->notify)
                        break;
                /* handle multiple pending RNDIS_RESPONSE_AVAILABLE
                 * notifications by resending until we're done
                if (atomic_dec_and_test(&rndis->notify_count))
                        break;
                if (status) {
                        DBG(cdev, "notify/1 --> %d\n", status);
                break;
static void rndis_command_complete(struct usb_ep *ep, struct usb_request *req)
        int                             status;
        /* received RNDIS command from USB_CDC_SEND_ENCAPSULATED_COMMAND */
//      spin_lock(&dev->lock);
        status = rndis_msg_parser(rndis->config, (u8 *) req->buf);
        if (status < 0)
                pr_err("RNDIS command error %d, %d/%d\n",
                        status, req->actual, req->length);
//      spin_unlock(&dev->lock);
static int
rndis_setup(struct usb_function *f, const struct usb_ctrlrequest *ctrl)
        struct f_rndis          *rndis = func_to_rndis(f);
        struct usb_composite_dev *cdev = f->config->cdev;
        struct usb_request      *req = cdev->req;
        int                     value = -EOPNOTSUPP;
        u16                     w_index = le16_to_cpu(ctrl->wIndex);
        u16                     w_value = le16_to_cpu(ctrl->wValue);
        u16                     w_length = le16_to_cpu(ctrl->wLength);
        /* composite driver infrastructure handles everything except
         * CDC class messages; interface activation uses set_alt().
        switch ((ctrl->bRequestType << 8) | ctrl->bRequest) {
        /* RNDIS uses the CDC command encapsulation mechanism to implement
         * an RPC scheme, with much getting/setting of attributes by OID.
        case ((USB_DIR_OUT | USB_TYPE_CLASS | USB_RECIP_INTERFACE) << 8)
                        | USB_CDC_SEND_ENCAPSULATED_COMMAND:
                if (w_value || w_index != rndis->ctrl_id)
                        goto invalid;
                /* read the request; process it later */
                value = w_length;
                req->complete = rndis_command_complete;
                req->context = rndis;
                /* later, rndis_response_available() sends a notification */
                break;
        case ((USB_DIR_IN | USB_TYPE_CLASS | USB_RECIP_INTERFACE) << 8)
                        | USB_CDC_GET_ENCAPSULATED_RESPONSE:
                        goto invalid;
                else {
                        u8 *buf;
                        u32 n;
                        /* return the result */
                        buf = rndis_get_next_response(rndis->config, &n);
                        if (buf) {
                                memcpy(req->buf, buf, n);
                                req->complete = rndis_response_complete;
                                rndis_free_response(rndis->config, buf);
                                value = n;
                        /* else stalls ... spec says to avoid that */
                break;
        default:
invalid:
                VDBG(cdev, "invalid control req%02x.%02x v%04x i%04x l%d\n",
                        ctrl->bRequestType, ctrl->bRequest,
                        w_value, w_index, w_length);
        /* respond with data transfer or status phase? */
        if (value >= 0) {
                DBG(cdev, "rndis req%02x.%02x v%04x i%04x l%d\n",
                req->zero = (value < w_length);
                req->length = value;
                value = usb_ep_queue(cdev->gadget->ep0, req, GFP_ATOMIC);
                if (value < 0)
                        ERROR(cdev, "rndis response on err %d\n", value);
        /* device either stalls (value < 0) or reports success */
        return value;
static int rndis_set_alt(struct usb_function *f, unsigned intf, unsigned alt)
        /* we know alt == 0 */
        if (intf == rndis->ctrl_id) {
                if (rndis->notify->driver_data) {
                        VDBG(cdev, "reset rndis control %d\n", intf);
                        usb_ep_disable(rndis->notify);
                if (!rndis->notify->desc) {
                        VDBG(cdev, "init rndis ctrl %d\n", intf);
                        if (config_ep_by_speed(cdev->gadget, f, rndis->notify))
                                goto fail;
                usb_ep_enable(rndis->notify);
                rndis->notify->driver_data = rndis;
        } else if (intf == rndis->data_id) {
                struct net_device       *net;
                if (rndis->port.in_ep->driver_data) {
                        DBG(cdev, "reset rndis\n");
                        gether_disconnect(&rndis->port);
                if (!rndis->port.in_ep->desc || !rndis->port.out_ep->desc) {
                        DBG(cdev, "init rndis\n");
                                               rndis->port.in_ep) ||
                                               rndis->port.out_ep)) {
                                rndis->port.in_ep->desc = NULL;
                                rndis->port.out_ep->desc = NULL;
                                goto fail;
                /* Avoid ZLPs; they can be troublesome. */
                rndis->port.is_zlp_ok = false;
                /* RNDIS should be in the "RNDIS uninitialized" state,
                 * either never activated or after rndis_uninit().
                 * We don't want data to flow here until a nonzero packet
                 * filter is set, at which point it enters "RNDIS data
                 * initialized" state ... but we do want the endpoints
                 * to be activated.  It's a strange little state.
                 * REVISIT the RNDIS gadget code has done this wrong for a
                 * very long time.  We need another call to the link layer
                 * code -- gether_updown(...bool) maybe -- to do it right.
                rndis->port.cdc_filter = 0;
                DBG(cdev, "RNDIS RX/TX early activation ... \n");
                net = gether_connect(&rndis->port);
                if (IS_ERR(net))
                        return PTR_ERR(net);
                rndis_set_param_dev(rndis->config, net,
                                &rndis->port.cdc_filter);
        } else
                goto fail;
fail:
        return -EINVAL;
static void rndis_disable(struct usb_function *f)
        if (!rndis->notify->driver_data)
                return;
        DBG(cdev, "rndis deactivated\n");
        rndis_uninit(rndis->config);
        rndis->notify->driver_data = NULL;
 * This isn't quite the same mechanism as CDC Ethernet, since the
 * notification scheme passes less data, but the same set of link
 * states must be tested.  A key difference is that altsettings are
 * not used to tell whether the link should send packets or not.
static void rndis_open(struct gether *geth)
        struct f_rndis          *rndis = func_to_rndis(&geth->func);
        struct usb_composite_dev *cdev = geth->func.config->cdev;
        DBG(cdev, "%s\n", __func__);
        rndis_set_param_medium(rndis->config, RNDIS_MEDIUM_802_3,
                                bitrate(cdev->gadget) / 100);
        rndis_signal_connect(rndis->config);
static void rndis_close(struct gether *geth)
        DBG(geth->func.config->cdev, "%s\n", __func__);
        rndis_set_param_medium(rndis->config, RNDIS_MEDIUM_802_3, 0);
        rndis_signal_disconnect(rndis->config);
/* ethernet function driver setup/binding */
static int
rndis_bind(struct usb_configuration *c, struct usb_function *f)
        struct usb_composite_dev *cdev = c->cdev;
        int                     status;
        struct usb_ep           *ep;
        /* allocate instance-specific interface IDs */
        status = usb_interface_id(c, f);
        if (status < 0)
                goto fail;
        rndis->ctrl_id = status;
        rndis_iad_descriptor.bFirstInterface = status;
        rndis_control_intf.bInterfaceNumber = status;
        rndis_union_desc.bMasterInterface0 = status;
        if (status < 0)
                goto fail;
        rndis->data_id = status;
        rndis_data_intf.bInterfaceNumber = status;
        rndis_union_desc.bSlaveInterface0 = status;
        status = -ENODEV;
        /* allocate instance-specific endpoints */
        ep = usb_ep_autoconfig(cdev->gadget, &fs_in_desc);
        if (!ep)
                goto fail;
        rndis->port.in_ep = ep;
        ep->driver_data = cdev; /* claim */
        ep = usb_ep_autoconfig(cdev->gadget, &fs_out_desc);
        if (!ep)
                goto fail;
        rndis->port.out_ep = ep;
        /* NOTE:  a status/notification endpoint is, strictly speaking,
         * optional.  We don't treat it that way though!  It's simpler,
         * and some newer profiles don't treat it as optional.
        ep = usb_ep_autoconfig(cdev->gadget, &fs_notify_desc);
        if (!ep)
                goto fail;
        rndis->notify = ep;
        status = -ENOMEM;
        /* allocate notification request and buffer */
        rndis->notify_req = usb_ep_alloc_request(ep, GFP_KERNEL);
        if (!rndis->notify_req)
                goto fail;
        rndis->notify_req->buf = kmalloc(STATUS_BYTECOUNT, GFP_KERNEL);
        if (!rndis->notify_req->buf)
                goto fail;
        rndis->notify_req->length = STATUS_BYTECOUNT;
        rndis->notify_req->context = rndis;
        rndis->notify_req->complete = rndis_response_complete;
        /* support all relevant hardware speeds... we expect that when
         * hardware is dual speed, all bulk-capable endpoints work at
         * both speeds
        hs_in_desc.bEndpointAddress = fs_in_desc.bEndpointAddress;
        hs_out_desc.bEndpointAddress = fs_out_desc.bEndpointAddress;
        hs_notify_desc.bEndpointAddress = fs_notify_desc.bEndpointAddress;
        ss_in_desc.bEndpointAddress = fs_in_desc.bEndpointAddress;
        ss_out_desc.bEndpointAddress = fs_out_desc.bEndpointAddress;
        ss_notify_desc.bEndpointAddress = fs_notify_desc.bEndpointAddress;
        status = usb_assign_descriptors(f, eth_fs_function, eth_hs_function,
                        eth_ss_function);
        if (status)
                goto fail;
        rndis->port.open = rndis_open;
        rndis->port.close = rndis_close;
        status = rndis_register(rndis_response_available, rndis);
        if (status < 0)
                goto fail;
        rndis->config = status;
        rndis_set_host_mac(rndis->config, rndis->ethaddr);
        if (rndis->manufacturer && rndis->vendorID &&
                        rndis_set_param_vendor(rndis->config, rndis->vendorID,
                                               rndis->manufacturer))
                goto fail;
        /* NOTE:  all that is done without knowing or caring about
         * the network link ... which is unavailable to this code
         * until we're activated via set_alt().
        DBG(cdev, "RNDIS: %s speed IN/%s OUT/%s NOTIFY/%s\n",
                        gadget_is_superspeed(c->cdev->gadget) ? "super" :
                        gadget_is_dualspeed(c->cdev->gadget) ? "dual" : "full",
                        rndis->port.in_ep->name, rndis->port.out_ep->name,
                        rndis->notify->name);
fail:
        usb_free_all_descriptors(f);
        if (rndis->notify_req) {
                kfree(rndis->notify_req->buf);
                usb_ep_free_request(rndis->notify, rndis->notify_req);
        /* we might as well release our claims on endpoints */
        if (rndis->notify)
        if (rndis->port.out_ep)
                rndis->port.out_ep->driver_data = NULL;
        if (rndis->port.in_ep)
                rndis->port.in_ep->driver_data = NULL;
        ERROR(cdev, "%s: can't bind, err %d\n", f->name, status);
        return status;
static void
rndis_unbind(struct usb_configuration *c, struct usb_function *f)
        rndis_deregister(rndis->config);
        rndis_exit();
        rndis_string_defs[0].id = 0;
        kfree(rndis);
/* Some controllers can't support RNDIS ... */
static inline bool can_support_rndis(struct usb_configuration *c)
        /* everything else is *presumably* fine */
        return true;
int
rndis_bind_config_vendor(struct usb_configuration *c, u8 ethaddr[ETH_ALEN],
                u32 vendorID, const char *manufacturer, struct eth_dev *dev)
        struct f_rndis  *rndis;
        int             status;
        if (!can_support_rndis(c) || !ethaddr)
                return -EINVAL;
        if (rndis_string_defs[0].id == 0) {
                /* ... and setup RNDIS itself */
                status = rndis_init();
                if (status < 0)
                        return status;
                status = usb_string_ids_tab(c->cdev, rndis_string_defs);
                if (status)
                        return status;
                rndis_control_intf.iInterface = rndis_string_defs[0].id;
                rndis_data_intf.iInterface = rndis_string_defs[1].id;
                rndis_iad_descriptor.iFunction = rndis_string_defs[2].id;
        /* allocate and initialize one new instance */
        status = -ENOMEM;
        rndis = kzalloc(sizeof *rndis, GFP_KERNEL);
        if (!rndis)
                goto fail;
        memcpy(rndis->ethaddr, ethaddr, ETH_ALEN);
        rndis->vendorID = vendorID;
        rndis->manufacturer = manufacturer;
        rndis->port.ioport = dev;
        /* RNDIS activates when the host changes this filter */
        /* RNDIS has special (and complex) framing */
        rndis->port.header_len = sizeof(struct rndis_packet_msg_type);
        rndis->port.wrap = rndis_add_header;
        rndis->port.unwrap = rndis_rm_hdr;
        rndis->port.func.name = "rndis";
        rndis->port.func.strings = rndis_strings;
        /* descriptors are per-instance copies */
        rndis->port.func.bind = rndis_bind;
        rndis->port.func.unbind = rndis_unbind;
        rndis->port.func.set_alt = rndis_set_alt;
        rndis->port.func.setup = rndis_setup;
        rndis->port.func.disable = rndis_disable;
        status = usb_add_function(c, &rndis->port.func);
        if (status) {
                kfree(rndis);
fail:
                rndis_exit();
        return status;
直接替换这个文件试一试: drivers/usb/gadget/f_rndis.c
楼主 #4 2021-04-06 09:08:53
MagicKind
已发帖子: 41
Re: tina编译错误
#include "rndis.h"
struct f_rndis {
        struct gether                   port;
        u32                             vendorID;
        int                             config;
        .bNumEndpoints =        1,
        .bNumEndpoints =        2,
        NULL,
        NULL,
        NULL,
        [2].s = "RNDIS",
        NULL,
        if (skb2)
        return skb2;
        int                             status;
                return;
        if (status) {
        /* after TX:
        switch (status) {
        case -ECONNRESET:
        case -ESHUTDOWN:
                break;
        default:
                        ep->name, status,
                /* FALLTHROUGH */
        case 0:
                        break;
                        break;
                if (status) {
                break;
        int                             status;
        if (status < 0)
static int
                        goto invalid;
                value = w_length;
                break;
                        goto invalid;
                else {
                        u8 *buf;
                        u32 n;
                        if (buf) {
                                value = n;
                break;
        default:
invalid:
        if (value >= 0) {
                if (value < 0)
        return value;
                                goto fail;
                                goto fail;
                if (IS_ERR(net))
        } else
                goto fail;
fail:
        return -EINVAL;
                return;
static int
        int                     status;
        struct usb_ep           *ep;
        if (status < 0)
                goto fail;
        if (status < 0)
                goto fail;
        status = -ENODEV;
        if (!ep)
                goto fail;
        if (!ep)
                goto fail;
        if (!ep)
                goto fail;
        rndis->notify = ep;
        status = -ENOMEM;
                goto fail;
                goto fail;
         * both speeds
                        eth_ss_function);
        if (status)
                goto fail;
        if (status < 0)
                goto fail;
                goto fail;
fail:
        if (rndis->notify)
        return status;
static void
        rndis_exit();
        kfree(rndis);
        return true;
int
        int             status;
                return -EINVAL;
                if (status < 0)
                        return status;
                if (status)
                        return status;
        status = -ENOMEM;
        if (!rndis)
                goto fail;
        if (status) {
                kfree(rndis);
fail:
                rndis_exit();
        return status;
大佬,你是将下面这部分的定义和有关rndis_dl_max_pkt_per_xfer 这个变量的部分去掉了吧,这样做的话有什么影响吗
static unsigned int rndis_dl_max_pkt_per_xfer = 3;
// module_param(rndis_dl_max_pkt_per_xfer, uint, S_IRUGO | S_IWUSR);
// MODULE_PARM_DESC(rndis_dl_max_pkt_per_xfer,
// 	"Maximum packets per transfer for DL aggregation");
static unsigned int rndis_ul_max_pkt_per_xfer = 3;
// module_param(rndis_ul_max_pkt_per_xfer, uint, S_IRUGO | S_IWUSR);
// MODULE_PARM_DESC(rndis_ul_max_pkt_per_xfer,
//        "Maximum packets per transfer for UL aggregation");
